seeWood
- 15
Alle im Urlaub hier
bereits vom 30.07.16
Have a good Summer, I will!!!
I9100 20160730 is UP!
Changelog:
Changelog:
- netfilter: x_tables: make sure e->next_offset covers remaining blob size --> CyanogenMod/android_kernel_samsung_smdk4412
- Gello artifact: v29 --> CyanogenMod/android_vendor_cm
- gello: unbreak the gellin'time --> CyanogenMod/android_packages_apps_Gello
- Add missing OnePlus Two contributors --> CyanogenMod/android_vendor_cm
- mountservice: Don't nuke all volumes when decrypting --> CyanogenMod/android_frameworks_base
- Fix orientation handling in secure camera --> CyanogenMod/android_packages_apps_Snap
- CMSettings: Add default overlay for forward and reverse lookup --> CyanogenMod/cm_platform_sdk
- sepolicy: Let the IO prefetcher look at sdcardfs --> CyanogenMod/android_vendor_cm
- Revert "extract_utils: Don't write multilib tags on 32-bit only devices" --> CyanogenMod/android_vendor_cm
- pm: Skip custom resolver use when mOnlyCore --> CyanogenMod/android_frameworks_base
- cm: sepolicy: Allow system_server dir read access --> CyanogenMod/android_vendor_cm
- cm: extract_utils: Rewrite file existence checks --> CyanogenMod/android_vendor_cm
- extract_utils: Don't write multilib tags on 32-bit only devices --> CyanogenMod/android_vendor_cm
- extract_utils: Add support for files in rootfs --> CyanogenMod/android_vendor_cm
- InputMethods: set the default value for preference --> CyanogenMod/android_packages_inputmethods_LatinIME
- lights: Make sure the lights are out --> CyanogenMod/android_frameworks_base
- healthd: Add DASH charger type --> CyanogenMod/android_system_core
- AM/PM: Fix incorrect am/pm text --> CyanogenMod/android_packages_apps_LockClock
- ZenMode rules: Show days list in the correct order --> CyanogenMod/android_packages_apps_Settings
- SysUI: Define config for showing screen on hints --> CyanogenMod/android_frameworks_base
- Add epub to the list of filetypes to get and send --> CyanogenMod/android_packages_apps_Bluetooth
- SimSettings: Make provisioning optional even if qti-telephony is present --> CyanogenMod/android_packages_apps_Settings
- sepolicy: Allow media_rw write to fix camcorder denials --> CyanogenMod/android_vendor_cm
- vold: Allow reset after shutdown --> CyanogenMod/android_system_vold
- mountservice: Shut down volumes before restarting framework --> CyanogenMod/android_frameworks_base
- NetworkSelection: Cleanup --> CyanogenMod/android_packages_services_Telephony
- NetworkSelection: Fix for setting shortcut --> CyanogenMod/android_packages_services_Telephony
- NetworkSelection: Fix double display of radio technology --> CyanogenMod/android_packages_services_Telephony
- Settings: Fix possible crash --> CyanogenMod/android_packages_apps_Settings
- Eleven: fix possible NPE --> CyanogenMod/android_packages_apps_Eleven
- Add missing truphone APNs --> CyanogenMod/android_vendor_cm
- Settings: Improve vibrator intensity dialog layout --> CyanogenMod/android_packages_apps_Settings
- sepolicy: Add policy for sdcardfs and configfs --> CyanogenMod/android_external_sepolicy
- sepolicy: Revert custom sdcardfs policy in favor of AOSP --> CyanogenMod/android_vendor_cm
- Improve the scan process --> CyanogenMod/android_frameworks_base
- sepolicy: A few more denials --> CyanogenMod/android_vendor_cm
- sdcard: Pass the umask to sdcardfs correctly --> CyanogenMod/android_system_core
- sepolicy: More policy for sdcardfs --> CyanogenMod/android_vendor_cm
- Timer: Do not rotate Alert timer --> CyanogenMod/android_packages_apps_DeskClock
- Settings: Always set text value in color temperature --> CyanogenMod/android_packages_apps_Settings
- camera: Apply pathmap for other Qualcomm project includes --> CyanogenMod/android_hardware_qcom_camera
- Underp build --> CyanogenMod/android_packages_apps_Messaging
- Themes: Expose new hard coded colors for themes --> CyanogenMod/android_packages_apps_Messaging
- Factory reset: Wipe media by default --> CyanogenMod/android_frameworks_base
- ThemeService:Component id is being changed for multiple entries in mixnmatch --> CyanogenMod/cm_platform_sdk
- cmsdk: Broker out CMAudioService --> CyanogenMod/cm_platform_sdk
- cm: include CMAudioService in builds --> CyanogenMod/android_vendor_cm
- CMAudioService: initial brokered port from cmsdk --> CyanogenMod/android_packages_services_CMAudioService
- manifests: add CMAudioService --> CyanogenMod/android
- SystemUI : Initialize state linked volume --> CyanogenMod/android_frameworks_base
- SystemUI: don't automatically disable compass tile --> CyanogenMod/android_frameworks_base
- Movistar [ES] APN updates --> CyanogenMod/android_vendor_cm
- surfaceflinger: Fix the fix of the opaque check fix --> CyanogenMod/android_frameworks_native
- sepolicy: Add rule to allow sdcardfs to read package list --> CyanogenMod/android_vendor_cm
- sdcard: Fix sdcardFS check --> CyanogenMod/android_system_core
- sdcard: Add support for sdcardfs! --> CyanogenMod/android_system_core
- sepolicy: Add sdcardfs support --> CyanogenMod/android_vendor_cm
- Telephony: Fix voicemail preference issue --> CyanogenMod/android_packages_services_Telephony
- sepolicy: Allow batterymanager and batteryproperties services to be found --> CyanogenMod/android_vendor_cm
- SysUI: Show hints if showing keyguard and provisioned --> CyanogenMod/android_frameworks_base
- Themes: Expose and separate hard coded colors for themes --> CyanogenMod/android_packages_apps_Gello
- fm: Remove unwanted media button key event listeners --> CyanogenMod/android_hardware_qcom_fm
- More...
