[ROM][I9100][MM][6.0.1] *05.11.16* CyanogenMod 13.0 [Linaro][SaberMod]
  • 808 Antworten
I9100 20160610 is UP!
Changelog:
  • net: wireless: bcmdhd: check privilege on priv cmd --> CyanogenMod/android_kernel_samsung_smdk4412
  • cm: Give BootReceiver permissions to read fsck log --> CyanogenMod/android_vendor_cm
  • String improvements --> CyanogenMod/android_packages_apps_Settings
  • art: Fix QCPERF workaround for ARM after Clang fixes --> CyanogenMod/android_art
  • Enable clang for ARM builds --> CyanogenMod/android_art
  • OMXCodec: Remove kClientNeedsFrameBuffer for S3D --> CyanogenMod/android_frameworks_av
  • android: add ahbottomnavigation library --> CyanogenMod/android
  • cmsdk: Provide coverage for serial number and unique device id --> CyanogenMod/cm_platform_sdk
  • Invalidate preferences headers when resuming --> CyanogenMod/android_packages_apps_CMFileManager
  • Framework: allow ResolverActivity to be specialized from other package --> CyanogenMod/android_frameworks_base
  • Settings: Allow sorting Applications by size --> CyanogenMod/android_packages_apps_Settings
  • Keyguard: Get your weather on... the lock screen [3/3] --> CyanogenMod/android_packages_apps_Settings
  • Keyguard: Get your weather on... the lock screen [2/3] --> CyanogenMod/cm_platform_sdk
  • Keyguard: Get your weather on... the lock screen [1/3] --> CyanogenMod/android_frameworks_base
  • CMSettingsProvider: load provisioned flag when creating DB --> CyanogenMod/cm_platform_sdk
  • Unregister from WeatherManager ONLY if service was actually registered --> CyanogenMod/android_packages_apps_LockClock
  • keyguard: SIM Display Name is now a config --> CyanogenMod/android_frameworks_base
  • art: Re-enable host clang --> CyanogenMod/android_art
  • Add valid number checks for block menu item --> CyanogenMod/android_packages_apps_ContactsCommon
  • skia: qc-perf: link against libqc-opt for msm8937/17/53 --> CyanogenMod/android_external_skia
  • Performance tweaks for DeepLinkCache and icon retrieval --> CyanogenMod/android_packages_apps_Dialer
  • Check if view is inited when screen rotated --> CyanogenMod/android_packages_apps_CMFileManager
  • Snap: Check photo orientation when creating thumbnail --> CyanogenMod/android_packages_apps_Snap
  • Nudges: Move roaming nudge logic to wifi listener --> CyanogenMod/android_packages_apps_Dialer
  • Initialize ContactsTile loader in SpeedDialFragment onStart --> CyanogenMod/android_packages_apps_Dialer
  • mm-video-v4l2: vdec: Avoid processing ETBs/FTBs in invalid states --> CyanogenMod/android_hardware_qcom_media
  • mm-video-v4l2: venc: Avoid processing ETBs/FTBs in invalid states --> CyanogenMod/android_hardware_qcom_media
  • Report correct status if failed to process weather update request --> CyanogenMod/android_packages_apps_LockClock
  • Ensures ProfileTrustAgent properly grants/revokes trust [1/2] --> CyanogenMod/android_packages_apps_Profiles
  • Ensures ProfileTrustAgent properly grants/revokes trust [2/2] --> CyanogenMod/cm_platform_sdk
  • Use child fragment manager for nested dialog fragment --> CyanogenMod/android_packages_apps_Settings
  • Gello: Update to v20 artifact --> CyanogenMod/android_vendor_cm
  • default.xml: Move external/libpng to android-6.0.1_r43 --> CyanogenMod/android
  • Contacts : Remove silent option from ringtone --> CyanogenMod/android_packages_apps_Contacts
  • msm8226: comment out ifeq with missing endif --> CyanogenMod/android_hardware_qcom_display
  • Messaging: fix multi participant "always-ask" MSIM flow --> CyanogenMod/android_packages_apps_Messaging
  • PhoneUtils: Doublecheck that the system default is actually usable --> CyanogenMod/android_packages_apps_Messaging
  • DcTracker: use IMSI with APN lookup --> CyanogenMod/android_frameworks_opt_telephony
  • TelephonyProvider: add apn lookup for imsi --> CyanogenMod/android_packages_providers_TelephonyProvider
  • Settings: use subid & imsi for MSIM apn lookups --> CyanogenMod/android_packages_apps_Settings
  • Telephony: pass subscriber id to apn settings --> CyanogenMod/android_packages_services_Telephony
  • Stop audio playback/recording in LOSS_TRANSIENT mode --> CyanogenMod/android_packages_apps_SoundRecorder
  • MtpServer: Fix concurrent access to mStorages --> CyanogenMod/android_frameworks_av
  • MTP: Fix crash when no storages are available --> CyanogenMod/android_frameworks_av
  • default.xml: cm: Update to 6.0.1_r46 --> CyanogenMod/android
  • Merge tag 'android-6.0.1_r46' into HEAD --> CyanogenMod/android_packages_services_Telephony
  • Merge tag 'android-6.0.1_r46' into HEAD --> CyanogenMod/android_system_bt
  • Merge tag 'android-6.0.1_r46' into HEAD --> CyanogenMod/android_packages_apps_PackageInstaller
  • Merge tag 'android-6.0.1_r46' into HEAD --> CyanogenMod/android_packages_apps_Bluetooth
  • Set notification to auto clean --> CyanogenMod/android_packages_apps_SoundRecorder
  • cmsdk: LiveDisplay: Enforce dump permission --> CyanogenMod/cm_platform_sdk
  • cm: Include CMSettingsProvider in test coverage report --> CyanogenMod/android_vendor_cm
  • cm: Change output html name for cmsdk test coverage --> CyanogenMod/android_vendor_cm
  • CMSettingsProvider: Add coverage for CMSettings' interfaces --> CyanogenMod/cm_platform_sdk
  • CMSettingsProvider: Fix defaults test for DEV_FORCE_SHOW_NAVBAR --> CyanogenMod/cm_platform_sdk
  • CMSettingsProvider: Register as CMTS package --> CyanogenMod/cm_platform_sdk
  • cmsdk: Add test package to CMTS targets --> CyanogenMod/cm_platform_sdk
  • cmsdk: Fix redundant case in themes contract's componentToImageColName --> CyanogenMod/cm_platform_sdk
  • cmsdk: Provide themescontract tests --> CyanogenMod/cm_platform_sdk
  • MmsRequest: Reimplement automatic data sub switch --> CyanogenMod/android_packages_services_Mms
  • systemui: Fix compilation failure --> CyanogenMod/android_frameworks_base
  • Handle >5 forecast items in cLock Forecast view --> CyanogenMod/android_packages_apps_LockClock
  • Gallery: Make sure no NPE happens --> CyanogenMod/android_packages_apps_Gallery2
  • isRoaming: fix possible NPE --> CyanogenMod/android_frameworks_base
  • CMUpdater: Prevent NPE --> CyanogenMod/android_packages_apps_CMUpdater
  • CMFM: Make sure no NPE happens --> CyanogenMod/android_packages_apps_CMFileManager
  • InCallUI: Fix possible OOBs --> CyanogenMod/android_packages_apps_InCallUI
  • Fix appearance of auxiliary circles in GlowPadView --> CyanogenMod/android_packages_apps_InCallUI
  • Trebuchet: Never show page indicator in app drawer --> CyanogenMod/android_packages_apps_Trebuchet
  • Wire up share visible contacts --> CyanogenMod/android_packages_apps_Dialer
  • SystemUI: Add support for persistent usb drive notification --> CyanogenMod/android_frameworks_base
  • More...
Reaktionen: Nick Knight und sourly
I9100 20160625 is UP!
Changelog:
  • SystemUI: Add margin in qs_tile_top between instruction text and add button --> CyanogenMod/android_frameworks_base
  • Revert "Revert "Ensure synchronized access of JNI callback object"" --> CyanogenMod/android_packages_apps_Bluetooth
  • Subscription updater: don't turn data off if we've never set a deafult --> CyanogenMod/android_frameworks_opt_telephony
  • Wifi: Clear lastConnectAttemptTimestamp variable on a Wifi turn off --> CyanogenMod/android_frameworks_opt_net_wifi
  • Wifi: Update WifiController state if Wifi turn On fails --> CyanogenMod/android_frameworks_opt_net_wifi
  • Don't create ScanDetailCache if entry absent in mScanDetailCaches --> CyanogenMod/android_frameworks_opt_net_wifi
  • wificonfig: store the scan cache for saved wifi configuration --> CyanogenMod/android_frameworks_opt_net_wifi
  • P2P: p2p flush on a group remove event --> CyanogenMod/android_frameworks_opt_net_wifi
  • Wifi: Add NULL check before processing gscan results --> CyanogenMod/android_frameworks_opt_net_wifi
  • Wifi : Add null check before accessing ScanDetailCache --> CyanogenMod/android_frameworks_opt_net_wifi
  • Wifi: Unblacklist the BSSIDs, if driver roams to the same again --> CyanogenMod/android_frameworks_opt_net_wifi
  • Wifi: send an explicit ENABLE_NETWORK with "no-connect" --> CyanogenMod/android_frameworks_opt_net_wifi
  • Wifi: Update Frequency before broadcasting intent --> CyanogenMod/android_frameworks_opt_net_wifi
  • wifi: Use isGbkString() to check if SSID is GBK encoded --> CyanogenMod/android_frameworks_opt_net_wifi
  • Wifi: Clear scan caches while loading configured networks --> CyanogenMod/android_frameworks_opt_net_wifi
  • Reduce the link de-bounce time to 4 from earlier 7 seconds --> CyanogenMod/android_frameworks_opt_net_wifi
  • Themes: Provide 100% test coverage for themes --> CyanogenMod/cm_platform_sdk
  • UI: Ensure "use for" options displayed when in landscape orientation --> CyanogenMod/android_packages_apps_Settings
  • wifi: Bring back mIsWiFiIpReachabilityEnabled check --> CyanogenMod/android_frameworks_opt_net_wifi
  • wifi: Enable WiFi IpReachabilityMonitor by default --> CyanogenMod/android_frameworks_base
  • SoundRecorder: Fix notifcation out of sync when audio focus loss --> CyanogenMod/android_packages_apps_SoundRecorder
  • Fix no icon for 3GP files --> CyanogenMod/android_packages_apps_CMFileManager
  • Assign application/octet-stream to unknown file extensions --> CyanogenMod/android_packages_apps_CMFileManager
  • Remove send/send multiple if intent doesn't resolve to any activity --> CyanogenMod/android_packages_apps_CMFileManager
  • Navigate to path when launched from folder shortcut --> CyanogenMod/android_packages_apps_CMFileManager
  • bt: Don't use CLOCK_BOOTTIME where CLOCK_MONOTONIC was expected --> CyanogenMod/android_system_bt
  • Add SM-T810 and SM-T815 --> CyanogenMod/android_vendor_cm
  • hotspot: Add a fallback to model-name for SSID --> CyanogenMod/android_frameworks_opt_net_wifi
  • android: Switch to our chromium-webview --> CyanogenMod/android
  • bt-vendor: Check for vendor SSR function before attempting to call it --> CyanogenMod/android_system_bt
  • Telephony Data: Introduce DataAllowed state --> CyanogenMod/android_frameworks_opt_telephony
  • Settings: Fix possible NPE --> CyanogenMod/android_packages_apps_Settings
  • sepolicy: put bash in shell context --> CyanogenMod/android_vendor_cm
  • Fix issue when two MMS requests with same priority on both SUB's --> CyanogenMod/android_frameworks_opt_telephony
  • Snap: Add picture resolutions for OnePlus 3 --> CyanogenMod/android_packages_apps_Snap
  • Themes: Fix ThemeManagerTest --> CyanogenMod/cm_platform_sdk
  • Themes: Fix applying default theme --> CyanogenMod/cm_platform_sdk
  • Telephony: handle 3rd party sms apps + 'always ask' --> CyanogenMod/android_frameworks_opt_telephony
  • Settings: handle 'always ask' for SMS subscription on 3rd party apps --> CyanogenMod/android_packages_apps_Settings
  • Revert "MmsRequest: Reimplement automatic data sub switch" --> CyanogenMod/android_packages_services_Mms
  • wipower: Only build a4wp if BSP is available --> CyanogenMod/android_packages_apps_BluetoothExt
  • Run the receive path in its own thread --> CyanogenMod/android_external_android-clat
  • Process packets in bursts --> CyanogenMod/android_external_android-clat
  • stagefright-plugins: call packet_queue_init earier --> CyanogenMod/android_external_stagefright-plugins
  • Actually verifies if CM weather feature is available --> CyanogenMod/android_packages_apps_LockClock
  • recovery: Initialize menu_show_start_ to avoid crash --> CyanogenMod/android_bootable_recovery
  • Verifies if weather service is available --> CyanogenMod/android_packages_apps_LockClock
  • libbt-vendor (BRCM): Add ssr_cleanup --> CyanogenMod/android_hardware_broadcom_libbt
  • sf: Only apply hwrotation to primary displays --> CyanogenMod/android_frameworks_native
  • Settings : Move trust agent search index to LockscreenSettings --> CyanogenMod/android_packages_apps_Settings
  • String improvements --> CyanogenMod/android_packages_apps_Messaging
  • Fix Rename on VFat --> CyanogenMod/android_packages_apps_CMFileManager
  • ListPopupWindow: set height of the list --> CyanogenMod/android_packages_apps_CMFileManager
  • Search: Hide progress spinner if search fails --> CyanogenMod/android_packages_apps_CMFileManager
  • Bring back the custom wallpaper picker [5/5] --> CyanogenMod/android_vendor_cm
  • Bring back the custom wallpaper picker [4/5] --> CyanogenMod/android
  • Bring back the custom wallpaper picker [3/5] --> CyanogenMod/android_packages_apps_Settings
  • Bring back the custom wallpaper picker [2/5] --> CyanogenMod/android_packages_apps_Trebuchet
  • Bring back the custom wallpaper picker [1/5] --> CyanogenMod/android_packages_apps_WallpaperPicker
  • CMUpdater: Check permissions for external storage --> CyanogenMod/android_packages_apps_CMUpdater
  • cmsdk: Prevent NPE in CMWeatherManager --> CyanogenMod/cm_platform_sdk
  • SystemUI: detect rotation and resize mKeyguardBlur accordingly --> CyanogenMod/android_frameworks_base
  • Weather API test: Wait for a bit before Mockito verifies if method was called --> CyanogenMod/cm_platform_sdk
  • Fix sort mode popup after rotation from portrait to landscape --> CyanogenMod/android_packages_apps_CMFileManager
  • Settings: Apply decor padding in landscape storage wizard --> CyanogenMod/android_packages_apps_Settings
  • Fix NPE in DocumentsUI when rotate UI before format as internal --> CyanogenMod/android_frameworks_base
  • More...
Reaktionen: sourly
Guten Morgen, ich habe seit gestern dank Nick Knight die Linaro Sabermod 5.1.1 bei mir auf dem Galaxy S2. Läuft soweit auch gut nur habe ich das Problem mit dem Wetter Widget immernoch. Wenn ich es aktiviere für den Sperrbildschirm wird es mir nicht angezeigt. Ich habe alle Einstellungen dafür gemacht aber ich bekomme es nicht angezeigt, genauso bei dem Widget für den normalen Desktop. Ich habe das Problem ja schonmal für die 4.4.4 beschrieben - da konnte mir niemand helfen, dann dachte ich eigentlich es wäre mit einem Update wieder zu haben das Feature...
Gibt es da eine Hilfestellung ? Das Problem muss ja weiter im System verankert sein als angenommen. Wo kann ich anfangen zu suchen ?
Viele grüße
EDIT: Also so wie es scheint wurde bei CM12 die Funktion des Weather Widgets für den Lockscreen rausgenommen und nicht wieder hinzugefügt. (Falls ich falsch liege bitte bescheid sagen) Meine Quelle dafür ist diese hier: Weather in CM12 lockscreen • /r/cyanogenmod
Des weiteren funktioniert das Wetter Widget für den "Homescreen" nur mit OpenWeatherMap.
So habe ich mir geholfen: Clock Widget mit Wetter Anzeige auf den Homescreen gelegt und in den Einstellungen von Yahoo Wetter in OpenWeatherMap gewechselt. Dann Standort neu bestimmen lassen und dann ging es. Nun kann ich auch wieder in Yahoo Wetter wechseln allerdings zeigt er bei der Aktualisierung keine aktuelle Zeit an sodass ich davon ausgehe das Yahoo Wetter defekt ist. Letztendlich habe ich wieder OpenWeatherMap reingemacht und dann das Clock Widget entfernt da es für mich nur Sinn auf dem Lockscreen macht. Nun habe ich die Funktion "Wetter in der Benachrichtigunsleiste" anzeigen ausgewählt und so muss es erstmal sein ! Alles gut.
@seeWood
Jetzt wo du es schreibst, fällt mir auch wieder ein, das Yahoo seinen Dienst eingestellt hat. Deshalb wurde in CM13 auch eine andere/neue Funktionen "Wetterdienst" hinzugefügt. Mit dem Xposed-Framework und "GravityBox LP" könntest du versuchen, dir das Wetterwidget auf den Sperrbildschirm zu legen. Ich persönlich halte nichts von solchen Widgets, da sie ja ständig aktualisieren müssen und somit den "Deep Sleep" verhindern, was Akku kostet.
Gruß Nick Knight
Reaktionen: seeWood und SunSide
Da gebe ich dir absolut recht. ich halte davon auch nichts. Ich habe den Aktualisierungsintervall auch auf Manuell gestellt und nur wenn ich das Handy in der Hand hatte um sowieso was zu machen das Widget aktualisiert. Ich kann mich aber auch gut ohne anfreunden :) Hatte es ja nur immer und wie das eben so ist mit veränderungen. @Nick Knight Hast du denn auch das Problem mit dem Trebuchet ? Bei mir kommt zwar nicht ständig aber des öftern das der Dienst beendet wurde. Und welchen Kernel hast du ? Ich würde gerne einen BLN Kernel nutzen es muss aber nicht unbedingt der Dori sein, aktuell bin ich aber auf dem Dori V11.0b042
Riesiges Update
I9100 20160703 is UP!
Changelog:
  • Use 2 zRAM compression streams (now that our driver can) --> CyanogenMod/android_device_samsung_galaxys2-common
    • galaxys2-common: Cleanup unused flags --> CyanogenMod/android_device_samsung_galaxys2-common
    • init: increase read-ahead value to 256 kb --> CyanogenMod/android_device_samsung_galaxys2-common
    • net: validate the range we feed to iov_iter_init() in sys_sendto/sys_recvfrom --> CyanogenMod/android_kernel_samsung_smdk4412
    • HID: hiddev: validate num_values for HIDIOCGUSAGES, HIDIOCSUSAGES commands --> CyanogenMod/android_kernel_samsung_smdk4412
    • KEYS: potential uninitialized variable --> CyanogenMod/android_kernel_samsung_smdk4412
    • mnt: Fail collect_mounts when applied to unmounted mounts --> CyanogenMod/android_kernel_samsung_smdk4412
  • ARM: EXYNOS: silence watchdog log spam --> CyanogenMod/android_kernel_samsung_smdk4412
  • Subscription updater: don't post messages on events in BroadcastReceiver --> CyanogenMod/android_frameworks_opt_telephony
  • TelephonyProvider: Add Channel 60 support --> CyanogenMod/android_packages_providers_TelephonyProvider
  • CellBroadcast Alerts : Enable CMAS Test alerts --> CyanogenMod/android_packages_providers_TelephonyProvider
  • Fix Mms failures due to wrong numeric --> CyanogenMod/android_packages_providers_TelephonyProvider
  • Merge regional apns to telephony db --> CyanogenMod/android_packages_providers_TelephonyProvider
  • TelephonyProvider: Add CDMA call forwarding/waiting function --> CyanogenMod/android_packages_providers_TelephonyProvider
  • Bluetooth : Handle SQL memory situation during OPP --> CyanogenMod/android_packages_apps_Settings
  • Grey out PIN1 enable/disable option when SUB is not ready --> CyanogenMod/android_packages_apps_Settings
  • Update OperatorInfo in Simstatus settings for correct subid --> CyanogenMod/android_packages_apps_Settings
  • Fix mcc-mnc population issue in apn editor --> CyanogenMod/android_packages_apps_Settings
  • Don't start auto scan if screen recovers from frozen state --> CyanogenMod/android_packages_apps_Settings
  • Wi-Fi: Do not display the not scanned saved networks forever --> CyanogenMod/android_packages_apps_Settings
  • IMS: Set Wifi calling preference to Wifi preferred by default --> CyanogenMod/android_packages_apps_Settings
  • Fix to enable data for non-dds sub --> CyanogenMod/android_packages_apps_Settings
  • Telephony(MSIM): Fix ANR on SIM deactivation --> CyanogenMod/android_packages_apps_Settings
  • Add intent to send STK app name --> CyanogenMod/android_packages_apps_Stk
  • Send slotId in message for OP_STOP_TONE --> CyanogenMod/android_packages_apps_Stk
  • MSIM: Add MSIM support for language selection event --> CyanogenMod/android_packages_apps_Stk
  • Fix the notification cancel during SIM refresh --> CyanogenMod/android_packages_apps_Stk
  • Do not go Fullscreen in StkInputAcvtivity --> CyanogenMod/android_packages_apps_Stk
  • Fix duplicate detection for ETWS primary and secondary notifications --> CyanogenMod/android_packages_apps_CellBroadcastReceiver
  • Regional: Support Channel 60 switch in CellBroadcast --> CyanogenMod/android_packages_apps_CellBroadcastReceiver
  • Add Msim support for Service State intent in CB receiver --> CyanogenMod/android_packages_apps_CellBroadcastReceiver
  • Use of SubId inplace of SlotId in CellBroadcastReceiver --> CyanogenMod/android_packages_apps_CellBroadcastReceiver
  • Added permission READ_PRIVILEGED_PHONE_STATE --> CyanogenMod/android_packages_apps_Dialer
  • Fix to incall screen for incoming call --> CyanogenMod/android_packages_apps_InCallUI
  • Add rtl support to GlowPadView --> CyanogenMod/android_packages_apps_InCallUI
  • Fix display 'null' for geocoder location --> CyanogenMod/android_packages_apps_InCallUI
  • IMS-VT: Fix for auto fullscreen issue during UI rotation --> CyanogenMod/android_packages_apps_InCallUI
  • Don't use global variable in libnetutils --> CyanogenMod/android_system_core
  • Copy the ETB dumps and maps file to /data/core --> CyanogenMod/android_system_core
  • healthd: Support new PD and USB Type C types --> CyanogenMod/android_system_core
  • Set APM mode property for RIL to access --> CyanogenMod/android_packages_services_Telephony
  • IMS-VT: Conf: Propagate call extras to UI --> CyanogenMod/android_packages_services_Telephony
  • SEEK: Change security check for getAtrUsingSubId --> CyanogenMod/android_packages_services_Telephony
  • Add "FDN service is not available" toast message --> CyanogenMod/android_packages_services_Telephony
  • Mms: Fix SMS is not sent in ECBM unless click send again --> CyanogenMod/android_packages_services_Telephony
  • Fix updating FDN using uri without subId issue --> CyanogenMod/android_packages_services_Telephony
  • Fix sound output from headset when switching speaker to BT --> CyanogenMod/android_packages_services_Telecomm
  • Fix disabled merge button on conference failure --> CyanogenMod/android_packages_services_Telecomm
  • Fix a bug where conference call does not automatically resume --> CyanogenMod/android_packages_services_Telecomm
  • Remove TONE_SUPERVISORY_CH --> CyanogenMod/android_packages_services_Telecomm
  • Fix to prevent NPE --> CyanogenMod/android_packages_services_Telecomm
  • Restrict ability to add call based on device provision status --> CyanogenMod/android_packages_services_Telecomm
  • gsmsst: Protect against "null" string literals --> CyanogenMod/android_frameworks_opt_telephony
  • Add channel 60 Cellboradcast support --> CyanogenMod/android_frameworks_opt_telephony
  • Fix ADN records loading removing EFEXT1 dependency --> CyanogenMod/android_frameworks_opt_telephony
  • FR29338: Read SIM Contacts from EF-ADN if EF-PBR read failed --> CyanogenMod/android_frameworks_opt_telephony
  • Check subid when querying network selection --> CyanogenMod/android_frameworks_opt_telephony
  • Revert "updateSpnDisplay: When PLMN values are same for before & after SIM loading in." --> CyanogenMod/android_frameworks_opt_telephony
  • Telephony: Config values for other languages --> CyanogenMod/android_frameworks_opt_telephony
  • Do not set "gsm.operator.idpstring" per phoneId --> CyanogenMod/android_frameworks_opt_telephony
  • MSIM: Fix ECBM dialog issue in G+C --> CyanogenMod/android_frameworks_opt_telephony
  • Setup data on new APNs only when APN changes --> CyanogenMod/android_frameworks_opt_telephony
  • IMS: Fix null pointer exception for call forwarding --> CyanogenMod/android_frameworks_opt_telephony
  • IMS: Exit ECBM before dialing a pending non-emergency MO call --> CyanogenMod/android_frameworks_opt_telephony
  • Telephony: CDMA: allow MT SMS when in ECBM --> CyanogenMod/android_frameworks_opt_telephony
  • Send shutdown command to modem --> CyanogenMod/android_frameworks_opt_telephony
  • Fix default data reset issue on device powerup --> CyanogenMod/android_frameworks_opt_telephony
  • Add the slot id when broadcasting card state to STK app --> CyanogenMod/android_frameworks_opt_telephony
  • Fix DDS switch issues for CDMA and IWLAN scenarios --> CyanogenMod/android_frameworks_opt_telephony
  • IMS: Fix phone app crash at setOutgoingCallerIdDisplay() --> CyanogenMod/android_frameworks_opt_telephony
  • MSIM: Use SIM specific subId for setMccMnc --> CyanogenMod/android_frameworks_opt_telephony
  • Finer grained character boundaries in computing SMS fragment lengths --> CyanogenMod/android_frameworks_opt_telephony
  • Parse the record number from byte to int --> CyanogenMod/android_frameworks_opt_telephony
  • Fix ims pdn request issue --> CyanogenMod/android_frameworks_opt_telephony
  • Fix to avoid unnecessary PS attach --> CyanogenMod/android_frameworks_opt_telephony
  • Fix Dds switch issue for wifi and IWLAN scenarios --> CyanogenMod/android_frameworks_opt_telephony
  • Use EVS codec for HD if carrier supports it --> CyanogenMod/android_frameworks_opt_telephony
  • Notify disconnect on phone dispose --> CyanogenMod/android_frameworks_opt_telephony
  • Fix to resolve data call issue for sim hot swap case --> CyanogenMod/android_frameworks_opt_telephony
  • Fix ims pdn issue on non dds sub on iwlan --> CyanogenMod/android_frameworks_opt_telephony
  • Fix emergency ims pdn setup issue --> CyanogenMod/android_frameworks_opt_telephony
  • Telephony: Reduce back to back same APN activation delay --> CyanogenMod/android_frameworks_opt_telephony
  • Set additional info for LaunchBrowser error case --> CyanogenMod/android_frameworks_opt_telephony
  • MSIM: Send FINISH request on flex map START fail --> CyanogenMod/android_frameworks_opt_telephony
  • dct: Sync with upstream --> CyanogenMod/android_frameworks_opt_telephony
  • TelephonyProvider: Add CDMA call forwarding/waiting function --> CyanogenMod/android_frameworks_opt_telephony
  • Add config to show HD icon on EVS codec --> CyanogenMod/android_frameworks_base
  • MSIM: Restrict data activity change to listeners with matching subId --> CyanogenMod/android_frameworks_base
  • Remove TONE_SUPERVISORY_CH --> CyanogenMod/android_frameworks_base
  • Ignore IMS type APN when notify data connection --> CyanogenMod/android_frameworks_base
  • combo bug when location reported by providers do not come with extras --> CyanogenMod/android_frameworks_base
  • Wifi: Make maximum selective channel scans and interval configurable --> CyanogenMod/android_frameworks_base
  • WifiDisplayController: Fix p2p disconnect before rtsp teardown completes --> CyanogenMod/android_frameworks_base
  • Bluetooth: Access mediaplayerlist in synchronized way --> CyanogenMod/android_frameworks_base
  • Encapsulate the unbindService with try catch block --> CyanogenMod/android_frameworks_base
  • Add absent sim info to locked screen text --> CyanogenMod/android_frameworks_base
  • BT: Set persiste Bluetooth State during enable timeout case --> CyanogenMod/android_frameworks_base
  • Avoid potential NPE when tearing down LLS --> CyanogenMod/android_packages_screensavers_Basic
  • libc: Fix invalid offset warning with Clang --> CyanogenMod/android_bionic
  • Do not depend on host bits to get the right size to write --> CyanogenMod/android_bionic
  • cmsdk: Update README --> CyanogenMod/cm_platform_sdk
  • Remove identifier that causes warnings under OpenJDK 8 compiler --> CyanogenMod/android_packages_apps_Messaging
  • Remove identifier that causes warnings under OpenJDK 8 compiler --> CyanogenMod/android_frameworks_opt_telephony
  • Remove use of '_' variable name --> CyanogenMod/android_frameworks_base
  • cmsdk: Create brokerablecmsystemservice concept --> CyanogenMod/cm_platform_sdk
  • cmsdk: Factor CMSystemServiceHelper to common --> CyanogenMod/cm_platform_sdk
  • Apply active profile if user enables system profiles --> CyanogenMod/cm_platform_sdk
  • Add Bluetooth sound recording --> CyanogenMod/android_packages_apps_SoundRecorder
  • feijao: Set voicemail's notification persistent --> CyanogenMod/android_packages_apps_CarrierConfig
  • Cleanup icon preview generation code --> CyanogenMod/android_packages_providers_ThemesProvider
  • fingerpint: Allow devices to configure sensor location --> CyanogenMod/android_packages_apps_Settings
  • Contacts metrics: corrected parsed timestamp values --> CyanogenMod/android_packages_apps_Contacts
  • Contacts metrics: flip contacts merge order since they have dependency --> CyanogenMod/android_packages_apps_Contacts
  • Fix apn restore issue for multi-sim --> CyanogenMod/android_packages_providers_TelephonyProvider
  • Send count stats with DIRECTORY_SEARCH events --> CyanogenMod/android_packages_apps_Contacts
  • cmhw: Whitespace cleanup --> CyanogenMod/android_hardware_cyanogen
  • settings: wifi: Default to numeric keyboard for static IP items --> CyanogenMod/android_packages_apps_Settings
  • Settings: Set root access options appropriately --> CyanogenMod/android_packages_apps_Settings
  • Revert "Revert "Only show keyguard panel if on lockscreen + no activity on top"" --> CyanogenMod/android_frameworks_base
  • WindowAnimator : Check KEYGUARD_PANEL when deciding to show/hide window --> CyanogenMod/android_frameworks_base
  • Fix input validation for calculator widget --> CyanogenMod/android_packages_apps_Calculator
  • PhoneWindowManager : Check CM_SETUP_WIZARD_COMPLETED for isUserSetupComplete --> CyanogenMod/android_frameworks_base
  • KeyguardSecurityViewFlipper : Fix sim unlock height overlap --> CyanogenMod/android_frameworks_base
  • Messaging: Use textutils to match against SIP scheme --> CyanogenMod/android_packages_apps_Messaging
  • LLS: Allow default enabled events to be overlaid --> CyanogenMod/cm_platform_sdk
  • Disable proximity check on power key properly --> CyanogenMod/android_frameworks_base
  • fw: GlobalActions: Always dismiss any existing dialog --> CyanogenMod/android_frameworks_base
  • Add Encrypted Google search engine --> CyanogenMod/android_packages_apps_Gello
  • Settings : Add country code to blacklist entry dialog --> CyanogenMod/android_packages_apps_Settings
  • FileManager : Update to use toybox ls --> CyanogenMod/android_packages_apps_CMFileManager
  • Don't remove today from the forecast --> CyanogenMod/android_packages_apps_YahooWeatherProvider
  • Don't remove today from the forecast --> CyanogenMod/android_packages_apps_WundergroundWeatherProvider
  • cortex-a9: Fix reference to __memcpy_base_aligned --> CyanogenMod/android_bionic
  • Fix crash when long press directory --> CyanogenMod/android_packages_apps_CMFileManager
  • IMS-VT: Remove unused QTI_IMS_CALL_RAT_EXTRA_KEY extra --> CyanogenMod/android_frameworks_opt_telephony
  • Ims: remove use of old nonexistant qti constant --> CyanogenMod/android_frameworks_opt_telephony
  • IMS: Encrypted Calling Extras Key Definition --> CyanogenMod/android_frameworks_opt_telephony
  • IMS: Interface change for VOPS and SSAC --> CyanogenMod/android_frameworks_opt_telephony
  • IMS: Explicit call transfer feature --> CyanogenMod/android_frameworks_opt_telephony
  • Remove APN pinternet.interkom.de from MCC 262/MNC 02 --> CyanogenMod/android_vendor_cm
  • T810: Build by T_I, based on T815 build of RaymanFX, added product name --> CyanogenMod/android_vendor_cm
  • Make sure LiveDisplay toggle default values are correct --> CyanogenMod/android_packages_apps_Settings
  • SystemServer: Do not start Atlas Service on lowram devices --> CyanogenMod/android_frameworks_base
Danke für die Info, was sagst du denn @j1gga84 zu meiner Problematik ? Hast du auch Abstürze beim Trebuchet ? Du hast ja auch 5.1.1 + Dori nur andere Builds...
@seeWood
Kann ich leider nichts zu sagen, da ich mein S2 nicht mehr aktiv nutze, außerdem hab ich den Trebuchet nie genutzt sondern seit eh und je den Nova Launcher.
Guten Morgen,
ich habe mir die CM12.1 vom 19.02.16 geflashed von Markox89 und nun auch keine Trebuchet Probleme mehr. Allgemein läuft sie etwas besser hab ich den Eindruck. Ich habe aktuell auch keinen Kernel geflashed. Gibt es für mich einen alternativen Kernel mit BLN Unterstützung ausser den Dori oder die Beta von Apolo für LP ?
Zum anderen hab ich das hier von Nick Knight gelesen:
Nick Knight schrieb:
v11.0.b042 Linaro, unglaublich gute Standarteinstellung, für Unerfahrene der beste LP-Kernel. Okay es gibt Trebuche Probleme,
@Nick Knight Meinst du es liegt am Dori das ich die Trebuchet probleme hatte oder woher weisst du das ? ich nutze mein S2 mit dem Trebuchet Launcher - Ich belasse das System eigentlich immer Stock.
Niemand der Antworten möchte ?
Also ich kann mir ehrlich gesagt nicht vorstellen, dass der Kernel für Launcher Probleme verantwortlich ist.
Generell ist der Trebuchet nicht der beste Launcher, probiere doch einfach mal einen anderen, wie z.B. den Nova oder Apex Launcher, ich habe es bis heute nicht bereut und eigentlich noch nie ein Problem gehabt.
Alternativen zum Dori oder Apolo Kernel gibt es nicht, da die Kernel Entwicklung für das S2 schon lange eingestellt wurde, einzig gsstudios arbeitet noch aktiv in der Kernelentwicklung, aktuell jedoch für CM13.0
Du könntest dir also auch mal die neuste CM13.0 von Markox89 mit dem neusten Dorimanx 12.0 b005 installieren, diese Kombi soll wohl recht gut laufen.
Ich danke dir das du mir antwortest, ja deshalb hat ich ja eigentlich @Nick Knight gemacht damit der gute Mann mal etwas dazu sagt :) Ich werde einfach mal deine Kombi ausprobieren, die 5.1.1 von dir läuft ja deutlich besser bei mir dann nehme ich auch mal deine Build vom Kernel...
Ist nicht von mir das Ganze ;) Habe es nur aus dem XDA-Forum ins Deutsche übersetzt ;)
Einfach mal etwas durchprobieren, die CM13.0 ROMs laufen inzwischen schon recht ordentlich, jetzt, wo der Dorimanx auf CM13.0 läuft.
Nutze das S2 zwar nur noch als Ersatzgerät, bin derzeit aber wieder etwas am Flashen & Testen ;)
@seeWood
Die Probleme, hauptsächlich FC, mit Kombi Trebuche und DorimanX habe ich nur sehr häufig in den Threads auf XDA gelesen. Ich selbst nutze den Launcher und auch diese ROM nicht.
Das weiss ich schon das es nicht von dir ist :) ich meinte nur damit das ich die Version habe von "Dir" die du in deinem Spoiler hast... Die letzte Version ausm März lief bei mir ja nicht gut allerdings in Verbidung mit dem Dori Kernel deshalb wäre jetzt wichtig zu wissen ob es am Dori liegt oder am Build von marcox89...
Da ich mein S2 also MainPhone nutze kann ich nur bedingt sachen testen und ausprobieren. Wenn du was brauchbares hast kannst es ja posten oder wenn ich fragen habe hau ich dich an...
@Nick Knight Ok, ja dann weiss ich bescheid wo du deine infos her hast ich hatte das auch mal gegoogled Trebuchet und LP Roms aber nichts brauchbares gefunden. was ist FC ?
EDIT: Force Closed - Wurde beendet :) alles klar !
Kurze Rückmeldung: ich habe mit der Build 5.1.1 vom 19.02.16 und der Dori V11.0b038 keine Trebuchet Abstürze mehr, allerdings ist mir das Handy über Nacht an der Ladestation ausgegangen und jetzt wieder im Dori Bootscreen hängen geblieben. Ich hab jetzt mein Backup eingespielt, Lollipop und Dori werden keine Freunde mehr denke ich, zumindest für mich nicht. Gibt es alternativen für mich BLN zu nutzen ? Gibt es Xposed BLN ?
@seeWood
Teste den V11.0b042 Linaro und schalte in STweaks unter "Dualboot" das Bootogo ab, ist eh nur eine Zwangspause für User die nur eine ROM nutzen. Seit LP bleibt es da auch gerne mal hängen.
BLN/BLNWW muss der Kernel unterstützen. Also wenig bis kaum eine Chance das anders zu lösen.
Gruß Nick Knight
Danke für den Tipp, die 11.0b042 Linaro habe ich schon drauf gehabt mit der 5.1.1. build vom 11.03.16 da gab es Trebuchet abstürze. Das Bootlogo kann ich allerdings wirklich abschalten das ist ein guter Tipp. Ich werde es nochmal mit der b038 probieren.
Hab mich am Freitag mal durchgerungen zum Nova Launcher. Nun kommt immer Nova Launcher wurde beendet. Ich habe dann mal wieder mein Backup eingespielt und ich lasse das System jetzt so. Wenn ich mal irgendwann zu MM wechseln sollte ist ja BLN integriert. Markox89 hat wunderbare Arbeit geleistet bei seiner ROM die läuft ohne Dori bei mir richtig gut ! Vielen Dank an Nick Knight und j1gga84 für support.
Rufuz66
Rufuz66
fireburner
F0x123
Nick Knight
Sir Charles
Sir Charles
