j1gga84
Ehrenmitglied
- 6.259
- Themenstarter
- #621
I9100 20150131 is UP!
- Updated Kernel Toolchain to Linaro 4.9.2 2015.01
- Revert "Mms:Better Android Wearable support" --> CyanogenMod/android_packages_apps_Mms-caf
- Mms:Better Android Wearable support --> CyanogenMod/android_packages_apps_Mms-caf
- create block map for all update packages on /data --> CyanogenMod/android_system_core
- open misc device in write-only mode --> CyanogenMod/android_system_core
- clear BCB in misc partition before rebooting --> CyanogenMod/android_system_core
- revert uncrypt back to dynamic linking, fix libs --> CyanogenMod/android_system_core
- change uncrypt to static linking --> CyanogenMod/android_system_core
- only do uncryption on packages in /data --> CyanogenMod/android_system_core
- recovery: 64 bit build issues --> CyanogenMod/android_system_core
- Fix a crash when going into recovery mode --> CyanogenMod/android_system_core
- program to store unencrypted files in an encrypted filesystem --> CyanogenMod/android_system_core
- sr: Remove uncrypt, it's moving to system/core --> CyanogenMod/android_bootable_recovery-cm
- Revert "Settings : Add tap/pay help url" --> CyanogenMod/android_packages_apps_Settings
- Tap & Pay - Give 'learn more' a URL --> CyanogenMod/android_vendor_cm
- macloader: Fix log output and return value --> CyanogenMod/android_hardware_samsung
- macloader: Use a variable for device type --> CyanogenMod/android_hardware_samsung
- macloader: Close file when we don't need it anymore --> CyanogenMod/android_hardware_samsung
- macloader: Use fchown() to change owner of the cidfile --> CyanogenMod/android_hardware_samsung
- macloader: Use fchmod() to change permissions --> CyanogenMod/android_hardware_samsung
- macloader: Fix build warning with LOG defines --> CyanogenMod/android_hardware_samsung
- macloader: Make macloader a C file --> CyanogenMod/android_hardware_samsung
- Update Cellcom Israel --> CyanogenMod/android_vendor_cm
- Rebuilt ICU stub data --> CyanogenMod/android_external_icu4c
- Add M12 to the changelog --> CyanogenMod/android_vendor_cm
- Rebuilt ICU files for Luxembourgish with unused data removed --> CyanogenMod/android_external_icu4c
- librilsec-client: Add support for xmm7260 modem --> CyanogenMod/android_hardware_samsung
- recovery: Allow 'mm' and friends to work --> CyanogenMod/android_bootable_recovery-cm
- Allow 0-byte files in full OTAs --> CyanogenMod/android_bootable_recovery-cm
