[ROM][I9100][MM][6.0.1] *05.11.16* CyanogenMod 13.0 [Linaro][SaberMod]
  • 808 Antworten
I9100 20141011 is UP! :cool:
Changelog:
* fixed Lycamobile APNs --> CyanogenMod/android_vendor_cm
* stagefright: STEVE BUYS DONUTS --> CyanogenMod/android_frameworks_av
* corrected Beeline UA apn --> CyanogenMod/android_vendor_cm
* added Afghanistan, Sri Lanka, Iraq, Kuwait apns --> CyanogenMod/android_vendor_cm
* corrected Yota APN --> CyanogenMod/android_vendor_cm
* updated NOS/MEO apn names --> CyanogenMod/android_vendor_cm
* cleanup: Spain APNs --> CyanogenMod/android_vendor_cm
* added Africell APNs, moved Movistar PA APN --> CyanogenMod/android_vendor_cm
* fixed Bouygues APNs --> CyanogenMod/android_vendor_cm
* add/cleaned apn for Moldova/Poland --> CyanogenMod/android_vendor_cm
* Remove duplicate --> CyanogenMod/android_vendor_cm
* base: display live wallpaper settings instead of wallpaper picker --> CyanogenMod/android_frameworks_base
* quiethours: fix vibration logic --> CyanogenMod/android_frameworks_base
* Camera: Cleanup qcom resources --> CyanogenMod/android_packages_apps_Camera2
* Camera: Make popup menus consistent --> CyanogenMod/android_packages_apps_Camera2
* Camera: Add ISO values for sony devices --> CyanogenMod/android_packages_apps_Camera2
* Customisable location tile(1/2) --> CyanogenMod/android_packages_apps_Settings
* Customisable location tile(2/2) --> CyanogenMod/android_frameworks_base
* bugfix: invalid memory access --> CyanogenMod/android_external_bash
* Bugfix: two local buffer overflows --> CyanogenMod/android_external_bash
* bugfix: change the encoding bash uses for exported functions --> CyanogenMod/android_external_bash
* bugfix: bash executing code following func def --> CyanogenMod/android_external_bash
* Camera2: Revert ZSL burst mode --> CyanogenMod/android_packages_apps_Camera2
* Changelog: Add M11, remove M6 --> CyanogenMod/android_vendor_cm
* Properly handle the first card inserted for an extension --> CyanogenMod/external_cyanogen_cmhomeapi
* Post all CM Home Api Card updates to a single background thread --> CyanogenMod/external_cyanogen_cmhomeapi
* wpa_cli: Use os_exec() for action script execution --> CyanogenMod/android_external_wpa_supplicant_8_ti
* hostapd_cli: Use os_exec() for action script execution --> CyanogenMod/android_external_wpa_supplicant_8_ti
* Add os_exec() helper to run external programs --> CyanogenMod/android_external_wpa_supplicant_8_ti
* hal: Expand FAST output guards --> CyanogenMod/android_hardware_qcom_audio-caf
* libmedia: Add flag for non-native FAST tracks --> CyanogenMod/android_frameworks_av
* Only change usecase to ultra-low-latency-playback if it's enabled --> CyanogenMod/android_hardware_qcom_audio-caf
* TeleService: fix event settings NPE --> CyanogenMod/android_packages_services_Telephony
* wlan: Modify sequence of events sent during DHCP phase --> CyanogenMod/android_frameworks_base
* Netd: remove redundant deletion for IPv6 mark rule --> CyanogenMod/android_system_netd
* netd: Add support for ipv6 tethering when using dun --> CyanogenMod/android_system_netd
* audio: update srcOutputs based on current outputs --> CyanogenMod/android_hardware_libhardware_legacy
* audio: Fix to update devices for all non-primary outputs --> CyanogenMod/android_hardware_libhardware_legacy
* audio: primary desc check for sonification --> CyanogenMod/android_hardware_libhardware_legacy
* policy_hal: Update offload restrictions --> CyanogenMod/android_hardware_qcom_audio-caf
* hal: Output latency optimization --> CyanogenMod/android_hardware_qcom_audio-caf
* stagefright-plugins: Allow use of HW codecs for Windows Media --> CyanogenMod/android_external_stagefright-plugins
* stagefright-plugins: Audio output port reconfiguration support --> CyanogenMod/android_external_stagefright-plugins
* omx: Add nBitsPerSample parameter for FLAC --> CyanogenMod/android_frameworks_native
* stagefright: Resolve turf war between FFMPEG and mm-parser --> CyanogenMod/android_frameworks_av
* ffmpeg: Add license notice files --> CyanogenMod/android_external_ffmpeg
* Alarms: Fallback to defualt when uri is invalid --> CyanogenMod/android_packages_apps_DeskClock
* Ion: Update supported media types --> CyanogenMod/ion
* Settings: cleanup new profiles UI --> CyanogenMod/android_packages_apps_Settings
* build: recovery: Remove INTERNAL_RECOVERY_FILES --> CyanogenMod/android_build
* cwm: Declare additional dependencies instead of relying on build hax --> CyanogenMod/android_bootable_recovery
* sr: Declare additional dependencies instead of relying on build hax --> CyanogenMod/android_bootable_recovery-cm
* exfat: Fix symlink generation --> CyanogenMod/android_external_exfat
* rild: Unbreak multi-SIM socket name --> CyanogenMod/android_hardware_ril
* Camera: Change copy right year back to 2012 --> CyanogenMod/android_packages_apps_Camera2
* settings: allow scroll in LED settings's color dialog --> CyanogenMod/android_packages_apps_Settings
* av: audioflinger: Fix SRS build --> CyanogenMod/android_frameworks_av
* SystemUI: fix nav bar arrow keys for RTL locales --> CyanogenMod/android_frameworks_base
* Update APNs for b-mobile (440,10,Japan) --> CyanogenMod/android_vendor_cm
* Settings: Fix carrier/sim slot string logic for msim settings --> CyanogenMod/android_packages_apps_Settings
* TeleService: Settings clean up --> CyanogenMod/android_packages_services_Telephony
* TeleService: Fix in call vibration/event settings for MSIM --> CyanogenMod/android_packages_services_Telephony
* added Truphone UK apn --> CyanogenMod/android_vendor_cm
* added TeleCable/Truphone/Mtel, fixed Lyca/Orange --> CyanogenMod/android_vendor_cm
* added Voiceworks Mobile BV / MVNO NL APNs --> CyanogenMod/android_vendor_cm
* Handle multiple paths in the SECONDARY_STORAGE variable --> CyanogenMod/android_packages_apps_BluetoothExt
* Send refreshRequested broadcast to installed API packages --> CyanogenMod/external_cyanogen_cmhomeapi
* Update contributors --> CyanogenMod/android_vendor_cm
* camera: Use project pathmap --> CyanogenMod/android_hardware_qcom_camera
* charger: Use project pathmap --> CyanogenMod/android_system_core
* Revert "Add the keys I used to sign the market version of Superuser." --> CyanogenMod/android_build
* Added missing line for Verizon APN (mcc 311 mnc 480) --> CyanogenMod/android_vendor_cm
* wifi: show devices behind a firewall that are connected to the WiFi hotspot --> CyanogenMod/android_frameworks_base
* cwm: Use pathmap for recovery --> CyanogenMod/android_bootable_recovery
* sr: Use pathmap for recovery --> CyanogenMod/android_bootable_recovery-cm
* build: Fix pathmap derp --> CyanogenMod/android_build
* build: Use project pathmap for recovery --> CyanogenMod/android_build
* Settings: Disable mobile network switch if MSIM --> CyanogenMod/android_packages_apps_Settings
* Settings: Check if NFC is supported prior to adding to pager --> CyanogenMod/android_packages_apps_Settings
* Settings: Fix NPE in Superuser settings --> CyanogenMod/android_packages_apps_Settings
* Dialer: Match dialer preference style across activities --> CyanogenMod/android_packages_services_Telephony
* Code cleanup --> CyanogenMod/android_packages_apps_Dialer
* Regenerate Android.patch --> CyanogenMod/android_external_sqlite
* hal: Add the missing 'else' for mixer_paths filename selection --> CyanogenMod/android_hardware_qcom_audio-caf
* audio: remove build varient check in audio daemon --> CyanogenMod/android_hardware_qcom_audio-caf
* hal: Add 8916 qrd skuhf sound card detection --> CyanogenMod/android_hardware_qcom_audio-caf
* hal: 8939: add support for 8939 skuk device --> CyanogenMod/android_hardware_qcom_audio-caf
* hal: msm8939: use mixer paths mtp xml for 8939 mtp --> CyanogenMod/android_hardware_qcom_audio-caf
* Revert "SystemUI: Fix missing top task in recent panel." --> CyanogenMod/android_frameworks_base
* Camera: Fix histogram on/off states --> CyanogenMod/android_packages_apps_Camera2
* Keyguard: Save Italy --> CyanogenMod/android_frameworks_base
* Update APNs for docomo and SoftBank (MCC:440 Japan) --> CyanogenMod/android_vendor_cm
* Stop allowing other APNs overriding Sprint LTE --> CyanogenMod/android_vendor_cm
* localgroups: fix null pointer access --> CyanogenMod/android_frameworks_base
The internship is very stimulating, I'm learning so much :D
And the colleagues / bosses are really nice people, it's a pleasure working with them :victory:
On the other side, it's more 8.30-19.30 than 9-18 :p
I also got a bad cold doing commissions at the court during these rainy morning :rolleyes:
P.S.
Build should've been up yesterday, but AFH had issues so...here it is :angel:
Reaktionen: ChrisFis und j1gga84
I9100 20141018 is UP! :cool:
Changelog:
* Change Regulatory Info Activity to prefer string over image --> CyanongeMod/android_packages_apps_Settings
* Only start one WifiClientScanner --> CyanongeMod/android_frameworks_base
* Android : Switch back to aosp mockito --> CyanongeMod/android
* Track whether updates have been handled --> CyanongeMod/external_cyanogen_cmhomeapi
* Dialer: Fix NPE in CallStats --> CyanongeMod/android_packages_apps_Dialer
* SystemUI: Fix data activity arrows for MSIM --> CyanongeMod/android_frameworks_base
* Fix uncaught exception when no location provider available --> CyanongeMod/android_packages_apps_Dialer
* Themes: Force recompiling common resources when scanning theme --> CyanongeMod/android_frameworks_base
* build: Enable Uyghur locale --> CyanongeMod/android_build
* SystemUI (MSIM): Add extra vaules for sim state ready --> CyanongeMod/android_frameworks_base
* minui: Asynchronous rendering for overlay mode --> CyanongeMod/android_bootable_recovery-cm
* Telephony: Decode Virgin Mobile US MMS --> CyanongeMod/android_frameworks_opt_telephony
* Camera: Disable video HDR on devices that don't support it --> CyanongeMod/android_packages_apps_Camera2
* build: Default to dtbToolCM --> CyanongeMod/android_build
* SystemUI: Rework SearchPanelView calculations --> CyanongeMod/android_frameworks_base
* mm-audio: aenc: make frame_count variable 64 bit --> CyanongeMod/android_hardware_qcom_audio-caf
* BTIF-AV: Do not attempt connection for unbonded devices --> CyanongeMod/android_external_bluetooth_bluedroid
* BT: Avoid extra power mode entry for AV --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Fix for NULL pointer check --> CyanongeMod/android_external_bluetooth_bluedroid
* HFP-HS: Abort parsing in case of format error --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: retry recv in case of EINTR --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Increase HF connection timeout --> CyanongeMod/android_external_bluetooth_bluedroid
* Print delay logs during A2dp streaming --> CyanongeMod/android_external_bluetooth_bluedroid
* Calculate number of sbc frames per AVDTP packet --> CyanongeMod/android_external_bluetooth_bluedroid
* BT: MHF: Check codec support for HS requesting SCO transfer --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth:GAP:Handled LMP Response time out event during SAP connection --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Check for NULL String --> CyanongeMod/android_external_bluetooth_bluedroid
* Connection management with non scmst capable remote --> CyanongeMod/android_external_bluetooth_bluedroid
* HID: Add JW MT002 and BORND Mouse(s) to blacklist --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: HID: Reject incoming connection from unpaired device --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Suspend AVDTP link in remote initiated Start --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Dont retry sniff --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: use different constructor for fast flag --> CyanongeMod/android_external_bluetooth_bluedroid
* Removes bond when user clicks on cancel pairing --> CyanongeMod/android_external_bluetooth_bluedroid
* PM: Stop Power Manager Timer if in sniff mode --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: A2DP Sink Logging --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: To disconnect HH profile at device unpair --> CyanongeMod/android_external_bluetooth_bluedroid
* BTIF-AV: Use valid memory for AVRCP message --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Move to proper SCO state --> CyanongeMod/android_external_bluetooth_bluedroid
* Enable required AVRCP Logging by default --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Reject second AVRCP connection --> CyanongeMod/android_external_bluetooth_bluedroid
* BT: Don't stop sniff timer before checking for service ID entry --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Updated ATD string parsing --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Validate the Metadata length --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Clear Notification array on AVRCP disconnect --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Handle missing key event --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Check RC Handle for processing pass-through Commands --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Add PORT_EV_TXFULL event if Tx queue is full --> CyanongeMod/android_external_bluetooth_bluedroid
* HID: Add proper check before accessing connecting bd address --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth:L2CAP: Handled invalid MTU Size and invalid Hci lengths --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: GAP: Avoiding two disconnections from DUT --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Avoid encryption within 5 seconds of an encryption complete --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth:GAP: Update Local device name immediately to NV --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Add Carkits in Blacklist for AVRCP --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: GAP: Update bonded device Name immediately on NVRAM --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Delete node properly --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: GAP: NULL pointer check in sdpu_build_attrib_entry --> CyanongeMod/android_external_bluetooth_bluedroid
* Add Carkits to Avrcp 1.5 Blacklist --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Adds SMP response timer for security request --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Initiate SCO after Mode change event --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: Ignore the Page timeout err for Remote name Request --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth:GAP: Increased max no of SDP records that server can support --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth: GAP: Changing the security to general bonding --> CyanongeMod/android_external_bluetooth_bluedroid
* Bluetooth:GAP: Handled collision scenerio with headset --> CyanongeMod/android_external_bluetooth_bluedroid
* Left handed navbar: fix keyboard placement in immersive mode --> CyanongeMod/android_frameworks_base
* hal: expand ultra low latency guards --> CyanongeMod/android_hardware_qcom_audio-caf
* Fix possible syntax error within localgroups --> CyanongeMod/android_packages_providers_ContactsProvider
* Trebuchet: Add some padding to overflow icon in transition settings --> CyanongeMod/android_packages_apps_Trebuchet
* Add 15.9MP and 11.9MP picture size to arrays --> CyanongeMod/android_packages_apps_Camera2
* contacts: CAF conflated "Delete" by adding multi-delete --> CyanongeMod/android_packages_apps_Contacts
* Contacts: Fix NPE when selecting a contact on a tablet --> CyanongeMod/android_packages_apps_Contacts
* contacts: Add missing tablet menu items --> CyanongeMod/android_packages_apps_Contacts
* Camera2: fix a crash in taking picture --> CyanongeMod/android_packages_apps_Camera2
* hal: Add support for listen playback concurrency --> CyanongeMod/android_hardware_qcom_audio-caf
* Development: Root for apps is unavailable if the su daemon isn't running --> CyanongeMod/android_packages_apps_Settings
* Weaken external rild symbol --> CyanongeMod/android_hardware_ril
* ARM Skia NEON patches - 36 - Color32 --> CyanongeMod/android_external_skia
* Add optimization of Skia S32A_Opaque blitter --> CyanongeMod/android_external_skia
* Always inline Filter_32_*_neon functions --> CyanongeMod/android_external_skia
* Fix SkBlitRow_opts_arm so that it works on ARM v4t --> CyanongeMod/android_external_skia
* Remove the unused SkCachePreload_arm --> CyanongeMod/android_external_skia
* ARM Skia NEON patches - 27 - S32A_D565_Blend --> CyanongeMod/android_external_skia
* ARM Skia NEON patches - 12 - S32_Blend --> CyanongeMod/android_external_skia
* ARM Skia NEON patches - 25 - S32A_D565_Opaque_Dither clean/bugfix/speed --> CyanongeMod/android_external_skia
* Support for HW JPEG Decoder in SKIA --> CyanongeMod/android_external_skia
* ARM Skia NEON patches - 20bis - BitmapProcState accurracy --> CyanongeMod/android_external_skia
* Add optimized S32A_D565_Opaque_Dither blitter --> CyanongeMod/android_external_skia
* ARM Skia NEON patches - 22 - S32_D565_Blend --> CyanongeMod/android_external_skia
* Modify sample buffer size for larger displays --> CyanongeMod/android_external_skia
* Add optimization of Skia S32A_Blend blitter --> CyanongeMod/android_external_skia
* ARM Skia NEON patches - 20 - New improved BitmapProcState code --> CyanongeMod/android_external_skia
* stagefright: Fix CTS failures --> CyanongeMod/android_frameworks_av
* stagefright: Scan for ".ts" files --> CyanongeMod/android_frameworks_av
* audio: Unhide MP2/WMA enums --> CyanongeMod/android_system_core
* bashrc: call resize command to init term dim --> CyanongeMod/android_external_bash
* AudioService: Reduce volume to safe level when headset is connected (2/2) --> CyanongeMod/android_frameworks_base
* Settings: Reduce volume to safe level when headset is connected (1/2) --> CyanongeMod/android_packages_apps_Settings
* hal: Limit MP2 and WMA offload to 8226/8974 devies only --> CyanongeMod/android_hardware_qcom_audio
* audio: Add support for offloading MPEG2 and WMA --> CyanongeMod/android_hardware_qcom_audio
* hostapd_cli: Use os_exec() for action script execution --> CyanongeMod/android_external_wpa_supplicant_8
* wpa_cli: Use os_exec() for action script execution --> CyanongeMod/android_external_wpa_supplicant_8
* Add os_exec() helper to run external programs --> CyanongeMod/android_external_wpa_supplicant_8
* audio_effects.conf - Add loudness enhancer --> CyanongeMod/android_packages_apps_DSPManager
* NetworkController: Extra WIMAX icon handling --> CyanongeMod/android_frameworks_base
* settings: Avoid NPE in NfcTrigger when device doesn't support NFC --> CyanongeMod/android_packages_apps_Settings
* setting: Always remove Left-handed mode setting for non-phones --> CyanongeMod/android_packages_apps_Settings
* repopick: support specifying a range of commits to pick --> CyanongeMod/android_build
* CMWallpaper: respect suggested size --> CyanongeMod/android_packages_apps_CMWallpapers
* sr: check if touch selections fall within menu area --> CyanongeMod/android_bootable_recovery-cm
* Edify: Add/Update abort messages for some asserts --> CyanongeMod/android_build
* cmhw: Use hardware's default value for display features --> CyanongeMod/android_packages_apps_Settings
* System/core: Start qrng daemon upon power up --> CyanongeMod/android_system_core
* f2fs: disable fsck check --> CyanongeMod/android_system_vold
* Open app when clicking on icon in App Info screen --> CyanongeMod/android_packages_apps_Settings
Reaktionen: KST66
I9100 20141025 is UP!
Changelog:
  • Fix light preference padding --> CyanogenMod/android_packages_apps_Settings
  • Add support for single color notification LED (1/2) --> CyanogenMod/android_frameworks_base
  • Add support for single color notification LED (2/2) --> CyanogenMod/android_packages_apps_Settings
  • Added a WANT_CONTACTS intent extra to indicate that we want to export --> CyanogenMod/android_packages_apps_ContactsCommon
  • When recieving the intent we now check if the WANT_EXPORT extra is present --> CyanogenMod/android_packages_apps_Contacts
  • Settings: Fix profiles volume override summary --> CyanogenMod/android_packages_apps_Settings
  • Add SoftBank(Japan) APN --> CyanogenMod/android_vendor_cm
  • hal: Add get_sample_rate for 8960 platforms --> CyanogenMod/android_hardware_qcom_audio-caf
  • Camera2: fix camera has stopped" after long press camera key --> CyanogenMod/android_packages_apps_Camera2
  • ContactsCommon: Add PHOTO_ID to contact tile loader projection --> CyanogenMod/android_packages_apps_ContactsCommon
  • TeleService: MSIM UI clean up --> CyanogenMod/android_packages_services_Telephony
  • InCallUI: Minor UI cleanup for displaying sim name --> CyanogenMod/android_packages_apps_InCallUI
  • msim: initialize sim icon to the known state --> CyanogenMod/android_frameworks_base
  • build: recovery: Support target specific resource selection --> CyanogenMod/android_build
  • sr: Header and font images for 480/720/1080 widths --> CyanogenMod/android_bootable_recovery-cm
  • DeviceInfoSettings: Update the cpuinfo parser --> CyanogenMod/android_packages_apps_Settings
  • Camera2: Fix crash on cameras with 6mp 16:9 resolution --> CyanogenMod/android_packages_apps_Camera2
  • SystemUI: Avoid NPEs during status bar recreation for MSIM --> CyanogenMod/android_frameworks_base
  • mm-core: Enable HW wma10pro decoder for msm7x30 --> CyanogenMod/android_hardware_qcom_media-caf
  • mm-core: msm7x30: Fix code formatting --> CyanogenMod/android_hardware_qcom_media-caf
  • mm-core: msm7x30: Enable HW mp3 decoder --> CyanogenMod/android_hardware_qcom_media-caf
  • mm-core: msm7x30: Update copyright to The Linux Foundation --> CyanogenMod/android_hardware_qcom_media-caf
  • Revert "hardware: ril: Avoid collision with RIL constant 1138" --> CyanogenMod/android_hardware_ril
  • SystemUI: Fix network label regression --> CyanogenMod/android_frameworks_base
  • qcom: keymaster: Include keymaster in all targets --> CyanogenMod/android_hardware_qcom_keymaster
  • Move UICC storage string to cm_strings --> CyanogenMod/android_frameworks_base
  • Modify the Development shortcut help text --> CyanogenMod/android_packages_apps_Settings
  • 'Delete application' development shortcut --> CyanogenMod/android_frameworks_base
  • Eleven: Improve strings --> CyanogenMod/android_packages_apps_Eleven-resources
  • TeleService: fix vibrate on answer --> CyanogenMod/android_packages_services_Telephony
  • Settings: Change labels for MSIM --> CyanogenMod/android_packages_apps_Settings
  • TeleService: Change labels for MSIM --> CyanogenMod/android_packages_services_Telephony
  • Keyguard: Change SUB label to SIM --> CyanogenMod/android_frameworks_base
  • SystemUI: Status bar UI cleanup for MSIM and roaming --> CyanogenMod/android_frameworks_base
  • P2P: Fix segfault when PBC overlap is detected --> CyanogenMod/android_external_wpa_supplicant_8
  • X.509: Fix internal TLS/X.509 validation of PKCS#1 signature --> CyanogenMod/android_external_wpa_supplicant_8
  • P2P: Extend the listen time based on the active concurrent session --> CyanogenMod/android_external_wpa_supplicant_8
  • Add string resource for UICC storage --> CyanogenMod/android_frameworks_base
  • adb/fastboot: Support SuperSpeed USB devices --> CyanogenMod/android_system_core
  • hal: Fixes for 8916 features --> CyanogenMod/android_hardware_qcom_audio-caf
  • symbols: Remove duplicate symbol --> CyanogenMod/android_frameworks_base
  • CameraNext: String improvements/fixes from Camera2 --> CyanogenMod/android_packages_apps_Camera2-resources
  • APN: Giffgaff -> giffgaff --> CyanogenMod/android_vendor_cm
  • Migrate Telenor Norway APN to IPV6 --> CyanogenMod/android_vendor_cm
  • Dialer: Fix possible crash in call details --> CyanogenMod/android_packages_apps_Dialer
  • Support for SEEK on Android --> CyanogenMod/android_hardware_ril
  • Settings: Fix "Use actual storage type of sdcard/usb (1/2)." --> CyanogenMod/android_packages_apps_Settings
  • Add 16:9 to strings --> CyanogenMod/android_packages_apps_Camera2
  • Rename "Wi-Fi AP" QS tile to "Wi-Fi hotspot" --> CyanogenMod/android_frameworks_base
  • Settings: Improve some strings --> CyanogenMod/android_packages_apps_Settings
  • SystemUI: fix crash when removing tile --> CyanogenMod/android_frameworks_base
  • Profiles: fix expanded desktop settings not applying --> CyanogenMod/android_packages_apps_Settings
  • Launch Protected Apps --> CyanogenMod/android_packages_apps_Settings
  • Add record time to details view --> CyanogenMod/android_packages_apps_Gallery2
  • MTU should be 1358 as per 3GPP standards, especially for LTE radio interfaces --> CyanogenMod/android_frameworks_base
  • Camera2: disable the shutter button when not previewing --> CyanogenMod/android_packages_apps_Camera2
  • ffmpeg_source: add url check to android_open --> CyanogenMod/android_external_stagefright-plugins
  • ffmpeg_source: do not adjust offset on read error/eof --> CyanogenMod/android_external_stagefright-plugins
  • Camera2: the menu button should not visible in some cases --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: fix flash light turn on after resume camera activity --> CyanogenMod/android_packages_apps_Camera2
  • added mvno matching for Denmark --> CyanogenMod/android_vendor_cm
  • added mvno matching for Canada --> CyanogenMod/android_vendor_cm
  • added Ringplus APN --> CyanogenMod/android_vendor_cm
  • added T-Mobile MVNO Wholesale apn --> CyanogenMod/android_vendor_cm
  • added Ooredoo Tunisie & Tunisie Télécom apns --> CyanogenMod/android_vendor_cm
  • Fix copyright headers --> CyanogenMod/android_packages_apps_Settings
  • camera2: Fix memory leak when suspend/resume camera --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: Add option to set max screen brightness --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: add new mime type for panorama picture --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: save the picture when rotate the device --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: wait for previous saving picture done during panorama capture --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: some aapt warnings cleanup --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: fix white balance still work when turn on the HDR mode --> CyanogenMod/android_packages_apps_Camera2
  • Fix WB indicator override --> CyanogenMod/android_packages_apps_Camera2
  • Revert "Camera2: Fix WB onScreenIndicator when some are settings filtered out." --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: fix The flashlight still is on after set scene mode not auto --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: update the flash icon when set HDR on --> CyanogenMod/android_packages_apps_Camera2
  • hal: Update msm8916 library with new feature support --> CyanogenMod/android_hardware_qcom_audio-caf
  • Use memmove from krait for cortex-a53 target --> CyanogenMod/android_bionic
  • hal: Don't mess with primary output --> CyanogenMod/android_hardware_qcom_audio-caf
  • Revert "libmedia: Add flag for non-native FAST tracks." --> CyanogenMod/android_frameworks_av
  • Remove potential cause of underrun --> CyanogenMod/android_frameworks_av
  • media: Cleanup some unnecessary old code --> CyanogenMod/android_frameworks_av
  • stagefright: Fix crash if PCM offload gets a null source --> CyanogenMod/android_frameworks_av
  • Support MPEG4 and H263 FourCC types in Matroska files --> CyanogenMod/android_frameworks_av
  • libstagefright: extend the interface to switch rtp transport --> CyanogenMod/android_frameworks_av
  • libstagefright: Handle INFO_FORMAT_CHANGED for dolby clips --> CyanogenMod/android_frameworks_av
  • effects: miscellaneous fixes --> CyanogenMod/android_frameworks_av
  • Camera: Block HFR option for Video HDR --> CyanogenMod/android_packages_apps_Camera2
  • Camera: Disable DIS option for unsupported resolution --> CyanogenMod/android_packages_apps_Camera2
  • Camera: Block DIS and Timelapse for HFR --> CyanogenMod/android_packages_apps_Camera2
  • Camera: Check if codec supports HFR resolution/fps --> CyanogenMod/android_packages_apps_Camera2
  • Camera: Change video capture duration with HFR --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: Fix ANR when switching camera during AF --> CyanogenMod/android_packages_apps_Camera2
  • camera: Override color effect when scene mode is active --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: fix unresponsive shutter button after failure --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: Don't report incorrect supported picture formats --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: fix camera crash when mPieRender is null --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: Fix video duration is wrong issue --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: fix a camera status bug --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: Do not restart preview to update flip params during orientation change --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: fix start preview when hdr is on issue --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: Still popup tips when change scene to other after turn off HDR --> CyanogenMod/android_packages_apps_Camera2
  • Camera: Disable HDR when scene mode is other than auto --> CyanogenMod/android_packages_apps_Camera2
  • Camera: open Camera and start Preview in a seperate thread --> CyanogenMod/android_packages_apps_Camera2
  • Adding optional screenshot upload to CMBugReport --> CyanogenMod/android_packages_apps_CMBugreport
  • Keyguard: Move string to cm_strings --> CyanogenMod/android_frameworks_base
  • extmediaplayer: miscellaneous fix --> CyanogenMod/android_frameworks_base
  • AudioService: Fix monitorRotation for landscape applications --> CyanogenMod/android_frameworks_base
  • Tethering: Enable NAT only when tether and upstream ifaces are different --> CyanogenMod/android_frameworks_base
  • lowmemorykiller: Overwrite LMK parameters for low-tier devices --> CyanogenMod/android_frameworks_base
  • Fix memory leak in nativeDecodeFileDescriptor --> CyanogenMod/android_frameworks_base
  • Settings: ButtonSettings: Introduce recents long press action --> CyanogenMod/android_packages_apps_Settings
  • Settings: Let users disable the left-corner Keyguard widget --> CyanogenMod/android_packages_apps_Settings
  • fastboot: Add missing USB ID --> CyanogenMod/android_system_core
  • Support full size application screenshots --> CyanogenMod/android_frameworks_base
  • Keyguard: Allow applications to customize left-corner widget --> CyanogenMod/android_frameworks_base
  • Recents long press: add pluggable implementation --> CyanogenMod/android_frameworks_base
  • Add Secure.Settings.RECENTS_LONG_PRESS_ACTIVITY --> CyanogenMod/android_frameworks_base
  • Provide non-interactive APIs to BackupManagerService --> CyanogenMod/android_frameworks_base
  • PackageManager: Add optional prelaunch check step --> CyanogenMod/android_frameworks_base
  • Update SET_ACTIVITY_WATCHER protection to signature|system --> CyanogenMod/android_frameworks_base
  • Settings: Allow Regulator Information Dialog Title to be overlaid --> CyanogenMod/android_packages_apps_Settings
  • TeleService: use MSimPhoneFactory for MSIM devices --> CyanogenMod/android_packages_services_Telephony
  • Camera: Add proper support for ListPreference --> CyanogenMod/android_packages_apps_Camera2
  • Add TF701T contributor --> CyanogenMod/android_vendor_cm
  • wl12xx: Don't build wl1251 if the kernel doesn't require it --> CyanogenMod/android_hardware_ti_wlan
  • wl12xx: Stop messing with modprobe --> CyanogenMod/android_hardware_ti_wlan
  • ContactsCommon: Add direct call from contact list feature. (2/2) --> CyanogenMod/android_packages_apps_Contacts
  • ContactsCommon: Add direct call from contact list feature. (1/2) --> CyanogenMod/android_packages_apps_ContactsCommon
  • SystemUI : RemoteDisplayTile use executor --> CyanogenMod/android_frameworks_base
  • Fix wrong scaling of QS tiles --> CyanogenMod/android_frameworks_base
  • Revert "Avoid collision with RIL constant 1138, used in some Samsung devices for RIL_UNSOL_TETHERED_MODE_STATE_CHANGED." --> CyanogenMod/android_frameworks_base
  • hal: Allow msm8916 to enable compress voip/compress capture/dolby --> CyanogenMod/android_hardware_qcom_audio-caf
  • fix: Settings FC when WiFi tethering is active --> CyanogenMod/android_packages_apps_Settings
Reaktionen: m3stolo und Spaulding89
I9100 20141103 is UP!
Changelog:
  • Updated Kernel Toolchain to Linaro 4.9.2 2014.10
  • keyguard: fix chopped layout on hdpi msim devices --> CyanogenMod/android_frameworks_base
  • sr: Header and font images for 1440 width --> CyanogenMod/android_bootable_recovery-cm
  • av: Various fixes and cleanups --> CyanogenMod/android_frameworks_av
  • stagefright-plugins: Return real bitwidth in getParameter call --> CyanogenMod/android_external_stagefright-plugins
  • stagefright: Query PCM output format and fix bugs --> CyanogenMod/android_frameworks_av
  • Solved problem with hanging decode call --> CyanogenMod/android_frameworks_av
  • stagefright: add an extra buffer to ANW's BUfferQueue --> CyanogenMod/android_frameworks_av
  • NuPlayer: use video hardware codec only --> CyanogenMod/android_frameworks_av
  • stagefright: Don't expose QTIFLAC definition unless enabled --> CyanogenMod/android_frameworks_av
  • libstagefright: Wrapper for FLAC CSIM decoder --> CyanogenMod/android_frameworks_av
  • sensorservice: add fusion sensors if all events are supported --> CyanogenMod/android_frameworks_native
  • Catch ActivityNotFoundException when launching GlobalSearchActivity --> CyanogenMod/android_packages_apps_Trebuchet
  • core: Improve strings --> CyanogenMod/android_frameworks_base
  • camera: Allow hardware/camera.h header to be overridden --> CyanogenMod/android_frameworks_av
  • SystemUI: Fix crash during notification/theme change --> CyanogenMod/android_frameworks_base
  • audio: handle events properly in AudioOutput::CallbackWrapper() --> CyanogenMod/android_frameworks_av
  • Settings: Minor string update for msim --> CyanogenMod/android_packages_apps_Settings
  • Settings (MSIM): Refactor tab labels to use global sim name --> CyanogenMod/android_packages_apps_Settings
  • ContactsCommon: Use global settings for msim name --> CyanogenMod/android_packages_apps_ContactsCommon
  • Dialer: Use global settings name for MSIM --> CyanogenMod/android_packages_apps_Dialer
  • InCallUI: Use global settings name for MSIM --> CyanogenMod/android_packages_apps_InCallUI
  • TeleService: Refactor sim name / sim label logic --> CyanogenMod/android_packages_services_Telephony
  • Global Settings (MSIM): Add global settings for naming sim cards --> CyanogenMod/android_frameworks_base
  • surfacemediasource: Do not assume that onBuffersReleased means EOS --> CyanogenMod/android_frameworks_av
  • native: Make setting the buffers size conditional to qualcomm hardware --> CyanogenMod/android_frameworks_native
  • WIFI: Fix wimax teardown when wifi connected --> CyanogenMod/android_frameworks_base
  • Launch theme chooser that supports cyngn.intent.category.APP_THEMES --> CyanogenMod/android_packages_apps_Settings
  • Launch theme chooser that supports cyngn.intent.category.APP_THEMES --> CyanogenMod/android_packages_apps_Trebuchet
  • Telephony: bugfix - let us edit 'My phone number' again --> CyanogenMod/android_packages_services_Telephony
  • Telephony: Close the FileReader when finished --> CyanogenMod/android_frameworks_opt_telephony
  • MSIM(DSDA): Update setMode properly --> CyanogenMod/android_frameworks_opt_telephony
  • Fix MMS sending issue in LTE on CDMA networks --> CyanogenMod/android_frameworks_opt_telephony-msim
  • TeleService: For Msim DSDS, set mode to 2g(all sims) prior to change --> CyanogenMod/android_packages_services_Telephony
  • perf: Send boost hint during initial launch --> CyanogenMod/android_frameworks_base
  • sr: Dejank the menus, fix colors --> CyanogenMod/android_bootable_recovery-cm
  • sr: Improve overlay again --> CyanogenMod/android_bootable_recovery-cm
  • sr: Remove extra image set --> CyanogenMod/android_bootable_recovery-cm
  • Dialer: fix last call card not initiating dial on click for multi sim --> CyanogenMod/android_packages_apps_Dialer
  • hal: Fix mismerge --> CyanogenMod/android_hardware_qcom_audio-caf
  • Adding API for NXP specific NCI command --> CyanogenMod/android_external_libnfc-nci
  • Adding MiFARE DESFire format support --> CyanogenMod/android_packages_apps_Nfc
  • Revert "camera: add support for samsung and htc camcorder modes" --> CyanogenMod/android_packages_apps_Camera2
  • Telephony: Fix NPE while opening allowed number --> CyanogenMod/android_packages_services_Telephony
  • DownloadProvider: fix secondary storage support --> CyanogenMod/android_packages_providers_DownloadProvider
  • sepolicy: Fix a few denials when debugging --> CyanogenMod/android_external_sepolicy
  • Camera2: Remove CAF video duration code --> CyanogenMod/android_packages_apps_Camera2
  • Camera: Don't enable shutterdown for count down timer --> CyanogenMod/android_packages_apps_Camera2
  • Camera: Decrease downsample factor for smaller resolution --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: enable WNR in video mode --> CyanogenMod/android_packages_apps_Camera2
  • Camera: cancel auto focus after snapshot done if in CAF mode --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: enable antibanding when dis is enable --> CyanogenMod/android_packages_apps_Camera2
  • sr: Kill logspam --> CyanogenMod/android_bootable_recovery-cm
  • sr: Update header image --> CyanogenMod/android_bootable_recovery-cm
  • stagefright: Avoid querying time from AudioPlayer after audio EOS --> CyanogenMod/android_frameworks_av
  • Dialer: do not assume which subscription to use in call detail header --> CyanogenMod/android_packages_apps_Dialer
  • After initially loading all API extension apps, request all to refresh --> CyanogenMod/external_cyanogen_cmhomeapi
  • Camera2: fix sawtooth in camera preview --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: Make menu not pop up in take picture interface --> CyanogenMod/android_packages_apps_Camera2
  • Update phoneSubInfo properly --> CyanogenMod/android_frameworks_opt_telephony-msim
  • Contacts: fix clicking on contact list item action with multi sim --> CyanogenMod/android_packages_apps_Contacts
  • Correct order of parameter in iccExchangeApdu() --> CyanogenMod/android_frameworks_opt_telephony
  • hal: Support the audio amplifier hook --> CyanogenMod/android_hardware_qcom_audio-caf
  • install: Properly mask the updater status before checking --> CyanogenMod/android_bootable_recovery-cm
  • Use actual storage type for format message strings --> CyanogenMod/android_frameworks_base
  • Improve screen timeout QS tile --> CyanogenMod/android_frameworks_base
  • linearlayout: fix measurement of childrens when parent and childrens have exactly the same pixels --> CyanogenMod/android_frameworks_base
  • build: Fix some colored build issues --> CyanogenMod/android_build
  • core: Correct the sensors UID --> CyanogenMod/android_system_core
  • galaxys2-common: Update RIL header to v9 [2/2] --> CyanogenMod/android_device_samsung_galaxys2-common
  • Contacts: Don't show phone-local profile as null --> CyanogenMod/android_packages_apps_Contacts
  • Telephony: Disable MSISDNEditPreference until init complete --> CyanogenMod/android_packages_services_Telephony
  • XMM626x: Update RIL to V9 [1/2] --> CyanogenMod/android_hardware_samsung
  • Camera2: correct image size recorded in media provider db --> CyanogenMod/android_packages_apps_Camera2
  • Trebuchet: RTL support for Settings Screens --> CyanogenMod/android_packages_apps_Trebuchet
  • frameworks: fix setting default ringtone for multi sim --> CyanogenMod/android_frameworks_base
  • camera: Always enable preview metadata --> CyanogenMod/android_frameworks_av
  • Revert "hal: Don't mess with primary output" --> CyanogenMod/android_hardware_qcom_audio-caf
  • SystemUI: Fix RemoteDisplayTile crash on clean boot --> CyanogenMod/android_frameworks_base
  • Access ProtectedAppsActivity from SystemUI Recents page if any components are protected --> CyanogenMod/android_frameworks_base
  • Add client-side support for TLS_FALLBACK_SCSV --> CyanogenMod/android_external_chromium_org
  • Add client-side support for TLS_FALLBACK_SCSV --> CyanogenMod/android_external_chromium_org_third_party_openssl
  • SCSV support --> CyanogenMod/android_external_okhttp
  • Add support for TLS_FALLBACK_SCSV --> CyanogenMod/android_external_openssl
  • Add support for TLS_FALLBACK_SCSV --> CyanogenMod/android_libcore
  • Fixing Contacts crash when trying to merge two contacts --> CyanogenMod/android_packages_apps_ContactsCommon
  • Enable support for groups in External contacts accounts --> CyanogenMod/android_packages_apps_ContactsCommon
  • Force colorsheme to SVG, since darkblue doesn't exist on X11 --> CyanogenMod/android_build
  • Don't try to restore Set on Boot settings before decrypting --> CyanogenMod/android_packages_apps_Settings
  • system: core: Add Sensors group --> CyanogenMod/android_system_core
  • ContactsCommon: Fix CONTACT_SNIPPET declaration --> CyanogenMod/android_packages_apps_ContactsCommon
  • Destroy client handles after they're closed --> CyanogenMod/android_hardware_qcom_gps
  • libstagefright: use appropriate hevc decoder on 8916 and 8939 --> CyanogenMod/android_frameworks_av
  • libstagefright: HSR: Read framerate from HSR key --> CyanogenMod/android_frameworks_av
  • Revert "stagefright: Disable HSR for now" --> CyanogenMod/android_frameworks_av
  • Fix Quiet hours for MSim --> CyanogenMod/android_packages_services_Telephony
I9100 20141108 is UP! :cool:
Changelog:
* Fix crash after upgrade due to ambiguous column --> CyanogenMod/android_packages_providers_ContactsProvider
* TeleService: Move IP prefix call setting config to system property --> CyanogenMod/android_packages_services_Telephony
* Dialer: Move IP prefix call setting config to system property --> CyanogenMod/android_packages_apps_Dialer
* Settings: Don't show IP prefix call options if not enabled --> CyanogenMod/android_packages_apps_Contacts
* Mms: Make Mms-caf the new Mms --> CyanogenMod/android_packages_apps_Mms-caf
* LibPhoneNumber : Remove TextUtils reference --> CyanogenMod/android_external_libphonenumber
* photophase: bump version (1.0.11) --> CyanogenMod/android_packages_wallpapers_PhotoPhase
* SoundRecorder: Bring out of gingerbread days --> CyanogenMod/android_packages_apps_SoundRecorder
* photophase: restart lwp service on bad egl context --> CyanogenMod/android_packages_wallpapers_PhotoPhase
* Settings : Don't disable persisting for MultiSelectListPreference --> CyanogenMod/android_packages_apps_Settings
* Blacklist : Strip extension from number --> CyanogenMod/android_packages_apps_Dialer
* LibPhoneNumber : Add stripExtension method --> CyanogenMod/android_external_libphonenumber
* Dialer : Add ability to delete from blacklist --> CyanogenMod/android_packages_apps_Dialer
* Mms: Dispaly wrong text message limit for per conversation --> CyanogenMod/android_packages_apps_Mms
* CMFileManager : Fix details menu for multiple selections --> CyanogenMod/android_packages_apps_CMFileManager
* Call recording encoder/format choice 2/3 --> CyanogenMod/android_packages_services_Telephony
* Call recording encoder/format choice 1/3 --> CyanogenMod/android_packages_apps_Dialer
* Call recording encoder/format choice 3/3 --> CyanogenMod/android_frameworks_base
* PackageManager: Add configuration APIs for pre-launch checks --> CyanogenMod/android_frameworks_base
* Add system|signature permission for intercepting package launch --> CyanogenMod/android_frameworks_base
* Add description to Nextbit Pass widget setting --> CyanogenMod/android_packages_apps_Settings
* Enable application widget (pass widget) for the mod lock too --> CyanogenMod/android_packages_apps_Settings
* Update marketing name for Appcast to Pass --> CyanogenMod/android_packages_apps_Settings
* Add hdpi-2048 tunings --> CyanogenMod/android_frameworks_native
* Settings: move getFormattedSimName() to frameworks (1/2) --> CyanogenMod/android_packages_apps_Settings
* CellBroadcastReceiver: use formatted SIM name --> CyanogenMod/android_packages_apps_CellBroadcastReceiver
* MultiSim: move getFormattedSimName() to frameworks (2/2) --> CyanogenMod/android_frameworks_base
* product_config: Set CM_BUILD priority above TARGET_BUILD_APPS --> CyanogenMod/android_build
* Dialer: Filter IP call from call log context menu if config is false --> CyanogenMod/android_packages_apps_Dialer
* Dialer: Add config for IP call settings on dialpad --> CyanogenMod/android_packages_apps_Dialer
* otg: when removing ED from readyQ also set flag --> CyanogenMod/android_kernel_samsung_smdk4412
* TeleService: Don't use a progress dialog when setting subscription --> CyanogenMod/android_packages_services_Telephony
* Settings: Don't use a progress dialog when setting msim data subscription --> CyanogenMod/android_packages_apps_Settings
* audio-caf: hal: bugfixes to PLATFORM_MSM8960 --> CyanogenMod/android_hardware_qcom_audio-caf
* Settings: Fix sim name derp --> CyanogenMod/android_packages_apps_Settings
* Settings: update Data Usage summary multi sim title --> CyanogenMod/android_packages_apps_Settings
* stagefright-plugins: Add a couple of sample format exceptions --> CyanogenMod/android_external_stagefright-plugins
* build: recovery: Support adding device-specific items --> CyanogenMod/android_build
* radio: Treat REGULAR_DEACTIVATION events as transient errors on AT&T --> CyanogenMod/android_frameworks_base
* Contacts: Don't reset cursor adapter in onPause --> CyanogenMod/android_packages_apps_Contacts
* Contacts: Prevent NPE on multi select in local group select --> CyanogenMod/android_packages_apps_Contacts
* hal: Fix compliation when debug logs are enabled --> CyanogenMod/android_hardware_qcom_audio-caf
* Revert "Bypass the lockscreen when the hardware keyboard is slid out and security mode is 'none'" --> CyanogenMod/android_frameworks_base
* TeleService: (MSIM) Avoid crashes when clicking actionbar home --> CyanogenMod/android_packages_services_Telephony
* Contacts: Use correct SIM contacts uri without MultiSIM --> CyanogenMod/android_packages_apps_Contacts
* Update APNs for Japan --> CyanogenMod/android_vendor_cm
* init: add a new charger-fs trigger in the power off charging mode --> CyanogenMod/android_system_core
* sr: Header and font images for 540 width --> CyanogenMod/android_bootable_recovery-cm
[quote name="Karpfenhai" post=56591441]Lollipop has already arrived certain devices ( galaxy s3 mini per example) so generally it works but has major bugs like calls not working.. I'm pretty sure we will see it soon on the i9100.
Regards[/quote]
[quote name="ahmedelhofy" post=56592122]Gs3 mini isn't an exynos device.....and they have an active developer there.. That's why it came pretty quick[/quote]
Seeing AOSP Lollipop is booting on I9300 (which is an Exynos device) actually made me a little more confident :)
But this isn't a promise! ;)
Reaktionen: Pr0TuRk38
I9100 20141115 is UP! :cool:
Changelog:
* Factory reset: Allow passing wipe_media to recovery --> CyanogenMod/android_frameworks_base
* Factory reset: Always show the "delete media" checkbox --> CyanogenMod/android_packages_apps_Settings
* DeskClock: add missing landscape view --> CyanogenMod/android_packages_apps_DeskClock
* Camera2: Allow devices to opt-out of threaded camera startup --> CyanogenMod/android_packages_apps_Camera2
* SystemUI : Improve heads up display logic --> CyanogenMod/android_frameworks_base
* Protect windowNoTitle and windowActionBar attributes --> CyanogenMod/android_frameworks_base
* Revert "Themes: Build icon cache when applying icons" --> CyanogenMod/android_frameworks_base
* wcnss_qmi: Allow targets to provide custom libwcnss_qmi --> CyanogenMod/android_hardware_qcom_wlan
* SystemUI: hide msim no-sim icons --> CyanogenMod/android_frameworks_base
* SystemUI: fix msim signal cluster text label spacing --> CyanogenMod/android_frameworks_base
* ContactsCommon: fix import vcard memory leak --> CyanogenMod/android_packages_apps_ContactsCommon
* ContactsProvider: Create add default contact as an overlay-able option --> CyanogenMod/android_packages_providers_ContactsProvider
* UsbSettings: Add UMS mode support --> CyanogenMod/android_frameworks_base
* ContactsCommon: always create local phone AccountType --> CyanogenMod/android_packages_apps_ContactsCommon
* Remove the static changelog from production user builds --> CyanogenMod/android_packages_apps_Settings
* mms: Fix FC when viewing slideshow --> CyanogenMod/android_packages_apps_Mms-caf
* Protected Apps: Delay Protected Apps changed reload till onResume --> CyanogenMod/android_packages_apps_Trebuchet
* Protected Apps: Allow all system apps to see Protected Components --> CyanogenMod/android_frameworks_base
* Protected Apps: Show state by component instead of by app --> CyanogenMod/android_packages_apps_Settings
* Ignore certain overlaid sms-sending packages --> CyanogenMod/android_frameworks_base
* Ignore certain sms-sending packages --> CyanogenMod/android_frameworks_opt_telephony
* UsbSettings: Fix UMS mode --> CyanogenMod/android_packages_apps_Settings
* Revert 'base: Add P2P interface "p2p0" to tethering support list' --> CyanogenMod/android_frameworks_base
* ThemeManager: Synchronize access to listeners --> CyanogenMod/android_frameworks_base
* sensorservice: Register orientation sensor if HAL doesn't provide it --> CyanogenMod/android_frameworks_native
* Add option to change timer alert sound --> CyanogenMod/android_packages_apps_DeskClock
* cm: Add 1440 bootanimation --> CyanogenMod/android_vendor_cm
* Update location tile(2/2) --> CyanogenMod/android_packages_apps_Settings
* Update location tile(1/2) --> CyanogenMod/android_frameworks_base
* Tether : Update settings app reference --> CyanogenMod/android_frameworks_base
* camera: allow device to append camera parameters --> CyanogenMod/android_frameworks_av
* Contacts: Make app name string overlayable --> CyanogenMod/android_packages_apps_Contacts
* SoundRecorder: fix when internal recording error shows --> CyanogenMod/android_packages_apps_SoundRecorder
* ContactsCommon: use formatted sim name when displaying msim cards --> CyanogenMod/android_packages_apps_ContactsCommon
* ContactsCommon: fix exporting SIM contacts the first time --> CyanogenMod/android_packages_apps_ContactsCommon
* ContactsCommon: fix "share visible contacts" showing up blank --> CyanogenMod/android_packages_apps_ContactsCommon
* Settings : Add overlay for hiding performance options --> CyanogenMod/android_packages_apps_Settings
* TeleService: Fix for NPE removing preference --> CyanogenMod/android_packages_services_Telephony
* Sanity-check paths of files to be restored --> CyanogenMod/android_frameworks_base
* Add additional field checks for deserialization --> CyanogenMod/android_libcore
* Check component class instead of action --> CyanogenMod/android_packages_apps_CertInstaller
* CameraService: Fix permissions check issues --> CyanogenMod/android_frameworks_av
* Externally Reported Low Severity Security Vulnerability: SMS Resend Vulnerability in Android --> CyanogenMod/android_packages_apps_Mms
* Fix crash while installing themes rapidly --> CyanogenMod/android_frameworks_base
* Check for null on originating address in an SMSMessage --> CyanogenMod/android_frameworks_opt_telephony
* UnifiedEmail: wrap message details in scroll view --> CyanogenMod/android_packages_apps_UnifiedEmail
* Contacts: hide Memory Status screen for now --> CyanogenMod/android_packages_apps_Contacts
* Update Asian APNs --> CyanogenMod/android_vendor_cm
* SettingsProvider: fix load protected sms setting logic --> CyanogenMod/android_frameworks_base
* Make people lookup default overlay --> CyanogenMod/android_frameworks_base
* Email : Ability to set default signature --> CyanogenMod/android_packages_apps_Email
* Telephony service: include libphonenumbergoogle --> CyanogenMod/android_packages_services_Telephony
* Telephony: remove libphonenumbergoogle dependency --> CyanogenMod/android_frameworks_opt_telephony
* Add special case for creating Drag Bitmap when dragging All Apps button --> CyanogenMod/android_packages_apps_Trebuchet
* Telephony: Hide getNormalizedAddressesFromPdus --> CyanogenMod/android_frameworks_opt_telephony
* Mms: Allow overlaying default sms templates --> CyanogenMod/android_packages_apps_Mms-caf
* Start autofocus only when we have a previewframe --> CyanogenMod/android_frameworks_base
* SystemUI: Utilize TextureView for CameraTile --> CyanogenMod/android_frameworks_base
* WhisperPush: Utilize RECEIVE_PROTECTED_SMS for authing --> CyanogenMod/android_external_whispersystems_WhisperPush
* Telephony: Implement protected sms broadcast API --> CyanogenMod/android_packages_services_Telephony
* Telephony: Add PROTECTED_SMS_RECEIVED_ACTION --> CyanogenMod/android_frameworks_opt_telephony
* Add API for protected SMS receive broadcasts --> CyanogenMod/android_frameworks_base
* Settings: profiles: fix volume streams override behavior --> CyanogenMod/android_packages_apps_Settings
* Settings: add "Untouched" ring mode option in profiles --> CyanogenMod/android_packages_apps_Settings
* Settings: fix Profiles expanded desktop choice mapping --> CyanogenMod/android_packages_apps_Settings
* SoundRecorder: add option menu to view recordings --> CyanogenMod/android_packages_apps_SoundRecorder
* SoundRecorder: make recording error message more descriptive --> CyanogenMod/android_packages_apps_SoundRecorder
* cmfm: secure storage and other improvements --> CyanogenMod/android_packages_apps_CMFileManager
* Contacts : Ability to have custom view contacts default selected --> CyanogenMod/android_packages_apps_ContactsCommon
* android: add libtruezip repo --> CyanogenMod/android
* android: add zip and unrar external repos --> CyanogenMod/android
* vendor: Add zip and unrar applets --> CyanogenMod/android_vendor_cm
* Revert "Update package names to make Mms-caf buildable" --> CyanogenMod/android_packages_apps_Mms-caf
* uevent: Allow multiple uevent listeners from the same process --> CyanogenMod/android_hardware_libhardware_legacy
* Expand android.permission.WRITE_THEMES to system|signature --> CyanogenMod/android_frameworks_base
* Fix possible crash during delivery delay --> CyanogenMod/android_packages_apps_Mms
* photophase: make lwp to survive a reboot --> CyanogenMod/android_packages_wallpapers_PhotoPhase
Reaktionen: j1gga84
I9100 20141122 is UP!
Changelog:
  • CMAccount: Fix camels --> CyanogenMod/android_packages_apps_CMAccount
  • Fix: Restore workspace gradients when returning from Widget drop --> CyanogenMod/android_packages_apps_Trebuchet
  • Crop wallpaper and lockscreen images before saving them --> CyanogenMod/android_frameworks_base
  • More Asian APN updates --> CyanogenMod/android_vendor_cm
  • Vectone UK (MNC01) considered non-roaming on T-Mobile (MNC30) --> CyanogenMod/android_frameworks_base
  • ums: support UMS on any volume --> CyanogenMod/android_frameworks_base
  • media: Match quality definitions with what the framework expects --> CyanogenMod/android_frameworks_av
  • MediaScanner : Add support for default ringtones per sim --> CyanogenMod/android_frameworks_base
  • Split out Airtel, adjust other Asian APNs --> CyanogenMod/android_vendor_cm
  • WhisperPush : Fix crash when going in background --> CyanogenMod/android_external_whispersystems_WhisperPush
  • Pass all theme apks to themeservice for processing --> CyanogenMod/android_frameworks_base
  • Revert "Center wallpaper when only one screen" --> CyanogenMod/android_packages_apps_Trebuchet
  • Revert "Exclude empty and custom screens when centering wallpaper" --> CyanogenMod/android_packages_apps_Trebuchet
  • Add makefile to allow quick building of bootimage --> CyanogenMod/android_vendor_cm
  • copy vendor/cm/bootimage/Android.mk to kernel/ --> CyanogenMod/android
  • Adjustment to patch for secure processing for CVE-2014-0107 by Ryan Berg based on feedack from Emmanuel Bourg --> CyanogenMod/android_external_apache-xml
  • Commit patch to handle secure processing. Thank you Ryan Berg --> CyanogenMod/android_external_apache-xml
  • Settings: Only show mobile data switch on preferred data sub --> CyanogenMod/android_packages_apps_Settings
  • ContactsCommon: Don't insert contact locally after exporting to sim --> CyanogenMod/android_packages_apps_ContactsCommon
  • bugfix: deal with non-contact file being opened as contact file --> CyanogenMod/android_packages_services_Telephony
  • Settings:Appops:remove OP_WIFI(BLUETOOTH/DATA)_CHANGE from MEDIA_TEMPLATE --> CyanogenMod/android_packages_apps_Settings
  • SetupWizard: Give option to turn on mobile data if off by default --> CyanogenMod/android_packages_apps_CMAccount
  • sr: Only use 4 items on wipe confirmation screens --> CyanogenMod/android_bootable_recovery-cm
  • sr: Fix screen flashing during wipe operations --> CyanogenMod/android_bootable_recovery-cm
  • sr: Fix vsync logic --> CyanogenMod/android_bootable_recovery-cm
  • cmfm: Readd drawer toggle item selection --> CyanogenMod/android_packages_apps_CMFileManager
  • Dialer: Force media scanner to scan file when recording finishes --> CyanogenMod/android_packages_apps_Dialer
  • lights: fix notification and attention lights --> CyanogenMod/android_frameworks_base
  • Revert "UsbSettings: Add UMS mode support" --> CyanogenMod/android_frameworks_base
  • InCallUI: Validate function return value to avoid NPE --> CyanogenMod/android_packages_apps_InCallUI
  • Search Provider: Remove Action.ASSIST preference Always return to Trebuchet on return gesture --> CyanogenMod/android_packages_apps_Trebuchet
  • TeleService: Allow msim users to clear voicemail notification --> CyanogenMod/android_packages_services_Telephony
  • core: Add HP ID to fastboot --> CyanogenMod/android_system_core
  • SECURITY: Don't pass a usable Pending Intent to 3rd parties --> CyanogenMod/android_packages_apps_Settings
  • Do not persist and restore the media button event receiver --> CyanogenMod/android_frameworks_base
  • Fix issue duplicate ArrayMap entries in Bundle.. --> CyanogenMod/android_frameworks_base
  • Change permission guard on bindBackupAgent() --> CyanogenMod/android_frameworks_base
  • Prevent malformed ICO files from recursively decoding --> CyanogenMod/android_external_skia
  • Fix overflow when comparing two ints by promoting the sum to 64-bits --> CyanogenMod/android_external_skia
  • Handle bad ICO data better --> CyanogenMod/android_external_skia
  • Add additional checks in ObjectInputStream --> CyanogenMod/android_libcore
  • Installer: Use nanoTime instead of currentTimeMillis --> CyanogenMod/android_frameworks_base
  • TelephonyService: Move REMOVE_BLACKLIST to static receiver --> CyanogenMod/android_packages_services_Telephony
  • SettingsProvider : Add ability to override default volumes --> CyanogenMod/android_frameworks_base
  • Fix crash of Samsung phones --> CyanogenMod/android_frameworks_opt_telephony
  • Fix error with invalid default uris --> CyanogenMod/android_packages_apps_DeskClock
  • Remove the "Pass widget" config from Settings --> CyanogenMod/android_packages_apps_Settings
  • Remove Application Widget from LockPatternUtils --> CyanogenMod/android_frameworks_base
  • Telephony service: add ability to always request focus for calls --> CyanogenMod/android_frameworks_opt_telephony
  • frameworks: add alwaysRequestAudioFocusForCalls overlay --> CyanogenMod/android_frameworks_base
  • SystemUI: protect Protected App notifications --> CyanogenMod/android_frameworks_base
  • Setting: broadcast protected app result if requested --> CyanogenMod/android_packages_apps_Settings
  • QS: Get your theme on from quick settings [2/2] --> CyanogenMod/android_packages_apps_Settings
  • QS: Get your theme on from quick settings [1/2] --> CyanogenMod/android_frameworks_base
  • update call recording file format --> CyanogenMod/android_packages_apps_Dialer
  • cmfm: Fix clear history button visibility logic --> CyanogenMod/android_packages_apps_CMFileManager
  • Add xxxhdpi icon --> CyanogenMod/android_packages_themes_Template
  • Mms: Partially revert 8fc72f871 --> CyanogenMod/android_packages_apps_Mms-caf
  • cmfm: Fix FC with hardware menu --> CyanogenMod/android_packages_apps_CMFileManager
  • Exclude empty and custom screens when centering wallpaper --> CyanogenMod/android_packages_apps_Trebuchet
  • CMFM: Improve strings --> CyanogenMod/android_packages_apps_CMFileManager
  • Add .gitignore to empty directories --> CyanogenMod/android_packages_themes_Template
  • Themes: Handle processing themes in separate thread --> CyanogenMod/android_frameworks_base
  • Move theme assets to example/ --> CyanogenMod/android_packages_themes_Template
  • Fix task behavior for ThemeChooser [3/3] --> CyanogenMod/android_packages_apps_Settings
  • Fix task behavior for ThemeChooser [2/3] --> CyanogenMod/android_packages_apps_Trebuchet
  • Mms: Remove unused strings --> CyanogenMod/android_packages_apps_Mms-caf
  • Mms: Move CAF strings --> CyanogenMod/android_packages_apps_Mms-caf
  • Settings: Improve location modes summary --> CyanogenMod/android_packages_apps_Settings
  • Protected Apps: Remove protected folder if there are no entries --> CyanogenMod/android_packages_apps_Trebuchet
  • Center wallpaper when only one screen --> CyanogenMod/android_packages_apps_Trebuchet
  • This fix sim activations after wipe data (msim devices) --> CyanogenMod/android_packages_services_Telephony
  • Fix build, RecoverySystem --> CyanogenMod/android_frameworks_base
Reaktionen: schgeedaa und Spaulding89
Sorry, falsches Forum!
I9100 20141129 is UP! :cool:
Changelog:
Updated Kernel Toolchain to Linaro 4.9.2 2014.11
* Update Japanese APNs --> CyanogenMod/android_vendor_cm
* BackupMangerService: Pass result code in non-interactive calls --> CyanogenMod/android_frameworks_base
* BackupManagerService: Unbreak "adb restore" --> CyanogenMod/android_frameworks_base
* Telephony: Fall back on deprecated createFromPdu --> CyanogenMod/android_frameworks_opt_telephony
* LockscreenInterface from ToggleLockscreenTile (Part 2 of 2) --> CyanogenMod/android_frameworks_base
* LockscreenInterface from ToggleLockscreenTile (Part 1 of 2) --> CyanogenMod/android_packages_apps_Settings
* Update Reliance APNs --> CyanogenMod/android_vendor_cm
* Fix the Example App to include pieces to actually build --> CyanogenMod/android_packages_experimental
* Make "stay awake" also work for wireless charging --> CyanogenMod/android_packages_apps_Settings
* Disabling "Charging sounds" should prevent wireless sound as well --> CyanogenMod/android_frameworks_base
* Delay reloading Dynamic grid after size change till onResume or settings panel collapses --> CyanogenMod/android_packages_apps_Trebuchet
* libstagefright: Make timed text for audio only files work on start --> CyanogenMod/android_frameworks_av
* macloader: Add SEMCO3RD and WISOL for BCM4354 --> CyanogenMod/android_hardware_samsung
* init: Increase the buffer for /proc/cpuinfo for ocata cores --> CyanogenMod/android_system_core
* wifi: Add semco3rd and wisol for BCM4354 --> CyanogenMod/android_hardware_libhardware_legacy
* wifi: Add log message if we fail to read the wifi type --> CyanogenMod/android_hardware_libhardware_legacy
* Fixes cases when a contact was deleted via the contacts app --> CyanogenMod/android_packages_providers_ContactsProvider
* Improved README.md --> CyanogenMod/android_packages_themes_Template
* CMFM: Improve delayed sync string --> CyanogenMod/android_packages_apps_CMFileManager
Reaktionen: Nick Knight
Eigentlich schade das auch in dieser Rom nur noch allgemeine CM fixes einfließen und nichts speziell mehr für unser S2. Es gäbe noch soviel um KK in punkto Funktionalität auf das Level von JB zu heben. Nur als Beispiel das Streamen der eigenen Videos via WLAN auf den TV oder das nutzen eines externen Gamepads.
I9100 20141206 is UP! :cool:
Changelog:
* SystemUI: Fix signal cluster hiding data icon on data disabled --> CyanogenMod/android_frameworks_base
* Fix the Reliance MMS APN (mcc 405, mnc 01) --> CyanogenMod/android_vendor_cm
* Move CM updater & remove summary --> CyanogenMod/android_packages_apps_Settings
* Restore list preferences from system preference instead of currently used values --> CyanogenMod/android_packages_apps_Settings
* Persist Wifi frequency band --> CyanogenMod/android_packages_apps_Settings
* Use Mms-caf for Mms --> CyanogenMod/android
* Mms: Improve caf strings --> CyanogenMod/android_packages_apps_Mms-caf
* Mms: Remove unused resources --> CyanogenMod/android_packages_apps_Mms-caf
* SystemUI: Allow showing data type with roaming indicator on MSIM --> CyanogenMod/android_frameworks_base
* Fix phone number returned by 'Das Telefonbuch' for business numbers --> CyanogenMod/android_packages_apps_Dialer
* LatinIME: Add "more" keys to ALL the keys in Greek layouts --> CyanogenMod/android_packages_inputmethods_LatinIME
* Few offsets still remained in the English India list causing incorrect timezone behavior. This change fixes that --> CyanogenMod/android_packages_apps_DeskClock
* Revert "adbd: switch to su domain when running as root" --> CyanogenMod/android_bootable_recovery-cm
* cwm: Allow device-specific recovery modules --> CyanogenMod/android_bootable_recovery
* apn updates for globul->telenor(bg), globalcom(ng) --> CyanogenMod/android_vendor_cm
* World Clock cities names and times incorrect --> CyanogenMod/android_packages_apps_DeskClock
* Update Last.fm API Key --> CyanogenMod/android_packages_apps_Apollo
* Mms: Only retain selected items when choosing recipients --> CyanogenMod/android_packages_apps_Mms-caf
* SettingsProvider: Animator settings are now in global --> CyanogenMod/android_frameworks_base
* Settings: added wifi country code for India --> CyanogenMod/android_packages_apps_Settings
* Themes: Remove an app's icons from cache when installing --> CyanogenMod/android_frameworks_base
* Telephony: Find creator package if sms is sent from systemuid --> CyanogenMod/android_frameworks_opt_telephony
* Mms: Add to no subject filter for mms messages --> CyanogenMod/android_packages_apps_Mms-caf
* Add images to README --> CyanogenMod/android_packages_themes_Template
* Mms: Fix NPE while attaching vcard --> CyanogenMod/android_packages_apps_Mms-caf
* CMFileManager: Fix force close when sharing more than one file at a time --> CyanogenMod/android_packages_apps_CMFileManager
* India Hutch is no longer a valid APN --> CyanogenMod/android_vendor_cm
* ContactsCommon: remove ticker text on importing contacts --> CyanogenMod/android_packages_apps_ContactsCommon
* otasigcheck: skip otasigcheck in headless mode --> CyanogenMod/android_vendor_cm
Reaktionen: schgeedaa und m3stolo
Neuste Weekly von 13.12.2014
https://www.androidfilehost.com/?w=files&flid=22224
Changelog von Weekly 13.12.2014:
  • Mms: Improve some strings --> CyanogenMod/android_packages_apps_Mms-caf
  • Mms: Remove SMS signature summary --> CyanogenMod/android_packages_apps_Mms-caf
  • Reuse @style/MmsHoloTheme in sub-activities --> CyanogenMod/android_packages_apps_Mms-caf
  • Add Bulsatcom APN --> CyanogenMod/android_vendor_cm
  • More support for inverted CM11 themes --> CyanogenMod/android_packages_apps_Mms-caf
  • Update Reliance RTel APN's --> CyanogenMod/android_vendor_cm
  • Added telenor 'smart' ipv4v6 apn --> CyanogenMod/android_vendor_cm
  • Telephony: Always allow ignored sms packages for premium sms --> CyanogenMod/android_frameworks_opt_telephony
  • Settings: fix profile triggers not showing up for RTL languages --> CyanogenMod/android_packages_apps_Settings
  • Themes: Fix memory corruption from closing asset before XMLTree --> CyanogenMod/android_frameworks_base
Reaktionen: m3stolo, Spaulding89 und j1gga84
I9100 20141220 is UP! :cool:
Changelog:
  • Updated Kernel Toolchain to Linaro 4.9.2 2014.12
  • XMM626x: fix Samsung RIL v9 update --> CyanogenMod/android_hardware_samsung
  • Protected Apps: Increase hit target of the launch app button --> CyanogenMod/android_packages_apps_Settings
  • media: Fix cts issues related to VideoEncoderDecoderTest --> CyanogenMod/android_hardware_qcom_media-caf
  • WhisperPush: Add all possible variants of WP registration number --> CyanogenMod/android_external_whispersystems_WhisperPush
  • libutils: Properly #ifdef NEEDS_VECTORIMPL_SYMBOLS --> CyanogenMod/android_system_core
  • Themes: Make notification action text color themeable --> CyanogenMod/android_frameworks_base
  • Only discard the roaming icon if we're not roaming anymore --> CyanogenMod/android_frameworks_base
  • Mms: Improve some more strings --> CyanogenMod/android_packages_apps_Mms-caf
  • Change BlacklistProvider logging to isLoggable instead of DEBUG constant --> CyanogenMod/android_packages_providers_TelephonyProvider
  • MimeUtils: add ODF presentation (template) --> CyanogenMod/android_libcore
  • Landscape: Dialpad is too big and it cover partially contacts --> CyanogenMod/android_packages_apps_Dialer
  • Settings: disable report button for system apps --> CyanogenMod/android_packages_apps_Settings
  • Store correct IMSI when retreived from SIMRecords and use it for RuimRecords --> CyanogenMod/android_frameworks_opt_telephony
  • Prioritize Airtel GPRS over Airtel Live in India --> CyanogenMod/android_vendor_cm
  • camera: Fix inclusion of CameraParametersExtra.h --> CyanogenMod/android_frameworks_av
Reaktionen: hsvl1ve, j1gga84 und m3stolo
so dann werde ich die letzte jetzt noch mal flashen, dann geht die S2-Zeit endgültig zu Ende. :thumbsup: Ich werde das Gerät nun im Bekanntenkreis verkaufen, wird schon lange nicht mehr benutzt, da ich ein S4 habe.
Danke an Alle die dieses Gerät supporten oder es getan haben.
Ich wünschte mir das das bei meinem jetzigen Gerät auch mal so wäre, habe ein GT-I9506, da ist der support alles andere als gut, CM ist da sozusagen das einzige was geht
Bye hier im S2 Bereich :flapper::tongue::biggrin:
Reaktionen: Truckerdidi
Bye hsvl1ve.
Ja die Community beim S2 ist echt einmalig. Zu mindestens hier bei AH.
Reaktionen: hsvl1ve und Truckerdidi
Super einen ROM mit aktuellen Build zu finden, werde den auch nochmal drauf ziehen. Bisher laufe ich auf einer Samsung basierenden CustomROM.
Ich wollte drauf hinweisen, dass der Link zum Download im Startpost nicht zu der aktuellen Version führt. Ich hoffe das ist mit den restlichen Dateien der Fall GApps etc.
Downloadlink der ROM im Opener wieder aktuell!
Reaktionen: Spaulding89
Es wird bis Januar kein neues Build erscheinen, da es momentan nur sehr wenige Änderungen bei CM11 gibt.
Reaktionen: j1gga84
Generell wird es auch keine großartigen Updates mehr für CM11 geben denke ich, genauso wenig wie für AOSP bzw. Slim.. Bin mal gespannt wie es mit den ROMs für das S2 weitergehen wird.
Weitergehen könnte es, technisch ist Lollipop für das S2 kein Problem denke ich, allerdings fehlen die Entwickler speziell für das S2 (Device Maintainer), leider..
Naja da ich des öfteren die Gits von CM verfolge kann ich schon sagen dass immer noch ein paar Änderungen einfließen aber halt nicht mehr so wie früher.
OT: Ich sehe es ja beim OPO selbst da kommt fast jeden Tag ne neue Version.
Rufuz66
Rufuz66
fireburner
F0x123
Nick Knight
Sir Charles
Sir Charles
