[ROM][I9100][MM][6.0.1] *05.11.16* CyanogenMod 13.0 [Linaro][SaberMod]
  • 808 Antworten
Hatte davor die Rom vom 25 drauf da lief ART noch ohne probleme, auf die neuste geupdatet und die ganzen Dienste stürzen nach dem Bootvorgang ab. Zurück flashen hat bei mir geholfen
Neuste Weekly von 08.04.2014
cm-11-20140408-MARKOX89-i9100.zip
Changelog von Weekly 08.04.2014:
  • Camera2: Surface Qualcomm HFR setting --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: Show post-picture spinner for slow shutter --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: Add proper support for SuperZoom --> CyanogenMod/android_packages_apps_Camera2
  • Telephony: fix null pointer exception --> CyanogenMod/android_frameworks_opt_telephony
  • Fix displaying of the sort order --> CyanogenMod/android_packages_apps_Trebuchet
  • Implement SMS mark for unread (Cyan-348) --> CyanogenMod/android_packages_apps_Mms
  • Trebuchet : Fix search bar icon/text disapearing --> CyanogenMod/android_packages_apps_Trebuchet
  • base: Fix screen on stats after a boot --> CyanogenMod/android_frameworks_base
  • touch -h: quickfix for bionic --> CyanogenMod/android_external_busybox
  • DcTracker: wait for default apn to disconnect before setting up new --> CyanogenMod/android_frameworks_opt_telephony
  • update config for 1.22.1, add F2FS volume_id support --> CyanogenMod/android_external_busybox
  • SamsungQualcommRIL: fix power on and off state --> CyanogenMod/android_frameworks_opt_telephony
  • DCTracker: upgrade stubbed apn to Qcril Standard. --> CyanogenMod/android_frameworks_opt_telephony
  • Telephony: Bring back older IMSI method for legacy RIL --> CyanogenMod/android_frameworks_opt_telephony
  • libarchive: open_zipped() does not need to check extensions for e.g. gzip --> CyanogenMod/android_external_busybox
  • Do not enable Camera widget on non-camera devices --> CyanogenMod/android_packages_apps_Settings
  • Update 'Wi-Fi display' string to 'Cast screen' --> CyanogenMod/android_packages_apps_Settings
  • Remove SemcQualcomm7x30RIL --> CyanogenMod/android_frameworks_opt_telephony
  • Revert "init: Fix serial number display for semc msm7x30 devices" --> CyanogenMod/android_system_core
  • Separate Change Encryption Password Entry (2 of 2) --> CyanogenMod/android_frameworks_base
  • Separate Change Encryption Password Entry (1 of 2) --> CyanogenMod/android_packages_apps_Settings
  • add Voice Wakeup switch --> CyanogenMod/android_packages_apps_Settings
  • Fix for crowdin --> CyanogenMod/android_packages_apps_Gallery2
  • frameworks: add SmartCover stubs --> CyanogenMod/android_frameworks_base
  • AppOps: Prompt to remember user choice in ASK mode --> CyanogenMod/android_frameworks_base
  • Use checkOperation in BroadcastQueue. --> CyanogenMod/android_frameworks_base
  • Use SSL for submitting stats --> CyanogenMod/android_packages_apps_Settings
  • Keyguard: allow keyguard to be dismissed via intent --> CyanogenMod/android_frameworks_base
  • add VoiceWakeup Settings value --> CyanogenMod/android_frameworks_base
  • Fix for crowdin --> CyanogenMod/android_packages_apps_Camera2
  • Fix for crowdin --> CyanogenMod/android_external_whispersystems_WhisperPush
  • audioflinger: OffloadThread fix for resume underrun --> CyanogenMod/android_frameworks_av
  • libmediaplayerservice: Fix bug due to operator precedence --> CyanogenMod/android_frameworks_av
  • AudioFlinger: Introduce CBLK_STREAM_FATAL_ERROR flag --> CyanogenMod/android_frameworks_av
  • libstagefright: mkv parser: check for divx format --> CyanogenMod/android_frameworks_av
  • stagefright: Correct the updation of extension sample rate --> CyanogenMod/android_frameworks_av
  • libmedia: Set the correct audio latency in offload mode --> CyanogenMod/android_frameworks_av
  • Framework: Fixing media server crash. --> CyanogenMod/android_frameworks_av
  • server: start cne service --> CyanogenMod/android_frameworks_base
  • Do not show new card dialog if config_auto_provision_enable is set --> CyanogenMod/android_frameworks_opt_telephony-msim
  • msim: Add DC-HSPAP support --> CyanogenMod/android_frameworks_base
  • MSimNetworkController: fix Quick Settings --> CyanogenMod/android_frameworks_base
  • Telephony: DcTracker: Fix CDMA APN Data issues. --> CyanogenMod/android_frameworks_opt_telephony
  • Telephony: Allow ruim to fetch in CDMA LTE mode --> CyanogenMod/android_frameworks_opt_telephony
  • SamsungExynos4RIL: buffer CAT Proactive Command --> CyanogenMod/android_frameworks_opt_telephony
  • systemui: fix qs tiles layout height in landscape mode --> CyanogenMod/android_frameworks_base
  • releasetools: use variable instead of fixed name for bootable image --> CyanogenMod/android_build
  • show connected devices or name of single device on Bluetooth Tile --> CyanogenMod/android_frameworks_base
  • bluetooth: notify ACTION_ALIAS_CHANGED --> CyanogenMod/android_packages_apps_Bluetooth
  • Solve three memory leaks related to PatchCache --> CyanogenMod/android_frameworks_base
  • remove unnecessary switchUser call --> CyanogenMod/android_frameworks_base
  • Prevent Lockscreen album art from activating FLAG_KEEP_SCREEN_ON --> CyanogenMod/android_frameworks_base
  • Do not show Home behind full screen activity --> CyanogenMod/android_frameworks_base
  • Hang off call by power button while screen is on --> CyanogenMod/android_frameworks_base
  • Trebuchet : Check if target is null for cancelled events --> CyanogenMod/android_packages_apps_Trebuchet
  • email: add support for Server Name Indication (SNI) --> CyanogenMod/android_packages_apps_Email
  • build: Add support for Luxembourgish --> CyanogenMod/android_build
  • WhisperPush: Remove Launcher Icon & Fix NPE --> CyanogenMod/android_external_whispersystems_WhisperPush
  • core: Add support for Luxembourgish --> CyanogenMod/android_frameworks_base
  • charger: Underp the backlight --> CyanogenMod/android_system_core
  • QuickBoot: Charger: add parameter to support QuickBoot mode --> CyanogenMod/android_system_core
  • bootanim: Add continuous splash support --> CyanogenMod/android_frameworks_base
  • Settings: Integrate Voice+ into Settings (1/2) --> CyanogenMod/android_packages_apps_Settings
  • VoicePlus: integrate into Settings (2/2) --> CyanogenMod/android_packages_apps_VoicePlus
  • Quiet Hours: Add 4 state (off, timed inactive, timed active and forced on) support --> CyanogenMod/android_frameworks_base
  • contacts: Holo Light ringtone picker dialog --> CyanogenMod/android_packages_apps_Contacts
  • email: Holo Light ringtone picker dialog --> CyanogenMod/android_packages_apps_Email
  • mediaprovider: Add theme support to Ringtone activity --> CyanogenMod/android_packages_providers_MediaProvider
  • base: Add theme support to Ringtone and Profile pickers activities --> CyanogenMod/android_frameworks_base
  • Buttons: Prevent toggling disable hardware keys too quickly --> CyanogenMod/android_packages_apps_Settings
  • Revert "Camera2: Add 50MP, 37.5MP resolution entry" --> CyanogenMod/android_packages_apps_Camera2
  • Settings: Fix Quiet Hours Tile long press action --> CyanogenMod/android_packages_apps_Settings
  • loki updates: --> CyanogenMod/android_bootable_recovery
  • vendor/cm: add more verizon apns --> CyanogenMod/android_vendor_cm
  • Handle 'UNSOL_STK_EVENT_NOTIFY' without 'SETUP_MENU'. --> CyanogenMod/android_packages_apps_Stk
  • Fix Samsung STK code for msim --> CyanogenMod/android_frameworks_opt_telephony
  • Fix Samsung STK code for msim --> CyanogenMod/android_frameworks_opt_telephony-msim
Reaktionen: ->TopAZ<-, Truckerdidi, ChrisFis und eine weitere Person
Sagt mal, habt Ihr eigentlich auch keinen "Landscape"-Modus bei Homescreen und App-Drawer?
Habe den Landscapemodus bei CM10.1 immer sehr gemocht, aber scheinbar geht das bei dieser ROM nicht mehr?
Oder kann jemand gegenteilige Aussagen machen?
Mfg Ice
Was läuft mit ART bei einigen nicht?
Ich habe bisher einige Apps probiert, diese klappen problemlos mit letzte Nighty (nich die Weekly davor). ´. Umgestellt im Entwickler Mode,
Ich habe eine Frage:
Also
Ich habe die Rom geflasht mit nem 3.0.64-CM Kernel.
Funktioniert auch alles Super, allerdings geht mein Simpsons: Springfield damit nicht.
Wie ich schon überall gelesen hab liegt das wohl an diesem Mali Treiber oder so...
Kann ich jetzt eine neue Kernel Version über die Recovery mit dem UKAS flashen?
Und wenn ja: Welche? Und muss ich dann die Rom auch neu aufspielen?
Mir ist egal wie aber ich will das das Spiel wieder läuft und das am besten auf dieser Rom xD
Danke und Gruß
20140416 is UP!
Check the md5sum before flashing!
Changelog:
  • fonts: Add LBha****aComplexSans font for Sinhala --> CyanogenMod/android_frameworks_base
  • build: Re-enable Sinhala language --> CyanogenMod/android_build
  • CM11 Themes: Store hash codes for target and overlay in idmap --> CyanogenMod/android_frameworks_native
  • CM11 Themes: Use 32bit hash to decide if idmap should be created --> CyanogenMod/android_frameworks_base
  • Softbank carrier overlay that fixes Mms User Agent for both Mms.apk & Hangouts --> CyanogenMod/android_vendor_cm
  • WhisperPush: add Privacy Policy links --> CyanogenMod/android_external_whispersystems_WhisperPush
  • revert camera icon disable when Settings.System.LOCKSCREEN_MODLOCK_ENABLED was set to 1 --> CyanogenMod/android_frameworks_base
  • Implement getPage with page id instead of key --> CyanogenMod/android_packages_apps_CMAccount
  • Settings: Apply Processor settings to all cpus --> CyanogenMod/android_packages_apps_Settings
  • CM11 Themes: Take into account ALL res/xml dirs --> CyanogenMod/android_frameworks_base
  • Changed "Wake on plug" description --> CyanogenMod/android_packages_apps_Settings
  • SF: Add known programs to cache --> CyanogenMod/android_frameworks_native
  • egl: Addition of eglGpuPerfHintQCOM --> CyanogenMod/android_frameworks_native
  • libhardware: Add dirty region field to hwc layer --> CyanogenMod/android_hardware_libhardware
  • frameworks/native: Propagate dirty region in hwc_layer --> CyanogenMod/android_frameworks_native
  • frameworks/base: Call setDirtyRect to update dirty rectangle --> CyanogenMod/android_frameworks_base
  • telephony: Disable MSIM settings if unavailable --> CyanogenMod/android_packages_services_Telephony
  • Move theme strings to cm_strings.xml --> CyanogenMod/android_frameworks_base
  • Keyguard: Fix album art sticking after playback is stopped --> CyanogenMod/android_frameworks_base
  • Fix the value type of def_noise_suppression --> CyanogenMod/android_frameworks_base
  • SysUI: Don't recreate controllers --> CyanogenMod/android_frameworks_base
  • Modified "Empty button" > "Leave empty" --> CyanogenMod/android_frameworks_base
  • Oh hey there --> CyanogenMod/android_packages_apps_Trebuchet
  • Add new themes items to personalization menu --> CyanogenMod/android_packages_apps_Settings
  • Make the default value of in-call noise suppression configurable --> CyanogenMod/android_frameworks_base
  • Lockscreen wallpaper for themes --> CyanogenMod/android_frameworks_base
  • wallpaper: add missing hides --> CyanogenMod/android_frameworks_base
  • Keyguard: more consistency with the new lockscreen wallpaper --> CyanogenMod/android_frameworks_base
  • LockClock: add a content provider for weather --> CyanogenMod/android_packages_apps_LockClock
  • add Custom Lockscreen switch --> CyanogenMod/android_packages_apps_Settings
  • add Custom Lockscreen switch --> CyanogenMod/android_frameworks_base
  • Wallpaper Overscroll and Transparent NavBar --> CyanogenMod/android_frameworks_base
  • Update settings after recreating status bar --> CyanogenMod/android_frameworks_base
  • New Theme Engine [6/6] --> CyanogenMod/android_vendor_tmobile_libs_com.tmobile.themes
  • New Theme Engine [5/6] --> CyanogenMod/android_vendor_tmobile_providers_ThemeManager
  • New Theme Engine [2/6] CM11 Themes --> CyanogenMod/android_frameworks_native
  • Runtime resource overlay, iteration 2 --> CyanogenMod/android_frameworks_native
  • New command line tool 'idmap' --> CyanogenMod/android_frameworks_native
  • New Theme Engine [4/6] --> CyanogenMod/android_build
  • Runtime resource overlay, iteration 2 --> CyanogenMod/android_build
  • New Theme Engine [3/6] --> CyanogenMod/android_external_skia
  • New Theme Engine [1/6] --> CyanogenMod/android_frameworks_base
  • Runtime resource overlay, iteration 2, test cases --> CyanogenMod/android_frameworks_base
  • Runtime resource overlay, iteration 2 --> CyanogenMod/android_frameworks_base
  • New command line tool 'idmap' --> CyanogenMod/android_frameworks_base
  • Remove T-mobile items not used by new theme engine --> CyanogenMod/android_frameworks_base
  • Dialer: Readd missing T9 strings --> CyanogenMod/android_packages_apps_Dialer
  • ConnectivtyService: Execute connectivityCheck in thread pool --> CyanogenMod/android_frameworks_base
  • phone: Add blacklist provider permission --> CyanogenMod/android_packages_services_Telephony
  • telephonyprovider: Add blacklist provider permission --> CyanogenMod/android_packages_providers_TelephonyProvider
  • settings: Add blacklist provider permission --> CyanogenMod/android_packages_apps_Settings
  • dialer: Add blacklist provider permission --> CyanogenMod/android_packages_apps_Dialer
  • base: Add blacklist provider permission --> CyanogenMod/android_frameworks_base
  • SysUI: Use LocationController from status bar service for GPSTile --> CyanogenMod/android_frameworks_base
  • browser: allow to load browser internal assets --> CyanogenMod/android_packages_apps_Browser
  • CYAN-3187: Bluetooth MAP SMS reciept sending entire phone number list --> CyanogenMod/android_packages_apps_Bluetooth
  • DevTools: Mock SMS (4/4) --> CyanogenMod/android_development
  • Telephony: Mock SMS (2/4) --> CyanogenMod/android_frameworks_opt_telephony
  • Settings: Mock SMS (3/4) --> CyanogenMod/android_packages_apps_Settings
  • Wrong product package: Gallery was replaced by Gallery2 --> CyanogenMod/android_build
  • Lockscreen: Fix SystemUI crash on initial selection of Custom Background --> CyanogenMod/android_frameworks_base
  • Version 6.0.4.8 --> CyanogenMod/android_bootable_recovery
  • Settings: Fix VoiceWakeup settings crash --> CyanogenMod/android_packages_apps_Settings
  • Set some GC parameters only for dalvik --> CyanogenMod/android_frameworks_base
  • manifest: Don't track Launcher3 --> CyanogenMod/android
  • manifest: Dont track QuickSearchBox --> CyanogenMod/android
  • QuickMessagePopup: pager fix on multiple messages --> CyanogenMod/android_packages_apps_Mms
  • build: edify: use set_metadata for backuptool --> CyanogenMod/android_build
  • Settings: Lockscreen custom wallpaper (2/2) --> CyanogenMod/android_packages_apps_Settings
  • Frameworks: Lockscreen custom wallpaper (1/2) --> CyanogenMod/android_frameworks_base
  • Add missing head sys/types.h to Volume.h Fix compile error of build with C++ --> CyanogenMod/android_system_vold
  • cm: sepolicy: Allow ueventd to load WiFi and audio irmware --> CyanogenMod/android_vendor_cm
  • cm: sepolicy: Allow ueventd to properly handle cpufreq changes --> CyanogenMod/android_vendor_cm
  • sysfs_devices_system_cpu should be a sysfs_type --> CyanogenMod/android_external_sepolicy
  • Start confining ueventd --> CyanogenMod/android_external_sepolicy
  • Move audio_firmware_file and /data/misc/audio entry to core sepolicy --> CyanogenMod/android_external_sepolicy
  • Isolate untrusted app ptys from other domains --> CyanogenMod/android_external_sepolicy
  • Fix denials encountered while getting bugreports --> CyanogenMod/android_external_sepolicy
  • Allow apps to execute app_data_files --> CyanogenMod/android_external_sepolicy
  • Make sure exec_type is assigned to all entrypoint types --> CyanogenMod/android_external_sepolicy
  • allow changing menu color --> CyanogenMod/android_bootable_recovery
  • mounts: add find_mounted_volume_by_real_node this function finds a mounted volume by the real device node(resolved symlink) --> CyanogenMod/android_bootable_recovery
  • allow using custom recovery_ui.c --> CyanogenMod/android_bootable_recovery
  • SoundSettings: Assigning a null to an unnecessary variable --> CyanogenMod/android_packages_apps_Settings
  • CMUpdater: collapse statusbar when upgrading from notification --> CyanogenMod/android_packages_apps_CMUpdater
  • build: Disable Punjabi & Sinhala languages --> CyanogenMod/android_build
  • Mms: Move Mark as unread strings to the correct places --> CyanogenMod/android_packages_apps_Mms
Reaktionen: CryptLoad73, ChrisFis und Pr0TuRk38
Moin!
Ich hab das mit der md5sum immer noch nicht geschnallt.
Steckt die nicht eigentlich in der .zip schon drin? Wieso gibt es die hier extra und was soll ich damit machen? Oder ist die md5 für odin und die .zip zum flashen im cwm?
Also
Danke und Gruß
ich habe die ROM nicht hochgeladen, auch nutze ich sie momentan nicht, habe nur das Changelog aus dem xda Thread hier gepostet :winki:
Wie dem auch sei, zu deiner Frage:
Ich habe schon gehört, dass es mit diesem Spiel auch in anderen ROMs Probleme gibt, ob nun ein anderer Kernel Abhilfe schafft kann ich dir leider nicht sagen.
Deine Vorgehensweise ist aber korrekt so, das UKAS benötigst du normalerweise nicht, ich nehme es nur, wenn ich z.B. von einem Custom Kernel zurück auf Stock (CM Kernel) gehe.
Du könntest also mal den Apolo 7.0b Kernel oder den Gustavo_s Kernel testen und schauen ob das Spiel damit läuft oder vielleicht vor dem Flash in den jeweiligen Threads hier im Kernel-Bereich mal nachfragen :thumbup:
Reaktionen: Aimyst
Neuste Weekly von 19.04.2014
cm-11-20140419-MARKOX89-i9100.zip
Changelog von Weekly 19.04.2014:
  • Update classpath to remove obsolete apps and to fix compile error when importing to eclipse --> CyanogenMod/android_development
  • Add missing permission to expand/collapse statusbar --> CyanogenMod/android_packages_apps_CMUpdater
  • adb: Do not look for bu in /system/bin when in recovery mode --> CyanogenMod/android_system_core
  • Keyguard: Fix "Show more than a "." when input wrong PIN code" issue --> CyanogenMod/android_frameworks_base
  • Add Entrypoint for theme sounds --> CyanogenMod/android_packages_apps_Settings
  • mms: Add CHANGE_PHONE_BLACKLIST permission --> CyanogenMod/android_packages_apps_Mms
  • LockClock: display date range for multi-day allday appointments --> CyanogenMod/android_packages_apps_LockClock
  • LockClock: remove external force refresh action --> CyanogenMod/android_packages_apps_LockClock
  • CMWallpapers: correct package name --> CyanogenMod/android_packages_apps_CMWallpapers
  • Add OpenCnam paid account settings keys --> CyanogenMod/android_frameworks_base
  • Dialer: Add support for OpenCNAM paid accounts --> CyanogenMod/android_packages_apps_Dialer
  • Fix a number of aapt warnings --> CyanogenMod/android_packages_apps_Settings
  • Cleanup theme assets when done with them --> CyanogenMod/android_frameworks_base
  • quickboot: Disable quickboot by default --> CyanogenMod/android_frameworks_base
  • manifest: track libtar --> CyanogenMod/android
  • libtar: Add const qualifiers to reduce compile warnings --> CyanogenMod/android_external_libtar
  • Revert "apns: Add type default for Sprint" --> CyanogenMod/android_vendor_cm
  • Dialer MSIM: display all IMEI/MEID for *#06# --> CyanogenMod/android_packages_apps_Dialer
  • Add entry to change lock wallpaper via themes --> CyanogenMod/android_packages_apps_Settings
  • RouteController: use fixed priority for ip rule --> CyanogenMod/android_system_netd
  • Netd: Do not reset routing policies --> CyanogenMod/android_system_netd
  • Netd: Use append to add routes to secondary routing table --> CyanogenMod/android_system_netd
  • core: Add support for Galician --> CyanogenMod/android_frameworks_base
  • settings: Make mobile settings a first-class citizen --> CyanogenMod/android_packages_apps_Settings
  • CMUpdater: Really collapse after installing from statusbar --> CyanogenMod/android_packages_apps_CMUpdater
  • Settings: disable lockscreen settings appropriately --> CyanogenMod/android_packages_apps_Settings
Reaktionen: ->TopAZ<-, ChrisFis, kiwikh und eine weitere Person
Danke!
Ich hoffe, dass die Version besser läuft bei mir. Bei der letzten hatte ich oft das Problem, dass das Handy hängengeblieben ist, wenn ich aus dem Sperrbildschirm direkt in die linke Schnellstartleiste wollte.
Läuft die ROM gut ? Ich werde nämlich mein S2 mein besseren Hälfte geben und selbst auf das S3 umsteigen. Deshalb soll das Handy rund laufen. Beste österliche Grüße
Ja natürlich läuft diese Rom gut!Mehr als das!Sie läuft sehr stabil!Ich habe ja auch mittlerweile ein S4 aber ich nutze immer noch das S2 als 2 Handy und diese Rom hier ist die beste Wahl!Also kann ich nur empfehlen;)
Reaktionen: Truckerdidi und ->TopAZ<-
+1
Wenn man sauber arbeitet beim aufsetzen und auch vor einem evtl. NOTWENDIGEN FactoryReset (inkl. Format SD intern) nicht zurückschreckt. Auf meinem S2 läuft diese ROM auch ma richtig rund. Der Verbrauch des Akkus im Ruhemodus (WLAN aus) lässt mich regelmäßig ein freundliches Grinsen ins Gesicht bekommen (0,2%/h).
Reaktionen: Truckerdidi und CryptLoad73
So lange es so eine super Rom gibt, brauche ich auch noch kein neues Handy :)))
@Truckerdidi
Ja kann man so sehen.Zumal man bedenken sollte,dass die S Reihe weiterhin schlechter wird.Nicht für die Hardware.Sondern wegen der Samsung Software!Knox und den neuen Bootloader von S4 und.....
Das Rooten wird einen immer mehr erschwert.Ich trauere auch schon das S2 hinterher.Denn leider habe ich mich vor dem S4 Kauf nicht richtig informiert!Weil durch das Rooten beim S4 die Garantie durch die neue Firmware von Android 4.4.2 verloren geht:(
Das S3 ist eigentlich auch noch eine gute Alternative.Aber alles darüber hinaus sollte man sich wirklich überlegen!Das S2 ist in der Tat durch diese Rom noch ein sehr gutes Handy.Dank CM und Linaro/SaberMod und vor allem durch den guten Markox89:thumbup:Der diese Rom am Leben hält;)
@CryptLoad
Offtopic = Das S4 hat ja jede Menge C-ROMs am Start. Auch ich Stand bis gestern noch vor der Wahl das S3 oder das S4 zu nehmen. Technisch ist das S4 ein Stückchen besser und die C-ROMs deutlich stärker vertreten auch hier im Forum. Da fiel mir die Entscheidung leicht :) Das S2 geht an meine bessere Hälfte (neues Original Samsung Rundum Cover mit neuem Akku und aktueller C-ROM von hier) :biggrin: Offtopic aus....
Was mir aufgefallen ist, ist das die Markox Rom mit Avast Mobile Security leicht stockt. Mit der SlimKat und Avast aber geht alles sehr schnell. Woran das liegt ?
@walangoo
Avast runterschmeißen, Problem gelöst ;)
Hatte auch eine Zeit lang diese Pseudo Security drauf bis ich mich auf xda und z.T auch hier eines Besseren belehren hab lassen, aber ist jedem seine eigene Entscheidung ;)
Avast ist für einen PC gut aber Mobil ist zur Zeit wohl nichts Vernünftiges auf dem Markt. Mein S2 HT noch den original Akku und auch alles andere ist wie am Anfang, keine Kratzer im display und der Akku hält mit dieser Rom bei normaler Nutzung fast 2 Tage. Und mit dieser Rom die ich vom Erscheinen bis jetzt Nutze, noch keine Probleme oder Hänger gehabt. Gruß Dietmar
Suche einen lauffähigen Kernel mit TWRP.
@achvio
Gustavo_s oder Apolo wobei ich den Gustavo_s vorziehen würde da er schon das neue TWRP mitbringt und der Dev hier noch regelmäßiger Updates bringt :thumbup:
Neue Version ist erschienen:
I9100 20140424 is UP!
Changelog:
  • PegasusQ is now the default CPU Governor
  • ROW is now the default I/O Scheduler
  • MSIM: Ui fixes, replace Subscriptions with real operator names --> CyanogenMod/android_packages_apps_Settings
  • MSIM: Replace names of tabs to real operator names --> CyanogenMod/android_packages_services_Telephony
  • MSIM: Replace SUBs with real operator name --> CyanogenMod/android_packages_apps_Mms
  • MSIM: Hide latest area info broadcast if not brazilian sim --> CyanogenMod/android_packages_apps_Settings
  • MSIM: Rework statusbar, order signal clusters to match settings --> CyanogenMod/android_frameworks_base
  • Settings: lock screen grammar fix --> CyanogenMod/android_packages_apps_Settings
  • QuickSettings: fix long press on Network Mode Tile --> CyanogenMod/android_frameworks_base
  • QS: smaller tiles: Fix the text labels on small screen devices --> CyanogenMod/android_frameworks_base
  • Settings: Only disable menu unlock options with custom keyguard --> CyanogenMod/android_packages_apps_Settings
  • QS: Make it possible to show smaller tiles (2/2) --> CyanogenMod/android_packages_apps_Settings
  • QS: Make it possible to show smaller tiles (1/2) --> CyanogenMod/android_frameworks_base
  • Fix MSIM Network Settings (2/2) --> CyanogenMod/android_packages_services_Telephony
  • Fix MSIM Network Settings (1/2) --> CyanogenMod/android_packages_apps_Settings
  • Dialer: Landscape support (for in-dock use / qwerty sliders) --> CyanogenMod/android_packages_apps_Dialer
  • InCallUI: Landscape support (for in-dock use / qwerty sliders) --> CyanogenMod/android_packages_apps_InCallUI
  • Settings: update a few CM strings --> CyanogenMod/android_packages_apps_Settings
  • CM11 Themes: Use theme name for audible name --> CyanogenMod/android_frameworks_base
  • CM11 Themes: Allow forcing idmap recreation --> CyanogenMod/android_frameworks_base
  • CM11 Themes: Remove type matching restriction --> CyanogenMod/android_frameworks_base
  • apns-conf: Add QUAM APNs --> CyanogenMod/android_vendor_cm
  • Silly Google --> CyanogenMod/ion
  • CM11 Themes: Put overlays in their own group --> CyanogenMod/android_frameworks_base
  • Trebuchet: Don't hideoutlines if in small overview mode --> CyanogenMod/android_packages_apps_Trebuchet
  • Don't show "Eject card" if the card is not accessible --> CyanogenMod/android_packages_apps_Settings
  • Add config_batterySdCardAccessibility to symbols.xml --> CyanogenMod/android_frameworks_base
  • apns: remove default- and dun-types for Verizon MMS 31x/48x --> CyanogenMod/android_vendor_cm
  • Revert "GFX-3D: Hold the BufferReference of GraphicBuffer in BpGraphicBufferAlloc" --> CyanogenMod/android_frameworks_native
  • hwc: allow targets to disable use of YUV overlay hardware --> CyanogenMod/android_hardware_ti_omap3
  • Download: add to support pause/resume download by manual --> CyanogenMod/android_frameworks_base
  • Settings: disable hardware unlock buttons while secure --> CyanogenMod/android_packages_apps_Settings
  • WhisperPush: change appearence to Holo --> CyanogenMod/android_external_whispersystems_WhisperPush
  • Keyguard: give the Keyguard a non-empty app label --> CyanogenMod/android_frameworks_base
  • Settings: lockscreen wallpaper crash fix --> CyanogenMod/android_packages_apps_Settings
  • Settings: remove screen-off animation checkbox --> CyanogenMod/android_packages_apps_Settings
  • Style previews [1/3] --> CyanogenMod/android_frameworks_base
  • Fix segfault removing theme assets --> CyanogenMod/android_frameworks_base
  • Browser: fix crash updating recycled favicon --> CyanogenMod/android_packages_apps_Browser
  • Settings: Remove Wallpaper selection from Display --> CyanogenMod/android_packages_apps_Settings
  • goldfish: fix emulator build --> CyanogenMod/android_packages_apps_LockClock
  • Parallel shutdown --> CyanogenMod/android_frameworks_base
  • fix WRITE_SETTINGS to be "dangerous" --> CyanogenMod/android_frameworks_base
  • GFX-3D: Hold the BufferReference of GraphicBuffer in BpGraphicBufferAlloc --> CyanogenMod/android_frameworks_native
  • Fix setSurfaceTexture to handle surface caching --> CyanogenMod/android_frameworks_base
  • Update timezone list --> CyanogenMod/android_packages_apps_CMAccount
  • Fix very long app_name crash --> CyanogenMod/android_frameworks_base
  • Fix for crash in LocationManagerService --> CyanogenMod/android_frameworks_base
  • Add dummy strings to prevent aapt warnings --> CyanogenMod/android_packages_apps_Settings
Reaktionen: CryptLoad73, ChrisFis, Truckerdidi und eine weitere Person
Rufuz66
Rufuz66
fireburner
F0x123
Nick Knight
Sir Charles
Sir Charles
