[ROM][I9100][MM][6.0.1] *05.11.16* CyanogenMod 13.0 [Linaro][SaberMod]
  • 808 Antworten
Changelog von Weekly 20.03.2014:
  • Open-source Google Dialer
  • CMFM: Allow restrict access to secondary users --> CyanogenMod/android_packages_apps_CMFileManager
  • Look for the msim settings in the new location deviceinfo/msim --> CyanogenMod/android_packages_apps_Settings
  • [4/4] Dialer lookup --> CyanogenMod/android_packages_apps_Dialer
  • [3/4] Dialer lookup --> CyanogenMod/android_packages_apps_InCallUI
  • [2/4] Dialer lookup --> CyanogenMod/android_packages_services_Telephony
  • [1/4] Dialer lookup --> CyanogenMod/android_frameworks_base
  • sepolicy: Allow vold to use rootfs entrypoint --> CyanogenMod/android_external_sepolicy
  • Add a domain for the recovery console --> CyanogenMod/android_external_sepolicy
  • CMFM: Use ellipsize middle --> CyanogenMod/android_packages_apps_CMFileManager
  • update minui library call --> CyanogenMod/android_system_core
  • Add support for ECDSA P-256 with SHA256 --> CyanogenMod/android_system_core
  • recovery: Compatibility with upstream minui change --> CyanogenMod/android_bootable_recovery
  • DeskClock: Add feature to play random song as an alarm --> CyanogenMod/android_packages_apps_DeskClock
  • VendorCM : Add default wallpaper density bucket for hdpi --> CyanogenMod/android_vendor_cm
  • Fix JNI generation on Darwin and XCode 5.1 --> CyanogenMod/android_external_chromium_org
  • SamsungQualcomm: Add support for Samsung's EMS dialing request --> CyanogenMod/android_frameworks_opt_telephony
  • VendorCM : Add density bucket for xhdpi --> CyanogenMod/android_vendor_cm
  • Camera: Fix the removal of histogram setting fix --> CyanogenMod/android_packages_apps_Camera2
  • Re-add apns from squashed revert --> CyanogenMod/android_vendor_cm
  • libstagefright: bring back mistakenly removed codec quirks --> CyanogenMod/android_frameworks_av
  • Squashed revert of mms and spn-specific overlays --> CyanogenMod/android_vendor_cm
  • apns: Add type default for Sprint --> CyanogenMod/android_vendor_cm
  • bluedroid: Disable AVRCP 1.5 by default --> CyanogenMod/android_external_bluetooth_bluedroid
  • Camera: Fix JPEG quality DB update --> CyanogenMod/android_packages_apps_Camera2
  • Camera: Fix removal of histogram setting --> CyanogenMod/android_packages_apps_Camera2
  • use correct USB PID for adb and new PID for adb+ums --> CyanogenMod/android_bootable_recovery
  • Add an ethernet network icon to the statusbar network area --> CyanogenMod/android_frameworks_base
  • Gallery2 : Store DATE_TAKEN as milliseconds --> CyanogenMod/android_packages_apps_Gallery2
  • Keyguard: Fix configuration change observer --> CyanogenMod/android_frameworks_base
  • CMFM: Fix association dialog layout --> CyanogenMod/android_packages_apps_CMFileManager
  • CMFM: Set theme before setContentView --> CyanogenMod/android_packages_apps_CMFileManager
  • Fix initialization of new installations --> CyanogenMod/android_packages_apps_Camera2
  • Fix the APN editor fix --> CyanogenMod/android_packages_apps_Settings
  • SamsungQualcommRIL: allow mQANElements to be device specific --> CyanogenMod/android_frameworks_opt_telephony
Reaktionen: ChrisFis, Truckerdidi und ->TopAZ<-
Funktioniert bei Euch der Google Dialer? Wenn ich im Kontakte/Suchen Feld einen unbekannten Namen eingebe, wird im Internet nicht nach der passenden Telefonnummer gesucht. Oder habe ich etas falsch verstanden zur Funtionsweise des neuen Dialers?
Neuste Weekly von 22.03.2014
cm-11-20140322-MARKOX89-i9100.zip | by Markox89 for Galaxy S 2
Changelog von Weekly 22.03.2014:
  • Android 4.4.2_r2
  • Camera: Avoid redefinition of ISO params --> CyanogenMod/android_frameworks_av
  • Camera: Remove merge artifact --> CyanogenMod/android_frameworks_av
  • AccountPreference: Sync in progress accessibility status --> CyanogenMod/android_packages_apps_Settings
  • Core/Keyguard: Cleanup CAF additions --> CyanogenMod/android_frameworks_base
  • Correct bad polish translation WI-FI quick settings bar --> CyanogenMod/android_frameworks_base
  • Launch the msim settings when the new card dialog appears --> CyanogenMod/android_packages_services_Telephony
  • releasetools: don't create prebuilt_dir path if it exits --> CyanogenMod/android_build
  • Camera2: Add 50MP, 37.5MP resolution entry --> CyanogenMod/android_packages_apps_Camera2
  • Don't hide baseband on dual sim devices --> CyanogenMod/android_packages_apps_Settings
  • Fix WifiHandler for MSim --> CyanogenMod/android_frameworks_base
  • msim: Add support for H+ icons --> CyanogenMod/android_frameworks_base
  • Expose /dev/hw_random to group "system" --> CyanogenMod/android_system_core
  • Allow installd to restorecon /data/data --> CyanogenMod/android_external_sepolicy
  • Revert "Add SELinux filesystem relabeling to init" --> CyanogenMod/android_vendor_cm
  • Convert all selinux_android_restorecon and _setfilecon calls to new API --> CyanogenMod/android_frameworks_base
  • Augment SELinuxMMAC functionality --> CyanogenMod/android_frameworks_base
  • Allow PMS to restorecon directories under /data --> CyanogenMod/android_frameworks_base
  • Convert all selinux_android_restorecon and _setfilecon calls to new API --> CyanogenMod/android_frameworks_native
  • Proper security labeling of multi-user data directories --> CyanogenMod/android_frameworks_native
  • restorecon /data/media when re-creating it for multi-user upgrade --> CyanogenMod/android_frameworks_native
  • Extend installd to support SELinux restorecon function --> CyanogenMod/android_frameworks_native
  • Run the console service shell in the shell domain --> CyanogenMod/android_system_core
  • Move creation of /data/misc/wifi and /data/misc/dhcp to main init.rc file --> CyanogenMod/android_system_core
  • Log a warning on services that lack SELinux domains --> CyanogenMod/android_system_core
  • Add -D option to restorecon for relabeling /data/data --> CyanogenMod/android_system_core
  • Revert "toolbox: Add levelFromUid categorization support to restorecon" --> CyanogenMod/android_system_core
  • Move restorecon and restorecon_recursive code to libselinux --> CyanogenMod/android_system_core
  • Convert all selinux_android_restorecon and _setfilecon calls to new API --> CyanogenMod/android_system_core
  • Do not change ownership on /sys/fs/selinux/enforce --> CyanogenMod/android_system_core
  • Trigger a policy reload from post-fs-data --> CyanogenMod/android_system_core
  • Apply restorecon_recursive to all of /data --> CyanogenMod/android_system_core
  • Apply strict SELinux checking of PROT_EXEC on mmap/mprotect calls --> CyanogenMod/android_system_core
  • Set security context of /adb_keys and /data/misc/adb/adb_keys --> CyanogenMod/android_system_core
  • Unify toolbox restorecon and libselinux restorecon implementations --> CyanogenMod/android_system_core
Reaktionen: ChrisFis, walangoo, Pr0TuRk38 und 2 andere
Ich habe die ROM vom 20.03 drauf und habe heute gemerkt, das wenn ich länger telefoniere die Verbindung nach ca. 5 Min einfach wegbricht. Das ist mir heute 3 mal im selben Gespräch passiert. Ist das bei bei einem von euch auch so? oder liegt es gar nicht an der ROM und am anderen Ende meines Gesprächspartners ? Ich weiss das Orakel wird gefragt...war so ein Gedanke :)
@walangoo,
das ist bei mir bis jetzt bei keiner Version passiert und ich update in der Regel einmal pro Woche bin also jetzt bei der vom 22.03. und alles läuft perfekt.
Gruß Dietmar
Bei mir ist die Rom vom 22.03 fehlerhaft, nach dem aufspielen waren viele APP verschwunden , nur durch Neuinstallation war das zu beheben. Das hatte ich bei noch keiner Nightly/Weekly. Das nächstes ist, das das S2 sich über Nacht total entladen hat, ohne das etwas geöffnet war. Bin ich da der einzige der dies Problem hat?
@hsvl1ve
Welchen Kernel benutzt du?Also ich habe solche Probleme nicht.Ich benutze den neusten Gustavo Kernel!Und ich habe bisher jede Rom von Markox geflasht.keinerlei Probleme feststellen können.Die Probleme hatte ich damals mal bei einer Infected Rom,als ich einen anderen Kernel benutzt habe.Ich empfehle dir,dass du mal diesen Script ausführen tust.Und dann die Rom neu Installierst!
https://www.android-hilfe.de/attach...-ultimative_kernel_aufraeum_script_v2.6.9.zip
Und wenn du den Gustavo Kernel benutzt hast dann gleich noch diesen hier:
https://www.android-hilfe.de/attach...od-11-nightly-builds-kernel_settings_wipe.zip
Und das schadet auch nicht:
Wipe Cache partition
Wipe Dalvik Cache
ROM.zip flashen
Wipe Dalvik Cache
Neustart
Auch wenn hier jemand der Meinung ist,dass dies nur bedingt hilft!Bei mir hat es immer geholfen;)
Die Rom von 22.03 sowie der Gustavo Kernel von 22.03.2014 läuft bei mir sehr gut und vor allem sehr stabil:)
Gruss
Reaktionen: Truckerdidi
ich habe den 99er Dori vom 20.03 am werkeln, auch schon bei der Weekly davor, da gab es das nicht, da hat der Akku 2 Tage durchgehalten, jetzt nicht mal eine Nacht. Und was noch komisch war, wie schon geschrieben, sind nach dem Flash einige Apps verschwunden, die ich über den Store wieder neu instalieren mußte.
ich habe auf jedenfall heute noch einmal die Rom downlodet.
Jetzt hat das Handy in 8 Stunden 10% Akku verloren, das ist in Ordnung, wo der Fehler liegt, ich weiß es nicht
@hsvl1ve
Ich habe den 99 Kernel auch mit der Rom von 20.03 getestet gehabt.Musste dann aber feststellen,dass die Markox Rom den Core verändert hatte.Somit ging dann auch nicht mehr der 99 Kernel.Und ich habe diesen dann abgestoßen.Und zeitgleich kam dann der Gustavo Kernel raus.Der mit dieser Rom hier am besten läuft.Leider hatte ich auch mit dem Gustavo Kernel heute mein ersten Absturz.Ich hoffe,dass dies einmalig war.Ansonsten macht diese Rom hier einen sehr guten Eindruck.Und wenn man auch mit dem Standard Kernel unterwegs ist,dann hält auch dieser schon sehr lange durch.Da ich aber nicht auf BLN verzichten will...
OT
So dann muss ich hier auch mal was zu dem Dori schreiben obwohl es hier nicht hingehört also der hohe Verbrauch am Akku kommt davon dass manchmal der Deep Sleep nicht einsetzt und das Handy immer wach bleibt aber wenn der Deep Sleep läuft verbraucht er sehr wenig.
Wo stellt man das genau ein ? Danke
Neuste Weekly von 25.03.2014
cm-11-20140325-MARKOX89-i9100.zip | ROM by Markox89 for Galaxy S 2
Changelog von Weekly 25.03.2014:
  • Telephony: Shorten some strings --> CyanogenMod/android_packages_services_Telephony
  • Settings: Cleanup CAF array --> CyanogenMod/android_packages_apps_Settings
  • Fix Apollo list padding --> CyanogenMod/android_packages_apps_Apollo
  • Readd removed AOSP string --> CyanogenMod/android_packages_apps_Dialer
  • ACodec: Add video codec fallback logic --> CyanogenMod/android_frameworks_av
  • audioflinger: Handle pause /resume in stopping state --> CyanogenMod/android_frameworks_av
  • stagefright: Fix AV sync issue for cached audio sources --> CyanogenMod/android_frameworks_av
  • AudioFlinger: Offload track transition fix --> CyanogenMod/android_frameworks_av
  • libstagefright: Fix in AudioPlayer media time mapping --> CyanogenMod/android_frameworks_av
  • audioflinger: remove unecessary call to HAL --> CyanogenMod/android_frameworks_av
  • AudioFlinger: Modify flush handling for offload path --> CyanogenMod/android_frameworks_av
  • libstagefright: Handle offload fallback for WAV content --> CyanogenMod/android_frameworks_av
  • audioflinger: Fix cleanup of asynccallback thread --> CyanogenMod/android_frameworks_av
  • ueventd: Add rules for governors and cpufreq --> CyanogenMod/android_system_core
  • Frameworks: fix possible NPE + and missing expandable panel --> CyanogenMod/android_frameworks_base
  • msim: Fix the dial settings theme to holo light --> CyanogenMod/android_packages_services_Telephony
  • apns-conf: fix NetCom (Norwegian --> CyanogenMod/android_vendor_cm
  • Settings: move Ad-hoc strings --> CyanogenMod/android_packages_apps_Settings
  • Workaround for removed AOSP strings --> CyanogenMod/android_packages_apps_Camera2
  • Settings: Cleanup CAF additions --> CyanogenMod/android_packages_apps_Settings
  • Round off when calculate next step in Seekbar --> CyanogenMod/android_frameworks_base
  • remove unused variable --> CyanogenMod/android_bootable_recovery
  • Dialer: Cleanup CAF additions --> CyanogenMod/android_packages_apps_Dialer
  • galaxys2: enable swipe controls in recovery --> CyanogenMod/android_device_samsung_galaxys2-common
  • Implement toggleLte --> CyanogenMod/android_packages_services_Telephony
  • Fix potential NPE --> CyanogenMod/android_packages_apps_InCallUI
  • galaxys2: Fix the inability to mount/unmount sdcard --> CyanogenMod/android_device_samsung_galaxys2-common
  • Camera2: Remove now unused strings --> CyanogenMod/android_packages_apps_Camera2
  • Email: Fix null string label on empty subject --> CyanogenMod/android_packages_apps_UnifiedEmail
  • Settings: Mirroring layout on RTL languages [2/2] --> CyanogenMod/android_packages_apps_Settings
  • Base: Mirroring layout on RTL languages [1/2] --> CyanogenMod/android_frameworks_base
  • Telephony: Cleanup CAF additions --> CyanogenMod/android_packages_services_Telephony
  • build: Degreenify java --> CyanogenMod/android_build
  • audio: Update Listen HAL API for MultiSession --> CyanogenMod/android_hardware_libhardware
  • ext4_utils: fix utility build --> CyanogenMod/android_system_extras
  • Avoid collision with RIL constant 1138 --> CyanogenMod/android_hardware_ril
  • Avoid collision with RIL constant 1138 --> CyanogenMod/android_frameworks_base
Reaktionen: ChrisFis, Truckerdidi und hsvl1ve
Bis jetzt nur den stock kernel am laufen aber der hält bei normaler Nutzung auch fast 2 Tage.
hatte sonst immer die CM auf den Handy am laufen. Nun hab ich ich aus Neugier mal diese ausprobiert. Sehe jetzt nicht den großen Unterschied. Zumindest stabil und unauffällig bis jetzt. Wenn ich sehe was im CM 11 Thread die Nutzer für Probleme haben. Liegt entweder an CM 11 oder das es mehr genutzt wird.
Gruß Uwe
CM Mod 11 läuft nicht mit Optimierter Rom!Das tut SaberMod aber sehr wohl!Deshalb bleibe ich bei dieser Rom!!!Diese Rom hat den Kernel von Linaro!Da kann sich mal CM mal eine Scheibe abscheiden!!!Allen voran der gute steve kondik und sein Team!!!
Mehr sage ich da nicht!Sonst heißt es wieder.......
Neuste Weekly von 30.03.2014
cm-11-20140330-MARKOX89-i9100.zip | cm-11-20140330-MARKOX89-i9100.zip | ROM by Markox89 for Galaxy S 2
Changelog von Weekly 30.03.2014:
  • Apollo: Update default album art --> CyanogenMod/android_packages_apps_Apollo
  • email: add support for Server Name Indication --> CyanogenMod/android_packages_apps_Email
  • email: Add isRunningJBMR1OrLater method --> CyanogenMod/android_packages_apps_UnifiedEmail
  • Reorganize setup wizard --> CyanogenMod/android_packages_apps_CMAccount
  • Settings: update Privacy Guard help text string --> CyanogenMod/android_packages_apps_Settings
  • power: Require TARGET_POWERHAL_VARIANT = cm --> CyanogenMod/android_hardware_cm
  • Only init legacy property environment once --> CyanogenMod/android_bootable_recovery
  • Apollo: Avoid crash when attempting to load many items --> CyanogenMod/android_packages_apps_Apollo
  • Added support for DC-HSPA+ also in opt/telephony --> CyanogenMod/android_frameworks_opt_telephony
  • Camera2: Add spinner for post-HDR mode --> CyanogenMod/android_packages_apps_Camera2
  • camera: Fading capture animation for ZSL mode --> CyanogenMod/android_packages_apps_Camera2
  • Reorder for GMS --> CyanogenMod/android_packages_apps_Trebuchet
  • Apollo: Use correct preference keys for artwork download --> CyanogenMod/android_packages_apps_Apollo
  • frameworks/base: forward port DC-HSPAP support from cm-10 --> CyanogenMod/android_frameworks_base
  • QuickBoot: enable QuickBoot Settings UI --> CyanogenMod/android_packages_apps_Settings
  • quickboot: Only enable QuickBoot if package is installed --> CyanogenMod/android_frameworks_base
  • build: Add support for Tamil --> CyanogenMod/android_build
  • build: Add support for Uyghur --> CyanogenMod/android_build
  • build: Refactor additional languages/locales --> CyanogenMod/android_build
  • Settings: Add screen color settings --> CyanogenMod/android_packages_apps_Settings
  • languages_full: Remove duplicate Hindi inclusion --> CyanogenMod/android_build
  • settings: hide settings of disabled components --> CyanogenMod/android_packages_apps_Settings
  • frameworks/base: Fix the random UI corruption --> CyanogenMod/android_frameworks_base
  • Squashed commit of QuickBoot feature from Qualcomm --> CyanogenMod/android_frameworks_base
  • apns-conf: Fix Movistar Argentina --> CyanogenMod/android_vendor_cm
  • Frameworks : Make sure a reply is sent when not provisioning default apn --> CyanogenMod/android_frameworks_opt_telephony
  • Revert "Add a copy of the updater binary to the recovery resources" --> CyanogenMod/android_bootable_recovery
  • Use legacy property environment if old update-binary --> CyanogenMod/android_bootable_recovery
  • Make legacy prop environment available to recovery --> CyanogenMod/android_bootable_recovery
  • lock orientation for the onboarding setup --> CyanogenMod/android_packages_apps_CMAccount
Reaktionen: hsvl1ve, ChrisFis und Truckerdidi
Gibt es hier noch andere User die kleine Möglichkeit sehen die Rom mit ART zu nutzen? Ich bin mir sicher das es schon funktioniert hat, jetzt überhaupt nicht mehr, ich kann jetzt nur nicht mehr nachvollziehen ab wann das so ist
@hsvl1ve
Ich glaube zu Wissen,dass ART bei der letzten Infected Rom lief!
ART ist nur lauffähig,wenn installierte Programme das auch unterstützten!Ist eine ältere App drauf,dann geht auch ART nicht mehr.Somit ist für mich ART noch in weiter ferne!Weil ich halt noch etliche ältere Apps benutze.
ART ist lauffähig aber die Installation von selbst neueren APPs wird teilweise nicht zugelassen und abgebrochen. Daher ist ART derzeit eher uninteressant. Das gilt auch für andere Custom-ROMs.
Reaktionen: Truckerdidi und hsvl1ve
Rufuz66
Rufuz66
fireburner
F0x123
Nick Knight
Sir Charles
Sir Charles
