[ROM][I9100][MM][6.0.1] *05.11.16* CyanogenMod 13.0 [Linaro][SaberMod]
  • 808 Antworten
@walangoo
Sorry wenn ich dir auf den Kragen getreten bin;)
Reaktionen: ->TopAZ<-
Neuste Weekly von 28.02.2014
cm-11-20140228-INFECTEDBYMARKOX-i9100
Changelog von Weekly 28.02.2014:
  • Several translations
  • Fixed photo editing issue related to Gallery2.apk
  • Revert "Added sahlnaskh arabic font and give it higher precedence than DroidNaskh" --> CyanogenMod/android_frameworks_base
  • Revert "Added sahlnaskh arabic font to Android.mk & fonts.mk files to actually get the font installed" --> CyanogenMod/android_frameworks_base
  • Fix compile without Bluetooth LE stack --> CyanogenMod/android_external_bluetooth_bluedroid
  • Camera2: Crowdin fixes --> CyanogenMod/android_packages_apps_Camera2
  • Revert "CMAccount: Fix for Transifex"*--> CyanogenMod/android_packages_apps_CMAccount
  • Bluetooth: Workaround for aapt warnings --> CyanogenMod/android_packages_apps_Bluetooth
  • [1/2] Speed up booting on multicore devices --> CyanogenMod/android_frameworks_base
  • [2/2] Speed up booting on multicore devices --> CyanogenMod/android_frameworks_native
  • MediaRecorder: Add pause interface --> CyanogenMod/android_frameworks_base
  • Camera: Add support for 4K camcorder --> CyanogenMod/android_packages_apps_Camera2
  • Camera: Avoid animating cature with decoded jpeg in long shot --> CyanogenMod/android_packages_apps_Camera2
  • Camera: Don't do cancel_af till all CBs are received in burst shot --> CyanogenMod/android_packages_apps_Camera2
  • Camcorder: Switch video torch when preview focused --> CyanogenMod/android_packages_apps_Camera2
  • Camera: Remove AF UI when faces are detected in photo ui --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: Check mCameradevice before setting skinToneEnhancement --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: Fix concurrency issues with camera messages --> CyanogenMod/android_packages_apps_Camera2
  • Camera2 : Reset mSnapshotInProgress if recording stopped. --> CyanogenMod/android_packages_apps_Camera2
  • Camera2:stop recording from camcorder app in case of error --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: Synchronize access to camera parameters --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: override Saturation&Contrast item when enable scence mode --> CyanogenMod/android_packages_apps_Camera2
  • Camera: Dont reset camera state while capture is in progress. --> CyanogenMod/android_packages_apps_Camera2
  • Camera: Add a filter to remove unsupported hfr modes in camcorder --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: Added pause button in Camcorder --> CyanogenMod/android_packages_apps_Camera2
  • Update settings pref values when BSM is not auto. --> CyanogenMod/android_packages_apps_Camera2
  • Camera: Add checker for null pointer exception during camera release --> CyanogenMod/android_packages_apps_Camera2
  • Camera: Prevent callling of resize before camera is initialized --> CyanogenMod/android_packages_apps_Camera2
  • camera: fix camera crash in hfr --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: Calculate UI aspect ratio based on preview size --> CyanogenMod/android_packages_apps_Camera2
  • Close open cursors --> CyanogenMod/android_packages_apps_Camera2
  • Camera: Disable livesnapshot for 4kx2k video --> CyanogenMod/android_packages_apps_Camera2
  • libstagefright: Fix ANR issue in HTTP Streaming --> CyanogenMod/android_frameworks_av
  • libstagefright: Signal input EOS after last buffer is released --> CyanogenMod/android_frameworks_av
  • libstagefright: Fix crash during seek --> CyanogenMod/android_frameworks_av
  • libstagefright: camcorder pause-resume implementation --> CyanogenMod/android_frameworks_av
  • Add 2 APIs CyanogenMod/suspend/resume in MediaPlayer --> CyanogenMod/android_frameworks_av
  • AwesomePlayer: Enable audio offload for widevine --> CyanogenMod/android_frameworks_av
  • stagefright: Various cleanups --> CyanogenMod/android_frameworks_av
  • Audio: Add Pause/Resume in AMR-WB tunnel recording --> CyanogenMod/android_frameworks_av
  • stagefright: do not offload LD-AAC decoding --> CyanogenMod/android_frameworks_av
  • libstagefright: Fix DP Parsing issue with mpeg4 SP,ASP --> CyanogenMod/android_frameworks_av
  • stagefright: do not offload MAIN-AAC decoding --> CyanogenMod/android_frameworks_av
  • libstagefright: fix force close issue when mute MPEG4 clips --> CyanogenMod/android_frameworks_av
  • libstagefright: Do not offload HEVC AV decoding --> CyanogenMod/android_frameworks_av
  • stagefright: Use pause/flush logic for all targets --> CyanogenMod/android_frameworks_av
  • f2fs-tools: release 1.3.0 --> CyanogenMod/android_external_f2fs-tools
  • f2fs-tools: show version on all tools --> CyanogenMod/android_external_f2fs-tools
  • f2fs-tools: create dump.f2fs symlink --> CyanogenMod/android_external_f2fs-tools
  • f2fstat: fix command-line options --> CyanogenMod/android_external_f2fs-tools
  • mkfs, fsck: change the results for readability --> CyanogenMod/android_external_f2fs-tools
  • f2fstat: add option to select partition to see status --> CyanogenMod/android_external_f2fs-tools
  • mkfs: fix the wrong nat bitmap size --> CyanogenMod/android_external_f2fs-tools
  • f2fs-tools: resolve build warnings --> CyanogenMod/android_external_f2fs-tools
  • fibmap.f2fs: add bdev information --> CyanogenMod/android_external_f2fs-tools
  • f2fs-tools: move fsck/fibmap.f2fs to tools/ --> CyanogenMod/android_external_f2fs-tools
  • Allow to build latest changes with android --> CyanogenMod/android_external_f2fs-tools
  • f2fs-tools: add f2fstat to print f2fs's status in sec --> CyanogenMod/android_external_f2fs-tools
  • mkfs: write the cp page 2 of the checkpoint pack 2 during format --> CyanogenMod/android_external_f2fs-tools
  • mkfs: completely abstract the dev IO during format --> CyanogenMod/android_external_f2fs-tools
  • fibmap: fix wrong block count --> CyanogenMod/android_external_f2fs-tools
  • f2fs-tools: add inline data check --> CyanogenMod/android_external_f2fs-tools
  • Update version on mkfs --> CyanogenMod/android_external_f2fs-tools
  • update-binary: Add collect_backup_data function --> CyanogenMod/android_bootable_recovery
  • BluetoothExt: Fix files for Crowdin --> CyanogenMod/android_packages_apps_BluetoothExt
  • Revert "camera: Add a few missing legacy camera params." --> CyanogenMod/android_frameworks_av
  • Bluetooth: Register new callback for HCI events callback --> CyanogenMod/android_packages_apps_Bluetooth
  • Bluetooth: Synchronise Key release command and Key State. --> CyanogenMod/android_packages_apps_Bluetooth
  • Bluetooth: Remove pending MAP authorization pop up --> CyanogenMod/android_packages_apps_Bluetooth
  • Bluetooth: Map: update proper interrupted state during bt on/off --> CyanogenMod/android_packages_apps_Bluetooth
  • Bluetooth: Add PXP profile reconnection after link loss --> CyanogenMod/android_packages_apps_BluetoothExt
  • Bluetooth: Include remote device name as part of filter list --> CyanogenMod/android_external_bluetooth_bluedroid
  • Bluetooth: Add support to send/receive raw command/event --> CyanogenMod/android_external_bluetooth_bluedroid
  • Fixes BLE LPP monitor callback issue --> CyanogenMod/android_external_bluetooth_bluedroid
  • Bluetooth: Handle invalid packet in incoming stream --> CyanogenMod/android_external_bluetooth_bluedroid
  • Bluetooth: Increase gatt discover service timeout --> CyanogenMod/android_external_bluetooth_bluedroid
  • Bluetooth: Header file changes to add new APIs for Test APK --> CyanogenMod/android_hardware_libhardware
  • ueventd: fix a busy loop while reading uevents --> CyanogenMod/android_system_core
  • gettop: fix symlink detection --> CyanogenMod/android_build
  • clean up unused variables and fix compiler warnings --> CyanogenMod/android_bootable_recovery
  • camera: add support for samsung and htc camcorder modes --> CyanogenMod/android_packages_apps_Camera2
  • Add apns/eri for Boost Mobile --> CyanogenMod/android_vendor_cm
  • Clean up Japanese APNs --> CyanogenMod/android_vendor_cm
  • Allow reading of cpufreq attributes --> CyanogenMod/android_vendor_cm
  • Disable Touch by Proximity Sensor --> CyanogenMod/android_packages_apps_InCallUI
  • DeskClock: Fix missed alarm notification flickering --> CyanogenMod/android_packages_apps_DeskClock
  • Camera2: Fix WB onScreenIndicator when some are settings filtered out. --> CyanogenMod/android_packages_apps_Camera2
  • Show panels on lockscreen in expanded desktop mode. --> CyanogenMod/android_frameworks_base
  • Avoid race condition that gets PanService stuck in STATE_DISCONNECTED. --> CyanogenMod/android_packages_apps_Bluetooth
  • unified-email: sanitize account name --> CyanogenMod/android_packages_apps_UnifiedEmail
  • Use AOSP version of wpa_supplicant_lib --> CyanogenMod/android_hardware_ti_wlan
  • capabilities ERANG error fix --> CyanogenMod/android_external_wpa_supplicant_8
  • nandroid: Allow tar backups of yaffs2 partitions --> CyanogenMod/android_bootable_recovery
  • Hardware: add ColorEnhancement support --> CyanogenMod/android_frameworks_opt_hardware
  • libc: krait: support KINGFISHER optimized memcpy --> CyanogenMod/android_bionic
  • Enable Back-key when go to Emergency call --> CyanogenMod/android_packages_apps_Settings
  • Unicode: Fix mismatched type initialization --> CyanogenMod/android_system_core
  • Fix the issue that the top of fullscreen dialog is clipped away --> CyanogenMod/android_frameworks_base
  • QS: Make it possible to show smaller icons (2/2) --> CyanogenMod/android_packages_apps_Settings
  • Create pop-up dialog for each application --> CyanogenMod/Superuser
  • Fix several compiler warnings --> CyanogenMod/Superuser
  • Fix Trash icon/action bug --> CyanogenMod/Superuser
  • Fix assertion failure --> CyanogenMod/android_system_core
  • Do not just silently fail if surface creation fails --> CyanogenMod/android_frameworks_native
  • Do not show disk errors if they are expected. --> CyanogenMod/android_system_vold
  • Set expanded desktop through profiles (2/2) --> CyanogenMod/android_packages_apps_Settings
  • Set expanded desktop through profiles (1/2) --> CyanogenMod/android_frameworks_base
  • java7: Implement new Locale APIs --> CyanogenMod/android_libcore
  • audioflinger: Power hints for audio activity --> CyanogenMod/android_frameworks_av
  • Fix crash on boot --> CyanogenMod/android_hardware_samsung
Reaktionen: Pr0TuRk38, ChrisFis, ->TopAZ<- und 3 andere
@CryptLoad73
Für mich war die Sache nichts persönliches, daher alles gut
:smile:
Zum Thema der neuen Build:
WOW... was für ein Changelog ! :thumbsup:
Reaktionen: Pr0TuRk38, ->TopAZ<- und Truckerdidi
Kann mir bitte jemand einen Tip geben zum Thema Video Kamera. Diese funktioniert leider nicht. Hab alles an Möglichkeiten ausgeschöpft was mir bekannt war.
Hab eben nochmal die aktuelle Nightly geflasht, aber auch da ohne Erfolg....
Problem ist, das das Bild einfriert und irgendwann die Galerie anhält
@mr bo
Lese mal Seite 37;)
#368 (permalink)
Reaktionen: ->TopAZ<-, ChrisFis, kiwikh und 2 andere
Er kann es einfach nicht lassen aber umso besser ;)
Übrigens soll ich alle von Markox89 grüßen, er dankt den deutschen Usern für den Support :)
Reaktionen: ->TopAZ<-, Fenerli60, kiwikh und 4 andere
Neuste Weekly von INFECTEDBYMARKOX 08.03.2014:love:
cm-11-20140308-INFECTEDBYMARKOX-i9100.zip | ROM by Markox89 for Galaxy S 2
Changelog von Weekly 08.03.2014:
  • Telephony: Fix network selection array --> CyanogenMod/android_packages_services_Telephony
  • [WIP]Settings: Convert AppOps array items to string references --> CyanogenMod/android_packages_apps_Settings
  • Settings: Fix AppOps arrays --> CyanogenMod/android_packages_apps_Settings
  • soundrecorder: Fix crash on devices without external storage --> CyanogenMod/android_packages_apps_SoundRecorder
  • Camera2: Do not issue autofocus cancel if preview stopped --> CyanogenMod/android_packages_apps_Camera2
  • Underp an ifdef --> CyanogenMod/android_system_core
  • Camera: Enable video stabilization setting --> CyanogenMod/android_packages_apps_Camera2
  • Register for WhisperPush during setup wizard --> CyanogenMod/android_packages_apps_CMAccount
  • Skip location settings page if Google account exists --> CyanogenMod/android_packages_apps_CMAccount
  • SystemUI: Only show H+ if config_hspa_data_distinguishable is set --> CyanogenMod/android_frameworks_base
  • Untangle the statusbar for dual sim --> CyanogenMod/android_frameworks_base
  • UiccController: Query GET_SIM_STATUS when radio state is ON --> CyanogenMod/android_frameworks_opt_telephony
  • Fix duplicate request responses. --> CyanogenMod/android_packages_apps_Bluetooth
  • libc: Fix memchr inclusion on scorpion --> CyanogenMod/android_bionic
  • Browser: Fix Progress bar when quick Controls Enabled --> CyanogenMod/android_packages_apps_Browser
  • Clean up preferences --> CyanogenMod/android_external_whispersystems_WhisperPush
  • Notify user of new incoming sessions --> CyanogenMod/android_external_whispersystems_WhisperPush
  • Allow registration to be started from service --> CyanogenMod/android_external_whispersystems_WhisperPush
  • Fix crash when reinstantiating preference fragment --> CyanogenMod/android_external_whispersystems_WhisperPush
  • refresh ui to Holo, removing actionbar --> CyanogenMod/android_packages_apps_CMAccount
  • Fix for positioning of glyphs within a bitmap --> CyanogenMod/android_frameworks_base
  • Release locked buffer when it fails to acquire graphics buffer*--> CyanogenMod/android_frameworks_base
  • Fixed upgrading from forward-lock application to system application --> CyanogenMod/android_frameworks_base
  • Fix graphics corruption caused by HWUI caches --> CyanogenMod/android_frameworks_base
  • Revert "audio: Fix check for sonification on digital docks" --> CyanogenMod/android_hardware_libhardware_legacy
  • settings: Relocate Privacy Guard icons to framework --> CyanogenMod/android_packages_apps_Settings
  • AppOps: Add more operations in app ops settings --> CyanogenMod/android_packages_apps_Settings
  • Block application install from unknown sources through adb*--> CyanogenMod/android_frameworks_base
  • Relocate and cleanup new app ops features and PGify it --> CyanogenMod/android_frameworks_base
  • Use MODE_ASK as the default ops mode in Privacy Guard --> CyanogenMod/android_frameworks_base
  • app ops: New ops, features, and modes --> CyanogenMod/android_frameworks_base
  • Store the value from BOARD_CUSTOM_BOOTIMG_MK to a file --> CyanogenMod/android_build
  • Fix "telephony: DataConnection: support old RILs" --> CyanogenMod/android_frameworks_opt_telephony
  • Add compatibility code with mainline's configuration options for unlock --> CyanogenMod/android_packages_services_Telephony
  • libc: Fix memchr inclusion --> CyanogenMod/android_bionic
  • cm: Move default ringtone override to telephony.mk --> CyanogenMod/android_vendor_cm
  • Trebuchet: fix icons disappearing from the dock --> CyanogenMod/android_packages_apps_Trebuchet
  • audio: Add support for tunnel mode recording and compress voip --> CyanogenMod/android_frameworks_av
  • Replace Cortex A15 strlen implementation with cortex-strings --> CyanogenMod/android_bionic
  • Import memchr implementation from cortex-strings for Cortex A15 --> CyanogenMod/android_bionic
  • Enable StatusBar Brightness control for tablets --> CyanogenMod/android_packages_apps_Settings
  • Add Japanese APNs/eri for au, docomo MVNO, EMOBILE and SoftBank --> CyanogenMod/android_vendor_cm
  • Decrease Vol Panel Transparency --> CyanogenMod/android_frameworks_base
  • Open-source Google Dialer --> CyanogenMod/android_packages_apps_Dialer
  • Send unsol_sim_status on radio_state change --> CyanogenMod/android_hardware_ril
  • Fix headset button double-click hCyanogenMod/andling with screen off --> CyanogenMod/android_packages_apps_Apollo
  • Add setting for system bars visibility on Keyguard in ExpCyanogenMod/anded desktop mode. --> CyanogenMod/android_packages_apps_Settings
  • SamsungQualcommRIL: allow mQANElements to be device specific --> CyanogenMod/android_frameworks_opt_telephony
  • Fix for current activity refresh --> Superuser
  • SystemUI: Fix displaying of user photo --> CyanogenMod/android_frameworks_base
  • bluedroid: remove duplicate BLUETOOTH_QCOM_SW define --> CyanogenMod/android_external_bluetooth_bluedroid
  • Move WhisperPush settings --> CyanogenMod/android_packages_apps_Settings
  • Add preferences activity --> CyanogenMod/android_external_whispersystems_WhisperPush
  • Trebuchet: Decouple iconMask and iconBack dependency*--> CyanogenMod/android_packages_apps_Trebuchet
  • New launcher icon*--> CyanogenMod/android_external_whispersystems_WhisperPush
  • Camera2: Correct copyright notice --> CyanogenMod/android_packages_apps_Camera2
  • core: Remove unused string --> CyanogenMod/android_frameworks_base
Reaktionen: ->TopAZ<-, Truckerdidi, walangoo und 2 andere
Moin!
Jetzt bin ich etwas verwirrt. Ich nehme mal an, die beiden (Infected und Markox) arbeiten nicht zusammen? Oder ist nun das Update von gestern von Markox eine Weiterentwicklung des Updates von vorgestern von Infected?
Chris
Reaktionen: achvio
@ChrisFis
Hi Chris!Der User Markox89 war in Kurzurlaub.Und der Meister Build Macher Infected hat von sich aus eine Build nachgeschoben.Alle beide Roms sind daher vollkommen identisch und die INFECTEDBYMARKOX Rom kann als Update betrachtet werden;)
Gruss
Reaktionen: ChrisFis
@CryptLoad73,
danke ich war auch ein wenig verwirrt ;-)
Schönen Sonntag noch
Gruss Dietmar
Reaktionen: walangoo und ->TopAZ<-
beim Aktivieren von GPS kommt bei mir immer die Abfrage zur Standortfreigabe, die ich ablehnen oder auch zustimmen kann. Egal was ich wähle, beim nächsten Aktivieren erscheint die Abfrage wieder. Ist dies ein Kitkat Feature oder ein CM Bug?
Könnt ihr mir sagen ob Die simpsons : springfield auf der Rom funktioniert?
Danke schon mal.
@Billgehtsnoch
So weit ich weiß ist das bei KK normal.In diesem Fall kein Bug;)
Neuste Weekly von 12.03.2014
cm-11-20140312-INFECTEDBYMARKOX-i9100.zip | ROM by Markox89 for Galaxy S 2
Changelog von Weekly 12.03.2014:
  • InCallUI: Cleanup CAF additions --> CyanogenMod/android_packages_apps_InCallUI
  • VolumePanel: Don't force navigation bar --> CyanogenMod/android_frameworks_base
  • Stk: Cleanup CAF additions --> CyanogenMod/android_packages_apps_Stk
  • Dialer: un-derp the keypad UI --> CyanogenMod/android_packages_apps_Dialer
  • sepolicy: Fix a few denials --> CyanogenMod/android_external_sepolicy
  • overlay: remove Verizon specific eri.xml --> CyanogenMod/android_vendor_cm
  • Settings: Fix value from being overwritten with null --> CyanogenMod/android_packages_apps_Settings
  • roomservice: Add recursive dependencies --> CyanogenMod/android_build
  • trebuchet: build headers from internal adapter instance --> CyanogenMod/android_packages_apps_Trebuchet
  • LockClock: detect default units based on locale --> CyanogenMod/android_packages_apps_LockClock
  • [CMFM] bookmarks and history in a navigation drawer --> CyanogenMod/android_packages_apps_CMFileManager
  • trebuchet: fix custom home transition effect --> CyanogenMod/android_packages_apps_Trebuchet
  • Install PicoTTS to /system/priv-app --> CyanogenMod/android_external_svox
Reaktionen: horst37, ChrisFis, Truckerdidi und eine weitere Person
Mal eine dumme Frage: Wenn ich eine aktuelle TWRP von einer Kitkat drauf habe, brauche ich wohl für diese ROM kein CWM flashen. Unterschied wäre wohl nur bei Backup/Restore relevant?
Hat sich in den letzten Wochen viel bei der Weiterentwicklung von Cyanogen 11 getan?
Oder ist diese Rom so viel besser?
Ich hatte meine ersten Erfahrungen mit Cyanogen mit dem Motorola Defy gemacht.
Da war wohl das teils auch auf CM basierende White Rabbit noch etwas überlegen. Aber das war vor Jahren.
Gastspiele mit dem Galaxy S2 unter Cyanogen 10.1 und 11 führten mich wiederholt zu stabilen und flüssig laufennden Sammys zurück.
Nun wieder ein Versuch mit Linaro/Sabermod und ich bin von Anfang an begeistert.
Danke für diese fabelhafte ROM.
@horst37,
schön zu hören, das Du mit der Rom auch zufrieden bist,
seid es Markox von Infected übernommen hat,
kommen nur 1x pro Wochen Updates aber ich finde das ist auch in Ordnung.
Ich nutze diese Rom von Anfang an und hatte bis jetzt noch keine Probleme.
Ein schönes Wochenende
Gruß Dietmar
Neuste Weekly von 16.03.2014
cm-11-20140316-INFECTEDBYMARKOX-i9100.zip | ROM by Markox89 for Galaxy S 2
Changelog von Weekly 16.03.2014:
  • use different USB PIDs for adb and adb+ums modes --> CyanogenMod/android_bootable_recovery
  • audio: Added lock during closing of direct output --> CyanogenMod/android_frameworks_av
  • Update the GPS tile to use the appropriate location modes --> CyanogenMod/android_frameworks_base
  • Camera: remove fine/normal/superfine jpegquality and use always int --> CyanogenMod/android_packages_apps_Camera2
  • CMFM: New high resolution launcher icons --> CyanogenMod/android_packages_apps_CMFileManager
  • FaceUnlock: Check if faceunlock is disabled --> CyanogenMod/android_frameworks_base
  • DeskClock: Support double-digit hours for timers --> CyanogenMod/android_packages_apps_DeskClock
  • Hide Titlebar while loading InCallUI (2 of 2) --> CyanogenMod/android_packages_apps_InCallUI
  • Hide Titlebar while loading InCallUI (1 of 2) --> CyanogenMod/android_packages_apps_Dialer
  • Handle album and artist view intents --> CyanogenMod/android_packages_apps_Apollo
  • Fix resource IDs being added to the android namespace --> CyanogenMod/android_packages_apps_Settings
  • Fix UXD for tablets --> CyanogenMod/Superuser
  • Remove QuickSearchBox from build --> CyanogenMod/android_build
  • Settings/Wifi: Add support for Ad-hoc (IBSS) networks --> CyanogenMod/android_packages_apps_Settings
  • MSimPhoneFactory: use custom RIL class --> CyanogenMod/android_frameworks_opt_telephony-msim
  • telephony: MSim: propagate roaming and data settings to SIM --> CyanogenMod/android_frameworks_opt_telephony
  • Settings: use CMHW serial number for MSim --> CyanogenMod/android_packages_apps_Settings
  • RIL: mark mInstanceId as protected --> CyanogenMod/android_frameworks_opt_telephony
  • Don't fetch deleted messages from IMAP folder --> CyanogenMod/android_packages_apps_Email
  • Don't recreate keyguard for MCC/MNC changes --> CyanogenMod/android_frameworks_base
  • bta_hh: Change bus_type to BUS_USB for USB HCI --> CyanogenMod/android_external_bluetooth_bluedroid
  • Send out USER_PRESENT broadcast on screen on if lockscreen is disabled --> CyanogenMod/android_frameworks_base
  • Don't let apps disable the SIM PIN entry screen --> CyanogenMod/android_frameworks_base
  • Buttons: Allow disabling hard navigation keys --> CyanogenMod/android_packages_apps_Settings
  • Runtime toggle of navbar --> CyanogenMod/android_frameworks_base
  • HAF: Add KeyDisabler stub --> CyanogenMod/android_frameworks_opt_hardware
  • ifdef "stagefright: Enable GraphicBuffer usage to decoder before querying formats" --> CyanogenMod/android_frameworks_av
  • SystemUI: reactivate WiFi activity indicators --> CyanogenMod/android_frameworks_base
  • libstagefright: Add NULL check for mHFRRatio --> CyanogenMod/android_frameworks_av
  • SamsungQualcomm: Skip new requests on old RILs --> CyanogenMod/android_frameworks_opt_telephony
  • SystemUI: fix calculating alpha for back button in landscape mode --> CyanogenMod/android_frameworks_base
  • DcTrackerBase: Dont provision APN if default is disconnecting --> CyanogenMod/android_frameworks_opt_telephony
  • SystemUI: Set Status bar opaque during drawer pulldown on tablets only --> CyanogenMod/android_frameworks_base
  • telephony: Fix initialization ordering of SMS middleware --> CyanogenMod/android_frameworks_opt_telephony
  • vendor/cm: We are at CM11 now --> CyanogenMod/android_vendor_cm
  • Mms: Cleanup CAF additions --> CyanogenMod/android_packages_apps_Mms
  • Fix ellipsizing of emoji symbols in StatisLayout --> CyanogenMod/android_frameworks_base
  • Revert regressions introduced by QRD update --> CyanogenMod/android_packages_apps_SoundRecorder
  • telephony: Clean up IccSmsInterfaceManagerProxy --> CyanogenMod/android_frameworks_opt_telephony
  • fix fread buffer has no terminating null string --> CyanogenMod/android_bootable_recovery
  • Camera: video stabilization setting - don't default enable --> CyanogenMod/android_packages_apps_Camera2
  • media_profiles: the HFR parameters don't need to be mandatory --> CyanogenMod/android_frameworks_av
  • Settings: Day and week on data usage cycle (2/2) --> CyanogenMod/android_packages_apps_Settings
  • frameworks/base: Day and week on data usage (1/2) --> CyanogenMod/android_frameworks_base
  • Tethering: fix NPE when retrieving active interfaces --> CyanogenMod/android_frameworks_base
  • camera: Histogram, ZSL burst mode, HDR-on-ZSL --> CyanogenMod/android_packages_apps_Camera2
  • camera: Add metadata-based ASD --> CyanogenMod/android_packages_apps_Camera2
  • Camera2: Fix burst mode, auto scene detect layout --> CyanogenMod/android_packages_apps_Camera2
  • settings: Put MSIM files in the right place --> CyanogenMod/android_packages_apps_Settings
  • telephony-msim: Fix package errors --> CyanogenMod/android_packages_services_Telephony
  • telephony-msim: Fix package issues --> CyanogenMod/android_frameworks_opt_telephony-msim
  • msim: Put files in the corret location --> CyanogenMod/android_packages_apps_InCallUI
  • Camera2: Smart scene icons w. original artwork --> CyanogenMod/android_packages_apps_Camera2
  • MMS: Disable Android 4.2 specific hack regarding keyboard behavior --> CyanogenMod/android_packages_apps_Mms
  • National roaming for Telfort in the Netherlands --> CyanogenMod/android_frameworks_base
  • Fixed stylus eraser being rejected by palm rejection --> CyanogenMod/android_frameworks_base
  • telephony: Remove CdmaLteUicc and CDMA fix --> CyanogenMod/android_frameworks_opt_telephony
  • SystemUI: Update Ringer tile code --> CyanogenMod/android_frameworks_base
  • Service: Keep services needing restart --> CyanogenMod/android_frameworks_base
  • Fix crash in network mode settings --> CyanogenMod/android_packages_services_Telephony
  • overlay: add tmo and att default LTE apns --> CyanogenMod/android_vendor_cm
  • PackageManager: Fix reconnection logic in Installer --> CyanogenMod/android_frameworks_base
  • telephony: disable the use of SMS_EXPECT_MORE by default (1/2) --> CyanogenMod/android_frameworks_base
  • telephony: disable the use of SMS_EXPECT_MORE by default (2/2) --> CyanogenMod/android_frameworks_opt_telephony
Reaktionen: Truckerdidi und ChrisFis
Rufuz66
Rufuz66
fireburner
F0x123
Nick Knight
Sir Charles
Sir Charles
