CryptLoad73
Nightly von 10.02.2014
Goo.im Downloads - Downloading cm-11-20140210-INFECTED-i9100.zip
Changelog von Nightly 10.02.2014:
- Fix pthread_create error handling in ril --> CyanogenMod/android_hardware_ril
- Revert "AudioMixer: Remove tracks from enabledTracks after reseting outTemp" --> CyanogenMod/android_frameworks_av
- Stop the kernel complaining about rild --> CyanogenMod/android_hardware_ril
- Remove an outdated hack --> CyanogenMod/android_hardware_ril
- libstagefright: unbreak hardware OMX on OMAP3 --> CyanogenMod/android_frameworks_av
- chromium: clear favicon bitmap prior to load an url --> CyanogenMod/android_external_chromium_org
- Settings: Hide left handed nav option in tablet --> CyanogenMod/android_packages_apps_Settings
- Replace removed NARROW_COLUMNS layout mode with TEXT_AUTOSIZING --> CyanogenMod/android_packages_apps_Browser
- [1/2] Left handed navbar during landscape mode --> CyanogenMod/android_packages_apps_Settings
- Settings LightSettingsDialog: update led on text change --> CyanogenMod/android_packages_apps_Settings
- BrowserSettings: update desktop UA string to match Chrome 30 --> CyanogenMod/android_packages_apps_Browser
- deskclock: split alarm settings into 2 lines for portrait phone devices --> CyanogenMod/android_packages_apps_DeskClock
- Camera: Fix saturation, contrast, sharpness parameters --> CyanogenMod/android_packages_apps_Camera2
- InCall full screen photo --> CyanogenMod/android_packages_apps_InCallUI
- Fix recovery reboot command by adding the init sys.powerctl property control --> CyanogenMod/android_bootable_recovery
- DisplaySettings: Add hardware-framework support for tap-to-wake --> CyanogenMod/android_packages_apps_Settings
- [2/2] Framework AppOps: Forward port ops from cm-10.2 --> CyanogenMod/android_frameworks_base
- Fix mkfs.f2fs calling in roots --> CyanogenMod/android_bootable_recovery
