[ROM][I9100][5.0.2][LP] *19.03.15* Beanstalk 5.0050 [FINAL][STABLE]
  • 22 Antworten
sourly
sourly
Update !!!
Features:
  • CM based
  • Lockscreen background options (Color fill, Custom image, Transparent)
  • Customizable Lockscreen text color
  • Lockscreen rotation
  • Option to enable all widgets
  • Minimize lockscreen challange
  • Use widget carousel
  • Slider Shortcuts
  • Static Lockscreen shortcuts
  • Lockscreen button actions
  • LCD Density
  • Scroll elasticity options
  • Default App grip option
  • Custom Carrier label
  • Dual Pane options
  • Customizable boot animation (off, default, set your own bootanimation)
  • Custom original BeanStalk Wallpapers by skyliner33v
  • Custom BeanStalk bootanimation by skyliner33v
  • Status bar color and transparency
  • Clock and date options which includes color, location, style
  • Signal Styles which include color and text instead of icons, alternate GB signal layout, hide signal icons
  • Breathing SMS option
  • Battery styles - Includes specific colors and styles. Also includes battery bar
  • Do not disturb option
  • Show notification count
  • Pie controls (need to have lockscreen background set to something other then default to work correctly (dont ask why) )
  • Fully customizable navigation bar - Includes style, layout, color, nav rings, pretty much everything you can think of.
  • Quick settings color settings, tiles per row, Quick pulldown, text color
  • Notification shortcuts, behaviour, drawer style (customizable colors), toggle colors, longpress quicksettings icon to enable/disable toggles
  • Keyboard and input method options which include disable full screen keyboard and auto rotate
  • Kil app back button with customizable timeout values
  • High end graphic effects option
  • option to disable/enable vibrate on expand for notifications alerts
  • Low battery warning customizable options
  • Recents RAM bar fully customizable with color styles
  • Clock widget for LockClock including extra options to fully customize every feature of the lockclock
  • Build.prop MOD options to enable/disable tweaks as preferred
  • Less frequent Notification sounds options
  • CRT screen off/on options to specify how the animation shows
  • Enable/disable wake up on charge option
  • Superuser fully embedded into the build and accessed from settings menu
  • CM Performance options and features
  • About BeanStalk option with links to github source and facebook for beanstalk. Also links to my twitter and donate.
  • insane amount of edits/tweaks/fixes to make this build absolutely fly
  • option to use a fully themable MMS packages. You can access from mms - settings - theme settings
  • Numerous other options hidding throughout the build
Please keep in mind some of the above features may not yet be fully ported into lollipop..
Download:
https://www.androidfilehost.com/?fid=95916177934543676
Gapps
https://www.androidfilehost.com/?w=files&flid=22782&sort_by=date&sort_dir=DESC
Super SU 2.46
SuperSU Download
Die `pico Gapps`werden vom Entwickler empfohlen, da das System ansich schon sehr viel Platz in Anspruch nimmt.
Flashanleitung:
1. Mache einen Fullwipe!
2. Nehme die CWM 6.0.4.5 Recovery oder höher
3. Flashe die ROM (könnte 5-10 Minuten dauern, einfach warten, es wird geflasht)
4. Flashe Die Gapps
5. Flashe Root (Diese ROM ist nicht pre-rooted! Wenn du Root haben willst musst du die super-su zip von oben flashen)
6. Reboot
Link zum XDA-Thread: [ROM][5.0.2][21/01/15]Beanstalk I9100 Unoffi… | Samsung Galaxy S II I9100 | XDA Forums
Reaktionen: felymm, Pompom, beicuxhaven und 2 andere
@sourly
Da hast Du Dir ja viel vorgenommen,
3 aktuelle Rom Threads gleichzeitig pflegen.
Ich könnte kaum einen Tagesaktuell halten.
Arbeit/Freundin etz.
Danke das Du es versuchst.
Gruß Nick
Reaktionen: sourly und beicuxhaven
@sourly
Vielen Dank für die Mühe die du dir machst :thumbup:
Habe den Threadtitel und Opener mal noch ein wenig angepasst. Bitte immer den Link zum XDA-Thread angeben und auch trotzdem nochmal die Flashanleitung da Neulinge nicht unbedingt erst noch andere Threads durchlesen wollen ;)
Danke & Grüße
Tja lesen bildet geht mir auch so :thumbup: Trotzdem Danke für die Hilfe:thumbsup:
Update siehe Startpost !! :thumbup:
Reaktionen: j1gga84
@sourly
Würde ROM gerne mal flashen.
Lohnt sich ein Versuch oder sollte man besser noch etwas abwarten?
Hab sie selber noch nicht geflasht,aber bis in der nächsten Stunde:winki:
Inzwischen geflasht ,am Anfang musste ich mehrmals beim Wifi den Key eingeben.Bisher recht zufrieden,auch die Kamera mit Photosphere installiert,funktioniert mit aufzeichnen :thumbup: Einziges Problem seit einigen Tagen und das bei jeder LollipopRom das Spiel Real Race 3 läuft nicht mehr:sad:.Als Kernel hab ich den Apolo Beta3 mit ApoloConfig :sleep:
Reaktionen: Nick Knight, achvio und j1gga84
OK, danke. Habe Rom mittlerweile auch geflahst. Die Installation verlief problemlos.
Mein erster Eindruck ist super. Alle von mir bevorzugten Apps laufen ohne Abstürze.
Mach mich nun an die Einstellungen, die ja sehr umfangreich sind.
Reaktionen: sourly
Also nach cm12, Omni und RR läuft jetzt die Beanstalk am flüssigsten auf meinem S2. WiFi ohne Probleme, Llama kann es an und aus schalten, wie der Accu Verbrauch ist, werde ich sehn.
Reaktionen: 315592 und sourly
Ich benutze keinen der Standardlauncher,sondern den Novalauncher mit dem ich sehr zufrieden bin.
Allerdings seit den Anfängen von den LollipopRoms,muss ich immer nach einem Neustart die einstellten
Apps wieder aktivieren (grauer Hintergrund)
ebenso benutze ich die Swiftkey Tastatur,die man auch nach einem Neustart wieder einstellen muss.
Denke da werden die Settings nicht richtig abgespeichert :sleep:
Bin von der Beanstalk wieder zurück zur Remix.
Die Beanstalk lief 2-3 Tage gut, hatte aber, ohne irgendwelche Einstellungen verändert zu haben, von jetzt auf gleich keine Mobildatrenverbindung mehr.
Konnte die Ursache leider nicht finden. Nach dem restoren eines vorhandenen Backups und anschließenden Reboot blieb mein S2 am Startbilschirm hängen.
Reaktionen: sourly
Scheinbar hab ich diesen Thread in der falschen Sparte (CyanogenMod/AOSP)bitte verschieben :scared::thumbup:
Geht ab..
Update !!! vom 11.2. :thumbup:
Reaktionen: 315592
Update 26.02. !!!!
Reaktionen: j1gga84
Update 19.03. !!!
Aber wohl letztes ,dann 5.1 :thumbup:
Reaktionen: j1gga84
Hallo, ich möchte auf meinem SGS2 eine neue Firmware installieren, kenn mich aber nicht gut damit aus.
Ist das SGS2 nach dem flashen (Lollipop) automatisch gerootet?
Gibt es auch Lollipop für das SGS2 in deutsch?
Danke für eure Hilfe!
SGS2
Hallo SgF21,
Nunja da ich nicht weiß wie gerne Du liest um Dir hier im S2 I9100 Bereich das Grundwissen zum flashen anzueignen geschweige wie experimentierfreudig Du bist, kann ich Dir erstmal nicht empfehlen direkt mit Lollipop anzufangen. Dann doch erstmal mit KitKat da gibt es die ausgereiften Kernels und ROM'S.
Gruß Nick
Hallo Nick,
ich bräuchte nur die Links für die Firmware usw.
Mit dem Flashen, denke ich klappt das schon.
Nochmals meine Fragen:
Gruß SGS2
