[ROM][I9100][4.4.2] *21.04.14* Beanstalk [Unofficial]
  • 142 Antworten
Pr0TuRk38
Pr0TuRk38
Dauer-User
1.551
Beanstalk ROM
Features
CM based
Lockscreen background options (Color fill, Custom image, Transparent)
Customizable Lockscreen text color
Lockscreen rotation
Option to enable all widgets
Minimize lockscreen challange
Use widget carousel
Slider Shortcuts
Static Lockscreen shortcuts
Lockscreen button actions
LCD Density
Scroll elasticity options
Default App grip option
Custom Carrier label
Dual Pane options
Customizable boot animation (off, default, set your own bootanimation)
Custom original BeanStalk Wallpapers by skyliner33v
Custom BeanStalk bootanimation by skyliner33v
Status bar color and transparency
Clock and date options which includes color, location, style
Signal Styles which include color and text instead of icons, alternate GB signal layout, hide signal icons
Breathing SMS option
Battery styles - Includes specific colors and styles. Also includes battery bar
Do not disturb option
Show notification count
Pie controls (need to have lockscreen background set to something other then default to work correctly (dont ask why) )
Fully customizable navigation bar - Includes style, layout, color, nav rings, pretty much everything you can think of.
Quick settings color settings, tiles per row, Quick pulldown, text color
Notification shortcuts, behaviour, drawer style (customizable colors), toggle colors, longpress quicksettings icon to enable/disable toggles
Keyboard and input method options which include disable full screen keyboard and auto rotate
Kil app back button with customizable timeout values
High end graphic effects option
option to disable/enable vibrate on expand for notifications alerts
Low battery warning customizable options
Recents RAM bar fully customizable with color styles
Clock widget for LockClock including extra options to fully customize every feature of the lockclock
Build.prop MOD options to enable/disable tweaks as preferred
Less frequent Notification sounds options
CRT screen off/on options to specify how the animation shows
Enable/disable wake up on charge option
Superuser fully embedded into the build and accessed from settings menu
CM Performance options and features
About BeanStalk option with links to github source and facebook for beanstalk. Also links to my twitter and donate.
insane amount of edits/tweaks/fixes to make this build absolutely fly
option to use a fully themable MMS packages. You can access from mms - settings - theme settings
Numerous other options hidding throughout the build
_______________________________________________
Installation
Installation:
0. BackUp anlegen
1. Neustart in ein aktuelles Recovery
2. Wipe Data/Factory Reset
3. Wipe Cache partition
4. Wipe Dalvik Cache
5. Format System
6. ROM.zip flashen
7. GoogleApps.zip flashen
9. Neustart und Willkommen bei der Beanstalk ROM !
Installation von einer vorherigen Beanstalk ROM:
1. Neustart ins Recovery
2. Wipe Cache/Dalvik Cache
3. Rom flashen
4. Wipe Cache/Dalvik Cache
5. Neustart !
Downloads
Beanstalk ROM 4.4.2 (Amazon Cloud Mirror)
Google Apps:
Google Apps Core
Changelog:
Code:
9/3/14
* Fixed wifi issue, everything should work fine now :)
* other changes, check out scott's git for changes
BeanStalk 4.4.247 - 2/11/2014
Added PIE - All credit to slimrom devs
Added BS Platlogo (thanks skyliner for drawables)
Port SmoothProgressBar: User Custom ProgressBar Setting - thanks hany
Cleaned up display settings
Large recents
recents background color
Fixed tablet menus
Improve apps ops detail screen
Added chameleon Gesture anywhere (thanks hany for the port job)
Added back xposed app
Add option to access xposed from settings - Thanks Hany
Plenty more, but im tired and going to bed.
27/1/14:
* Removed unneeded apps such as BeanstalOTA (not supported) and launchers to save space
* synced to latest tree
More updates Here
BeanStalk 4.4.225 - 1/21/2014
* Fixed languages
BeanStalk 4.4.225 - 1/20/2014
* Forward ported theming options for MMS app
- Includes fully customizable theming options for conversation list and message view
- Removed TDRS compatibility since theme is fully customizable
- Set default bubble theme with kitkat UI colors in mind
* Favorite contact tile
* Smart pulldown
* Fixed navring longpress options
* Fixed accessibility force close
* Fixed zero percent battery tile
* Quicksettings - Quick collaps
* Home and menu unlock options
* button longpress lockscreen options from CM
* lockscreen battery percentage options
* Glowpad torch
* Telo Radio (option to customize mobile data during specific events - settings - more - connection manager)
* Listanimation views and interpolator
* Text signal display option
* Text signal color option
* Signal hide option
* Vibrate notification expand
* Custom tiles
* LTE power widget/quicksettings tile fixes
* More AD fixes
* Flip to Mute/Reject Call
* CM sources merged
* Plenty of small fixes around the build
BeanStalk 4.4.215 - 1/10/2014
* Removed goomanager and added BeanStalkOTA app. OTA updates for GAPPs and ROM updates. Huge thanks to the PA team as I used their base OTA package to get started. Please keep in mind that this will only find updates if your device maintaner uploads to the official beanstalk goo account.
* Setup change log webpage at http://www.scotthartbti.com/index.php/beanstalkbuilds/
* Couple of fixes to Active Display
* Added option to view rambar in GB instead of MB
* Changed the busy dialog animation font to match 4.4 UI
* Added Misc features under lockscreen menu which include the following:
- Lockscreen blur
- Lockscreen blur radius
- Lockscreen transparency
- Lockscreen rotation
* Option to set signal icon to either LTE or 4g
* Forward ported notification drawer brightness slider
* Added Gesture navigation
* Added longclick switchbutton
* Sleep Screen shortcut
* Option to set the phone to 2g while screen is locked to save battery
* Hidden 'android animation' planted somewhere secretely in the build
* Added system update to about phone. Setup to point to BeanStalkOTA
* Forward ported sound settings
* Forward ported power connect/disconnect
* Added Stylus gesture features
* Tons of UI fixes and improvements to better suite the 4.4 theme
* Tons of misc fixes and imrpovements throughout.
9/1/14 -
* Huge Camera update with lots of new settings plus external/internal storage selection for video/photo
More updates Here
8/1/14 -
* Fixed sound recording issues that caused video and memo recording to crash
5/1/14 -
* option to use floating window for quick settings
* add never sleep screen mode
* notification drawer brightness slider
* Configurable LTE icon into 4G instead
* couple pick fixes
* Revert "option to use floating window for quick settings
* Storage Settings: Allow user to trigger a volume rescan …
More updates Here
3/1/14 -
* fix non instrusive incallui layout
* make launcher icon match the new google green color
* Revamp DSP Manager
* fix italian and french translation
More updates Here
31/12/13 -
BeanStalk 4.4.205 -
* Added CPU info option (developer settings)
* Fast Torch option (controlled by holding power button when screen is off)
* Added IME features (languages and input settings)
* Made clear recents button configurable
* Ported circle memory meter for recents
* SlimROM chamber of secrets option (developer options)
* Quick sound record title
* Updated TRDS with newer drawables
* Updated brightness status bar slider code
* New screen record built in app with customizable options from beanstalk display options
* Screen record option can also record audio
* Made the power menu profile switcher optional and fixed the implementation which allows it to follow current power menu style layouts that the user defines. (disabled by default)
* Added screen recorder power menu option (disabled by default)
* Double tap to sleep gesture
* Expanded TRDS to numerous system apps
* MMS bubbles from slimrom
* NUMEROUS fixes and improvements throughout.RL]
Bugs
Links
Beanstalk ROM XDA-Thread
Es wird keine Haftung für eventuelle Schäden übernommen. Flashen geschieht auf eigene Gefahr!
Reaktionen: Feed Me, DerHaarKiller, lecter1 und 8 andere
Hi.
Hab die Rom auch schon seit über ne Woche drauf und bin einfach nur begeistert. Läuft einwandfrei. Auch mit nem anderem Kernel (gustavo/apolo).
Für die, die es brauchen, ART läuft auch mit dieser Rom.
Es gibt jeden Menge Optionen zum einstellen und es laufen auch wirklich alle.
Also ich bin wirklich begeistert von dieser Rom. Meiner Meinung die bislang beste KitKat Rom. Sollte wirklich jeder mal antesten!
:thumbup::thumbup::thumbup:
Reaktionen: Pr0TuRk38
Hatte diese Rom auch kurz drauf.
Lief wirklich super und super Funktionen.
Aber mir war diese eindeutig zu wenig eingedeutscht ;)
Reaktionen: hsvl1ve
Hallo !
Die Beanstalk kommt heute noch mit einem update,laut xda :thumbup:.Hab aber im Moment ein anderes Problem.Ich versuche über einen Mhl-Adapter das Bild 1:1 auf den TV zubringen.Bei einem 4.1.2 Custom Rom (z.B. Biftor v14)geht es.
Bei dieser 4.4.2 geht es nicht.Mein Verdacht ist,es liegt an der Rom da kein offizielles Rom ist.
Oder gibt es eine andere Möglichkeit ? TV ist über Router im Wlan,ist DLNA fähig.Die 4.4.2 sollte das doch können (Miracast)? Wahrscheinlich hinterdenke ich mich nur:blink:
Weiss jemand einen Rat und falls ich hier im verkehrten Forum bin entschuldige ich mich hiermit :unsure:
P.S. Bin im Moment auf dieser[ROM][4.4.2][ART][STABLE] CeleriterRom v2.2 [04 JEN 2014][I9100] - xda-developers auch sehr guten Rom
Der MHL-Adapter läuft nur mit offiziellen Samsung-Roms. Samsung hat zwar mittlerweile die Sources dafür veröffentlicht, aber die Portierung ist wohl sehr schwer und dauert.
Wie du Filme etc auf deinen Fernseher bekommst, erfährst du über die Board- und Googlesuche ;)
Die neue Nightly ist verfügbar. Links + Changelog aktualisiert
das ist auch meine Erfahrung, hatte die auch kurz drauf
Deutsch sollte schon sein
Neue Nightly mit gefixter Sound + Video + Memo Recording ist erschienen.
Ich habe nun auch mal den Versuch gewagt.
Mein erstes Problem: Finde die richtige Tastenkombination für Download- und Recovery-Modus bei Samsung wieder heraus xD (länger nicht mehr verwendet)
Danach hat alles gut geklappt. Philz-Kernel geflashed, danach das CWM aktualisert und schlussendlich nach Anleitung vorgegangen.
Nach dem ersten Start reagierte der Touchscreen nicht, also Neustart gemacht und danach gings. Das Wischen bei der Google Tastatur scheint nicht zu gehen. Ich swipe zwar, aber die Wörter erscheinen danach nicht. Tippen geht allerdings.
Bis dato kann ich sagen, läuft gut und stabil. Mal schauen, ob ich mein S2 irgendwann noch mal lieben lerne...
Ganz vergessen. Einige Apps sind trotz deutscher Sprache noch in Englisch, unteranderem die Einstellungen. Vielleicht kommt da noch eine Übersetzung.
Mal eine kurze Frage, an die anderen Nutzer dieser ROM. Wenn ihr die neue Version von heute via CWM flashed, wird bei euch auch ein Werksreset gemacht oder habe ich den ausversehen vorhin mitgemacht?
Bin mir nicht ganz sicher, daher meine Frage. War auch nicht dramatisch, weil ichs aktuell eh nur teste.
Nee....!
Okay, grade nochmal geflashed. War mein Fehler mit dem Factory Reset.
Links + Changelog aktualisiert. Update ist empfehlenswert.
ich habe diese Rom heute in neuster Version mal wieder aufgespielt. Die BS ist ja von den Einstellmöglichkeiten besonders zum modden, mit das Beste an KitKat Roms. Nur leider hat sich mit der Eindeutschung der Menüführung nichts getan, da nutzen die vielen Möglichkeiten nichts, wenn ich als nicht englisch sprechender Erdenbürger das alles nicht eindeutig zuordnen kann.
Ich für mich habe daher die Rom wieder runter gehauen, eine eindeutige deutsche Menüführung ist mir zu wichtig, da man mit den falschen Klicks auf viel dazu beitragen kann, das das System nicht rund läuft
Reaktionen: picsle
Hilfe!
Ich komme nicht weiter. Nach dem Flashen der aktuellen Beanstalk bleibt der Startvorgang beim Samsung-Schriftzug stehen.
Ich komme von der CM11 unofficial von milaq (Stand 24. Jan). Ich bin halt neugierig wie sich diese ROM auf meinem S2 macht.
Zuvor über CWM (version 6.0.4.7) Backup gemacht, data / factory wipe sowie system wipe (wie unter #1 beschrieben). Die ROM und die entsprechende GApps geflasht.
Auf der xda-Seite wird es folgendermaßen beschrieben:
Instructions:
1. Wipe data/cache using philz recovery
2. wipe system
3. flash rom
4. flash gapps
Change Log
Liegt hier der Hund begraben?
Ich nutze das CWM Recovery und als Kernel 3.0.64-CM-g992f0e8 jenklins@exnet.me Fri Jan 24
Brauche ich etwa auch einen anderen Kernel für Beanstalk?
In der Zwischenzeit habe ich mein Backup wieder eingespielt, um wieder erreichbar zu sein. Vielen Dank im Voraus.
Liebe Grüße
Lizzy1965
data/factory Reset und anschließend format system. Danach dann alles beides Flashen. Sollte normalerweise auch funktioneren.
Warum versuchst du nicht die Installationsanweisung im Opener?
