[ROM][I9100][4.3] *15.08.13* SuperNexus 3.0 Build 1
  • 8 Antworten
SchalkerJung1984
SchalkerJung1984
26
Hallo, hier ist die Supernexus 3.0 ROM basierend auf Android 4.3 :thumbup:
Ich, Android-Hilfe.de oder die Entwickler der ROM, übernehmen keine Haftung für mögliche Schäden an eurem Gerät!
Ihr seid daher für euer Handeln selbst verantwortlich!!!
System Details:
  • Android 4.3 Jelly Bean (JSS15J - Android-4.3_r2.1)
  • Latest CM Kernel
  • All Jelly Bean Features and Apps (Nothing excluded from AOSP)
  • No Visual Changes!
  • Stock Jelly Bean Look and Feel
  • This will turn your Samsung Galaxy S II into a Nexus 4
ROM Features:
  • Fully Deodexed
  • Zipaligned APKs
  • Rooted (Super SU)
  • BusyBox Installed
  • No 3rd Party App
  • ZERO Bloatware
  • Android Source Code vastly improved and optimized (i.e. Bionic, Dalvik, Webkit, Framework, libcore, SQlite etc)
  • Official JellyBean bootanimation
  • Init.d Support
  • Rsync Support
  • UserInit Support
  • Bash & Nano Support
  • Native SIP/VOIP Support
  • OpenSSH Support (ssh, sshd, scp, stfp)
  • HSPA+ Support
  • OpenVPN Support
  • Ad-Hoc Network Support
  • exFAT and NTFS-3G support
  • EXT4 File System Optimizations
  • Large APN & SPN List
  • SELinux enabled
  • Framework Features:
    -Extended Power Menu (Reboot, Recovery, Download & Screenshot Options)
    -Improved Scrolling Cache
    -Tweaked Animation Values Of Progress Spinners (Silky Smooth Loading Spinners)
    -Enabled Rotation Lock Tile in Quick Settings for Phones (Previously was only enabled on Tablets)
    -Increased Lockscreen Widget limit from 5 to 9
    -Options for switching between USB Mass Storage and MTP/PTP (On Specific Devices)
  • Browser Features:-
    -Increased Maximum Tab limit from 16 to 64
    -Incognito Tab Option (When long pressed on an URL)
    -Option To Close All Tabs With One-Click
    -Allowed Any Type Of File To Be Downloaded
    -HTML5 WebSockets
  • Phone Features:-
    -Noise Suppression
  • Miscellaneous Features:
    -Allowed Installation Of Apps From Unknown Sources By Default
    -Disabled Data Roaming By Default
    -Dialer auto-complete enabled by default (Stock T9 dialer)
    -Removed Google's Software Updates Option from Settings
    -Enabled Gesture Input By default
    -Hardware Information of the device (Settings>About Device>Hardware Information)
Bekannte Fehler
  • Minimale Grafik Probleme
Screenshots:
Installation
Erstinstallation von SuperNexus 3.0 oder Ihr kommt von einer anderen ROM:
- Kopiert die Google Apps und die SuperNexus ROM auf Eure SD Karte, Intern oder Extern, das ist egal
- Boot into Recovery (Volume up + Home + Power)
- Macht einen DATA WIPE / FACTORY RESET (andererseits, bleibt Euer Gerät hängen)
- Flash SuperNexus ROM
- Flash Google Apps
- Startet das Handy neu
Upgrading von SuperNexus 2.0:
- Boot into Recovery(Volume up + Home + Power)
- Wipe Cache
- Wipe Dalvik-cache
- Flash Google Apps
- Reboot
Downloads
Hotfile.com: 1-CLICK Dateihoster: SuperNexus-3.0-i9100-BUILD1.zip
Goo.im Downloads - Downloading gapps-jb-20130813-signed.zip
Credits:
  • Simon Brunton - Website (Graphic Designer)
  • Google
  • CyanogenMod Team
  • Teamhacksung
  • Codeworkx
  • Xplodwild
  • Nebkat
  • Espenfjo
  • Pawtip
  • Chainfire
  • Thanks to all those who donated
Quelle: http://forum.xda-developers.com/showthread.php?t=2407449
Reaktionen: djkeno, beicuxhaven, mastakilla und 5 andere
Reaktionen: darth_mickrig
Vor allem, weil 95% des xda-Threads übernommen wurden und wie wir alle gelernt haben, ist das nichts so erlaubt.
Rom mal geflasht und wollte meine Meinung hier dazu äußern.
Bei mir läuft die Rom bisher sehr stabil, keinerlei Reboots oder FCs. Die oben erwähnten Grafik Probleme stören eigentlich nicht.
Bei bekannten Bugs würde ich noch hinzufügen das die Galerie App nicht korrekt funktioniert und Bilder nicht anzeigt. Abhilfe schafft ihr z.B. die QuickPic App aus dem Play Store, die ich persönlich als super Alternative für die Standard App seh. Was in dem Zusammenhang mich am meisten stört ist dann das Problem mit der Kamera, hier kann man dann leider nicht mehr die Bilder durch sliden anschauen weil dort ja da Standard Galerie App aufgerufen wird.
Soweit mein Fazit, mal schauen wie sich die Rom die nächsten Tage schlägt - von den 4.2.x Builds war ich auf jedenfall schon begeistert :)
Anbei noch ein paar Screenshots :)
Andi
muss auch sagen das sie stabil läuft nur die kamera will manchmal nicht.
Die ROM ist perfekt weil ich noch nie eine ROM hatte die nach eine woche immer noch 11000 Punkte im benchmark hatte.. Sie ist schlicht und einfach perfekt..
Wir an der Supernexus noch gearbeitet oder ist das Projekt still gelegt?
