Sky
Krass, die neuen GAPPS sind aus der Zukunft, oder aus Australien
finnq schrieb:Kann ich nur empfehlen! Die sind echt Klasse, flashen!
Changes:
* Adds Jelly Bean Youtube (not available in Google Play Store).
* Adds TalkBack (Accessibility app).
* Adds Jelly Bean Gmail with two-finger expansion.
* Add libpatts_engine_jni_api.so to fix Google Maps not announcing street names.
* Adjust install and update scripts to remove source-built QuickSearchBox.apk (Search) and replace with Velvet.apk (renamed as QuickSearchBox.apk). This prevents the user from ending up with two Search apps.
* Still no good way to fix Gallery not syncing to Picasa without ending up with a second gallery app.
Sky schrieb:Krass, die neuen GAPPS sind aus der Zukunft, oder aus Australien![]()
