Q
QuesT
It is unofficial and unsupported by the CyanogenMod team. This ROM is mainly for developers/testers/advanced users - people who are aware that this ROM is incomplete. I'm really not interested in hearing whining about non-working things (and questions when they will be fixed), actually I couldn't care less if you have issues with this ROM.
There's instructions/sources in the third post to build CM10.1 yourself. If you must have something fixed right now - you better do it yourself.
You'll need at least 160mb system partition for the ROM and gapps to fit. Both gen1->gen2 and G2 TPTs are available at Amphoras' TPT Helper.
Working:
Link: [DEV][ROM][1.1.] CyanogenMod 10.1 (Android 4.2.1) - ZTE Blade / Libra ROMs & ROM customisation - MoDaCo
_____________
Changelog
29.3.2013 changelog:
6.3.2013 changelog:
10.2.2013 changelog:
29.1.2013 changelog:
19.1.2013 changelog:
Download:
cm-10.1-20130329-KonstaKANG-blade.zip
http://www.mediafire...jibb4nlfaan9w44 (mirror)
md5:fe14bbd451e952abf881857d59d27b3f
gapps-jb42-20130307-KonstaKANG.zip
http://www.mediafire...ss5khtjf9a5v4s9
md5:8545baba12c25aab6c849595eb96827d
Working:
- Wifi
- RIL (mobile network & data)
- GPS
- Audio (playback/input/routing/headphones/etc)
- Camera (photos, camcorder & panorama)
- Hardware acceleration and OpenGL rendering
- Hardware video decoding & encoding
- SD card
- USB-storage & adb
- USB-tethering
- Browser
- Touchscreen/multi-touch
- Sensors
- LEDs
- Project Butter - no vsync
- Bluetooth (& bt-tethering)
- Wifi tethering (use an external app, e.g. WiFi Tether for Root Users)
- FM radio
- CyanogenMod team & everyone who's been working on CM10.1
_____________
Changelog
- updated Effem and other FM related updates (thanks to daemond)
- possible fix for texture corruption on some rare occasions (thanks to daemond)
- increase PIE controls trigger area and allow PIE controls without enabling expanded desktop
- change default cpu governor to smartassv2
- more Ad-Hoc changes (1,2,3)
- compiled using AOSP gcc 4.7 toolchain
- included daemond's Effem (FM Radio) app
- fixed audio routing and FM Radio volume control issues (thanks to C3C0)
- backported bluetooth UHID driver - added support for bluetooth input devices (thanks to plaguedbypenguins)
- pie controls (1,2,3,4,5)
- semi-working Ad-Hoc support (open networks) (1,2,3,4,5,6)
- phone: Make going to call log after call optional (1)
- am: Allow more hidden apps on devices with lots of RAM (1) + limit max background processes
- Use jpegOptimized bootanimations (1)
- new Apollo (merged)
6.3.2013 changelog:
- FM radio with RDS support (thanks to daemond)
- qcom-fm: audio: add support for FM feature (1,2,3)
- FM Radio: avoid deadlock when disabling RDS (1)
- update KGSL from CAF, fixes GPU out of memory issues (i.e. white textures, thanks to daemond)
- disable camera hdr
- disable hw acceleration on lockscreen
- fix navbar height option
- bring back Apollo music player
- Apollo: Fetch album art from media provider if present (1)
- new Superuser (merged)
- framework: fix rotation of electron beam animation (1)
- removed couple of non-standard/useless features (e.g. persistent notification when headphones are plugged in)
- Android 4.2.2
- included czech and portuguese (pt_PT) dictionaries
- surface texture enhancements (thanks to daemond)
- call statistics (merged)
- hardware vsync events (thanks to daemond)
- fixed some audio routing issues (thanks to daemond)
- fixed messed up u/v plane alignment in some videos (thanks to daemond)
- Custom lock screen background (1,2)
- option to toggle dimming of the notification shade (1,2)
- Fix restoring network mode preference on reboot (1)
- Mms auto-retrieval (1,2,3)
- Wifi tethering: disable wow and add wakelock (thanks to daemond)
- build hwcomposer and fake vsync events
- fixed native wifi tethering (thanks to daemond)
- fixed squished pattern/sim unlock screen
- fixed bluetooth (thanks to Ganster)
- set correct permissions for boostpulse (now it actually works
- enabled divx and wma hw decoding (thanks to Ganster)
- Added flip and shake to snooze (1)
- fixed charger mode detection
- fixed missing videoplayer controls
- fixed video playback in portrait mode
- fixed messed up third party camera apps (Camera 360, Barcode scanner, etc)
- SystemUI: always use transparent notification shade (1)
- fixed hardware video decoding/encoding, e.g. YouTube HQ, HTML5 playback, Camcorder, etc (thanks to Ganster, psyke83 and everyone else involved)
- fixed camera preview glitches (thanks to psyke83)
- NavigationBar : Customization (1,2)
- NavigationBar: Custom height (1,2)
- Allow purging of asset bitmaps (1)
- added option to disable bootanimation
- backported USB gadget driver from msm-3.0 kernel (thanks to WaylandACE)
- fixed native USB tethering
- fixed issues with apps failing because of borked usb0 interface (e.g. network speedtest apps)
- switched to wpa_supplicant_8
- added power hal and boostpulse support to ondemand governor
- Quick Settings: Swipe to switch (1)
- Add persistent notification when headphones are plugged in (1)
- CyanogenMod clock widget - Chronus (merged)
- new world order
Download:
