[ROM][9.0][OFFICIAL] Havoc OS v2.5 [WHYRED]
  • 72 Antworten
mr.a
mr.a
Stamm-User
175
Havoc OS v2.5
https%3A%2F%2Fraw.githubusercontent.com%2FHavoc-OS%2Fandroid_vendor_extras%2Fpie%2FXDA%2FImages%2FHavoc_Logo.png
Link ins Forum mit Infos:
[ROM][9.0][OFFICIAL] Havoc OS v2.5 [WHYRED][12.05.2019]
Download whyred:
Havoc-OS - Browse /whyred at SourceForge.net
Neues Build online 19.05.2019
Reaktionen: l3art, limuc und misterx31
Mal wieder was Neues, vom 27.5.19
Device Changelog -
• Updated MIUI Camera blobs
ROM Changelog -
• Optimized the size of statusbar icons on the right
• Smart Charging compatibility improvements
• Increased media art blur
• Added more actions for HW keys/Navbar
• Fixed SystemUI crash when Portugese is set as system language
• Fixed disappearing Q clock
• Fixed Amber accent color
• Fixed Home button while ringing
• Fixed Battery estimates showing in statusbar
• Added Double tap for ambient display
• Added toggle to disable weather on lockscreen
Reaktionen: mr.a
Update - 12/06/2019
What's New -
Device Changelog -
Updated to MIUI V10.3.1.0 PEIMIXM (pie blobs)
• Removed MIUI Camera
• Added Google Camera
• Disable 4K on front cam
• Added thermal changes
ROM Changelog -
• Merged June security patches
• Added an animation for charging
• Added back Night Light
• Added battery saving mode for location
• Added toggle for lockscreen charging animation
• Changed Android Q clock to Accent color
• Updated Lawnchair to alpha-2081
• Added a toggle for charging animation
• Added Battery temp in battery usage
• Fixed analog clocks not refreshing in AOD
• Improved Android Q clock related stuff
• Some more fixes/improvements
Um auf Havoc-OS-v2.6-20190612-whyred-Official ohne Clean-Install zu kommen, habe ich meine Erfahrung hier -> [ROM][9.0][OFFICIAL] crDroid v5.2 [WHYRED] gepostet. Ist ja kein Unterschied von der Vorgehensweise zu crDroid v5.x (gleicher Dev). Lest noch einige Posts davor, dann sollte im Zweifel alles vieles klarer werden.
xda Forum -> [ROM][9.0][OFFICIAL] Havoc OS v2.6 [WHYRED][12.06.2019] &
[Recovery][3.3.1-3] Team Win Recovery Project [9fw][all working]
Recovery Project -> https://www.mcsm.ml/html/twrp.html
Havoc Builds -> Havoc-OS - Browse /whyred at SourceForge.net
Firmware Updater -> Downloading File / - XiaomiFirmwareUpdater - OSDN
Reaktionen: harryup
Update - 04/07/2019
What's New -
Device Changelog -
• Add dummy perf profile
• Update thermals config
• Kernel compiled with clang 9.0.4
• Upstreamed Kernel with tag 4.4.184
ROM Changelog -
• Merged July Security Patches
• Improved Gaming mode
• Improved Statusbar icon padding
• Improved Smart charging
• Removed Quick unlock
• Updated Lawnchair to alpha-2238
• Other fixes and improvements
Removed Quick Unlock:1f632:
Das heißt? Jetzt nur noch langsam entriegeln?
Steh auf'm Schlauch:1f615:
@l3art Habe die Quick Unlock Funktion eh nie kapiert. Für mich war das immer doppelt gemoppelt ...Quick Unlock=Direktes Entsperren.
Außerdem ist die Beschreibung der Funktion ja auch ziemlich Gaga...Automatisches Entsperren nach Eingabe der PIN/des Passworts/Fingerprint???...ist doch eigentlich selbstverständlich, oder?
In Sicherheit & Standort finde ich nichts dergleichen was du da auf'm Screen hast. Und gesehen habe ich das wenn ich so zurückdenke auch noch nie:1f606: Liegt vielleicht an Displaysperre -> Wischen (only)?
Und ist das nun ein Nachteil, dass das fehlt in der 2.7?
Nö.
In der CrDroid ist es auch nicht vorhanden.
@l3art Hopalla...muss mich bei dir entschuldigen... bin ja auf crDroid 5.5:1f605:
Schau mal unter Sperrbildschirm nach.
Bin mal gespannt, da Havoc ja vom gleichen Maintainer ist, fliegt die Funktion bestimmt auch bei crDroid raus.
@Mister Lon ...macht ja nüschts ...sind doch alle nur Droiden:D
Hab jetzt nochmal mit diversen Stichwörten durchsucht und finde nichts. Ist wohl schon rausgeflogen bei Havoc.
Der Maintainer testet bestimmt mal hier und dann da und wenn es hier läuft fliegt es dann da auch raus, oder so ähnlich:1f606:
Mister Lon schrieb:
... fliegt die Funktion bestimmt auch bei crDroid raus.
Ist ja dort auch gar nicht vorhanden. Ich nutze Muster und Fingerabdruck.
Recovery Update -> OrangeFox-R10.0_1-Stable-whyred
* fixed spontaneous reboots if device is encrypted with non-default key
OrangeFox Recovery Files
Reaktionen: harryup und OnkelLon
Update - 13/07/2019
What's New -
Device Changelog -
• Increase amount of visible notifications
• Remove HWUI properties
• Update GPS from LA.UM.7.2.r1-07000-sdm660.0
• Disable unused location services
• Update Wi-Fi configs from V10.3.1.0.PEIMIXM
• Update time service blobs from LA.UM.7.2.r1-06900-sdm660.0
• Update system build props from V10.3.1.0.PEIMIXM
• Add missing dynamic fps node
• Update gps.conf from V10.3.1.0
• Enable DFS channel scanning in P2P search
So, nach dem aufregenden Juni-Update (arb_fw_whyred), nun wie früher problemlos auf's nächste Release (OF+2.7). Alles halb so wild:1f606:
Hab mir heute die neueste Havoc 2.7 vom 13.7 installiert, die Lags beim Display waren auffallend, der Kernel 'purecaf x6 EAS' hats beseitigt.
Die OrangeFox-Variante 10.xx finde ich gewöhnungsbedürftig, bin wieder auf die Original TWRP 3.3.1 zurück.
Update - 02/08/2019
What's New -
Device Changelog -
• Added overlay to set white color unconditionally
• Allow 120fps video recording
• Illusion Kernel prebuilt
ROM Changelog -
• Added Gesture Anywhere
• Added NFC Sounds
• Added translations for Text Clock
• Changed Text Clock color to Wallpaper based
• Improved Battery Estimates
• Improved Pocket Lock
• Improved App info
• Improved Sound settings
• Fixed PiP for Multi-user
• Removed QS tile overlays from app list
• Updated Lawnchair to alpha-2338
• Added Gaming mode QS tile
• Improved OP gestures feedback duration
• Improved Aggressive battery
• Improved LiveDisplay
• Fixed crash with some music players
• Performance improvements
@l3art Hat der Maintainer bei Havoc auch wieder die Kamera App geändert?
Geht mir bei crDroid so langsam auf die Nüsse, dieses ewige hin und her geswitche:1f621:
Reaktionen: Muhtant
Oha, das sieht auch gut aus. Ich glaube ich muss mal testen.
Was macht die Kamera App hier? Was ist da mit dabei? Immer noch die GCam?
AI Kamera zeigt ein Screen wenn ich das Ding anklicke. Aber keine Ahnung ob der schon wieder gewechselt hat, ich brauch die Kamera einfach zu selten.
Reaktionen: Muhtant
linuxnutzer
  • linuxnutzer
linuxnutzer
l3art
linuxnutzer
