[ROM][10.0][FINAL] Havoc OS v3.12 [WHYRED][25.12.2020]
  • 153 Antworten
l3art
l3art
Havoc-OS v3.12
__________________________________________________
Forum [xda-developers]
ROM [Download]
Gapps [Download]
Recovery [Download]
Root [Download]
- Device Changelog -
• Fixed Hotspot (Read note)
- Source Changelog -
http://bit.ly/2WLd9jq
• November Security Patch
- Note -
• After booting, enable Developer options
• go to Networking
• turn off Tethering hardware accerelation and Reboot.
• Enable AOD
• Add double tap gesture support
• Improve statusbar layout
• Ignore notch view
• Update graphics blobs from LA.UM.8.2.r1-04300-sdm660.0
• Update ADSP from LA.UM.8.2.r1-04000-sdm660.0
• Update peripheral manager from LA.UM.8.2.r1-04000-sdm660.0
• Update Time service from LA.UM.8.2.r1-04000-sdm660.0
• Update media blobs from LA.UM.8.2.r1-04000-sdm660.0
• Update wifi configs from MIUI 9.9.24
• Fixed Hotspot
• DesertEagle kernel prebuilt
• Added battery styles
• Added switches to disable privacy icons
• Added some props from Google Pixel
• Added SafetyHub from Google Pixel
• Added optimizations
• Improved media notification
• Improved Ambient music
• Improved Screenshot tile
• Improved ScreenRecord tile
• Fixed Screenrecord FC when using custom dpi values
• Fixed possible SystemUI crashes
• Other fixes and improvements
• Force enable IMS and WiFi-calling
• Show battery icon in QS header
• Switch to qsee implementation
• Extended kernel prebuilt
• Added toggle for battery estimates in QS
• Added seekbar to change animation values
• Added Old style mobile type indicators
• Added toggle to swap back and recents buttons
• Improved Screenrecord
• Improved QS header info layout
• Improved Heads up text style
• Improved Styles & Wallpapers app
• Added VoLTE icon to statusbar
• Added QS status bar header image
• Added QS panel opacity
• Added Custom rounded corner and padding preferences
• Added Aspect ratio hack configurable on app level
• Added Notch friendly network traffic
• Added a bolt when battery icon is hidden and charging
• Added Help links in Settings
• Improved Styles & wallpapers app
• Improved Fingerprint dialog on devices with FOD
• Improved CastTile
• Optimized statusbar icons size and layout
• Updated Webview providers
• Removed center clock option for devices with notch
• Fixed QS customizer column menu setup
• Fixed root detection for banking apps
• Fixed default ringtone for 2nd slot on MSIM devices
• Upstreamed kernel with tag v4.4.205
• Merged December Security Patch
• Added Edge lighting
• Added Data Switch QS tile
• Added translations for TextClock
• Added toggle to hide arrow for back gesture
• Added more sounds from Pixel
• Updated sounds from Pixel 4 XL
• Improved Small mobile type icons
• Improved HD VoLTE icon toggle
• Improved Partial screenshot
• Improved Brightness Dialog
• Improved QS tile size and padding
• Improved Bluetooth battery level icons
• Improved Fingerprint settings for devices with FOD
• Moved Notch Cutout settings under display
• Moved Custom DP settings under display
• Fixed DnD icon margin in Volume panel
• Fixed Bluetooth battery level
• Fixed Heads Up in Gaming Mode
• Fixed NavBar layout preference
• Update power off alarm blobs from chiron
• Enabled call recording
• Upstreamed kernel with tag v4.4.206
• Merged AOSP r18 tag
• Added Running Services icon in QS panel
• Added QS footer icon visibility toggles
• Added Warp charging support
• Added more Font size steps
• Added Custom brightness for Ambient display
• Improved Brightness slider layout & design
• Removed forced battery percent on keyguard
• Fixed Bluetooth icon color
• Update CarrierConfig for Indian users
• Kang system props from coral
• Fix In-call mic with earphones
• Use pixel fp to bypass safetynet
• Switch to coral fingerprint
• Address sepolicy denial
• Upstreamed kernel with tag v4.4.207
• Added QS panel rows customization
• Added Custom duration for edge lightning
• Added Auto color option for edge lightning
• Added Ambient Visualizer
• Added Flashlight blink for call waiting
• Added Flashlight blink on incoming calls
• Added support for ADB over network
• Added ADB over network QS tile
• Added Optional screenshot type
• Added an option to change the device hostname
• Added pattern visibility settings
• Added Lock pattern grid size customization
• Improved DataSwitchTile
• Improved Lockscreen battery temperature
• Increased call log limit
• Turned off some debugging
• Updated some prebuilt apps
• Allow all apps to use smart replies
• Update power hal to 1.3
• Disable window rounded corner animations
• Beautify rounded corners
• Add Xiaomi Parts
• Add Dirac (Mi Sound Enhancer)
• Add support for smart charging
• Add display mode mappings
• Fix bluetooth audio issues
• Upstreamed kernel with tag v4.4.208
• Clean up props
• Build with VNDK
• Sync audio props from LA.UM.8.2.r1-04800-sdm660
• Reorganize radio props
• Build WfdCommon
• Enable connected MAC randomization
• Kernel Upstreamed with tag v4.4.210
• Added Samsung like lockscreen clock
• Added toggle to hide lock status icon
• Added Screen off animations
• Added dark blue primary color
• Changed back gesture height intervals
• Improved Sound Search QS tile
• Improved QS statusbar and header layout
• Fixed textApperance for some dialogs
• Fixed mobile data usage in qs detail
• Switched to Cloudflare DNS as the default fallback
• Updated Pixel launcher
• Updated Bluetooth battery level icons
• Enable VoLTE/VoWIFI for Digi Mobil
• Enable VoLTE/WoWIFI for Megafone, MTS and Tele2/ECC/Volgogr
• Enable Wifi Calling for India users
• More rendering tweaks
• Kernel Upstreamed with tag v4.4.213
• Merged AOSP r27 tag (February Security Patch)
• Added extended screenshot port from OOS
• Added Power off charging animation from Pixel
• Updated some icons to MD2
• Updated raw animations from Pixel 4 XL
• Improved Styles and wallpapers app
• Improved QS panel layout
• Improved partial screenshot
• Improved Airplane mode
• Removed Aggressive battery
• Removed some ugly clock styles
• Added new Partial screenshot implementation
• Added icon for Private dns
• Added more Custom clocks
• Improved theming in Settings
• Improved QS multiuser icon animation
• Fixed Statusbar Camera icon size
• Fixed Screen off animations
• Removed Overlays from apps list
• Enable IWLAN assisted mode
• Enable Codec2
• Fixed SafetyNet
• Kernel Upstreamed with tag v4.4.214
• Added QS background blur
• Added Vibration patterns from OOS
• Added Screen Stabilization QS tile
• Added AOD QS tile
• Added Sound QS tile
• Added Ambient as a gesture action
• Added Wake device as a gesture action
• Added Dark theme scheduling settings
• Added Battery temperature in Battery stats
• Added Back gesture haptic feedback toggle
• Added Permission group for signature spoofing
• Added Edge lighting repeats setting
• Improved Edge lighting color modes
• Improved Cellular QS tile
• Improved Gesture actions list theme
• Moved In-Call Vibration settings to Sound
• Removed AoD opt-in from Setup Wizard
• Disabled LiveDisplay low power consumption
• Fixed ThemePicker crash with Live wallpaper
• Fixed video playback issues
• Fixed swipe gesture causing keyboard crash
• Fixed opening messaging app with gestures
• Fixed gesture dialog SeekBar color in light theme
• Fixed extra page in QS when the last page is full
• Fixed Failed unlock attempt dialog button
• Fixed incorrect position of FOD on keyguard
• Optimized some things
• Merged March Security Patch
• Added ADB root
• Added double arrow for extended swipe gesture
• Added navigation handle length customization
• Improved QS blur
• Improved running services fragment layout
• Removed Screen off animations
• Cleaned up and improved Config Center
• Added long swipe back gesture actions
• Added setting to toggle Navbar
• Added Navbar buttons customizations
• Added option to show Arrow keys while typing
• Added some more Button backlight options
• Added FOD animation from OOS
• Added setting to clamp min auto brightness
• Added FPS Info QS tile for some devices
• Added option to always show Edge lighting
• Added Notification color option for Edge lighting
• Fixed Edge lighting repeat count
• Improved UI theming
• Changed ADB over network tile icon
• Moved volume steps preference to Sound
• Moved some gesture toggles to Config Center
• Use coral march fp
• Add smart charging support
• Ignore RSSNR signal lever
• Update auto brightness overlays
• Make WiFi Calling preference editable for Jio (India)
• Enable VoWiFi for Airtel
• Enable VoLTE/VoWiFi/ViLTE for entire 460 mcc
• Enable VoLTE/VoWiFi for Digi Malaysia
• Enable ViLTE for Airtel (India) & 404 mcc
• Enable burn-in protection in Ambient display
• Update Perf/IOP from jasmine
• Update camera blobs from MIUI V11.0.3.0
• Update ADSP from jasmine
• Update Media blobs from jasmine
• Update CDSP blobs from jasmine
• Update PowerOffAlarm from jasmine
• Update TimeService blobs from jasmine
• Update Bluetooth/ANT+ from jasmine
• Update Audio from jasmine
• Update thermal blobs from jasmine
• Update Radio/IMS from jasmine
• Update QMI from jasmine
• Update GPS from jasmine
• Update WFD blobs from jasmine
• Update DPM from jasmine
• Kernel Upstreamed with tag v4.4.216
• Fixed hotspot/usb tethering issue
• Reverted WFD blobs (Fixed WiFiDisplay)
• Kernel Upstreamed with tag v4.4.217
• Added Android R style Screenrecord dialog
• Added FOD circle below pattern/pin view
• Added panels for some QS tiles on long press
• Added haptic feedback to Switches
• Added Notification log
• Added Skip/Previous Song function to back gesture actions
• Improved Navbar toggle code
• Fixed minimize keyboard navbar button
• Moved fullscreen gesture setting to navbar gesture length
• Update CarrierConfig from violet
• Clean fingerprint blobs
• Update audio & thermal blobs from stock
• Update some more blobs from stock
• Fix manual network selection
• Reorganize some props
• Update UceService & cacert hal
• Add missing product radio deviceinfo blobs
• Update jasmine blobs to V11.0.5.0.QDIMIXM
• Force enable mobile network settings v2
• Merged April Security Patch
• Added Face unlock
• Added new bootanimation (Thanks to @Mithrandirx96)
• Added Adaptive playback
• Added Music heads up on new tracks
• Added toggle for fingerprint animation
• Improved Less boring headsup
• Fixed Custom lockscreen wallpaper
• Fixed Android Auto
• Fixed Charging status in keyguard shown twice
• Fixed Bluetooth turning on in airplane mode
• Removed touch gestures settings on unsupported devices
• SELinux Enforcing
• Update some blobs from LA.UM.8.2.r1-05100-sdm660.0 (Radio, QMI, CNE, PostProcessing)
• Update MIUI camera from Mi A2 10 release
• Update Media blobs from LA.UM.8.2.r1-05100-sdm660.0
• Update Graphics Blobs Vulkan from LA.UM.8.2.r1-05700-sdm660.0
• Address a lot of sepolicy denials
• Added FPS info QS tile
• Add Pixel power HAL
• Update to coral april fp
• Update caf telephony stack
• Enable VoWIFI for MTS (Russia)
• Enable VoLTE for Viettel Vietnam
• Enable VoLTE/VoWIFI for Turkcell/Digi
• Add full Support Carrier Smartfren ViLTE
• Update QtiRadio HAL to Version 2.4
• Disable forced shutter sound on MiuiCamera
• Update manifests from CAF
• Fix offline charging
• Switched to RAD EAS x4 (4.4.218)
• Added Per-app cellular data, vpn and wifi restrictions
• Added Screen off FOD
• Added Swipe up on keyguard to use Face Unlock
• Added toggle to hide space below keyboard when navbar is hidden
• Added internal audio recording to screenrecord
• Added a bitrate selector to screenrecord
• Improved Screenrecord dialog layout
• Removed LTE tile
• Fixed TypeClock layout
• Fixed Flashlight action for buttons and gestures
• Fixed duplicate charging status on keyguard
• Fixed keygugard layout with face unlock
• Update media_codecs_performance to Q
• Update ADSP and its modules from LA.UM.8.2.r1-05100-sdm660.0
• Update some more blobs from LA.UM.8.2.r1-06300-sdm660.0
• Update cnss-daemon from from LA.UM.8.2.r1-06200-sdm660.0
• Update powerhint for better performance
• Kernel Upstreamed with tag 4.4.219
• Merged May Security Patch
• Added 2 Lockscreen clocks
• Added 5 Primary theme colors
• Added Percentage inside battery icon
• Added Notification LED settings
• Added toggle to show icon with Screen Off FOD
• Synced battery icon in settings with status bar
• Fixed Phone ringtone setting for Multi SIM device
• Fixed 2nd QS tile row disappearing in landscape
• Fixed Freeform windows
• Removed Face unlock
• Update to coral may fp
• Update thermal blobs from LA.UM.8.2.r1-06200-sdm660.0
• Address some more sepolicy denials
• Finetune mediacodec performance values
• Kernel Upstreamed with tag 4.4.222
• Added Face Unlock (Only for Official)
• Added Notch hide settings
• Added some new Fonts
• Added Smart Pulldown
• Added OOS styled Network speed indicator
• Added Network speed indicator modes
• Added Network speed indicator refresh interval
• Added Navigation Bar QS tile
• Added Switch to 3G mode to suspend actions
• Added Hotspot setting to allow VPN upstreams
• Added Dark theme support to AOSP apps
• Added setting to set the default GPU renderer
• Improved Mobile Data QS tile
• Fixed Screenrecord crash
• Nuked XiaomiParts
• Reverted to old camera blobs
• Moved dirac to Sounds - Mi Sound Enhancer
• Update CarrierConfig from LA.UM.8.2.r1-06500-sdm660
• Address more SELinux denials
• Fixed offline charging
• Kernel Upstreamed with tag 4.4.224
• Update blobs from LA.UM.8.2.r1-06300-sdm660.0
• Enable Smart Pixels
• Fixed some random audio issues
• Merged June Security Patch
• Added Status bar notification ticker (Only for devices without a notch)
• Added 4 new clocks
• Added TextClock translations
• Added Battery Bar
• Added Sensor block per package switch
• Added Rounded hexagon icon overlay
• Added some accent color overlays
• Updated some GApps
• Switched to Shady Launcher
• Improved network traffic icon holder
• Cleaned up some fonts
• Fixed bootanimation stutter
• Fixed Wallpaper bug that caused bootloop
• Update to coral june fp
• Address some selinux denials
• Use QCOM implementation for audio effects
• Update audio configs
• Update ESE-Powermanager from LA.UM.8.2.r1-06200-sdm660.0
• Fix battery light not lit after notification light off
• Optimize ART props
• Increase audio HAL buffer size to 240
• Fixed some minor issues
• Kernel Upstreamed with tag v4.4.226
• Added Battery Bar
• Update blobs from miui_JASMINEGlobal_V11.0.8.0.QDIMIXM
• Import SSR blobs from Platina 10 QKQ1.190910.002 20.6.11
• Set model name properly
• Enable zygote pre-forking (faster app launching)
• Fixed smart charging
• Fixed data activation delay
• Kernel Upstreamed with tag v4.4.227
• Merged July Security Patch
• Added Per app network isolation
• Added VoWiFi statusbar icon
• Added VoLTE icon from OOS 10
• Added VPN QS tile
• Added ability to show daily data usage
• Added toggle to force custom doze brightness
• Added icon shapes from Android R
• Added QS tile accent tint
• Added QS statusbar style
• Added Raise to wake
• Added toggle to disable SIM
• Added Edge light animation direction
• Added Edge light Faded/Solid view
• Added configurable sensor block package list
• Added Ringtone focus mode
• Improved QS detail view layout
• Improved AOD QS tile
• Improved Biometric dialog
• Improved AOD charge settings
• Improved IME space toggle code
• Fixed Notification guts color in dark theme
• Fixed Network speed format for 10*KB
• Fixed custom theme crash in landscape mode
• Fixed App drawer background transparency
• Decreased USB-Debugging notification priority
• Update to coral july fp
• Update blobs from Jasmine V11.0.11.0.QDIMIXM
• Update data-ipa-cfg-mgr from LA.UM.8.2.r1-06900-sdm660.0
• Update lmkd configs
• Update static iuicc names in device
• Enable ringtone audio focus for Wired/BT headset
• Switch to stock vibration pattern
• Fix legacy app scaling
• Prevent RTT VT call on networks that don't support it
• Upstreamed Kernel with tag 4.4.229
• Added VPN QS tile
• Switch to QTI bt stack and enable a2dp offload
• Update a2dp blobs
• Use prebuilt libbtconfigstore for now
• Update vendor security patch from Jasmine V11.0.11.0.QDIMIXM
• Updated audio configs
• Change USB autosuspend delay to 7s by commandline
• Switched to Extended EAS Kernel7
- Device Changelog (Same as previous build) -
• Added toast notification for clipboard access
• Added Lockscreen timeout configuration
• Added Pulse navbar audio visualizer
• Added toggle to disable dashboard tiles
• Added notification counters
• Added haptic feedback to SeekBar
• Fixed Network traffic visibility on theme change
• Fixed Preference text overlap with switch bar
• Improved Immersive display cutout mode
• Improved VoLTE/VoWiFi icon code
• Improved QS panel auto brightness toggle
• Moved owner info to the left for Type clock
- Launcher -
• Added option to change icon size
• Added option to always keep the wallpaper centered
• Improved Icon pack code
• Improved App drawer layout to match Pixel Launcher
• Removed some app activities from app drawer
• Fixed bottom padding when Search bar is hidden
• Fixed Search bar roundness when using round icons
• Fixed App drawer transparency
• Fixed multi-line labels for folders
• Disable NearbyMessagingService & NearbyDiscoveryService
• Merged August Security Patch
• Added Expanded volume panel
• Added Linotte font
• Added touch response optimizations
• Added back Permissions hub in GApps builds
• Added toggle to disable permissions hub
• Added VOOC charging support
• Added Home button wake support
• Extended NavBar Pulse to LockScreen
• Moved some settings into Media section
• Improved Clipboard access toasts
• Improved Carrier label settings
• Added translations for a few languages
• Update to coral august fp
• Update Audio, Graphics & Media blobs from LA.UM.8.2.r1-06700-sdm660.0
• Set screen off delay to 0
• Adjust powerhint config for sdm636
• Update some more audio stuff
• Remove unnecessary common camera blobs
• Kernel Upstreamed with tag 4.4.232
• Merged September Security Patch
• Improved Pocket Lock
• Improved FOD
• Improved Screen Recording
• Improved Aspect ratio hack
• Improved Lockscreen Visualizer
• Improved Fingerprint Unlock speed
• Improved Face Unlock
• Updated Face Unlock Service
• Fixed Auto Night Mode when location is off
• Added App volume row to volume dialog
• Added support for MiSound FX
• Update to coral september patch
• Fix no sound in call recordings
• Kernel Upstreamed with tag 4.4.236
• Added System integrated App Lock
• Added option to cycle through ringer modes
• Kernel Upstreamed with tag 4.4.237
• Merged November Security Patch
• Improved App Lock
• Added Automated DC Dimming
• Added Powershare support
• Added option to set default home page
• Updated icon overlays from Android 11
• Fixed Quick Unlock with long PIN/Password
• Fixed off-center notifications on Lockscreen
• Fix deep sleep issue while Bluetooth is turned on
• Kernel Upstreamed with tag 4.4.243
• Update to coral december fp
• Kernel Upstreamed with tag 4.4.248
__________________________________________________​
Reaktionen: Muhtant, JustDroidIt, wassolldas und eine weitere Person
Android 10 ...ja, warum denn eigentlich nicht ;)
Vorhanden:
- OrangeFox-R10-RC-3.1-whyred (OrangeFox Recovery Files)
- Firmware HMNote5Global_V10.3.1.0.PEIMIXM (Downloading File /Stable/V10/whyred - XiaomiFirmwareUpdater - OSDN)
- reichlich Backup's
Flash:
- Wipe Dalvik, Cache, Data & System
- Havoc-OS-v3.0-20191107-whyred-Official (Havoc-OS - Browse /whyred at SourceForge.net)
- Ins System gestartet (erfolgreich) und wieder zurück zum Recovery
- open_gapps-arm64-10.0-pico-20191006-BETA (OpenGApps - Browse /arm64/beta at SourceForge.net)
- Neustart in Recovery
- Magisk-v20.1 (https://github.com/topjohnwu/Magisk/releases/download/v20.1/Magisk-v20.1.zip)
- Reboot System
Meine Bug's bisher:
- MigrateBackup in OF fehlgeschlagen (Error 7), aber TitaniumBackup in Havoc erfolgreich.
- Die UI spinnt noch ein klein wenig, aber läuft soweit dennoch flüssig.
- WLAN verbindet nach Neustart nicht automatisch, erst wenn mann kurz die Einstellungen öffnet. Lösung: #4
- ??? In Magisk ist nun -> avb 2.0/dm-verity beibehalten: aktiviert & SafetyNet -> ctsProfile: false Lösung: #4
- Ansonsten fällt mir für den Moment nichts weiteres Ungewöhnliches auf.
Auch wenn noch nicht alles übersetzt ist und noch ein paar Einstellungen fehlen, läuft die Beta bisher sehr ordentlich. Ich hatte bisher noch kein Abstürze und bin fast auf dem Stand von v2.9. Was z.B. noch fehlt ist ViPER4Android, was aber wohl etwas tricky ist ([ROM][10.0][OFFICIAL][BETA] Havoc OS v3.0 [WHYRED][07.11.2019] - Post #60). Das schau ich mir nochmal in Ruhe an.
Yippie-Ya-Yeah Schweinebacke! :D
Reaktionen: Muhtant, JustDroidIt, wassolldas und 2 andere
@l3art
...gut beschrieben, danke! "Möge die Macht mit Dir sein" 😉😂
...habe bei mir aber bereits die 10.3.2.0-firmware installiert...?!
Reaktionen: l3art
- Der WLAN-Fehler ist jetzt weg. Wahrscheinlich hat ein wenig entstauben geholfen. Oder was auch immer.
- SafetyNet/cts jetzt 'true' - Android 10 will beim einrichten nun unbedingt den Fingerabdruck in Kombination mit Muster/PIN/Passwort haben. Ablehnen kann man zwar im nächten Schritt nach Auswahl einer der drei Vorgaben, aber mit dem Ergebnis das das Gerät nicht zertifiziert ist und SafetyNet/cts mit 'false' quittiert wird.
Meine Lösung: Man braucht die MagiskModule -> Busybox NDK und MagiskHide Props Config + einem Terminal aus dem Store (z.B. Termux). Bin dann nach dem Video vorgegangen. Natürlich auf unser Modell abgestimmt. Gerät nun zertifiziert.
Achja ...die 10.3.2.0 Firmware bekomme ich erst gar nicht insalliert :2753: 😟
Reaktionen: wassolldas
@l3art Yo! ist bei mir genau so 😕 10.3.20 lässt sich nicht installieren.
@l3art Hmm...ich bin da ein bisken ratlos, weil ich die 10.3.1.0 schon installliert hatte und den letzten Orange Fox R 10 RC 3.1 benutze🤔
So! Neue Stable Firmware 11.0.3.0 ist raus!
Xiaomi Firmware Updater
Werde mal mein Glück erneut versuchen😟
Kann hier jemand bitte nochmal seine Baseband Version unter 10.3.1.0 oder 10.3.2.0 checken?
Nach Installation der 11.0.3.0 habe ich folgende Baseband Version:
MPSS.AT.3.1-00777-SDM660_GEN_PACK
1.209285.1.210383.1
Reaktionen: wassolldas und l3art
Die 11.0.3.0 habe ich noch nicht probiert. Die 10.3.2.0 wird zwar von Device Info HW ausgelesen, aber im System bzw. Vendorpfad wird in der build.prop weiterhin die 10.3.1.0 ausgelesen. Keine Ahnung was nun stimmt.
Reaktionen: wassolldas und OnkelLon
@l3art Sehr krude alles! Also ich habe die 11.0.3.0 geflasht und mir wird in HW Info genau das gleiche angezeigt 🤔 🤨
...bei mir sieht's so aus:
vorherige firmware 10.3.2.0
aktuelle firmware 11.0.3.0
@wassolldas Hey!....Das ist unfair! 😄😉 Bei der xiaomi.eu wird bei jedem Update die aktuelle Firmware automatisch mit installiert...leidet bei den AOSP CR nicht😟😭🥺
Aber im Grunde sollte das doch auch wurscht sein, sind doch alles Pie-Firmware's.
Und MIUI 11 basiert ja auch weiterhin auf Pie.
Und ob es noch Android 10 Firmware bzw. MIUI geben wird für's RN5?
@Mister Lon
danke für den Hinweis... dann muß ich mir das noch einmal anschauen, denn auf dem ersten screenshot von mir ist die "original eu-firmware" enthalten, auf dem zweiten die - über den xiaomi firmwareupdater nachinstallierte - "global stable firmware" -> das passt ja dann eigentlich nicht zusammen...☺
...muss ich wohl die letzte eu weekly nochmal drüberbügeln, damit ich wieder "straight" auf "EU-Kurs" bin...🤪😄
...stellt sich für mich dann aber echt die Frage, was das ganze "Hin u.Her" mit der Firmware eigentlich soll... wo ist der Nutzen für uns User...?! 🤔😕
EDIT: ...selber recherchiert, nachgelesen und verstanden... und zurück zum eu original Baseband geflasht. Sorry fürs viele "Off topic" und zurück zu Havoc 3.0...😉
Update Post #1 - new Build
Ich kam noch nicht zum updaten, denn hier stapelt sich die Arbeit 🥵
Ich habe den Update gewagt. Leider habe ich seit dem beim Telefonieren ein Echo beim Gesprächspartner. Bei mir klingt alles super aber der Gesprächspartner hört sich selber um eine Sekunde versetzt. Ein Werksreset und ein Downgrade auf 2.9 bringt keine Verbesserung.
Habe langsam keine Idee mehr.
Nach mehrfachen hin und her sowie kompletten Plattmachen habe ich das Echo wegbekommen wenn ich HD-LTE (4G-Anrufe) aus mache. Damit kann ich erst einmal leben.
Was mich aber seit einer weile schon nerven tut ist wenn ich das Handy neustarte jedes mal der Hinweis zum auswählen der Daten-Sim kommt. Hat dafür jemand eine Lösung?
edit: Ich benutze das Handy mit zwei Sims
Als ich 2 SIM-Karten genutzt habe, hatte ich das in Netzwerk & Internet -> Mobilfunknetz konfiguriert.
Also welche Karte für was benutzt werden soll. Aber vielleicht ist es noch ein Bug.
  • linuxnutzer
linuxnutzer
linuxnutzer
mr.a
OnkelLon
OnkelLon
