[ROM][MARSHMALLOW][LB/UB][570] eXistenZ Marshmallow
  • 65 Antworten
eagle30
eagle30
Stamm-User
247
jdyfvmy4-png.414569
Quelle: XDA Thread:
[ROM][MARSHMALLOW][LB/UB][570] eXistenZ Marshmallow | v1.0.0 | 28/04
Main Features
  • Status Bar
    Quote:
    • Various batteries status styles (Sony, Icon Landscape, Icon Portrait, Circle, Text).
    • Clock (Color, Alignement, AM/PM indicator, ...).
    • Date (Style, Format, Color, ...).
    • Network Trafic Monitor (Color, Outgoing/Incoming, Display Unit, Update Interval, ...).
    • Network trafic.
    • Battery Bar.
    • Double Tap to sleep.
  • Notification Panel
    Quote:
    • Status Bar Header
      • Carrier Text.
      • Weather.
      • Long Pressing on Setting is opening edition of quick toggles.
      • Long Pressing on Weather is opening CLock App.
    • Quick Settings
      Quote:
      • Quick Pulldown (Off, Right, Left).
      • Complete Cyanogen OS Quick toggles management.
      • Tiles diplayed in Paged View.
      • Show/Hide Brigtness Slider.
      • Enlarge first Row.
      • Unlimited Quick Toggles Number.
      • All Quick Toggles With Long Press Options.
      • Wifi and Bluetooth Quick Toggles.
      • Brightness Quick Toggle (Long press to switch between Auto and Normal mode).
      • Tri-state Location Quick Toggle.
      • Mobile Data Quick Toggle.
      • Network mode Quick Toggle.
      • NOT WORKING! Reboot/Recovery Quick Toggle (Press to select Reboot or Recovery, Long press to apply your previous choice).
      • Screen Timeout Quick Toggle.
      • Heads Up Quick Toggle.
      • eXistenZ Settings Quick Toggle.
      • Compass Quick Toggle.
      • Volume Panel Quick Toggle.
      • Music Quick Toggle.
      • Caffeine Quick Toggle.
      • ADB over network Quick Toggle.
      • Battery saver Quick Toggle.
      • Color inversion Quick Toggle.
      • Screenshot Quick Toggle.
      • System stats Quick Toggle.
      • USB tethering Quick Toggle.
    • Heads Up
      Quote:
      • Heads Up on/off
      • Heads Up Timeout.
      • Expand all Notifications on/off.
    • Notification Panel:
      Quote:
      • Blur Notification Panel background.
      • Xperia X style (Full Width).
  • Recent Menu
    Quote:
    • Show/Hide Search Bar.
    • Show/Hide Close All Button.
    • Show/Hide Small Apps.
    • Enable Multi-Windows.
    • OmniSwitch.
    • Slim Recent.
  • Navigation Bar
    Quote:
    • Resize Navigation Bar Height.
    • Resize Navigation Bar Width.
    • Cursor Control (Add arrows to control cursor when keyboard is used).
    • Disable Google Now gesture.
    • Long Press Recent go to last task.
    • Force show menu button.
    • Power menu.
    • Swap Back & Recent buttons.
    • Swipe To Sleep.
    • Softkeys Fade mod.
  • Lockscreen
    Quote:
    • Double tap anywhere to sleep.
    • Xperia X lockscreen.
    • Force See Through Clock (Transparent clock while playing media and with all themes/wallpapers).
    • Enable/Disable Voice Assist Shortcut.
    • Full Screen Album Art.
  • Various
    Quote:
    • Fully Deodexed.
    • Datas On/Off Warning Dialog removed.
    • Overflow Button animation bug fixed (The 3 little dots).
    • Email Attachment fully work in Email app.
    • National Data Roaming added to Network Settings.
    • Use only 2G added to Network Settings.
    • eXistenZ Theme.
    • eXistenZ Boot Animation.
    • eXistenZ Widgets (Music, On/Off tools).
    • Xperia X themes.
    • Xperia X Wallpapers.
    • Xperia X Icons Pack.
    • AOSP Sony's internet Browser.
    • Search panel removed as first pane of app drawer.
    • Swipe down gesture to open search panel removed from desktop.
    • Rooted with latest SuperSU.
    • Latest TWRP recovery pre-installed.
    • Locked and Unlocked Bootloaders.
    • And more...
Screenshots
Installationsanweisung(en)
INSTALL INSTRUCTIONS
All is include in the ROM, no need to flash SuperUser fix or Kernel.
Fresh installation:
From Stock Sony Marshmallow:
  • Reboot in recovery.
  • Do a factory reset.
  • Flash the rom.
  • Flash update if available.
From eXistenZ Premium v7.x.x:
  • Do a fresh install.
From anything else (CM10, PAC, ...):
Downloads
eXistenZ Marshmallow v1.0.0 (mega): https://mega.nz/#!VQd0FSYI!72gdQy3kz...udw5Bzis4xLZoU
eXistenZ Marshmallow v1.0.0 (mediafire): http://www.mediafire.com/download/dk...low_v1.0.0.zip
Version Information
Status:
Stable
Current Stable Version: 1.0.0
Stable Release Date: 2016-04-28
Created 2016-04-28
Last Updated 2016-04-28
Update auf Version 2.0.0
Changelog:
  • Based on BETA 6.0.1 23.5.A.1.151
  • 23.5.A.0.575 Kernel.
  • Fixed issue with the status bar clock.
  • Quick pulldown is now working normally.
  • Fixed issue with navigation bar keys.
  • Edit Stamina code to work with .575 kernel.
  • Allow animations with Battery Saver and Stamina.
  • Implement all Xperia X boost features.
  • Reworked all Quick Tiles management.
  • Add Lockscreen Weather.
  • Add Landscape Rotation option to lockscreen.
  • Add Quick Torch (Long press power buton when screen off).
  • Add Middle Shortcuts to lockscreen.
  • Add App Sidebar to Slim Recent.
  • Add Blur Recent panel option.
  • New Blur Notification panel code with Blur Radius and Blur Scale settings.
  • Latest Xperia X SystemUI and Lockscreen.
  • Stamina and Ultra Stamina.
  • New Power Menu and Ringer mode Quick Toggles.
  • Removed Reboot Quick Toggle.
  • Xperia X Animations and Framework.
  • Xperia X Settings.
  • Xperia X apps (Conversations, InCallUI, Clock, Home launcher, ...).
  • And many more...
Mehr News sowie Install-Anweisungen in diesem XDA-Thread
Update auf Version 2.5
Changelog:
  • Fixed Ambiant Display enabled by default with Switch off.
  • Fixed Power Controller Bug (by Sony).
  • Reworked Notification Panel code.
  • Revert to previous Blur engine with modifications.
  • Remove some Boost enhancements.
  • Xperia X Smart Cleaner is now fully supported (I hope
  • Add Animations speed settings.
Alles weitere hier *klick*
Update auf Version 3.0
Changelog:
  • Based on BETA 6.0.1 23.5.A.1.203
  • Xperia X Smart Cleaner is finally working.
  • Add Xperia X Smooth Scrolling.
  • No more permanent notification when Stamina is activated.
Alles weiter hier *klick*
Reaktionen: medik95, sammo82, Digger T und 3 andere
Wie aktiviert man denn so einen Mod?
Der sollte nach Installation unter Einstellungen -Designs zu sehen und zu aktivieren sein.
Reaktionen: DerAxl
Jetzt habe ich 3x das Handy neu geflasht bis ich endlich den Bootloop-Fix entdeckt habe. :) Ansonsten ist der erste Eindruck recht gut, nun beginnt der Langzeittest.
Hallo Leute,
Ich habe das Problem, das die Uhr aus der Statusleiste verschwunden ist, wenn ich das Gerät neu starte.
Unter den Existenz Einstellungen muss ich die Uhr auf links stellen und wieder auf rechts, damit ich die Zeit oben in der Leiste habe.
Ist das bei euch auch so? Ich lasse mir das Datum auch anzeigen. Entweder ist beides weg oder beides zu sehen.
Viele grüße,
Sammo
Bei mir ist das Mikrofon extrem leise muss immer fast schreien das mich der andere hört. Habe Mikrofoneinstellungen alle 3 varianten ausprobiert alle das selbe ergebnis. Hat noch jemand das problem??
[doublepost=1462100119,1462099869][/doublepost]@-jfk93-
ging mir genau so wolle schon das handy mit der original rom bespielen weil ich nicht ins recovery mehr kam falschen knof immer gedrückt dann fix drauf und handy läuft bis auf mein oben gennantes problem top seid 4 Tagen akku hält für meine bedürfnisse auf Top 2 tage
Wenn ich unterwegs bin habe ich kein mobiles Internet. Kann es über die Interneteinstellungen nicht aktivierten. Es kommt die Meldung, dass ich WLAN einschalten soll. Wenn ich in WLAN bin und die Einstellungen runter lade, WLAN deaktiviere habe ich trotzdem kein mobiles Internet.
Der Dienstanbieter ist richtig eingestellt.
Viele Grüße,
Sammo
Telefon schonmal neu gestartet?
Ja, öfter schon.
EDIT:
Ich habe die apn Einstellungen manuell vorgenommen, jetzt geht's. (Musste die apn Einstellungen noch nie manuell einstellen)
Ich weiß nicht, ob mein Problem mit der eXistenZ MM zusammen hängt, oder ein Sony-Problem ist.
Will ich mit Google Chrome etwas downloaden, läuft das so:
1) Download anstoßen
2) Meldung "Chrome benötigt Speicherzugriff"
3) Änderungsversuch der Berechtigung: Einstellungen/Apps/Chrome/Berechtigungen/Speicher: Versuch zu aktivieren führt zu Meldung: "Display-Overlay erkannt, muss deaktiviert weden".
Und genau diese Einstellung ist ausgegraut, ich kann sie nicht ändern. Ein Download mit Chrome ist nicht möglich. Mit dem Standardbrowser funktioniert das reibungslos.
Das gleiche passiert mir z.B. auch, wenn ich versuche, den Standardklingelton der SMS-App zu ändern.
Hat das noch jemand? Kann mir jemand helfen?
Keiner sonst dieses Problem? Keiner einen Tipp?
Hau Chrome doch mal aus den System Apps raus= deinstallieren/löschen und installiere es anschließend über den playstore
Danke für die Antwort.
Deinstallieren/löschen war leider nicht die Lösung! Hab Chrome aus System/Apps gelöscht (mit Titanium Backup war deinstallieren nicht möglich) und dann aus dem Playstore neu installiert. Problem ist noch immer da.
Ja die Lautstärke vom Mikrofon stört etwas aber es geht.
Hat von euch jemand das Problem, dass manchmal die System Ui neustartet?
Aktuell betrachte ich die ROM mit gemischten gefühlen. Der Akku hält trotz fehlendem STAMINA ungefähr genauso lange wie mit der EXISTENZ 7.0. Dafür habe ich das Gefühl, dass Handy läuft insgesamt etwas hakeliger. Das Entsperren erscheint mir immer etwas rucklig und auch das Löschen der letzten Anwendungen im TASK kommt mir schwerfällig vor.
Dem kann ich nur beipflichten,
Die Ui Abstürze kommen übrigens vom aktiv schalten des Blureleffektes vom Pulldownmenu.
Es hat ja auch einige Vorteile und wird ja auch stetig weiterentwickelt.
Trotzdessen muss man ja auch weitere Fehler anmerken.
Weiterhin fehlen mir die in Existenz lollipop vorhandenen Unmengen an Einstellungsmöglichkeiten im Bezug auf das Pulldown Menü und das Ausschaltmenü.
Was mich aber doch schon richtig nervt, ist das von Version zu Version immer weitere und größere zusammenfassen von einzelnen threads, ja schon immer mehr unterschiedliche, nicht einmal zwangsläufig zusammenhängenden Programmen zu einem riesigen Prozess. Der leider für Endanwender unmöglich und für die sich mit der Materie auskennenden Personen sehr schwierig gestalteten Differenzierung bzw. Eher Trennung und dadurch einzelne Einstellungen der genannten threads und Programme.
Für Android bzw. Google ist dies natürlich gewollt und von enormen Vorteil. Das kann ich auch aus deren Perspektive gut nachvollziehen.
Trotzdem ärgerlich!
Nungut Schluss mit dem rumgejammer, ich bin Schindluder etwas abgeschweift.
Was haltet ihr von der momentanen Version?
Ist euch noch etwas anderes aufgefallen?
Mfg SoRRy_frEAk
Moin,
da ich meinen Startpost nicht editieren kann, hier die News zu Existenz.
- deleted -, da in Startpost eingearbeitet.
ROM ist im übrigen auf Version 2.5 angesprungen.
Reaktionen: wwallace1979 und eagle30
knofi
gene
  • SchwesterStefan
SchwesterStefan
