[ROM] [.314] [2 IN 1 ]Ultimate PureXZ2 [WHITE/BLACK]
  • 10 Antworten
bandit_crc
bandit_crc
Ein neues ROM von dipesh1502
Link zum OriginalThread auf XDA
Features
Aroma
Better battery
Tweaked Semcphone
Cost saving feature in messaging
Stock Kernel (No need to touch flashtool anymore)
Advanced Reboot menu
Many Android themes for better looking Z2
Superuser mod included
Various SystemUI Mods Like
5 BUTTON NAV BAR
5 BUTTON NAVIGATION BAR MOD WITH OLD STYLE TILES
5 BUTTON NAVIGATION BAR MOD WITH 5 TILES ROW
3 BUTTON NAVIGATION BAR WITH INVISIBLE POWER BUTTON MOD
3 BUTTON NAVIGATION BAR ,INVISIBLE POWER BUTTON OLD STYLE
Some updated apps from T3
For the 1st time for Z2, Autostarts (This enables you to control the user apps and system apps to prevent them to start at boot up
For the 1st time for Z2, Ultimate menu (in settings) with important apps
Xposed framework
Gravitybox
Xperia xposed
Kernel tuner
Cpu stats
Cpu controller
Xposed Modules
Boot Manager
Cyber-shot Xposed by Rizal Lovins
GravityBox
Xperia Xposed (KK) by Serajr
Varius Mods
Choice of Black/White Apps (For the 1st time for Z2)
Nav bar dpi mods
Sound mods
Lockscreen mods
and more....
The Special Feature Of The Rom Is That On The Start Of The Aroma Installer,It First Asks You To Chose The Rom To Install
1.Ultimate PureXZ2
2.Ultimatte BlackXZ2
INSTALLATION
You Require Root And Recovery
1.Copy Rom To SD Card
2.Enter Recovery
3.Wipe Cache
4.Wipe Dalvik Cache
5.Flash Rom
6.Follow The AROMA Installer
7.Do Not Chose To Reboot The Device
8.Return To Recovery
9.Flash SU FIX SuperSU Download
10.Flash Nut Recovery http://nut.xperia-files.com/download...NoYWJsZS56aXA=
11.Flash Kernel https://www.mediafire.com/?ucsz91v3rhucb1j
12.Reboot​
F.A.Q
Q.Does This Rom Support D6502?
A.At The Moment No.But In Future Yes
Q.Do I Need To Flash Kernel Seperately ?
A.No Its Already Included.
Q.Full Screen Caller From Aroma Doesnt Work
A.Yes For Now Its A Future Project
CHANGELOG
Ultimate PureXZ2 V1 29.07
Initial Version​
DOWNLOAD
Ultimate PureXZ2 V1
http://www.mediafire.com/download/8d...te_PureXZ2.zip
====== BETA UPDATE ======
Please Check The Stability And The Bug Fixes Except The White In-call dialler..
Ultimate PureXZ2 V1.1[BETA]
*Fixed Missing Tap To Wake Up
*Fixed Volume FC
*Fixed Email/Exchange Server FC
*Added Picassa In Album.
*Added In Aroma Option To Install Stock Themes With Thick Colours.
Instructions
1.Flash Zip
2.If You Are Using White Rom Select 1/Else if Black Rom Select 2 Accordingly
3.Follow Aroma
4.Reboot
P.S From Now On
White Rom Is Ultimate PureXZ2.
And Black Is Ultimate BlackXZ2.
DOWNLOAD - http://www.mediafire.com/download/9d...eXZ2_V1.1_.zip
This Is A Beta Version
Der ursprüngliche Beitrag von 20:51 Uhr wurde um 21:00 Uhr ergänzt:
ich habe das rom mit "dirty flash" installiert und der erste eindruck ist gut.
ich teste einmal und poste dann ob good, bad or ugly :rolleyes2:
endlich wieder :thumbsup: BLACK APPS :thumbsup:
Reaktionen: Wolf65 und Robby57
Screenshots Android L, LG und andere Themes
Ich bin schon gespannt auf deine Bewertung.
@bandit_crc
...also das ist jetzt schon ein wenig frech -> drag & drop!
Das kann ich mir bei xda genauso anschauen!
Da das hier eine deutsche Seite ist hätte ich mehr erwartet!
Abgesehen davon hab ich es auch seit gestern drauf...schauen wir mal!
@XperiaZx
naja, faule säcke machen eben sich das leben leichter :biggrin:
dafür habe ich die arbeit in die screenshots gesteckt.
hier mein erfahrungsbericht:
+ die akkuleistung ist gut (deepsleep über nacht 98%, Wlan, Mobile Daten an)
+ viele themes zur auswahl
- FC Datenaustauschdienste
- FC bei Einstellungen -> Töne -> Lautstärke
- FC bei Einstellungen -> Ultimate Menu -> Xposed Framework und den Modulen Xperia Xposed und GravityBox
die fehler treten bei dirty flash sowie bei clean install auf.
das ROM hat gute ansätze aber auch noch einige Kinderkrankheiten.
ich werde erst einmal wieder zu Monx wechseln und auf die updates von dipesh1502 warten.
akku - sehr gut
datenaustausch -läuft
lautstärke - fc, über lautstärke wippen bei medieneinstellung(gravitybox) kein thema
xposed framework nur fc wenn man über diese einstellung geht, über apps menü läuft es!
ich bleib erstmal hier :D
GRuß
-ach ja faule ......:flapper:
Naja selbst ohne FCs kann ich mir kaum vorstellen dass die Rom Monx das Wasser reichen kann (noch nicht). Einzig die Black Apps wären interessant. Themes kann man sich auch selbst installieren. Abgesehen davon werden wohl kaum kostenpflichtige mit in der Rom enthalten sein.
Inwiefern meinst du "kostenpflichtige", Robby ? :D
Naja der Dev scheint nicht unerfahren zu sein. Finde es jedoch generell immer tricky, wenn der Dev das Device nicht selbst besitzt. :(
Was noch nicht ist, kann ja noch werden.
Der ursprüngliche Beitrag von 12:48 Uhr wurde um 12:49 Uhr ergänzt:
Nachtrag: 1. Stable Build soll wohl alsbald folgen ;)
Reaktionen: Robby57
Hi meet
Meinte die Design Themes welche du ja im Playstore nachinstallieren kannst.
Sowohl freie als auch kostenpflichtige. Einige Devs haben diese ja auch schon abgeändert und zum Download bereit gestellt. Man kann sich da nicht ganz sicher sein ob es sich nicht um gleiche handelt nur unter anderen Namen. Deshalb lade ich lieber vom Playstore, da weis ich jedenfalls dass alles legal ist.
Hatte da selbst schlechte Erfahrung gemacht in meinem eigenen Rom und musste daraufhin beweisen daß es sich um kostenlose Apps handelte.
Aber egal, finde es auch etwas merkwürdig eine Rom zu kochen ohne das Z2 zu besitzen.
LG Robby
Reaktionen: meetdaleet
Update V1.1 ~ 37 MB
OP aktualisiert
knofi
wwallace1979
wwallace1979
wwallace1979
COOGOR
