Android 4.4 - CyanogenMod 11.0 NIGHTLIES online !
  • 31 Antworten
Technoolli
Technoolli
Stamm-User
112
Android 4.4.2 - CyanogenMod 11.0 NIGHTLIES online !
CyanogenMod is based on the Android Open Source Project with extra contributions from many people within the Android community. It can be used without any need to have any Google application installed. You will need to provide your own Google Applications package (gapps). CyanogenMod does still include various hardware-specific code, which is also slowly being open-sourced anyway.
CyanogenMod is a free, community built, aftermarket firmware distribution of Android 4.4.2 (KitKat), which is designed to increase performance and reliability over stock Android for your device.
Code:
#include
* Your warranty is now void.
* We are not responsible for bricked devices, dead SD cards,
* thermonuclear war, or you getting fired because the alarm app failed. Please
* do some research if you have any concerns about features included in this ROM
* before flashing it! YOU are choosing to make these modifications, and if
* you point the finger at us for messing up your device, we will laugh at you.
Instructions:
First time flashing CyanogenMod 11 your device, or coming from another ROM?
1 Download the zip(s).
2 Optional: adb backup
3 Boot into recovery
4 Perform a NANDroid backup of your current ROM.
5 Full wipe[data, cache, format system].
6 Flash CyanogenMod Rom Zip.
7 Optional: Install the Google Apps addon package.
8 Reboot.
Latest Build cm-11-20131226:
Code:
http://get.maclaw.pl/?id=379
Gapps:
Code:
http://get.maclaw.pl/?id=164
Quelle:
Code:
http://forum.xda-developers.com/showthread.php?t=2528466
Reaktionen: Lice
[ROM] [UB] [Kitkat] [4.4.2] CyanogenMod 11.0 NIGHTLIES
Code:
#include
Instructions:
8 Reboot.
UPDATE: 24/12/13
Latest Build:
Code:
http://d-h.st/oqO
Gapps:
Code:
Quelle: [ROM] [UB] [Kitkat] [4.4.2] CyanogenMod 11.0 NIGHTLIES - xda-developers
OMX scheint nach wie vor nicht zu laufen. :(
Neues Update:
Neuer Maclaw-Build
OMX -Gefixt
Bluetooth -Gefixt
Alles andere -Gefixt
Nur Videorecording funktioniert nicht
Und wo bleibt der link. ;D
Sagen Sie mal Mister, nicht mal mehr im Besitz eines Xperia U, und dann noch zu faul zum Googlen sein...
PS: Ist immer noch der selbe Link wie die letzten 50 male :*
Reaktionen: nexus_5
Natürlich :p
Reaktionen: joshua1996
Da meine Freundin das xperiaU besitzt und die 4.0.4 oft rumzickt. Dachte ich auch da CM zu flashen.
gibts da irgend welche grössere Bugs? (nicht funktionierende sensoren, Wlan Bug oder ähnliches?)
Hey
Bin wohl komplett unfähig, denn ich finde die Zip(s) nicht. Kann mir da jemand helfen?
LG :)
Download der Rom sollte hier zu finden sein: http://get.maclaw.pl/?id=379
Und hier noch die Patchnotes von maclaw:
New release (20131226) of CM11.0 for Xperia U is available!
Do full backup before installation and wipe data/cache (factory reset) after installation (only from stock ROM).
If you’re updating from older CM10.1/10.2/11.0 version, you don’t have to perform a wipe!
Changelog:
CM sources update
manual network finding fixed
bluetooth finally works (but still buggy) [munjeni/95A31]
wifi works correctly
update to 4.4.2
all changes with video (OMX) as for S3 Mini
Features
2D/3D HW Acceleration
audio (both speakers/headphones/microphone)
GPS and A-GPS – fast fix getting
compass
sensors
Wi-fi
Wifi/USB tether
Google Play
CM11 functionallity
CPU sleep mode
MTP
ADB
YouTube HQ
Wifi direct
external storage
camera/video playing
offline charging
built using Linaro toolchain
Issues
Bluetooth
I’d be glad, if you shared links to our download page, instead of direct links to download.
Also would be great, if you wouldn’t create the mirrors ;-)
Thanks.
Hab noch ein Screenshot angehängt auf dem man den Download sieht. Einfach drauftippen. :)
Reaktionen: Lice
SUPER!, aber bei mir kommt CWM status 7
Vielen Dank :)
Wann kommt denn eine "normale" Version der ROM raus?
Was meinst du mit 'normale' Version?
Eine offizielle ROM wird fürs Xperia U nie kommen, eine Stable Version (also für Daylie-Use) hingegen ist aber schon raus.
Also einfach die letzte Stable runterladen.
PS: zum Status 7: das ist ein Fehler in der updater-script, dazu in der zip nach \META-INF\com\google\android navigieren, und die updater-script editieren.
Da nur die Zeilen löschen:
assert(getprop("ro.product.device") == "ST25i" || getprop("ro.build.product") == "ST25i" ||
getprop("ro.product.device") == "ST25a" || getprop("ro.build.product") == "ST25a" ||
getprop("ro.product.device") == "kumquat" || getprop("ro.build.product") == "kumquat");
Dann die Datei überschreiben und nochmal versuchen zu flashen.
Hat mir bisher immer beim Status 7 Code geholfen ;)
Reaktionen: Peterschaf
Seit gestern ist ein neues Release des CM11 raus :D
Bei der ersten Installation hatte ich dann auch den Status 7 Error. Ich war da aber noch auf der Stock Rom (also die CM11 Erstinstallation) und vermute, dass der Fehler irgendwie mit dem alten CWM zusammen hängt. Jedenfalls hab ich dann den Kernel (boot.img) extra geflashed, ins CWM gebootet und die Installation ist dann problemlos durch gelaufen.
CM11 läuft am Xperia U ja richtig geil 8)
Reaktionen: Eichhorn
Hallo alle zusammen,
ich werde wohl demnächst ein Xperia U in die Finger bekommen und möchte dort CM11 drauf bringen. Zur Zeit muss da wohl irgend eine offizielle JB Version drauf laufen und das geht gar nicht. Wie bekomme ich die CM11 Version auf dieses Phone? Ich selbst habe ein Samsung ACE2 und habe mich somit bisher nur damit beschäftigt. Das Xperia ist wohl noch im original Zustand, also weder gerootet, noch sonst irgend etwas. Wie genau ist bei diesem Phone die Vorgehensweise? Was benötige ich noch alles dazu? Mit welcher Tastenkombination komme ich bei diesem Phone in das Minibetriebssystem? Brauche ich dazu noch irgend eine CWM Version?
Vielen Dank schon mal für eure Hilfe
Gruß Eichorn
Hi, Stock JB wird (kann/darf) nicht drauf laufen, da das letzte Update ICS war ;)
Tastenkombis brauchst du nur (Handy ausgeschaltet):
Vol up + USB-Kabel einstecken = Fastboot = Modus um kernel zu flashen
Vol down + USB-Kabel einstecken = Flashmode = Stock-Firmware flashen
CWM liegt bei Sony mit dem Kernel in einer Partition, musst also einen Kernel mit CWM flashen (ist im CM11 Kernel drin)
Kürzester Weg:
Bootloader unlocken
CM11 zip aufs Handy
CM11 Kernel flashen , über fastboot (aus der CM11 zip)
Anschalten und noch beim Sony Logo Vol down drücken
Im CWM CM11 flashen
Tutorial zum unlocken und Flashtool gibt es hier genügend ;)
So, nach einem ganzen Tag Arbeit an meinem XU habe ich jetzt Bootloader unlock, Rootrechte und CWM v6.0.1.2 geflasht.
Im ersten Versuch CM11.0 zu installieren habe ich die Fehlermeldung Status 7 bekommen.
Habe dann wie oben beschrieben das updater-script bearbeitet.
Jetzt bekomme ich einen neue Fehler Status 6 :confused2:
Hab auch leider im großen G nix passendes gefunden :-/
Es ist die erste custom die ich versuche auf das XU zu flashen.
EDIT:
Wer Googeln kann ist klar im vorteil.
Ich musste die updater-script mit notepad++ als UNIX code speichern
http://forum.xda-developers.com/galaxy-s2/help/cwm-error-status-6-t1535546
http://boardreader.com/thread/update_zip_error_status_6_677jjXi0hq.html
so hats dann geklappt =)
EDIT2:
So weit, so gut.
nur hab ich zwei probleme
a.) ist es normal das man kein google-konto einrichten kann?
b.) ich habe drei apps über .apk installiert. alle drei funktionieren nicht. "xyz" wurde beendet
habe versucht firefox, playstore und flappybird installiert zum testen.
playstore schließt sofort unf firefox nach 4sekunden.
flappybird läuft komischerweise am längsten :huh:
kann mir da jemand was zu sagen?
Habt ihr auch das Problem, dass das Xperia U extrem träge läuft?
Ich habe Build cm_kumquat-userdebug 4.4.2 KOT49H t3157a0c40 test-keys drauf und noch 110MB RAM frei, trotzdem reagiert es sehr träge auf Eingaben - ist das normal?
Habe diese (cm-11-20140311-UNOFFICIAL-kumquat) drauf und es läuft super.
Nur mit dem Akku kämpfe ich zur Zeit. Knappe 24 Stunden sind echt knapp. Suche gerade den/die Übeltäter.
Hallo liebe Forengemeinde,
ich möchte gerne CM11 auf mein SXU flashen, bin mir aber noch nicht ganz sicher wie der exakte Ablauf ist. Habe bereits den Bootloader geöffnet. Das hat problemlos geklappt. Ich habe mir die CM11.zip und die gapps geladen.
Wenn ich das jetzt richtig verstanden habe, ist der nächste Schritt den Kernel mit dem Flashtool zu flashen. Richtig?
In der CM11 zip habe ich jetzt etwas gesucht. Ich bin mir aber nicht sicher welche Datei das ist. Die einzigste Datei die ich mir vorstellen könnte ist die Boot.img.
Ich habe das dann so verstanden, dass der Kernel ein CWM Recovery mitbringt. Also würde ich nachdem der Kernel drauf ist zunächst ins CWM booten und ein Backup von der Stock ROM machen. Danach dann die CM11 zip Datei aufs Handy kopieren und wieder aus dem CWM die zip flashen. Vor dem flashen ein full wipe und den Dalvik cache löschen.
Dann noch die gapps auch aus dem CWM flashen? Und dann sollte es schon erledigt sein oder?
Ich habe leider keine Anleitung gefunden die das so genau beschreibt...
Vielen Dank für Eure Tipps
Viele Grüße
Stephen
