[Rom] [JB] Paranoid
  • 13 Antworten
johannes123
Gast
http://forum.xda-developers.com/showthread.php?t=1959091
THREE MUSKETEERS PRESENSTS
UNOFFICIAL PA for XPERIA S
Hey guys after being a member of XDA for many years and IMO longtime helper of others I have decided to try my hand at ROM building. Along with a great group of guys namely vertigo and benjamin.j.goodwin we started doing stuff on the Sensation Xl. We have now decided to branch out and build roms for other devices. This rom is a collaboration of us 3 working together and creating a hell of a compile machine...................... Enough now about the ROM
Features:
- this needs no mention as PA is now well reknowed.
- Pure PA build complied from source 26/10/2012
- Interface tweaks are fully functional as instructed by my beta testers
- Performance settings and per app colour should work
- customise and colour nav and status bar also icons
- full hybrid mode for Phablet and Tablet UI
BUGS:
- some cm10 bugs my be present
- YOU TELL ME
PA 2.5.2 will be compiled soon and there will be a stock version of PA and Inverted version Dark Passion with loads of inverted apps
- as far as screenshots go there are many all over XDA for PA
Install:
- obviously you need UNLOCKED bootloader and CWM recovery installed
- download rom zip and gapps and copt to internal sdcard
- boot into recovery
- wipe data/factory reset, wipe cache, in advanced wipe dalvik cache and fix permissions(optional)
- in mounts and storage format system
- install zip from sdcard and choose zip to install
- install gapps
- reboot
Enjoy the rom
I have not personally tested this as my Xperia S has LB but this has been tested by Felimenta97 and greatpatel007 that its almost fully functional. I implore you to hunt for bugs as I cant and report so we can do our best to fix it and make this fully functional
Beta Testers
greatpatel007
Felimenta97
This is the thanks bit now... firstly the other Musketeers...
Benjamin.j.Goodwin - for being an absolute star, giving me pointers and helping also for being absolutely nuts
Vertigo - for his tireless compiling, testing, ideas and generally keeping the team blessed... and of course being a legend
Thanks also goes out to
CM team
PA team
DutchDanny - AMazing Guy and Leader
BinDroid Team for loads of help when I first started
XDA for just about everything else
If you think you need to be thanked, just let me know
ROM DOWNLOAD:
http://d-h.st/6Km
Latest GAPPS
http://goo.im/gapps/gapps-jb-20121011-signed.zip
http://tinyw.in/poPq
Reaktionen: xspit
Habe die Rom seit heute drauf.
Läuft sehr sehr flüssig, man kann bei allem zwischen tablet oder Telefon modus tauschen.
Man hat generell sehr viele Einstellungsmöglichkeiten.
Das einzige was einen vielleicht von der Rom abhält ist die nicht funktionierende Kamera, für mich jedoch kein K.O Kriterium.
Bei Fragen fragt ruhig ;)
bildchen :D
mobil getippt auf meinem Xperia S mit Paranoid
Wie siehts mit HDMI aus.
gesendet von meinem Sony Xperia S
Geht noch nicht, wird aber kommen.
Das ist flasch. HDMI funktioniert mit dem ROM (wie auch unter CM10). :D
Vielleicht noch nicht 100% rock solid, aber Audio/Video/Bilder kann man über TV anschauen.
Das ROM ist wirklich gut. Ich habe es heute mal für einen ganzen Workday im Test. Funktioniert bisher klasse.
Reaktionen: xspit und Bobbie25
Könntest du bitte einen Screenshot posten, wo man das Datenroaming einstellt, bzw. ein- und ausschaltet?
Wäre super.
Wäre super.
Reaktionen: rolex0815
funktioniert der camera-fix mit dieser ROM?
Müsste man mal ausprobieren :o
mal sehen, am Wochenende vielleicht :- )
Sehr unwahrscheinlich. PA basiert auf CM10/FXP >=144 und da funktioniert der Fix auch nicht mehr.
Reaktionen: xspit
So, das Warten hat ein Ende. Auch bei PA kommt der Kamera-fix. Ich habe eben eine inoffizielle Testversion (dürfte baldigst auch released werden) geflasht und die Kamera funktioniert. Zwar mit den bekannten Einschränkungen, aber sie funktioniert.
Damit hat das leidige Thema CM9 (ICS) oder CM10 (JB) für mich endlich ein erfreuliches Ende gefunden. CM10 (bzw. PA) und damit JB bleibt mein daily ROM! :scared:
Reaktionen: xspit
  • Gonzales70
Gonzales70
meetdaleet
  • Gesperrt
  • Angepinnt
  • meetdaleet
meetdaleet
meetdaleet
Belze
Belze
Belze
