[ROM] JB AOSP 4.3 alpha 1 - few bugfixes and things added
  • 20 Antworten
Belze
Belze
Stamm-User
206
Besser als je zuvor. :winki:
Die Rom läuft Super stabil, flüssig und mit erheblich besseren Akkuverbrauch.
:winki:
JB AOSP 4.3 alpha 1 by LeTama
:cool2: Dieser Post wird immer aktuell gehalten. :cool2:
Install Notes
  • You need unlocked bootloader and a working recovery.
  • Download installation zip
  • Copy it to internal storage
  • Wipe Data/Cache
  • Install gapps for 4.3. Currently, we don't have "official" gapps from CM team, I used PA ones with good success.
  • Reboot and let the rom settle down a bit
Working:
Display / 3D (with some stuttering, under investigation)
Audio (without LPA, won't add it)
Calls / SMS / MMS / Data
Camera (Pictures / Videos)
Bluetooth
Wifi
Wifi Tethering
Sensors
GPS
Hardware video encoding/decoding
Offline charging
NFC
Not working:
FM radio: I won't implement it in aosp with current proprietaries as they will conflict with 4.2+ bluetooth.
HDMI.
Auto brightness (disabled now)
And probably more, let me know
WIFI EAP. (untested, can anyone confirm ?)
SELinux
Missing
TRIM Support
Known issues
1080p video stuttering (waiting for new Sony firmware)
voip audio disabled, voip is going through normal channels (waiting for new Sony firmware)
Wifi direct disabled (waiting for new Sony firmware)
subway surfers game is not working
Market complains he can't update apps on internal storage.
Camera is missing 12 and 9 MP profiles
SuperSU not working. You can flash a working one here.
Download
Changelog
2013/08/07 - Alpha 1
- SELinux added
- Media server crash on audio notification fixed
- Move to SD fixed
- Ril crash on some mvno fixed.
- SuperSU updated to 1.51
- 12 and 9M camera size
- Panorama fix
- Google backup selected as default
- EAP finished
2013/08/03 - Alpha 0
__________________________________________________
Thanks to Letama
:scared: ein Danke ist immer gern gesehen :scared:
Reaktionen: Fafy, trebor287, Androidfan7 und eine weitere Person
Hm komisch.
Geht nicht flashen, es bleibt immer beim flashen hängen.
genauer gesagt bei "installing update..."
Edit: Hat mit Sideload geklappt! Klasse Rom!
Androidfan7 schrieb:
Hm komisch.
bei mir hat es auf den normalen weg geklappt....
Sieht mir nach Custom Rom aus.....ist das richtig??
Und von was wurde die Rom portiert?
es werden doch sicherlich noch einige Funktionen hinzukommen oder?
Ja klar ist das ne Custom Rom, was auch sonst :D
Es ist nicht geportet!:
" Here is my attempt to bring pure JB AOSP 4.2.x to our Xperia S. It's based on AOSP work initiated by JB Queru from Google and Sony. Sony did put it on hold waiting for approval for proprietaries release, but as I don't have such requirements, I started working on it. It's currently a mix of CM10 proprietaries, Nexus 4 Adreno drivers and a fxp based kernel that supports them."
Die Rom ist komplett aus sourcen compilt, jedoch wurden einige Treiber vom nexus 4 und einem Samsung gerät geportet. Deswegen wird auch oft von mako und hal Versionen gesprochen. Das nexus 4 hat zwar eine andere GPU, die Treiber scheinen zum teil aber gleich zu sein.
Funktionen werden denke ich nicht hinzukommen, da aosp wirklich pures vanilla Android ist, ohne Modifikationen wie z.B bei cyanogenmod.
Reaktionen: trebor287
Hallo Leute,
also ich muss ehrlich sagen, für ne alpha ist diese rom ziemlich stabil. hab die alpha jetzt seit knapp ner woche drauf. lief die ganze zeit problemlos.
also durchaus für den daily use geeignet. mir fehlt jetz echt nur noch die möglichkeit das sxs als massenspeicher nutzen zu können.
jetzt werd ich mir mal die alpha 1 gönnen :)
Ja, dem stimme ich vollkommen zu. :D
Akkuverbrauch ist besser als bei 4.2 und 4.1 - läuft schnell und stabil.
Damit das Xs als Massenspeicher erkannt wird benutze ich unter dieser Rom die app xperia sd card mounter von doomlord :)
die app hab ich auch schon probiert, aber bei mir klappts nicht :confused2: irgendwelche tipps?
Hab die Rom nun seit ein paar Tagen am laufen!
Keine Bugs, keine Hänger, keine Probleme mit wichtigen Funktionen, läuft bei mir ehrlich besser als jene Stock und besser als alle anderen Costum die ich bis jetzt drauf hatte!
Nachtrag(22.8): Ich kann keine Videos bei Youtube gucken!
Oder MX Player nutzen, wenn man kein You Tube auf dem Handy haben will.
Läuft sehr schön! Um einiges aufgeräumter und übersichtlicher als PAC.
Hey,
die Rom ist super läuft sehr schön.
Eine Frage wie kann ich mein S jetzt rooten ?
Wird wohl noch eine Rom mit TRIM kommen?
  • Gonzales70
Gonzales70
Nostix
  • Nostix
7 8 9
alinho61
Belze
Belze
Belze
