[ROM] Du@lcore Rom [Simple, Clean & Fast] [TWEAKS] [AROMA]
  • 80 Antworten
Nostix
Nostix
Dauer-User
572
[ROM] Du@lcore Rom v5.1 [Simple, Clean & Fast] [TWEAKS] [AROMA] [15.09.2012] - xda-developers
- Based on 6.1.A.2.50
- Bug Free and battery friendly
- New ! Battery % + Status toggles mod AOSP themed
- Push some app in /system/app with Rw-r-r permissions
- Remove lot of junk from Sony (Timescape and all addon, Facebook and extension, Home Xperia...)
- Remove lot of Bloatware from the 6.1.A.2.50 Generic firmware
- Latest NOVA Launcher (Very fast
) or Sony Xperia GX launcher
- Latest Titanium Backup Root
- Cyanogenmod 10 HD Boot Animation (very nice
) or Stock Boot Animation or Nexus Boot Animation (NEW ! Galaxy Nexus
- AOSP lockscreen compatible with music shortcuts (thanks to skyfir123 for the framework
) or Stock lockscreen
- Added Jelly Bean Animation
- Wake up MOD with volume up and down key
- Added Adobe flashplayer (because you can't download it from market
- Added Quick Setting Panel for toggles
- AOSP themed with lot of stuff from Skifyr123 ( please check his thread and "thanks" him => here)
For AOSP theme in system menu, go to settings/display/theme and choose the theme at the left
CHANGELOG :
Du@lcore ROM v9 :
Added new features !
- Cybershot MOD 2.0
- Motion Snap by Sony
- Android 4.2 Clock
- Android 4.2 Keyboard (Swype)
- Android 4.2 Camera
- Android 4.2 Gallery
- Removed SD Mounter from /system/app (just install yourself as a classical apk)
- Some little fixes
Tweaks :
- Thunderbolt (good performance and battery life)
- NullVoid (very smooth
- Long life battery tweak (For better battery life
- Performance tweak (Powerful but not battery friendly)
I recommand NullVoid tweak, it rocks
Sony apps you can find in this rom :
- Notes
- Walkman
- Xperia keyboard
- Radio FM
- Xperia Smart tags
- Stock E-mail app
Known issues:
- GPS icon bug but GPS works perfectly
- Broken colors in aroma installer (sometimes)
Installation instructions :
- Download Du@lcore ROM and choose ONE tweak "ONLY FOR UNLOCKED BL"
(I recommand NullVoid) from XDA File Server (please hit the thanks button
New user :
- Go to "mount and storage" and choose "Format system"
- Wipe everything you want (if you want a clean install but this step is optional)
- In case of problem with my rom do a factory reset in recovery and wipe cache partition before install
- Install zip with recovery
- Reboot and enjoy ! (And don't forget to hit the thanks button
Du@lcore ROM user :
- Go to mount and storage => format system
- Install rom without wipe anything
- Flash your tweak again
Reaktionen: xspit
super ROM, hab's schon ne Weile drauf, ist sehr flüssig und schnell, und zuverlässig.
Ist wirklich sehr gut. Leider ist die Auswahl an Xperia S Roms nicht gerade groß...
Gesendet von S2
läuft es auch mit einem locked-bootloader?
Reaktionen: fabiosinus, xspit und trebor287
gerootet ist das handy schon bootloader ist offen .
RECOVERY-MENUE klappt jetzt was muss ich nun machen um ne rom z.b. die 5.2 aufzuspielen ?
MFG
rom als .zip auf den speicher vom handy packen, im recovery "install zip from sdcard" und dann die zip auswählen...
Reaktionen: bomann
besten dank hat alles geklappt !!
MFG
hab von 5.1 auf 5.2 geflashed, alles prima!
Reaktionen: trebor287
bis auf GPS fixed... war aber auch schon in der 5.1 ein Bug
Was ist das für ein bug? GPS funktioniert bei mir.
Die Anzeige spinnt....Soll aber trotzdem problemlos funktionieren...
Hab übrigens auch ein anzeigefehler von w-lan, die Anzeige wird nicht blau obwohl ich verbunden bin. Ist aber nur sporadisch.
Hat das von euch auch wer?
Gesendet von meinem LT26i mit der Android-Hilfe.de App
WLAN Anzeige stimmt bei mir.
wie trebor287 schon sagte, es GPS funktioniert, wird aber, wenn GPS fix ist, zu nem Download-Zeichen ... nervt auf Dauer
Irgendwie habe ich permanent reboots jedoch habe ich ne app in verdacht ...
Gibt es irgendwie ne Möglichkeit zu Protokollieren wann/warum es reboot gab?
ich habe folgendes Problem. Gehe ich in den Flugmodus und schalte ich Wlan danach an, wird mein Wlan-Netz nicht angezeigt. Seltsamerweise andere schon. Ist das so beim Dualcore Rom?
Vielleicht noch zur Info V5.2 + Advanced Stock ICS Kernel Build 15
Gruß, tjay.
Habe es gerade getestet. Funktioniert bei mir problemlos. Nutze die gleiche version und Kernel. Ich habe aber immer noch reboot Probleme obwohl ich es neu geflasht habe.
Gesendet von Sony Xperia S
Reboots hatte ich bis jetzt keine...
Mein Wlan-Problem liegt wohl am Router. Ist ein W921V von der Telekom.
tjay
Habe den gleichen Router mit Firmware 1.17! Ohne Probleme ... :D
  • Gonzales70
Gonzales70
meetdaleet
  • Gesperrt
  • Angepinnt
  • meetdaleet
meetdaleet
meetdaleet
Nostix
Belze
Belze
