[ROM][4.2.2 JDQ39 AOSP] Eos 4.0 -- Nozomi
  • 99 Antworten
Belze
Belze
Stamm-User
206
Endlich die ROM für das XS vom Team-EOS.
Team-EOS-Nozomi
Dieser Post wird nicht mehr aktuell gehalten. :cool2:
Features
NX Gesture Navigation Bar
Custom Quick Toggles Tiles with Brightness & Volume Seekbars
Softkeys Long-Press Actions
Custom Navigation Bar Ring Quick Launch Targets
EOS Status Bar Toggles
Navigation Bar Color w/ Project Glass (Auto-Transparency, not the Google Project Glass :p)
Status Bar Color
Battery Indicator Mods
Clock Mods
T-Mobile Theme Engine
Hide System Bars
Performance Settings
Volume keys switch depending on rotation. So the volume up key is always either on the top or to the right of volume down. (Toggle-able)
Default Volume Control Stream (Ring or Media)
Advanced power menu with reboot options.
Eos Control Center
MORE...
Install Notes
Going to EOS4.2.x from a rom < 4.2.x:
Backup everything !
Go to recovery
Make a full wipe / factory reset
format /system
Flash the rom
Flash optional kernel
Flash gapps
Wipe cache/dalvik
Reboot
Updating from EOS 4.2.x #XX to #YY:
You can usually skip the full wipe step.
If ever you encounter an issue make sure you make a full wipe first before reporting though.
Changelog
V18 u. V19
ALL
• Bug fix - I broke glass but archer100 fixed it for me
xda-developers - View Single Post - [ROM][JB 4.2.2] [Team EOS 4] [Nightlies -- TF101]
PHONES
• Xperia S (Nozomi) - BIG BUG FIX UPDATE #2
Reduced camera freezes/fc's as much as possible
ALS: blob DASH, restore JB ALS curve, enable auto-brightness
Kernel: resolve various lockup issues/LoD (Lag of Death) scenarios
12MP shooting removed, will be re-introduced with the 3.4 kernel
ALL
• Enable/Disable ECC icon and Expanded Desktop icon. If you want the
icon, you got it. If you don't, you don't get it. That's how it
should be. Look in ECC interface settings. This will likely
move later.
• Fix WiFi region code not sticking in ECC
• Clean up UI Mode summary in ECC. It now shows current mode.
• REVERT NAVIGATION DRAWER API IN SETTINGS! My apologies
to those who enjoyed it. The "not like" voices were louder here.
But I assure all of you, this is not over!
• Glass: Use bit shifting for alpha/color coversions
• This week's build was mostly to revert the Settings commit
that almost got me lynched by Eos tablet users. Note to users
with hardware key devices: I got my HTC One TMobile variant!
So i will be putting heavy focus on getting Cap key devices
where they need to be. Besides, I feel dirty running Sense!
Our HTC One device tree is almost ready now. Just needs some
polish.
V17
PHONES
Fixed: camera, ALS (DASH), weird 2nd core behaviour
Modified: kernel: compile CIFS modular to /system/lib/modules
ALL
• Show/hide menu overflow button: Fixes disappearing
action bar menu on tablets.
• new Navigation Drawer API for Settings! Much love and
credit to epic developer 0xD34D for porting it over.
• Phones: Fix disappearing left-aligned navbar when
on landscape orientation. This has a unique feel.
Give it a run.
• NX: remove bar glow feedback when action detected. NX 2.0
is definately on the agenda.
• Total Glass (Bar Transparency) Overhaul! Much cleaner and
simpler logic, valueAnimate glass bar transitions. This
smoothes out window changes dramatically. ECC: Contextutally
accurate dialogs for glass. I still want to do even more work
here, but this is good for now.
• Fix double bluetooth icons in system icon area on tablets
• Get HTC One device tree set up! Yes... I am finally forced
to get some quality hardkey controls in place. Look for some
Eos builds coming very soon ;D
V16
ALL
• Expanded Desktop from Cyanogenmod. Controls in ECC
Toggle in Global Actions power menu when enabled
Quick Settings tile for additional control
• Volume panel controls. Controls in ECC.
Single, expands, expanded, and none.
• Unlink notification and ringtone volumes
• Enable/disable volume hardware key tones
• Navigation Bar/Tablet UI Bar transparent with Live
Wallpaper when Glass is enabled. This is my personal
favorite this time around. It just looks epic!
• Bug fixes and misc code cleanup
• Fix back softkey color update on ime hint
• Some Quick Settings tiles did not have proper
Long Press actions, they do now.
TABLET
• Fix systembar clock size on large screens
V15
ALL
• Fix bug in which system would not respond to changes in ECC
I couldn't reproduce because i always launch ECC from
quick settings settings toggle long press. The bug came
from launching ECC from Settings
• Bug fix in which in some cases, tablet ui panel would
not open when the notification area was touched
PHONES
• Tuna series - update to LeanKernel v6.7exp230
V14
ALL
• Overhaul how UI modes are handled and controlled. All devices,
all UI configurations.
• Major bottom bar UI cleanup. Ticker is clean now, but could
still use some polish. Most UI blemishes are clean now.
• ECC - Navigation fragment now shows features contextually,
based on current UI mode. Cap key devices - i know it's
a little empty in there. Rlasalle and RaymanFX have some
stuff coming. They promise ;D
• Temporarily disable hide bars. I'm gonna bring in CM's
Extended Desktop implementation. It's stronger and better. But
had to disable for now as it's not set up with new UI controls.
• Fix rare SystemUI fc caused by Null Pointer on Mobile Data toggle
• Internals - Bring up feature observers when ECC is foreground,
unregister observers when ECC leaves foreground. This is a unique
feature to Eos! All other builds have about 100 content observers
running in SystemUI all the time! That's wasting precious CPU
cycles.
• This UI overhaul is part of a bigger picture. You will be able to
seamlessly and effortlessly transition from one UI style (soon to
include Pie ;D) regardless of device type.
• Build system - preparation for GCC 4.8 toolchain
• XDA user EvilDobe is now managing bug reports for us. There's too
many repeat reports coming in. Xoom and TF101 users, DISABLE HOTWORD
DETECTION PLEASE!!!!!!!!!1 And use a third party keyboard app. Please.
V13
BUG FIX UPDATE ONLY FOR PHONES.
PHONES
• Fixed up weird Navigation bar behavior here it would not move
to landscape and softkeys would disappear. 100% absolutely fixed
now. This only affected "normal screen" devices, also known
as "phones" ;D
• Tuna Series - update LeanKernel to 6.6exp230
V12
ALL
• Fix Airplane mode legacy toggle, but legacy toggles are gone
for the time being. But they will likely make guest appearances.
• Update wpa_supplicant from CM upstream. Thanks guys.
• Much more work on tablet UI. Still a WIP for sure. Keeping in
mind, we're not using any form of DPI change. That's for noobs!
We're using pure logic in configuring and loading resources.
So this feature will continue to get polished.
• Removed legacy notification toggles. All toggles are now
Quick Settings toggles! Added QS toggles to tablet ui.
to landscape and softkeys would disappear. At least i'm 99%
sure it's fixed ;D
PHONES
• Enable tablet UI
This is still a work in progress. There's definately style
work to do. But it's very fast and very stable and very fun!
• Nozomi - calibrate WiFi
fix torch system-wide
latest mako blobs
add back adreno200 3D egl blob
partial ANT+ support
• LGOG - updated device tree, vendor, and kernel
V10
ALL
• Enable Dalvik JIT (Just-In-Time compiler) Somehow this got
lost in a merge at some unknown point. Benchmarkers, start your engines ;D
• Center clock
PHONES
• Capacitive key devices - force a navigation bar (optional)
• Nozomi - fix location-based services
TABLETS
• Tablet style system bar (optional)
V9
ALL
• Update frameworks/av, frameworks/native, libhardware, and
libhardware_legacy to latest CM upstream.
PHONES
• Nozomi - RaymanFX pushed like crazy getting Nozomi online and running
Be sure to thank him if you enjoy our build!
• Tuna Series - bring LeanKernel up to v6.5exp230
• Almost done with TabletBar for large and xlarge screen devices. I'm doing
some prep work to bring in Paranoid Android's Pie UI. As always, keeping things smooth, steady, stable, and interesting.
Download
Team-EOS V19 goo.im
Gapps package goo.im
Team-EOS V18 share-online
Team-EOS V17 share-online
Team-EOS V16 share-online
Team-EOS V13 share-online
FAQ
What is better now, 4.2.2 rom X or teameos?
Performance wise: teameos! definately! We have Linaro all over, and only clean-select and implement features
AOSP is faster than CM-10.1. I won't judge about other roms, but see yourself...
These builds (teameos nightlies) will receive fixes faster than any other 4.2.2 rom! I am close to getting 1080p video recording to work!
The device configuration was build from the ground up, only minimalistic sonyxperiadev configs were used.
Planned features:
Trigger navigation bar for all devices
Optional PIE control
Custom EOS OC kernel featuring 1.7ghz max clock, 2d/3d adreno220 overclock, 2d gpu scaling
1080p video recording (to be fixed soon!)
Known Bugs:
No 1080p video recording
No FM Radio
HDMI
TEAM-EOS beinhaltet einen angepassten Kernel.
Thanks to Team-EOS
:scared: ein Danke ist immer gern gesehen :scared:
Reaktionen: syphex, ladebildschirm und ComicMan
Na die Rom ist schon geil :o
Aber erst wenn 1080p video gefixt ist :D
Gesendet von meinem LT26i mit Tapatalk 2
Habe noch paar Screen´s von mir im Ur-Zustand der V9 eingefügt.
Reaktionen: ComicMan
Hallo zusammen
ROM echt geil :smile: Habe aber ein Problem.
Bei mir funktioniert die Pull down bar nicht.
Komisch, funktioniert bei mir wunderbar.
Unterwegs mit XperiaS TeamEos 4
Geht wieder.
Hab die ROM mal neu installiert.
Gesendet von meinem Xperia S mit Tapatalk 2
@BrunoXkiller - spitze
V10 verfügbar
verlinkt in Post1
Hallo Belze,
Ich habe deine ROM gestern instaliert V9 und war echt zufrieden, es lief richtig super und keine Probleme.
Aber vorhin sagte mir das Programm das ein Update verfügbar ist(denke mal die V10) und das habe ich dann auch runtergeladen übers Handy.
Als er fertig war mit laden des Updates, kam wieder der Bildschirm mit dem bunten X ... und der leuchtet jetzt seit ca 1h und seitdem geht garnichts nix mehr.
Ich kann es weder aus machen noch neu starten oder ,oder, es reagiert gar nichts.
Kannst du oder andere hier im Forum vieleicht weiter helfen was ich jetzt machen kann?
Mfg und danke schonmal, bin für jeden Tip dankbar ,weiß echt nicht weiter:confused2::confused2::confused2:1
Update: Ca 1,5h später...Mittlerweile habe ich es hinbekommen das Handy neu zu starten und es startete ganz normal mit der V9.
Es funktioniert wieder alles super und gibt keine Probleme...ist wirklich eine klasse ROM.
Aber eine Frage hätte ich noch da ja der Udate herausgekommen ist...lohnt sich der Update von V9 auf V10 ??
Wie siehts mit Akkuverbrauch aus?
Misterx1140 schrieb:
Hallo Belze,
Das musst du selbst herausfinden aber eine neuere version hat (fast immer) bugfixes, neuerungen vllcht sogar besser akkulaufzeit daher lohnt es sich immer updaten (;
Updates lohnen sich meistens ;)
Gesendet von meinem Nexus 7
@misterx - hehee , schön wär's, ist aber nicht meine Rom. :rolleyes:
Zum Update - Schau nochmal in Post 1 bei Install Notes
Ich update auch nicht über den Goo-Manager. Läuft meist nicht so rund. Wie man sieht. ;)
Neue Rom auf Sd Karte, im recovery mit den Schritten ausser fullwipe installieren. Gapps nicht vergessen.
Im Changleog stehen die neu dazugekommenen Features.
@keinbockwurst - besser als bei der Leak oder den angepassten Leak-rom's
Ich Poste demnächst paar Screenshots.
Gesendet von TF101 mit TeamEOS4
Die Features für das nächste Update (V11) sind:
Torch fixed (statusbar toggle, 3rd party apps, etc).
WiFi calibrated. Should be better now.
Partial ANT+ support.
New mako egl blobs
Added back a missing adreno egl blob
Es tut mir leid, dass ich mit einer Anfängerfrage komme:
Ich habe folgende Punkte bereits unternommen:
- Bootloader Unlocked
- Root
Kann ich jetzt hier an dieser Stelle weitermachen, oder fehlt mir etwas??
Backup everything ! => bereits erledigt
Go to recovery
format /system
Flash the rom
Muss ich die EOS-nozomi-20130513-10.zip auswählen von der SD Karte meines Xperia S per Recovery Mode?
Was muss ich hier machen? Oder kann ich das auch auslassen?
Flash gapps
Muss ich das direkt nach der Rom Installation machen ohne das ich sie jemals gestartet habe?
Wipe cache/dalvik
Reboot
Ja du hast alles richtig gemacht :thumbup:
Jetzt einfach wipe data also factory reset, dann wipe dalvik cache und dann kannst du direkt die ZIP und die gapps flashen und rebooten :)
Der ursprüngliche Beitrag von 12:19 Uhr wurde um 12:19 Uhr ergänzt:
Einen optionalen kernel musst du nicht flashen, der kernel ist schon dabei.
Reaktionen: ladebildschirm
Echt sau schnelle und sehr geile Rom! Ich bin begeistert:thumbsup:! Allerdings habe ich auch zwei kleine Bugs entdeckt:
- LED Flash lässt sich nicht per App oder auch nicht beim Videorekording aktivieren. Kennt jemand eine Lösung!
- Manchmal wenn man die Kamera öffnet, kommt die Meldung: "Galerie beendet".
Ansonsten 200 % schneller als die Sony Rom:thumbsup::thumbsup::thumbsup::thumbsup:!
Und endlich Android 4.2.2!
Hast du schon mal SlimBean getestet?
Ist meine erste Custom Rom seit meinem G1. Ich bleibe erstmal bei der Rom. Nach einem Tag testen bin ich immer noch sehr zufrieden. Die Rom ist so viel stabiler und schneller als das Sony Original.
Wenn du das sagst muss ich sie auch mal ausprobieren :D
Wenn du ein HDMI kabel hast teste mal ob es auch am Fernseher läuft
Ps: es heißt nicht Sony original sondern
Stock
Nein, HDMI funktioniert noch nicht. Zumindest nicht richtig. Steht auch in den FAQ.
