Belze
Stamm-User
- 206
Dieser Post wird nicht mehr aktuell gehalten. (letzter Stand 28.06.13)
Trinity Vengeance RaptorX V2.3
for Unlocked Bootloader
Features
Fully optimized and tweaked
Superuser Included
Doomlord Leaked JB kernel
Zipalign
Touch Sensitivity
Enabled Illumination Lights
Adjusted 3G / 3.5G Internet Speed
RAM Management
AROMA Based Installer
Bloatware applications removed
Zipaligned (Improved RAM management)
Zipalign on boot (for user applications on data partition)
sysro/sysrw commands support
Increased Battery Life
Adobe Flash Player support In AROMA added
Android 4.2.1 (Jelly Bean) - BASED On .200 Official
E8.0
Fully Customized Build.prop
Fully Deodex
Sony Xperia S / SL
Zipalign
Darky ZipAlign
Fully Tweak ROM
Governor Tweak
DarkyZipAlign
S-Force Audio
Over-The-Air Update
OTA
Mod Downloader
Trinity Mod
1080P Video Recording
Improved GPS Locking
Improve Performance At the Maximum Boost
Superuser Included
Zipalign
Touch Sensitivity
RAM Management
E8.0
Fully Deodex
Sony Xperia S / SL
Zipalign
Darky ZipAlign
Fully Tweak ROM
Governor Tweak
DarkyZipAlign
S-Force Audio
Over-The-Air Update
OTA
Mod Downloader
Trinity Mod
Changelog
Change-log for 2.3 Edition :
Using Aroma 2.X Fixed Starting AROMA Problem
Fix Acro S SD Card
Added LB Kernel
Zipaligned
1080p Recording Increase Bitrate
Added IO Tweaks Ultimate V1
Battery Tweak - BLX ( Battery Life eXtender Support At 1.6 Trinity Kernel. )
SWEEP2WAKE Config File Initial - files only -
Added SIO Tweak
Added Lionheart Tweak
Re-vamped AROMA UI
Added Trinity Files
Added ThunderBolt Tweak
Added GPU Gov. Tweak ~ Thanks to Github
Added Mpdecision Tweak
Added Thermald Tweak ~ Upto. 1.9Ghz OC Without Intense Back Heating will be available when 1.6 Kernel Has been released
Remove init.d ZRAM
Added New Build.prop
Added 5Ghz WiFi - Test init.d Tweak
Added swappiness Tweak
Added Readahead Tweak
Blocked Ads
Bloatware Remove
+ 6 More.
Change-log for 2.2 COLD Edition :
Fix Aroma Error 7 and Status 7
Added Auto-Reboot If Installation Is Done AROMA
Remove Touchscreen AROMA
Added The Use of Volume Keys @ AROMA
Rebased to .211
Added All Kernel At AROMA
Added Xperia SL Build.prop
Added Xperia S Build.prop
Added Acro S Build.prop
Fix Acro S Build.prop With Sensor Fix
Added Darky_Zipalign
Added I/O Tweak V2 - Increased I/O Score
Added Mobile Bravia Engine 2 - LB
Added Fiops Tweak init.d
Added Lionheart Tweak init.d
Increase mpdecision wakeup
Beats Hack
Version 2.1
I/O Performance Tweak
Added Trinity Kernel 1.5 Deluxe Edition
Added mpdecision Tweak
Added Trinity App Kernel
Added Black Themes
Added Initial File Fore StatusBar
Added Init.d Tweak
Added -O3 Tweak
Added New OTA System | Initial File |
Revamped Aroma
Added Smoothass Tweak
Added Ondemand Tweak
Added Dancedance Tweak
Fix Battery leak or Drain - init.d
Added VRT Hack
Added New build.prop
Fix 1080p Decoder
Fix Video Playing Lag
Fix Phone App Slow UI
Added Bulletproof
Added SuperCharge V6 - V2
Added OOM Tweak
Added init.d Startup /system/bin
Version 2.0
Stripped Now Available
Added New Kernel Of DooMLord
Add VR Tweak
Added Performance Tweak
Added OnDemand Tweak
Remove XDA Prem. ( warez )
Optimized settings.apk
Added Governor Tweak
Many Kernel Tweak Please See init.d
Stripped Version - SAME Changelog.
Version 1.9 Omega JB ( Jullie Series ) AROMA VERSION ONLY! STRIPPED NOT AVAILABLE UNTIL 2.0
Based At Official JB World
Added Test V1.0 Andreno Drivers
Added New Luncher
Added Kernel at AROMA - 3 Kind Of Kernel Created By Me Soon!
Added Security Measure To Insure my AROMA-config Will not be Copied
Added Navigation Bar Selection - Test
Added Root - SuperSU - Test
Added New DarkyZipAlign
Added Init.d Support
Added SuperCharge V6 - Will Be Fix When Drain Flow Occur
Bloatware Remove 1.0
Added Init.d Support Lock. Just To Make Sure
#!/system/bin/sh export PATH=${PATH}:/system/bin:/system/xbin chmod 777 /system/etc/init.d/* logwrapper busybox run-parts /system/etc/init.d/
Added PluX Sound Engine
Zipalign Apk
Deodex Apk
1080p Recording V1.1 Bitrate Increased
Added Signature at META-INF | AROMA To Make Sure my AROMA Won't be Used.
Version 1.8 Ultimate JB ( Delta Series )
Based In Official JB .200
Deodexed
Zipalign
Darky Zipalign
Performance Tweak
Battery Tweak
AROMA V1.1 ReVamped
Auto /system RW
Build.prop Tweak
OTA Support
Fixed Bootloop Issues
Added CPU Rendering
Added Google DNS
Added 3G or 3.5G Tweaks
Added Media Tweaks
Added Playback Tweak
1080p Video Recording
Version 1.7 Beast EDITION:
Fix updater-script-installer
Version 1.6 Beast EDITION:
Fix AROMA GUI
Added New Conversation Selection
Added New File Manager AROMA
Added New Battery Tweaks
Added 1080p Video Playback Mod
Added Performance V1.2 Tweaks
Added New Root Selection SuperSu or SuperUser
Added New Bootanimation Selection RC1
Added New .lib For Audio
Version 1.5 SPECIAL EDITION:
Added ThunderBolt Tweaks
Added 1080p MOD
Added S-Force Sound Engine
Added New OTA File
Added BlackTheme Initial Files
Added AROMA Tweak Selection
Added New Warning Notification.
Added New PuA Audio Engine
Version 1.4 :
Rework AROMA Settings
Fix Google Application at AROMA
Added Workaround in AROMA TO Get In
Fix S4 Luncher Now Working
Fix Twitter Now Working
Fix Supercharged V6 To Bulletproof
Added New Settings.ap API 16
Added New Luncher
Added Studio Audio
Version 1.3 :
Added Supercharge V6
Added ThunderZ Tweaks Support
Revamped Settings
Added New Setting Option Fixed 200%
Added Initial File for Official JB ( AROMA )
Added New Settings At AROMA
Added SuperScrolling Tweak
Added Velocity Tweak
2nd Bloatware Removed
Fix GSM
Fix 2G In Leaked Beta
Added New UI
Added Files for OTA 1.4
New Beats Sound System
New PsU Sound System
Version 1.2 :
Added OTA - Over the Air update
Added OC Tool In Settings
Added SMS Count in the Settings
Added LED Control In the Settings
Added New Tweak In Init.d
Remove Some Tweak that Cause Bootloop 2-6 Every Fresh Install
Remove Some Theme becuase of Size
Added New OTA ID
Added ZRAM
Added New SustemUI App.
Added WhiteBalance
Completely Remove Bloatware
Added Swarm Audio Engine
Added SRS
Added Beats
Added Galaxy S4 Luncher - BETA
Added DarkyZipalign
Version 1.1 :
Added Zipalign Init.d
Added DarkyZipalign Inti.d
Added Governor Tweaks Init.d
Added VR.Tweak
Added ZRAM Tweak
Added CFSK Tweak
Added Citbun Tweak
Added Netspeed Tweak
Added Edt_Tweak
Added Modified Speedy Tweak
Added Journalism Tweaks
Added RAM optimization
Added Init.d Sscript R/W System Files
Added New 4 Themes AROMA
Added sloopy smooth Tweaks Init.d
There Are 7 More :S Cant Remember.
Intial Release :
Initial Release
Added Luncher
Added Build.prop Tweaks
Added Illumination Lights
Added Sinsitivity Tweak
Added Tons of GApps At AROMA
Added Application at AROMA
Added Apex Luncher at AROMA
Added Nexus Luncher at AROMA
Added Apollo Music Player
Added MIUI Music Player
Added 3G/3.5G Tweaks
Added H+ Tweaks
Added Boot Tweak
Fix Acro S SD Card
Added LB Kernel
Zipaligned
Added SIO Tweak
Re-vamped AROMA UI
Added Trinity Files
Remove init.d ZRAM
Blocked Ads
Bloatware Remove
+ 6 More.
Rebased to .211
Beats Hack
Version 2.1
Added Black Themes
Added Init.d Tweak
Added -O3 Tweak
Revamped Aroma
Added VRT Hack
Fix 1080p Decoder
Added Bulletproof
Added OOM Tweak
Version 2.0
Add VR Tweak
Added New Luncher
Zipalign Apk
Deodex Apk
Deodexed
Zipalign
Darky Zipalign
Performance Tweak
Battery Tweak
AROMA V1.1 ReVamped
Auto /system RW
Build.prop Tweak
OTA Support
Added CPU Rendering
Added Google DNS
Added Media Tweaks
Fix AROMA GUI
Added 1080p MOD
Added New OTA File
Version 1.4 :
Added New Luncher
Added Studio Audio
Version 1.3 :
Revamped Settings
Fix GSM
Added New UI
Version 1.2 :
Added New OTA ID
Added ZRAM
Added WhiteBalance
Added SRS
Added Beats
Added DarkyZipalign
Version 1.1 :
Added VR.Tweak
Added ZRAM Tweak
Added CFSK Tweak
Added Citbun Tweak
Added Edt_Tweak
Intial Release :
Initial Release
Added Luncher
Added H+ Tweaks
Added Boot Tweak
Install Instructions
UB : Instruction
Installation Instruction!
1. Make sure Flash DooMLord Advance Kernel JB
2. Make Sure, Just Enjoy =)
2. Make sure After flashing Download My ROM
3. Click Install Zip from /sdcard
4. Click Toggle Signature Verification
5.Go to my ROM and Install.
6.then If Ask Install untrusted zip Click Yes.
LB : Instruction
0. Read this first!! http://forum.xda-developers.com/show....php?t=2326978
1. Make Sure You Have CWM
2. And Make Sure you are in .200 JB and Have A LB CWM,
F.A.Q #1
Experience Freeze On AROMA,
Solution : Use Keys ( Volume Button - / +) on Installing/F.A.Q #2
You have enable the signature verification but till freeze in the Starting AROMA.
Solution : Place it in A Desk and Do The instruction Provided
F.A.Q #3
Ive Ended Up A Android Error Image after AROMA installation
Solution : Force Reboot Power Up + Power Button It's Okay Its Successfully Installed.
F.A.Q #4
Battery Drain! OMG! Jessus!
Solution : Drain your Battery Until 0% Then Charge It Until 100%
LB : Instruction
F.A.Q #1
F.A.Q #3
F.A.Q #4
Download
Thanks to TrinityHaxxorX
ein Danke ist immer gern gesehen
