{X10}[DEVELOPMENT] - CM9.0 - FXP142 FreeXperia Project
  • 213 Antworten
Q
quercus
Gast
Quelle: XDA
{X10}[DEVELOPMENT] -FXP124- CM9.0 - FreeXperia Project
We suport following accesorries
LIVEVIEWLiveView | Phone Remote - Sony Smartphones (UK)
LIVEWATCH http://www.sonyericsson.com/cws/prod...ch?cc=gb&lc=en
SOURCES
https://github.com/freexperia
DONATE
https://www.paypal.com/cgi-bin/websc...=THUJZQB2U5PNC
Our team is not responsable of any damage that you or you phone will suffer by using our work
__________________
FreeXperia Project
Latest release FXP111
CM7.2 RC3
FXP124
FXP124_CM7.2_RC3
mirror
Files of jerpelea
CM9.0 RC0
FXP123
FXP123_CM9.0_RC0
mirror
Files of jerpelea
cm7.2 GAPPS ADDON - http://cmw.22aaf3.com/gapps/gapps-gb...828-signed.zip
cm9.0 GAPPS ADDON - http://cmw.22aaf3.com/gapps/gapps-ic...317-signed.zip
Face Unlock ADDON - http://cmw.22aaf3.com/gapps/gapps-ic...131-signed.zip
Baseband 64 (recomanded for 2011 devices)
SEMC BASEBAND 64 - http://ul.to/folder/yrqfhn
Supported Xperia Devices
ST Ericsson
U
Sola
MSM8660
S - nozomi
MSM8255
Active - satsuma
Arc - anzu
Live - coconut
Mini - smultron
Mini Pro - mango
Neo - hallon
Neo V - haida
Play GSM - zeus
Play CDMA - zeusc
Pro - iyokan
Ray - urushi
QSD8250
X10 - es209ra
BUGTRAKER & CHANGELOGS @ freexperia - FreeXperia - Google Project Hosting
Update auf FXP137 FXP137-cm-9-20120908-UNOFFI…zip (127,18 MB) - uploaded.to
Update-Ordner aller Geräte FXP137_CM9.1
Update auf FXP141 FXP141_cm-9-20121006-UNOFFI…zip (127,20 MB) - uploaded.to oder Download file FXP141_cm-9-20121006-UNOFFICIAL-es209ra.zip
Update-Ordner aller Geräte FXP141_CM9.1 oder Download file FXP141_CM91
Update auf FXP142 FXP142-cm-9-20121013-UNOFFI…zip (127,21 MB) - uploaded.to oder Download file FXP142-cm-9-20121013-UNOFFICIAL-es209ra.zip
Update-Ordner aller Geräte FXP142_CM9.1 oder http://rapidgator.net/folder/1161998/FXP142_CM91.html
http://forum.xda-developers.com/showthread.php?t=1938933 für den Cam-Fix unter CM9
Danke an das ICH​
Reaktionen: lkrys, bluelight21, mieszekatze und 2 andere
Wird man dafür einen unlocked bootloader brauchen?
Wahrscheinlich schon, brauchst für CM7 ja auch.
Error (404) wird angezeigt wenn ich gapps laden will pls reup.
Dangööö
UPDATE 06/03/2012
{ {X10}[DEVELOPMENT] - CM9.0 - FXP109 FreeXperia Project 06/03/2012
Update
{X10}[DEVELOPMENT] - CM9.0 - FXP112 RELEASED FreeXperia Project 19/03/2012
Gibts schon eine Übersicht was mit CM9 FX113 funktioniert?
Gesendet von meinem X10i mit der Android-Hilfe.de App
{X10}[DEVELOPMENT] - CM9.0 - FXP113 RELEASED FreeXperia Project 24/03/2012
Mein Freund, steht alles auf der ersten Seite - anklicken (changelog) und du weißt es. ;)
UPDATE
{X10}[DEVELOPMENT] - CM9.0 - FXP114 RELEASED FreeXperia Project 31/03/2012
Ahh ich bekomme es nicht insterliert :(
Bei meine Galaxy geht es so einfach. Aber hier sagt er mir immer in Recovery geht net.
Das X10 ist aber das es209ra oder? :> ich weiß nicht was ich machen soll *g*
Das was jeder halbwegs vernünftige User machen soll:
Genau schreiben wie er was gemacht hat - dann erst kann man auch helfen. ;)
PS: Welche Vorstellungen hast eigentlich von der halbfertigen ROM?
Habe das Handy heute geschenkt bekommen *g* habe ja mein Galaxy wollte nur mal gucken wie CM9 oder auch 7.2 auf dem Xperia läuft, bin mit ICS auf dem Galaxy mehr als zufrieden ;)
also ich habe nun CM7.2 zum laufen bekommen. Bei CM9 Hängt er beim dem Free Xperia Logo. Aber ich habe in der Update Zip auch kein Kernle gefunden den ich vorab über Flashtools insterlieren soll vielleicht liegt es daran??
edit.
Ich habe jetzt die Costum ftf in der EXP113 gefunden :) nun läuft zwar cm9 aber es ist alles orange??
ich hab über SEUS mein x10 auf stock 2.3.3 geflasht, über das flashtool gerootet, bootloader entsperrt, xrecovery draufgemacht und über dieses cm7.2 geflasht aber beim reboot bleibt es beim se schriftzug hängen.
woran liegt das?
UPDATE Seite 1 ;)
{X10}[DEVELOPMENT] - CM9.0 - FXP117 RELEASED FreeXperia Project 21/04/2012
Hi
Update auf FXP121 Download FXP121 update RC0 es209ra UNOFFICIAL signed zip
Update-Ordner aller Geräte Files of jerpelea: FXP121_CM9.0_RC0 folder
Im xda-Thread wird allerdings von Problemen mit dem Kernel gesprochen, laut FreeXperia soll man nicht vergessen den Kernel zu flashen, nur gibt es kein eigenes Kernel-Paket wie bei der FXP119. Einige reden davon den Kernel aus der .zip zu nehmen, alias kernel.sin, und daraus eine .ftf mit dem ftf-Creator zu erstellen, oder eine bundle. Siehe ab hier http://forum.xda-developers.com/showpost.php?p=26330593&postcount=563http://forum.xda-developers.com/showthread.php?p=26330593#post26330593
MfG
Hi
habe mit dem Flashtool eine Custom-Kernel.ftf erstellt, mit diesem fährt das Handy hoch hat aber einen extremen Gelbstich. Daraufhin den Kernel von der FXP119.7z Datei und danach nochmal FXP121.zip drüberinstalliert und der Gelbstich ist weg.
Der Kernel ist nun auch online http://uploaded.to/file/9jgnnzgk/from/ccquyj.
Wenn es damit auch das Problem mit den Farben gibt, soll man laut xda-Form, die Datei /system/lib/hw/copybit.qsd8k.so und mit der von der FXP113 ersetzen. Einfach mit Root-Rechten das ganze erledigen.
MfG
Mikemr
  • laugfred
Benji96
Teknicker
