[ROM] FreeXperia Sony UI Achotjan CM7.0.3 SE | FXP 2.0 | 31/10/2011 | V3 Released
  • 22 Antworten
Q
quercus
Gast
Quelle: XDA
Autor: Achotjan
Link: [ROM] FreeXperia Achotjan ARC_2.3.5 | CM7.03 SE - Gingerbread | 23/10/2011
[x10] Semc Debrand Engine | CM7.0.3 | FXP3.1 | FreeXperia Project **Released**
FreeXperia Achotjan CyanogenMod 7.0.3 SE Remplacement ROM
Hy this is a SE Remplacement ROM cm7.0.3 with Stock app and theme
this rom is Build using My SE Debrand sources, FreeXperia sources and cm7 sources
Feature Inclueded In This Rom :
--- Bravia Engine ---
--- Windows Media Audio Support !! ---
--- Stock Music Player ! ---
--- Stock Theme ! ---
--- Gallery with Facebook integration ---
--- based on latest (Gingerbread) CM-7.1 2.3.5 ---
--- Facebook inside Xperia and more ... ---
Credits :
FreeXperia Team , and cyanogenmod team
<B>REQUIREMENTS
  • Rooted 2.3.3 Stock ROM or custom froyo 2.2 / gingerbread 2.3 with (New SEMC Kernel)
  • xRecovery
  • work with New SEMC Kernel and baseband, 71+
Added from 2.3.3 stock or Arc / Play rom
  • SEMC MUSIC
  • tetris
  • PlayNow
  • oficesuite
  • Quadrapop
  • Creatouch
  • Facebbok inside Xperia
  • Favorite and call log widged
  • Timer Widget
  • NeoReader
  • Timescape and timescape widget
  • LiveWare Manager
  • PhotoWidget Big working !
  • SemcGallery with Facebook integration
  • Semc Calendar !
  • Semc Email !
  • AmbienTime visualisation wallpaper !
  • Backup and restore !
  • SemcSetupWizard !
WORKING
  • phone & data
  • location (GSM and GPS)
  • BT
  • WIFI
  • Multi Tuch (dualtouch)
  • sensors
  • Voice Command
  • GPS
  • USB Storage
  • video playback
  • video and audio streaming
  • camcoder 720p video / HD1080 pics
INSTALLATION
  1. Do a factory reset
  2. Wipe Cache Partition
  3. Wipe Dalvick cache
  4. Wipe Battery stats
  5. Flash the update.zip package via xRecovery
  6. Enjoy !
Check Post #2 for detailed changelog for each version
DOWNLOADS
CM7.1
" A update Before the 7.1 one wich will be the bestest "
Theme chosser : http://www.mediafire.com/?il7nrq2blc0490c
</B>
Reaktionen: lkrys
@Quercus: Du hast die ja bestimmt schon getestet, wie läuft die Rom so?
Vergleichbar mit Wolfbreak?
Hi debiba,
tja gute Frage - das alles dürfte eher ein persönliches empfinden als ein allgemeines sein.
Momentan laufen alle gut, da ja nicht wirklich großartige Veränderungen vorgenommen werden.
Einfach mal testen - und dir eine eigene Meinung bilden. :)
Oke gut ;-)
Danke, werd mich nachher mal dran geben :)
Sent from my X10i using Tapatalk
Hallo! Habe ein Problem mit dem Email konto, r2r Client. Was soll ich machen?
Danke.
Gehts vllt bisl genauer^^
Hier kann-soweit ich weis-keiner hellsehen
Was hättest du denn gerne genauer? Du kannst doch Lesen? Das Problem ist nicht googemail sondern das andere Email Konto: Meldung r2r Client wurde unerwartet beendet.
Mfg
Berila
:cursing:
Hallo
Bitte immer schön die Fassung waren. Un ein Hallo hat noch nie geschadet Debiba :thumbup:
Könnte beim installieren etwas schief gegangen sein?
gruss Lucien
Danke.
Sry war in eile, aber mit sonem post konnte ich nicht wirklich was anfangen, da nur von einem problem die rede ist, und nichts genaues genannt wird.
Grus
Reaktionen: lkrys und SirMarco
V 7.03.SE und FXP 2.0
Hab es auch mal drauf gehabt für ein paar Stunden! Ist aber nicht so mein ding (vorinstallierte Spiele usw.)! Bei reboot kann man Auswählen zBsp. recovery jedoch funktioniert es nicht! :bored:
Statt im recovery modus zu landen bootet es ganz normal ... :confused2:
wie lief es denn sonst so, performance, scrollen, batterylife...?
die apps kann man ja deinstallieren.
Preformance wie bei alle andren in Moment (gibt doch kein rom in Moment wo wirklich lahm ist)! Scrollen flüssig ... Batterie kann ich nicht sagen da zu kurz getestet.
Wenn ich ehrlich bin komme ich immer wieder zu WB zurück.
Läuft doch meiner meinung nach am besten ...
(bei den anderen Roms abgesehen von MIUI ist nix womit sie sich unterscheiden würden)!
ich habe auch WB 6.0 drauf
wobei ich meine das 4.0 irgendwie flüssiger lief, die 5.0 hatte ich nicht getestet.
hats du mal unterschiede bei WB-Roms festgestellt...?
Nun ich fand die alten WBs irgendwie Innovativer ...
Am besten lief bei mir noch das Ultima (das ja auch auf WB basiert)
Jetzt sind wir aber ein wenig offtopic :blushing:
Ja genau diese! Fand sie super gut nachdem ich sie nur kurz testen wollte blieb sie über mehrere tage auf dem x10 drauf :razz:
Ist einen blick wert
morgen.. eine frage an quercus,
es sind 2 download links..
ich weis jetzt nichmehr welcher welcher war, aber das eine konnte ich mit xrecovery ganz einfach installieren, war eine volle rom.. das zweite steht bei mir nicht zur installation dort.. also es ist auf der SD karte schon drauf, habs auch mal umbenannt und alles.. aber im xrecovery menü zeigt der mir das nich an...?
meetdaleet
  • Gesperrt
  • Angepinnt
  • meetdaleet
meetdaleet
meetdaleet
Teknicker
Q
quercus
Q
