Q
quercus
Gast
Quelle: XDA
Autor: achotjan
Link: [ROM] 2.2.1 froyo_Achotjan v03 sources developpement almost compleat
[ROM] CM-6.1.3 froyo_Achotjan v03 Fully Released ! ** 15/06/2011 **
Requirements:
1. Rooted 2.1 eclair ROM or custom froyo 2.2 / gingerbread 2.3 with (multitouch kernel)
2. xRecovery
3. Baseband ALL baseband supported , .67 is verry stable!
Installation:
- phone & data
- location (GSM and GPS)
- BT
- WIFI
- Multi Tuch (dualtouch)
- sensors
- Voice Command
- GPS
- USB Storage
- video playback
- video and audio streaming
- camcoder
- Timescape and timescape widget ! Arc Retail moded!
- LiveWare Manager (from Arc)
- PhotoWidget ( only small widget not use large one or you will have many FC when scrooling ! to stop FC go to settings/application/running app and clear data of Home.apk )
<B>
</B>
Autor: achotjan
Achotjan_Froyo_2.2.1
hi this is a SE like style Froyo cm6.1.3 ( 2.2.1 ROM ) by me, added Arc apps , widgets , settings and more
this rom is based on my own sources
Requirements:
2. xRecovery
Installation:
1. Do a factory reset
2. Wipe Cache Partition
3. Wipe Dalvick cache
4. Wipe Battery stats
5. Flash the update.zip package via xRecovery
6. Reboot and leave the phone alone 5min , Login into the market then reboot
7. Install new market via xRecovery , reboot
8. Go to CyanogenMod Settings , Tweaks and extras : and Select theme and choose " CM6.1.3-V4 "
9. Enjoy !
9. Enjoy !
Credits:
Zdzihu , Jerpelea , doixanh , and Android team to make this possible for our x10!
--- Achotjan_2.2.1_cm6_V03 ---
-- Changelog --
- http://forum.xda-developers.com/show...&postcount=960 -
-- Changelog --
Download :
Baseband 54 / 55 / 58 / 61 / 65 / 67
Baseband 46 / 49 / 52
WORKING : ( Everything)
- phone & data
- BT
- WIFI
- sensors
- Voice Command
- GPS
- USB Storage
- video playback
- camcoder
- added from 2.1 stock or Arc / Play rom
- tetris (Xperia Play )
- PlayNow
- oficesuite (Xperia Play )
- Quadrapop
- Creatouch (new)
- for NeoReader install neoreader app
- PlayNow
- Quadrapop
- Creatouch (new)
if you have no signal :
- open Dev Tools app / Bad Behavior / Crash system server
-for theme issue extract the CM6.1.3-V4.xml of update.zip/sdcard/cmtheme/ and put it on the phone sdcard/CMTHEME/- open Dev Tools app / Bad Behavior / Crash system server
<B>
If
