[2.3.3+2.3.7+arc][04/03/2012]ThGo2 v16.0 [Greatest] [ICS theme] [with T.E.A.M]
  • 33 Antworten
Q
quercus
Gast
Quelle: XDA
Autor: ThJap
[2.3+2.3.7+arc ROM][04/03/2012]ThGo2 v16.0 [Greatest] [ICS theme] [with T.E.A.M]
attachment.php
<B>
Latest info:
[Mar 4]
Code:
v16.0 some mod theme ported calendar, clock, JapaneseIME, calc, from xperia S ported Email, music, message, phonebook from xperia S ported widget, DLNA from xperia S make an addon ported Timescape, facebook-inside from xperia S update busybox mod theme, animation fix small bugs remove latinIME, add xperiaS IME update timescape addon modded home app***** kernel ***** update rpcrouter to newest (Thanks to tkymgr) support BZIP2/LZMA compress enable htrick update jhash to version3 native suppport ext3, ext4, cifs, nls_utf8 FPS uncap call volume fix added Scheduler (SIO & BFQ & V/R) added CPU governor (smartassV2, interactivex, Scary & lagfree), power up (ondemand, consavative) drivers update (CPU, video, and more) freqs and voltage 128000-1000 384000-1000 576000-1050 768000-1150 998400-1300 1075000-1300 1113600-1325 1152000-1350 1190400-1375 1228800-1400 a lot of smoother tweaking !! and more...You can see change history
System Requirements -
baseband: .71
xrecovery
- tweak -
Code:
--- ROM --- rooted xrecovery fully working native adblocking build.prop optimized Japanese like Xperia arc FPS fully uncap thanks to Z!! Bravia engine thanks to Z!! some audio files move to SDcard Automatic wipe of Dalvik Cache when flashing Update [Phone needs longer to settle at first Boot now but will be faster after some Time] Automatic ZipAlign (just 1st booting) SD Card Speed boosted VM/Sysctl tweaks Kernel tweaks Android Internal Taskkiller tweaked I/O Scheduler tweaks Reduced lags Better memory management Network speed tweaks & improvements Zip allined all Audio lags less 15% speedup reading database deep tweak SD readable freq xLoud enable (my kernel adjusted for xLoud, but it may brake your speaker)--- Included kernel details --- FPS uncap call volume fix BFQ I/O as default scheduler ext3, ext4, CIFS, TUN & UTF8 support add compcache touch respons up screen respons up battery fix update lowmemorykiller driver tweaks & many more! support BZIP2/LZMA compress fix SDcard driver backport some source from 2.6.32 CPU up to 1.22 GHz If you want to control CPU manually, you would need SetCPU from here: SetCPU In SetCPU remember to check "Set on Boot", but using O/C Daemon gives much better performance and battery then SetCPU Many CPU governors (SmartassV2, Ondemand, Performance, lagfree, minmax) overclock & downclock undervolt optimized CPU setting (latency, speed ...) 128000-1000 384000-1000 576000-1050 768000-1150 998400-1300 1075000-1300 1113600-1325 1152000-1350 1190400-1375 1228000-1400
Installation
Optional: Back up your mobile data APNs using APN Backup, as they will be erased when flashing this ROM.
1. Full wipe, Wipe dalvik cache, and wipe battery stats. include update scripts (thanks to tkymgr)
2. Flash the ThGo_v.XXX.zip package via xRecovery
3. Install Addon via xRecovery
4, Flash .71 baseband to use Flashtools (only first time!!)
5. boot & wait til phone will be stable...
6. If you done unlock, please flash my unlocked kernel. another kernel is getting low speed for my ROM.
fWxeG
Known isuue:
- tethering switch has an error 1st time
My ROM exclude even any google apps, you can install newest them from market
Google Search, Voice Search, Gmail, Maps, Street, YouTube,
Adobe Flash Player,
Change log:
* Have to read change log before install |
Change log in English | kernel change log
Known Issue
Downloads:
fWxeG
ThGo2_v16.0.zip :via xrecovery recommended full wipe
If you done unlock, please flash stock kernel. another kernel is getting low speed for my ROM
fWxeG
*addon timescape & face book from xperiaS:
- for unlock bootloader -
X10_2.3.3_Th_kernel-n1.1-BootManager-v2.0: for unlocked x10
X10_2.3.3_Th_kernel-n1.1_wifi: for unlocked x10
Th_min_voltage4: I got a minimum CPU voltage. If not booting, try to do down voltage.
old files
* Sonny Ericsson Driver for Win *
download driver (rar file)
* Add-on * via xrecovery
switch_to_arc_hardkey: switch hardkey to arc style for 2.3.3
switch_back_to_x10key: switch_back_to_x10key for 2.3.3
* custom kernel
I made new thread for kernel
</B>
Reaktionen: Mario1974, lkrys und Scum
Mensch Wilhelm Du bist ja wieder fleißig als Rom Scout unterwegs!!
TANKEEE
hatte gestern abend die installation versucht, funzte nicht...
1 was meint er mit " include update scripts"
3 welches addon?
4 wird das baseband nicht zuerst geflasht?
ich kam von baseband 54 mit froyo
habe per recovery die ThGo2_v2.2.zip geflasht
danach reeboot hing bei se-logo
akku raus, wieder ein, baseband 71 geflasht, hing wieder bei se-logo...?
hätte ich mal stattdessen "die alm" geguckt...:flapper:
wer weiss rat?
Du brauchst das 2.3.3 und das Baseband 71 - gerootet mit XRecovery - DANACH kannst diese ROM fehlerfrei flashen.
ok, installation erfolgreich..
mich hat das rom nicht begeistert
erstmal hatte ich nicht das black-design sondern den hintergrund vom 1.6
ließ sich auch nicht ändern (ohne aufwand)
lief mit ca 1100 mhz, akku hält wohl nicht so lange, obwohl nach seinen angaben undervoltet.
empfand es als nicht so performant.
bootvorgang dauerte jedesmal so lange dass ich dachte es hängt
hatte den eindruck dass es mit launcher p+ etwas fixer lief
ist nur mein persönlicher eindruck
Na hat doch schon mal funktioniert - super - na dann, auf zur nächsten! :)
ich hab nun schon einiges ausprobiert...
doch ich denke ich bleibe bei "wolf gb 4.0.4" hängen
läuft ohne oc top
stimmt - noch besser ohne Mod-Kernel.
läuft ohne oc top
Sehe es genau so ... :glare:
v4.1 fix
remove Setxperia
fix build.prop
fix scripts
kernel 028a
add 245MHz CPU freq
CM7!
Siehe Seite 1
V6
Seit dem Update auf V6 - kann man auch diese ROM mal testen.
V 7.0 - jetzt ist die ROM als durchaus brauchbar zu werten!
Chancelog:
v7.0
add & modify some scripts
update to Superuser 3.0
update link2SD app to 1.9.2
automatic CPU control (work around limitation when it's not installed CPU tuner, SetCPU, OverclockWidget, CPU master app)
screen on Max 998MHz Min 128MHz smartassV2
screen off Max 384Mhz Min 128MHz conservative
speed up booting
kernel 029d
speed up touch resons, moving and more
add some freqs and default voltage
128000-1000
384000-1000
576000-1050
768000-1150
998400-1300
1075000-1300
1113600-1325
1152000-1350
1190400-1375
1228800-1400
fix GPS conf (for all around the world, no need any GPS packs )
V 7.5
update superuser to 3.0.5
edit some scripts
compcache disable by script
kernel029e
GCC 4.6.2 106821
v9.3 just small update,install over v9.0
fix theme
back to my stable kernel 029e for longer life battery
[2.3ROM][31/10/2011]ThGo2 v10.0beta1 [collaborated withT.E.A.M] [ICS theme]
heavymetall66
  • heavymetall66
heavymetall66
heavymetall66
Q
quercus
Q
Q
LionZ
