[ROM] Xperia Pro Ultima
  • 56 Antworten
Dexxmor
Dexxmor
Philosoph
1.262
Neue Rom für unser Pro Xperia Pro Ultima. Es ist eine Xperia S Stockrom, gepaart mit CM Features. Ausserdem soll der Doomkernel drinnen sein.
attachment.php
ROM Features
Almost all Xperia S apps integrated except for lockscreen, conversations(you can use the Xperia S one if you want it's also bug free), FM Radio.
Reboot power menu integrated (Reboot, Fastboot, Recovery)
12 Power Notification menus with QuickPanel settings app to customize the notification menus.
Customized Xperia S Homescreen(Rotateable Home, 7 homescreen, 2 top desk corners enabled)
Beats audio support
Clear Bass support(no bugs)
Framework-res, framework.jar & SystemUI.apk mods applied
Xperia S Power Module enabled
Pre-Rooted
CosmicFlow & 3D Earth live wallpapers included
Xperia S theme chooser
Modified Package installer
And many more...
Kernel & Ramdisk Features
Overclocking support Overclockable up to 2.01Ghz (defaults at 1.02Ghz)
Lots of kernel governors enabled (SmartassV2, interactiveX, lagfree, minmax, Scary, smartass, and all the common governors)
Undervolting support
IO Schedulers noop, anticipatory, deadline, cfq, bfq, vr etc.
Swap enabled
TUN driver integrated
Some of Doomlords latest patches on Doomkernel
Doomlord's Touch Based CWM Support
Init.d Support
How to install
1. Download Rom and copy to SDCard
2. flash provided kernel using "fastboot flash boot <kernel name>"
3. Boot CWM
4. Flash the zipped rom using CWM.
5. Reboot & Enjoy
Version 1.01
http://www.sendspace.com/file/spkf1d - ROM
http://www.sendspace.com/file/3jcf8e - German Keyboard Layout version by cccs1
http://www.sendspace.com/file/s6qq0n - Kernel
http://www.sendspace.com/file/kw7gop - Flashable Wifi Modules [untested]
http://www.sendspace.com/file/ziaslh - Flashable File Manager (ES File Explorer) [untested]
Happy Flashing
Reaktionen: xdodox und Lubomir
gerade aufgespielt....bootet!!!! :) bald mehr!!!
Erster Eindruck ist Super. Keine nennenswerte bugs. Hoffe das das powermanagment auch akzeptabel ist.
Gesendet von meinem MK16i mit der Android-Hilfe.de App
Weiß man warum das FM Radio fehlt? Kann im XDA-Thread dazu nix finden (&darf nicht posten) -- scheint als würde das nicht viele interessieren, obwohl die SE-Handies schon immer die besten Tuner hatten, imho...
Alle von mir gehören Radiosender bieten AAC+ 48kbits. Das läuft 1a im Auto(A2DP zum Android Autoradio), zuhause usw AUCH wenn man nach eine bestimmte Datenmenge gedrosselt wurde.
Was soll ich mit FM?? Schlechtere Qualität, sehr nerviges Ruherauschen, ...
Hätte das Handy DAB+ würde ich dir sofort zustimmen und die Funktion vermissen. Aber FM??
Hast ja grundsätzlich recht: DAB wäre natrürlich klar vorzuziehen.
Aber auf der anderen Seite sind die Radios in den Sony Handies immer von herausragender (Empfangs-)Qualität gewesen (und wer bietet sonst noch RDS?).
Ausschlaggebend ist aber was anderes: ich könnte es auch beim Pendeln ins Ausland nutzen (was für mich bedeutet: von Österreich nach Deutschland).
Auf der xda-Seite gibt es eine "German Version" die ist inklusive qwertz layout, Android Market und FM-Radio.
Es (V1.1.1) läuft bei mir super und ist für mich das beste ROM, das ich bisher probiert habe (und verträgt sich im sich Gegensatz zu CM7 sogar mit der Fritzbox bei der Arbeit!).
Das einzig nervige ist noch die "Großschreibautomatik" nach Satzzeichen, neuer Zeile usw., wie man die wohl mal abstellen kann...
Edit: leider startet das Fon während fast jedem zweitenTelefongespräch neu, schade...
Dexxmor schrieb:
Probier doch die Xperia Ultima ROM mal aus, sau mäßig G*** was die ROM leistet :D meiner meinung nach die beste GB ROM (nutze sie gerade im wechsel mit CM10)
hab die rom mal wieder drauf
ist schon geil 2.3.7 auf dem Pro... und sauschnell ist das teil auch noch
schade dass sie die Themes im Menü nicht fehlerfrei übernimmt (aber das NXT menü sieht auch Blau schwarz schön aus)
und ich konnte meinen Löschwahn befriedigen.. sicher 120 Sysapps gekickt :scared:
du hast sie ja schon länger? wie siehts mit Akkuleistung aus?
Ich nutze sie im Wechsel mit CM10 und PA (ICS kommt mir nichtmehr auf mein Pro :D) Sie läuft sehr gut, Batterie Leistung ist auch sehr gut (1,4 GHZ ) und der wechsel zwischen den Apps ist so saumäßig schnell :wubwub: Keine nervigen Ladezeiten :D Kann sie nur empfehlen.
(ICS kommt mir nichtmehr auf mein Pro )
wir verstehen uns :D
ICS + sony ist die dümmste erfindung seit es Android gibt (Sony und GB ist dafür die beste)
die Ultimo ist auch beim untertakten (800 mhz, brauch ja nicht so hardcoreapps, blos halt ausdauernd) sauschnell - fast so wie auf dem S :D
den kernel hab ich schon lange... denn er hat den besten Governor dens überhaupt gibt: Scary :guru:
was ich allerdings etwas schade finde, ist dass sie mit beats gepflastert ist... vieleicht ist das nur ein Subiektives Empfinden, aber im vergleich zur Standartlips von Sony find ich den Sound etwas weniger druckvoller und vorallem in den Mitten etwas schwächlich (der bass ist immer noch angenehm warm und die höhen knackig)... aber das ist meckern auf hohem Niveau - schlecht klings trotzdem nicht.
Ich würde mir den lupus Kernel für GB wünschen, nochmal ne Ecke mehr an Performance. Zum Sound kann ich nichts sagen, mein Kopfhörer Ausgang hat die wackelkontakt Krankheit, nutze ihn also nicht. Aber So flüssig wie die ultima ROM ist selbst CM7 nicht, also ist sie die beste verfügbare GB ROM. Dazu noch die timescape Oberfläche :wubwub: (natürlich mit 3er Screen)
Summ, Summ, Summ, der Dexxmor summt herum.
Reaktionen: noob_fl
also bei Sony GB kommt keine Custom (auch CM) nicht an die Performance einer stock based rom heran..
ich find sowieso die CMs allgemein etwas träge - schon bei meinem Desire S war die CM nur schneller als Sense (kinderspiel) aber gegen MIUI und Oxgen eine schnecke
... 3er screen? heisst das der Timescape Fenstermod dens auf XDA gibt ist kompatibel mit der Ultimo??? oder gibts da nen anderen launchermod für die Screenanzahl :) haben muss @ 3 homescreens maximal... simplefiy the device
Die ICS sachen nicht, aber....... wenn du etwas weiter bei den Themes suchst, findest du mehrere Timescape UI's, sogar welche mit der Ecken auswahl (wie bei den Minis) Editiere hier gleich mal nen Link rein. Die Sache mit der Trägheit der CM's... ich denke das liegt an dem sehr einfachen CM Kernel. Mit nem alternativen CM Kernel, würde man da noch viel rausholen können.
EDIT: Home.apk angehängt, ist eine 3 Screen MOD mit Ecken Auswahl. Wie immer installieren (nach /system/app verschieben und auf rw-r-r setzen, bitte einen Fallback Launcher VORHER! installieren)
  • Home.apk
Reaktionen: noob_fl
super danke... werd ich mir gleich mal draufhauen :thumbsup::thumbsup::thumbsup:
Das beste an der ROM ist aber das Keyboard, sogar besser als Swiftkey 3, bei CM brauch ich Swiftkey, hier nicht :D
Reaktionen: noob_fl
etwas schade ist die Telefonapp, schaut zwar schick aus, aber sie ist genau so langsam wie die vom S... zum glück nicht so lahm wie die von der ICS version *lol*
nein, im grossen und ganzen beginnt mir die Rom zu gefallen - sie macht vieles richtig, was andere Roms falsch machen
- in den Build,props keine Batteriefressenden einstellungen deren Performancegewinn fragwürdig sind... keine überflüssigen skripte - reines Xperia feeling :thumbsup:
lustig sind allerdings die Apps die Standartmssig von der 2012 linie übernommen wurden... das NFC zeugs halt *lol*
jetzt muss sich die Rom bei mir nur noch im Alltag beweisen :thumbsup:
Ja mit ROM hat Riyal ein Meisterstück abgeliefert. Bei mir hat sie den Alltagstest schon längst bestanden :D Ein richtiges Social Media Center :D
Reaktionen: noob_fl
Hallo Ihr beiden,
Ihr habt mich neugierig auf die ROM gemacht. Momentan benutze ich JB's ROM und ärgere mich mittlerweile darüber, dass der Akku trotz geringer Benutzung und sparsamen Governor nur wenig mehr als 24 Stunden hält bevor das Teil wieder an die Steckdose muss.
Wie lange hält denn die Ultima GB ROM durch? Ist es realistisch damit wieder an die Werte der originalen ROMs zu kommen? Mit denen hatte ich bei ganz geringer Benutzung auch schon mal 3 Tage bis ich wieder aufladen musste.
Ist durchaus Realistisch, du kannst ja mal mit setCPU nen Bildschirmaus Profil einrichten > Bildschirm aus : Governor Powersafe
Reaktionen: noob_fl
tutur
Lenoid
Lenoid
  • darkarth
darkarth
Ayumi
silencethree
