Dexxmor
Philosoph
- 1.262
hier der link zum threat mit CM9 für unser pro {PRO}[DEVELOPMENT] - CM9.0 - FXP103 FreeXperia Project - xda-developers.
Oder schaut im CM7 Threat von Lubomir nach, wie ihr den Kernel flasht.
step 1 - copy update.zip and GAPPS ADDON to sdcard
step 2 - flash new kernel (always use the kernel provided in CM9 / it is incompatible with stock ROM)
ON PC - run fastboot flash boot boot.img (an black window will open and will stay open untill kernel is flashed)
ON PHONE - put phone in fastboot mode (power off then press lower right key and plug usb cable) and phone LED will light BLUE
step 3
- when phone is booting (FreeXperia Logo) press volume down key several times to enter recovery
- choose apply update from sdcard and select rom
- choose apply update from sdcard and select GAPPS
- wipe device
- reboot
