Scum
Moderator
Teammitglied
- 12.235
http://forum.xda-developers.com/showthread.php?t=1537717
Here is a ROM for ARC/S users.. Based on Stock ICS 4.0.3 FW .562.. I don't own an Arc but this Rom is made entirely from Arc files... similar to my Ray Rom
Its NOT AOSP
Most of the Sony Bloatwares and Useless apps and other files removed for smoothness and made it look like AOSP ICS as much as I could do to give you stability, performance and Best of Both Worlds...
Light - Stable - Fast
NEW
Features
Things that are AOSP or look alike
1) Apps and those from Sony are changed to AOSP icons
2) Matching Lock Screen and Modded Framework.jar to have AOSP touch
3) AOSP Sounds
4) Matching AOSP Toggle Widgets (thanks to hansip87)
5) Removed lots of Sony Stuff... too lazy to Mention...
6) AOSP Keyboard
Others:
1) Latest Android market (Play Shop)
2) Init.d and build.prop tweak. thanks to Nexperia Team
3) Most Gapps included
4) Stock Sony Camera with AOSP icon
5) APN Settings Predefined
6) xloud and bravia engine included
Instructions:
Download the ROM..
Put in SD Card..
Flash ICS Kernel with CWM Recovery... No need to Flash kernel if you have already...
Go into Recovery and DO FULL WIPE and Flash the ROM,.. boot the ROM once... Flash any Addons then
Reboot
DOWNLOADS
(No Sony Addons can be Flashed) Just Wipe Delvik and Cache if coming from v2.0..
(FULL WIPE IS A MUST if coming from v1.2 or other ROMs)
( If u are having Titanium Back Problems with v 2.0, Read THIS)
OR
b) ROM v1.2 Hybrid (21-4-2012)
(Most Sony Addons can be Flashed)
OR
b) Use Kernel by jimbo77 HERE (for Overclocking)
OR
c) DoomLord ICS kernel but dont know since I dont have ARC to test..3) OPTIONAL Deodex Patch.. For those who want to deodex ROM (Applies for Both 1.2 and 2.0) ... Not Necessary to flash....
]IMPORTANT: (Notes and TIPS)
Having Titanium Back Problems with v 2.0? Read THIS
1) After booting up ROM there will be no Keyboard... So please go to Settings>Language and Input> and Click Default and Select Android Keyboard. Will make a Patch for Sony Keyboard if most guys want...
2) Please allow the ROM to settle for atleast an 2-3hrs as Media Scanners, sync etc etc always run on First boot... Then check the smoothness...
3) Set Windows animations in Developers Options to .5x or just disable it for a snappier experience...
4) For Trebuchet Launcher, my favourite app drawer animation is ZOOM in (Trebuchet Settings>Drawer>Transition animations).. its smooth and cool...
5) If you want to take Screenshots, press Vol Down+Power Button for 1 sec
6) If you want to Save Battery , use FREE Underclocking app from Google Play Store(Market) called No-frills CPU... (thanks Sirkay for the tip)
Set CPU
Min -122Mhz
Max 768 or 806Mhz.. (Rom will still run Smooth...)
and I/O Scheduler- noop
Secondly, If you dont Sync Gallery photos then turn off Photo Sync in Settings> Accounts>Tap ur email>Sync Google-Photos (turn it Off)
7) You can use SuperCharge Scripts to Lockhome in Memory
8) If you have questions regarding the Rom, please don't pm me... just ask your questions on thread. . i read every post and will answer as much as i could...
Bugs: Complete list of Bugs HERE. Other than that there is NONE...
Changelog:
1) Added AOSP Dialer and Contacts (BIG THANKS to Zdzihu for Telling me the trick)
2) Removed MTP Mode. The phone will automatically connect as Mass Storage USB and ADB Debugging mode when connected to PC
Remaining same as ver 1.2...
DO NOT FLASH SONY ADDONS and BATTERY MODS They dont work woth ver 2.0, will provide those later...
Replaced Nova Launcher with Apex
Fixed Lost Status Bar with Black wallpaper issue(thanks hansip87 for finding the prob. He has been really very helpful
Added Livewallpaper Picker
Added AOSP Power Widgets by Default
Added Blue Color/Date in Status Bar Time By Default
Replaced MIUI Music player with AOSP Music Player
Fixed Bookmarks Sync Issue with Browser
Fixed 3G Data File size download Limitation
Added Latest Google Market
Added latest Gmail
JJHybrid Official Ver 1.0 (14-4-12)
Features:
Based on Official Version ICS Sony..
Nova Launcher instead of Trebuchet on users demand
Added Google Quick Search
Removed most of those Bloatwares stuff and apps and their country settings to make it global.
Added Toggle Widgets
Added Reboot Menu
Added 2G/3G toggle
Added AOSP LockScreen
Added Widgets for Phone and Messaging Counters...(DONT Update it via Market since its modded one-just ignore the update)
AOSP Theme by default (Dont apply Black Theme)
Battery mods and Widgets and all those status bar mods present by default. Battery % mods in second post(Will be provided later)
Revised and added Only two tweaks added in init.d.. U can try urs which
Rooted with Busy box and SQlite installed
AOSP Exchange Added
MIUI AOSP Music Player added
Reboot Menu not present. will wait for hansip otherwise wait for official
Added AOSP Digital + Analogue Clock Widget from KANG AOKP Rom..
Updated to Latest Youtube, Market and Gmail (4.0.5) application
Zip Aligned All Apks
Added aditional patch for enabling Colored clock, Power Widgets.
Added Latest MIUI FileExplorer and LED Flash Widget in User Data so its easily removable on choice
Add-ons
Remove_DATA_Disabled_Notification.zip - [Click for QR Code] (134.2 KB, 1008 views)
Sony-ICS-Black-Keyboard-ENG_JJHyb.zip - [Click for QR Code] (1.34 MB, 76 views)
SonyMusicPlayer_NO_Widget_JJHyb.zip - [Click for QR Code] (1.26 MB, 48 views)
SonyMusicPlayer_with_Widget_JJHyb.zip - [Click for QR Code] (2.41 MB, 79 views)
Add_On_Screen_Keys_JJHyb_DefaultAnim.zip - [Click for QR Code] (7.63 MB, 47 views)
Add_On_Screen_Keys_JJHyb - FOLDAnim.zip - [Click for QR Code] (7.63 MB, 49 views)
Restore_Default_Window_Animations.zip - [Click for QR Code] (6.19 MB, 78 views)
Remove_DATA_Disabled_Enabled_Notification.zip - [Click for QR Code] (134.7 KB, 13 views)
__________________
Habe diese Roms seit ca. 24H drauf (gerade Update auf die neue V2.1 gemacht!
Meiner meinung nach eins der Besten Roms für Arc ...
Nutze es mit Stock ICS Kernel
Its NOT AOSP
NEW
Features
3) AOSP Sounds
6) AOSP Keyboard
Others:
Screen Shots
Instructions:
Download the ROM..
Put in SD Card..
Reboot
DOWNLOADS
1) ROMS
a) ROM v2.1 Hybrid Revolution (6-5-2012)
OR
2) KERNELS
a) Stock ICS Beta Kernel with CWM HERE (thanks cobrato)
OR
OR
Set CPU
Min -122Mhz
Changelog:
Changelog:
JJHybrid Official Ver 2.0 Revolution (25-4-12) JJHybrid Official Ver 2.1 Revolution (6-5-2012) - 93mb Only
- Cut down the ROM size by 23mb by removing Lots of Useless Apps and Framework Files not needed...
- Average 180-200mb Free. ROM Feeling Snappier
- Aligned Status bar Icons Thanks jtc4 ( will fix batt mod alignment later)
- Removed AOSP Email (Flash from v2x Addons if u need)
- Phone FC fixed after Private caller Calls ends...
- Returned USB Mode in Settings
- Removed New Adreno Drivers by arcatarc and placed Original Ones as they were laggy. The ROM goes Lag free now..
- Superuser initial warning issue STILL Not fixed with Titanium Backup. Just let TB fix it by itself is solution..
- Added KANG Stock Launcher
- Latest MIUI File Explorer
JJHybrid Official Ver 1.2 (21-4-12)
1) Deodex Patch for those who want to Deodex ROM
2) Added Latest Adreno Drivers
3) Improved UI Animations ... the Smooth Became Smooooooother than before...
4) Fixed Email Exchange
5) Some UI Changes to Make it more like AOSP
6) Removed some useless files and frameworks..
JJHybrid Official Ver 1.1 (16-4-12) 1) Deodex Patch for those who want to Deodex ROM
Added latest Gmail
Features:
Added Reboot Menu
Added 2G/3G toggle
AOSP Exchange Added
Add-ons
Addons
UPDATED 27-4-2012
(Flash in Recovery)
UPDATED 27-4-2012
(Flash in Recovery)
For V 1.2 only - Sony Addon Lovers
(I am not going to support you if you get Force Closes or UI lags after installing Sony Apps.. These Addons are put only on Request and is not the aim of the ROM)
C) Sony Stock Music Player.
For Music Widget you have to add more bloatware like Default Stock Sony launcher aswell as it only appears there. If u are willing then FlashSony Music Player with MusicWidget (Just delete Music.apk from system/app if you dont want to use AOSP Music player
D) EleganT Black Theme v1:(Soon)
D) WINDOW ANIMATIONS
1)FOLD Window Animations : (Keep Animations Speed at 0.5x) Unlocking screen to Home causes a Black Flash. Thats Normal.
2) RESTORE Default Window Animations
F) On Screen HW Keys MOD
1) With DEFAULT Animations
2) With FOLD animationsBoth will replace your Battery Mod. DO NOT APPLY BATT MODS on ONSCREEN KEYS else it will remove this Mod
To Remove OnScreen Keys, Flash Restore Default window Animations + any of the battery Mods
For Ver 2x Revolution Only
1) Download Battery Mods
2) RESTORE DEFAULT (Remove Battery% Mod)
Attached Files A) BATTERY 1% MODS (v2.x Revolution Only)
Please Delete any previous Ones. It had a Major Bug...
B) Add-On Screen Keys (already has 1% AOSP icon Battery Mod- Don't flash battery Addons otherwise u might loose the Mod)- To remove, flash ROM without wipes)
C) Sony Music Player (No Widget)- Labels are Black and I know that..I will try to Edit it later and make it white. Its dependent on Sony framework for Colors which has been changed to AOSP.
Delete Music.apk in system/app if u dont want to use AOSP music player
__________________
