[Rom][GB]CM7.0.3 - Free xperia project
  • 42 Antworten
Freut mich, endlich kommt ein bisschen Bewegung in die Sache. Ich finde es sowieso sehr schade wie wenig dieses geniale Phone von den Devs beachtet wird :(
Mittlerweile gibt es eine "pre Beta 005".
CM7 progress
FIXED
GSM - voice and data
SENSORS - precompiled
WIFI - from source
BT - precompiled
FM - from source (no audio for now)
LIGHTS - from source
GPS - precompiled
VIDEO - from source
Gralloc - from now incomplete but works
AUDIO - from source (no headphones for now)
BROKEN OR NOT TESTED
3D
RECOVERY
CAMERA
CAN NOT BE DONE NOW
HDMI - no framework suport
Early Preview BETA 005
http://hotfile.com/dl/121158853/a8cc...w_a005.7z.html
Quelle: [DEVELOPMENT] - CM7.1.0 - BETA 005 Free xperia project - xda-developers
Hallo
Hoppla das geht voran mit CM7.1.0 - BETA 010Free xperia project:D
http://hotfile.com/dl/122564209/15c0...w_b010.7z.html
CM7 PROGRESS
FIXED
WIFI - from source
FM - from source (not working for now)
VIDEO - from source
AUDIO - from source
GPS - precompiled
BT - precompiled
Gralloc - from source (still buggy)
LiveView - UGLY but SMART Accesory
RECOVERY - almost ready
HDMI - from source - almost ready
3D -precompiled
HOTSPOT
FOR NOW IMPOSIBLE
CAMERA
BUGHUNTING
REPORTED BUGS
-touchscreen not registering touches over 460x800
-wifi AP
-flickering in video playback on some formats
-tearing on scrolldown lists
FIXED BUGS
-sdcard incorectly mounted
-gameloft games compatibility
-skype compatibility
HOWTO
to flash cm7 rom you have to take 3 steps (after unpacking the 7z archive)
step 1 - copy update.zip to sdcard
step 2 - flash new kernel (always use the kernel provided in CM7 / it is incompatible with stock ROM)
ON PC - run flash_kernel.cmd (an black window will open and will stay open untill kernel is flashed)
ON PHONE - put phone in fastboot mode (power off then press lower right key and plug usb cable) and phone LED will light BLUE
step 3 - when phone is booting (first 5 seconds) press volume down key several times to enter recovery and choose apply update from sdcard
WARNING - if you used another rom (stock or custom) you have to wipe data or device will not boot
Gut gearbeitet haben die Jungs von XDA.
Warte nun noch auf die Kamera, das kann ja noch etwas dauern.
Hallo
Läuft jetzt tadelos , nur auf die Kamera muss man noch verzichten, und es wird wohl nicht ganz einfach werden.
Kernel Progress
k003 - patched CYPRESS
k002 - patched PMEM
k001 - patched ACPU
BUGHUNTING
REPORTED BUGS
-wifi AP
-sound concurency
-Torch Hygh Brigtness crashes
FIXED BUGS
-reboot to recovery
-gameloft games compatibility (some games are still incompatible)
-touchscreen
-recovery backup
Fairy Stable - BETA 014 - FOR RECOVERY
http://hotfile.com/dl/123551002/9503...FXP014.7z.html
Ich hab da ein Installationsproblem in der aktuellsten CM7 Beta 014
Also ich hab das mal wie in der xda Anleitung beschrieben wurde den Clockword Mod draufgeflasht, die Update.Zip über die "apply" Funktion eingespielt, voher "wipe data" durchgeführt und siehe da. Ein Fehler tritt auf. Schon nach einigen Sekunden gibts
die Fehlermeldung
E:Error in /sdcard/….zip
(Status 7)
Installation aborted
Das Handy musste ich danach wieder neu mit der OriginalFW flasehen, weil es im Bootscreen beim SE Logo hängen geblieben ist.
Was habe ich falsch gemacht? Bzw. was ist passiert? Ich bin mir sicher, dass ich die Anleitung genaustens befolgt habe. Soweit ich das verstanden hatte gabs doch keine besonderen Voraussetzungen an die Software, die vor dem Flashen drauf ist?
Hallo
Eine Vorausetzung ist nur ein offener Bootlader.
Sonst musst du es noch einmal probieren, bei klappt es.
Bootloader ist offen, habs grad nochmal überprüft
C:\android-sdk>fastboot.exe -i 0x0fce oem unlock 0x----------
... INFOUnlock phone requested
FAILED (remote: Phone is already unlocked!)
Vlt jemand noch eine Idee?
Status 7 bedeutet eigentlich das die Rom die du installieren willst nicht zu dem Gerät passt.
Welche Recovery verwendest du?
Hast du vorher auch den kernel mit der CMD geflasht und benutzt DIESE Recovery ?
Falls ja: Lad den ROM neu runter, vllt ist die Datei defekt oder so?!
mfg
Bin4ry
Reaktionen: lkrys
Also, wenn ich das richtig verstanden habe, dann habe ich den Kernel installiert, der
in dem xda Paket dabei war ( BETA 014 - FOR RECOVERY including RECOVERY )
Und zwar der, mit dem ClockworkMod. (Das ist doch der Kernel? - weil auch das Einzige was ich geflasht habe mit dem cmd)
Des Weiteren habe ich auch die dazu gehörige update.zip auf die SD Karte geschoben. Alles was in dem Paket drin war.
Ich hoffe ich habe da jetzt irgendwas nicht gravierend missverstanden. Danke für deine Hilfe!
Gibt bei der Beta 18 die selben probleme beim Instalieren wie bei der Beta 14
Welche Problem hast du denn beim Installieren? Bei mir läuft alles durch ohne Probleme.
Gib mir mal bitte eine ordentliche Fehlerbeschreibung am bestem mit dem recovery.log im Anhang. Dann werde ich den Updater nochmals nachbessern.
mfg
Bin4ry
Reaktionen: SatioBoy2010 und lkrys
quercus schrieb:
Habe diese 20er vor ein paar Tagen mal ausprobiert. Sie fühlt sich gut an, und man kann sich deshalb vorstellen, dass es bald was werden könnte. Aber leider geht die Kamera nicht und der Touchscreen hat noch tote Stellen. Deshalb bin ich zurück zur StockRom.
Freue mich schon darauf wenn es funktioniert, aber ohne Kamera, fehlt eben was wichtiges.
Das stimmt allerdings ! Das Licht am Ende des Tunnels wird heller - :smile:
es gibt schon erste bestätigungen das die Kamera wohl schon ein bißchen funktioniert ;)
Salvadore
meetdaleet
  • Gesperrt
  • Angepinnt
  • meetdaleet
meetdaleet
meetdaleet
  • Gesperrt
  • diuty
iSchneiderle
I
