[ROM][KK][Official][ION]VanirAOSP[nightlies]
  • 7 Antworten
I
iSchneiderle
Ehrenmitglied
678
Hier könnt ihr euch Informieren;
[ROM][KK][ ARC/S / Pro ] [ ION ] VanirAOSP [official] [nightlies] [4.4.2] [anzu] GCC4.8 Linaro+ART optimizations - xda-developers
Rom;
http://www.emccann.net/nuclearmistake/VanirAOSPNightlies/anzu/
Gapps;
https://www.androidfilehost.com/?fid=23622183712468126
Code:
[B]Funktionen[/B]
[U][B]Status Bar[/B][/U]
- Quick Setting including numerous customizations
- Customize clock display and location, customize signal bar
- % displayed in battery + circle mod
- Transparency
[B][U]Navigation Bar[/U][/B]
- Customizable buttons + colors
- Customizable height + width
- Navi Ring
- Transparency
[B][U]Lockscreen[/U][/B]
- Fully customizable targets/rotation/widgets/ and more
- Transparency
[B][U]General Tweaks[/U][/B]
- Ad blocking
- PIE: with extended options
- Tablet UI Chooser
- DPI/LCD changer + force tablet settings mode
- Theme Chooser: Including inverted theme
- Galaxy Nexus Parts
- ADB over network
- Bravia Engine 2.0
- Custom Carrier text
- Custom backlight
- Expanded Desktop: with different modes
- Extended Power menu
- A-GPS. - Kang PrimeDirective –> Credit happily1986
- Long press back to kill (in developer options)
[B][U]Application Tweaks[/U][/B]
- Selectable Gtalk
- Expanded Phone: noise reduction, advanced settings, speaker proximity
- Expanded MMS including Quick Emoji
- Camera: Enhanced settings (credit CM)
- Functional Sound Recorder
- Koush’s Superuser
- Vanir Keyboard – removed tracking/logging – highly optimized
[SIZE=2][B][U]Performance Manager[/U][/B][/SIZE]
- Processor governor + speed
- Voltage control
- I/o Scheduler
- Disable boot animation
- Enhance recent menu
So Installiert ihr es:
(Erstinstallation)
1. Kopiert die Rom und Gapps ZIP's auf die SD-Karte
2. Kernel (entpacktes boot.img aus der Rom ZIP) mit flashtool flashen
3. Neustart ins Recovery
4. Wipe Data/Factory Reset
5. Format Data, Format Cache, Format System
6. Install zip from sd-card und installiert die Rom
7. Startet euer Handy erneut neu ins Recovery
8. Flasht die Gapps und Startet neu Booten lassen und genießen.
Update Installation
1. Rom.zip auf die SD-Karte kopieren
4. Wipe Cache/Dalvik Cache
5. Install zip from sd-card und installiert die Rom
6. Startet euer Handy neu Booten lassen und genießen.
Bootloader offen ?.
How To Bootloader Öffen
Ladet euch das Flashtool von www.Flashtool.net runter und Installiert dieses.
Wenn es Installiert ist geht ihr Arbeitsplatz Win XP ( Computer unter Vista,7 und 8) und geht auf den Flashtool Ordner dann auf /Driver und öffnet diese. Sucht nun die Treiber für das Xperia Ars herraus und setzt den Hacken dann scrollt ihr ganz nach unten und Installiert die Flashmode und Fastboot treiber noch mit auch einfach Hacken vor machen.
Nun habt ihr den ersten schritt erfolgreich gemacht. FLASHTOOL ist einsatz berreit.
Jetzt besorgt euch den Unlockcode von der Sony Seite.
Are you really sure? | Sony Xperia
Wenn ihr den Code habt öffnet das Flashtool und klickt auf BL dann bekommt ihr eine Meldung Angezeigt was ihr machen sollt Handy ausschalten und während ihr die zurück Taste gedrückt haltet hängt ihr das Handy an den Pc die Meldung müsste dann Automatisch weggehn dann noch den Unlockcode aus Punkt 2 einfügen und durchlaufen lassen nun ist euer Bootloader offen und ihr konnt mit der Installation für Fortgeschrittene weiter machen.
Wenn das alles erledigt ist macht euer Handy aus und hängt es an den Pc während ihr die Menü Taste gedrückt haltet( Blaues Licht geht an).
Öffnet nun das Flashtool dort müsstet ihr angezeigt bekommen DEVICE CONNECTET IN FASTBOOTMODE.
Geht auf den Großen Blitz und wählt Fastbootmode aus dann Select Kernel from ( schaltet unten auf .img sonst findet ihr den Kernel nicht)
Flasht den Kernel wenn das Fertig ist bekommt ihr das Angezeigt.
Schaltet euer Handy aus und wieder an während ihr es anschaltet drückt Volume Down dann solltet ihr ins Recovery kommen.
Wipe/Data/Factory Reset
Wipe/Cache
Mount and Storage Format/System
Install zip from SD-Card Rom auswählen und Installieren
Gapps Installieren
Neustarten und Genießen.
Bitte Flasht nur wenn euer Akku mindestens 50% hat!!
WICHTIGER HINWEIS: Weder ich, noch Android-Hilfe.de, übernehmen die Haftung für jegliche Beschädigungen an eurem Xperia Arc oder Arc S !
Daher flashen auf eigene Gefahr. !!
Screenshots:
Reaktionen: Turcin
Information für euch User,
Bei dieser Rom gibt es jeden Tag ein Update,dieses wird sogar via OTA geliefert das heißt ihr bekommt auf dem Handy angezeigt wenn Updates verfügbar sind.
Reaktionen: Bernulf und Turcin
Update ist raus. VanirAOSP hat nun auch das Update auf Android 4.4.3 erhalten.
Reaktionen: Turcin
Update ist raus.
Android 4.4.4
Reaktionen: Turcin
iSchneiderle schrieb:
Update ist raus.
Android 4.4.4
Auch noch geupdatet also bald sind alle rom s mit 4.4.4 version
jubelnnnn :lol::lol::lol::lol::lol:
man o mann das ist echt hammer :cool2:
Wie sieht es mit der Akku Leistung aus?
Nabend , Kannst du einen link zu den Gapps einfügen bitte:scared:
Mini Gapps eingefügt.
Reaktionen: Turcin
bildmacher
evasion
evasion
I
  • iSchneiderle
Bernulf
