[ROM][KK][Official]AORP und Xperia UltraKat
  • 310 Antworten
I
iSchneiderle
Ehrenmitglied
678
http://forum.xda-developers.com/showthread.php?t=2578719
Rom
http://stalk.basketbuild.com/downloa...-MK1--anzu.zip
Gapps
http://d-h.st/zfG
Upstream Android 4.4.20
UI Changes
Dark UX - rebel style
Performnace Updates
Battery Life
performance Settings
Many features which i don't remember
Numerous fixes and improvements throughout Rom
Halo
Fast Torch
Ram Bar
Some features ported from AOKP
Numerous Fixes around the Build
Browser lag (fixed)
Camcoder (Fixed)
Fixed Almost everything
Upstream Cm changes
Working :
LCD
Touch
RIL 2G & 3G
SMS/MMS
Accelerometer
Proximity sensor
Ambient Light sensor (including automatic brightness)
Vibrator (including vibrator intensity tuning)
Audio
Headphones
Button & keyboard leds (including brightness adjustment)
Notification led (including soft dim effect)
Physical keyboard
Hardware keys
SD card
USB: Mass storage
USB: MTP
USB: PTP
USB: ADB
USB: OTG
USB tethering
GPS
Camera
Video recording
Panorama mode in Camera
Flashlight (including red-eye mode)
Torch (including high brightness mode)
Bluetooth music
Bluetooth calling
Bluetooth tethering
Offline charging
Overclocking (up to 1.4GHz)
Undervolt
CWM recovery (including rainbow mode)
Browser
webview (completely fine)
Upgrading frame phase 1
TRDS (Dark Ui) is back !!
wifi hotspot fixed!
some upgrades to wifi
forcing highend GFX mode in performance control
and over super stable base for creating next upgrades
Kernel Flashen der in der Zip der Rom ist.
Reboot ins Recovery
Wipe/Data/Factory Reset
Wipe/Cache
Mount and Storage/format System
Install Zip from SD-Card
Rom auswählen und Installieren
Gapps Installieren
Neustarten und Genießen
Bootloader offen ?.
How To Bootloader Öffen
Ladet euch das Flashtool von www.Flashtool.net runter und Installiert dieses.
Wenn es Installiert ist geht ihr Arbeitsplatz Win XP ( Computer unter Vista,7 und 8) und geht auf den Flashtool Ordner dann auf /Driver und öffnet diese. Sucht nun die Treiber für das Xperia Ars herraus und setzt den Hacken dann scrollt ihr ganz nach unten und Installiert die Flashmode und Fastboot treiber noch mit auch einfach Hacken vor machen.
Nun habt ihr den ersten schritt erfolgreich gemacht. FLASHTOOL ist einsatz berreit.
Jetzt besorgt euch den Unlockcode von der Sony Seite.
Are you really sure? | Sony Xperia
Wenn ihr den Code habt öffnet das Flashtool und klickt auf BL dann bekommt ihr eine Meldung Angezeigt was ihr machen sollt Handy ausschalten und während ihr die zurück Taste gedrückt haltet hängt ihr das Handy an den Pc die Meldung müsste dann Automatisch weggehn dann noch den Unlockcode aus Punkt 2 einfügen und durchlaufen lassen nun ist euer Bootloader offen und ihr konnt mit der Installation für Fortgeschrittene weiter machen.
Wenn das alles erledigt ist macht euer Handy aus und hängt es an den Pc während ihr die Menü Taste gedrückt haltet( Blaues Licht geht an).
Öffnet nun das Flashtool dort müsstet ihr angezeigt bekommen DEVICE CONNECTET IN FASTBOOTMODE.
Geht auf den Großen Blitz und wählt Fastbootmode aus dann Select Kernel from ( schaltet unten auf .img sonst findet ihr den Kernel nicht)
Flasht den Kernel wenn das Fertig ist bekommt ihr das Angezeigt.
Schaltet euer Handy aus und wieder an während ihr es anschaltet drückt Volume Down dann solltet ihr ins Recovery kommen.
Wipe/Cache
Mount and Storage Format/System
Install zip from SD-Card Rom auswählen und Installieren
Gapps Installieren
Neustarten und Genießen.
Der 1 Boot Vorgang dauert etwas Länger also nicht wundern
WICHTIGER HINWEIS: Weder ich, noch Android-Hilfe.de, übernehmen eine die Haftung für jegliche Beschädigungen an eurem Xperia Arc oder Arc S !!!!!
Daher flashen auf eigene Gefahr. !!
Reaktionen: knallratte, dj fex, TackMaison und 2 andere
Hier findet ihr alle Infos zur Rom;
http://forum.xda-developers.com/showthread.php?t=2648304
Hier könnt ihr es Laden.
http://www.mediafire.com/download/3tk1w2l0zfpw4xo/Xperia_UltraKat_v2.0_By~Stevan_Dj_
Gapps:
http://www.mediafire.com/download/ldybmiyhy95w76p/Gapps_4XUKR_
Kernel:
http://www.mediafire.com/download/tyrkza7v6zoaifl/Kernel2.0_
Xperia UltraKat Version 2.0.1 (4/4/2014)
Rebased the ROM on LexacyXperia build 20140319
Improved Battery life
Improved Performance and Stability
Added support for Hallon, Haida
Updated framework-res with almost everything from Xperia Z2 including; -
Every F*cking Single animations
Spinners
Progress spinners
Dark & light backgrounds
Switch toggles
More Xperia Z2 Stuff including;-
Xperia Z2 SystemUI with Fixed Back key layout
Xperia Z2 Messaging app
Xperia Z2 Entrance (What's New)
Updated Xperia Z2 Calendar app
Updated Xperia Z2 Home
Fixed SD Cards apps Shortcuts Disappearing issue
Xperia Z2 Ringtone and Notification sound
Xperia Z2 Wallpapers
Replaced Next Browser with Dolphin Browser (Chrome Icon )
Fixed sound bugs
New Boot-animation from Xperia JB
Added ClearAudio+ and Sound Enhancements
Fixed Network No signal after Deactivating & activating Airplane Mode
Re-sized On-Screen-Buttons (OSB); -
Portail: 25.00dip
Landscape: 00.00dip
Removed dock image in Xperia Home (like Xperia Z2)
Improved smoothness and performance
Overall more Xperia themeing & feeling.
Screenshots:
Reaktionen: Börger, dj fex, VectraV12 und eine weitere Person
@schneiderle
Guten abend
ich habe diese rom BeanStalk 4.4 Kitkat Official "instaliert."
Angabe von @Master619 beim booten immer hängen und der Akku verbrauch ist auch etwas hoch
@schneiderle :Für die Rom wird es Wahrscheinlich kein Update mehr geben =(
Zu deinen Problem mach Backup deiner Apps und Daten und Flash Clean den es bleibt nicht hängen NORMAL =).
Sollen wir umsteigen? Carbon 4.4 ,cm-11.0--LX-NIGHTLY-anzu ,usw usw
das gleiche theater haben wir auch mal festgestellt wie der @Master619 :cursing:
Ich frag mal nett und höfflich was ist mit diese ROM
wie länge hält Akku bessere als andere ?
stabiler als Beanstalk? Hängt beim neustart des handy
Bug´s ?
Wir bitten um deine hilfe ,anweisung,empfehlungen ratschläge
Viel erfolgt
alles gute
von heute aus Schöne feiertage ,Guten Rutsch ins neues Jahr
MFG
Turcin
Edit : [Rom] [BETA #1] [Arc/s] [KitKat] [Official] [AORP - 4.4.20] [20-Dec
es handelt sich Beta version
also kann noch verbesserungen vorführen
Ich kann zu der Rom noch noch nicht viel sagen hab sie erst seit heute drauf =) Sonntag gebe ich dir Rückmeldung wie sie ist =)
Reaktionen: Turcin
Meiner Meinung nach besser als Beanstalk :) Werde eine Review Schreiben sobald eine Stabilere Version verfügbar ist owo
Reaktionen: iSchneiderle und Turcin
bei mir geht der wlan nicht :o so eine schitte ey
bei andere Rom bis ich jetzt aus probiert habe
immer bug s boahhhh
hab ich linke finger, oder ich bin einfach blöd zum rom ´s instalieren
Bei Mir klappts ohne Probleme :o Versuch mal neu Installation aber dieses mal gehste auf mounts and storage und gehst auf Format System . Ansonsten alles normal Wipen . :) Geb Rückmeldung wenn geklappt hat :D
ich habe schon alle s probiert .format und und und
klappppttt niee
ich probiere noch eine mal
backup von titanium und clockworkmod schon gelöscht
ich melde mich wenn geklaptt hat
danke
Eigenartig :/ Versuch mal Stock ICS zu Flashen und danach die Rom .
Hast du den Kernel geflasht der in der Rom zip ist?
Reaktionen: Turcin
hallo helfer des Thread
wie gesagt alles ausprobiert
klappt nicht
ich lese "Verfolge " immer eure anweisungen ihr seid sehr hilfsbereit :thumbsup:
danke noch mal @schneiderle
So dann mal anders =)
KERNEL FLASHEN
WIPE DATA FACTORY RESET
WIPE CACHE
FORMAT SYSTEM
FORMAT DATA
FORMAT CACHE
WIPE DAVALIK CACHE
ROM INSTALLIEREN
NEUSTART INS RECOVERY
GAPPS INSTALIEREN
NEUSTART UND DANN MŰSSTE ALLES GEHN
Wenn das nicht geht lade dir die Stock Fimeware runter und flash diese über das Flashtool. Danach booten lassen dann den Kernel von AORP flashen und wie in der Anleitung vorgehen.
Falls du die Stock Fimeware nicht findest sag Bescheid ich suche sie dir dann schnell raus.
Reaktionen: Der-Marc und Turcin
@ Schneiderle
jetzt hat gut geklappt mit deinem anweisung
warum muss ich wie oben beschrieben hast .
instalieren ?
kann sein dass ich bis heute ziemliche ROM ´s ausprobiert habe
darum nicht der Wlan geklappt hat
boahh
jetzt muss ich mal gucken .
wie lange der Akku hält
ob der bug s hat wie die andere ROM s
oder stabiler als andere betriebssysteme
einfach probieren TURCIN :thumbup:
schön abend noch
danke an deine hilfe .danke an marc auch
viel erfolgt schneider
le :)
Kein Problem =) Viel Spaß damit =)
iSchneiderle rettet irgendwie jedem den Tag :O
Ne nicht jedem =)
Ne nicht jedem =)
Guten Morgen @ Schneiderle
Du bist wie die andere ihr hilft zur uns ,Ihr lässt die leute nicht ins stich
also mit diese sagenhafte ROM bis jetzt einzige probleme zur frieden:bis
*Video aufnahme der hängt und friert ein :huh:
Akku ist besser als die andere rom
Läuft flüssiger -:thumbup:
*EDIT: Hab von googleplayer GIFCAMERA instaliert das gleiche
ansonsten ich habe kein andere Bug s festgestellt
Hiermit ich wünsche an jeden seinem lieben Familienmitglieder" auch hier bei uns "Board" angemeldet ist
alles gute ,Schöne feiertage .Guten Rutsch ,Gesunde Jahr viel erfolgreicher lebensstill
Ps
TURCIN
Edit 2 :Von XDA Board kommt meldung
Marchinho6
Today, 11:22 AM
#62
Senior Member Thanks Meter 75
More Info >
Quote:
Originally Posted by vashta
Can you describe, what are those cm bug?
Video recorder dont work
Browser lags und Viedeo Aufnahme werden gefixt das weiß ich schon vom Dev der Rom =)
Reaktionen: Turcin
Findet ihr ich sollte von BeanStalk 4.4 auf diese Rom umsteigen? :)
Frag den richtigen aber
@Schneiderle
der kann dir gute rat geben
welsche rom besser und stabiler ist
Turcin
rene3006
bildmacher
stromy
