Knorpel
Dauer-User
- 946
Wird das 10.1v hier nicht mehr unterstützt? Ich habe dieses ROM bei mir drauf und kann nur sagen, absolut TOP!
Hier der Original Link aus dem XDA:
[04.Aug] Cyanogenmod 10 - Android 4.1.1 (Jelly Bean) - EXPERIMENTAL - xda-developers
ORiZorrie schrieb:I was thinking that we need a separate topic on this ROM so that we don't go too much offtopic in the CM9 topic.
All credits go off course to :good: pershoot :good: (be sure to thank him)
INFO
CyanogenMod 10
This is Android 4.1.1 (Jelly Bean) + CM10 for the Samsung Galaxy Tab 10.1v
DOWNLOAD
Index of /galaxy/roms/cm10/p3
INSTALLATION INSTRUCTIONS
/!\ Before doing anything make sure your bootloader is unlocked and you have a rooted device!
1. Backup your apps+data using Titanium Backup.
2. Go to Index of /galaxy/roms/cm10/p3
3. Download 'recovery.tar.md5' to your PC. It's Clockworkmod 6.0.1.0 (latest version). If it's not available on the above location, it's also attached to this post.
4. Download 'cm-10-*-EXPERIMENTAL-p3.zip' and put it in internal storage.
5. Download 'gapps-gb-*-signed.zip' from Goo.im Downloads - Browsing gapps and put it in internal storage. gapps-gb-20110729-signed.zip has been confirmed to work fine.
6. a. Flash recovery.tar.md5 on your device using ODIN3 (go into downloading mode, wait for USB connected on screen, then select the file using PDA and click Start)
6. b. You can also use fastboot (for some reason I prefer this method). Just extract the recovery.img from 'recovery.tar.md5' and then flash it using fastboot ("fastboot flash recovery recovery.img" (permanent on device) and/or "fastboot boot recovery.img" (just boot it from pc))
7. Once in recovery: clean cache & clean dalvik cache. (I did a full wipe to be sure I don't report bugs to pershoot which are linked to data problems).
8. Flash 'cm-10-*-EXPERIMENTAL-p3.zip'.
9. Flash 'gapps-jb-*-signed.zip'.
10. Reboot
11. Enjoy your ROM :fingers-crossed:
12. Put back all your apps (using batch Titanium Backup) but don't restore system apps!
WORKING
bluetooth
browser
back camera (8MP)
gps
install/move apps on sd card
mobile data 3g/2g
rotation
sound (notifications, calls, ringtones, alarm, music)
superuser
MTP
video playback
vibration
wifi
youtube
NOT WORKING
google now (might work in some special cases) Bei mir geht es
front camera (2MP)
voice calls (not working in any rom yet, hopefully it can be ported from the GTab 2)
wifi tether
BUGS
notification settings
If you find any other bugs, please report them in this thread!
