[ROM][JB][AOSP][ALPHA] Android 4.1.1 - Jelly Bean - [GT-P7510][GT-P7500][18.7.12]
  • 17 Antworten
teddy3
teddy3
Dauer-User
283
[ROM][JB][AOSP][ALPHA] Android 4.1.1 - Jelly Bean - GT-P7510 - xda-developers
NOT WORKING
- Front-facing camera
- 3G & 4G (SCH-I905)
WORKING
- Rear camera (GT-P7510)
- Wi-Fi (thanks to pershoot)
- Audio (thanks to pershoot)
- HW accelerated video (thanks to rmcc)
- Google Now
- Network based location
CM10 OR AOSP?
CM10 is a customized ROM with additions to the system: About
AOSP (Android Open Source Project) is android in pure form, just straight out from Google: About
Which one to choose is your decision.
This ROM includes a few additions from CM10, just the necessary so it won't deviate much from AOSP. This additions are:
- Extended boot menu (long pressing power button).
- Performance settings (to control overclock and other settings without an external app).
- Kill app back button.
- Toggle system bar (hide/show system bar - merged from sgt7)
BEFORE INSTALLING
Check that you have the last version of your recovery, and that it's the right one for your model. If you don't do this you'll get assert error 7 when trying to install.
For CWM, go to this thread: [Recovery] ClockworkMod - 5.5.0.4
For TWRP, go to this thread:[Recovery] Team Win Recovery Project (TWRP) - 2.2.0
A full wipe is recommended, also formating /system . (Do this before reporting problems)
DOWNLOADS
Wi-Fi Only (GT-P7510) -> 09-08-12.12-36-jellybean-alpha-p4wifi-sig.zip
(thanks to 512kbyte's hosting)
md5: fac75f1a2168f0d4c36fc0e13f642fb2
sha1: 8c7ac13af63eb145920eac020879f75e97d59da0
Wi-Fi+3G (GT-P7500) -> Coming soon. In the meantime, try the CM10 version.
Google Apps
gapps-jb-20120729.zip
gapps-jb-20120717-signed.zip
gapps-jb-20120716-signed.zip
FLASH SUPPORT
Check this guide: [GUIDE] [HOW-TO] Install Adobe Flash Player on Android 4.1 Jelly Bean
Be aware, it may cause troubles with web surfing, consider this before reporting problems.
Video von mrlollog:
Reaktionen: bartlinux, thomasoeli und Neodym80
Update auf die Version v. 15.7.
Ist ein bißchen verwirrend, dass bei "Not Working" steht, dass das 3G beim P7500 noch nicht funktioniert.
Aber es gibt einen Download für das "Wi-Fi+3G (GT-P7500)"? Funktioniert es mittlerweile doch schon und es ist nur noch nicht der Punkt "Not Working" geändert wurden?
Weiterhin würde mich mal interessieren wie das mit der Hardware Beschleunigung implementiert werden kann? Ist das ähnlich zum HD2 mit ICS, wo man monatelang auf die richtigen Modemtreiber für den Kernel gewartet hat?
Ich hoffe, dass ich das mit dem Modemtreiber beim HD2 richtig verstanden habe. ;-)
Wie läuft das beim Tab ab, weiß das jemand?
Ich danke euch.
Gruß Thomas
Hi
Jo es gibt eine Version fürs 3G, allerdings funzt dort nur WLAN und kein 3G. So ists gemeint.
OP update auf neueste Version und OP aufgeräumt, da C&P nicht erwünscht.
Hallo. Kann es sein das Datei bzw Archiv defekt ist. Flashen klappt net
Gesendet von meinem Galaxy Nexus mit Tapatalk 2
Was für ein Fehler kommt den?
Reaktionen: Lambkin
Einfach md5 summen vergleichen;-)
hanspampel schrieb:
Gibt ne neue Version. Zumindest schonmal für WiFi.
DOWNLOADS
Wi-Fi Only (GT-P7510) -> 20-07-12.16-09-jellybean-alpha-p4wifi-sig.zip
md5: f238a91afc229139f6f2f7885459589a
sha1: 4740f2ebcd5c6ef8668bacd1e9a124b0dfbc5760
Quelle
Mit der neuen Version funktioniert jetzt auch Hardware accelerated video!:D
Die WiFi-Version wurde wieder aktualisiert.
Wi-Fi Only (GT-P7510) -> 24-07-12.11-48-jellybean-alpha-p4wifi-sig.zip
md5: d52a228db88074aba36f2a8b76c1d807
sha1: 5270bcc272151821437b8536451b8fe6c07d4784
Ein Update für die 3G-Version durfte ich vorhin testen, aber da gibt es (mindestens) noch kleine Probleme mit den APN-Einstellungen.
Update auf Version vom 26.07. (Wifi only) und Howto Flash support.
Update auf Version vom 31.07. (Wifi only).
Am Wochenende wird eventuell wieder ein neuer Test-Build (inkl. 3G) für das P7500 gebastelt.
:D
Von CM9 getapaltk :)
Hast du dazu vielleicht eine source? Auf xda wird das 3G seit ICS release ja ignoriert. Fürs wifi gibts schon 3 ROMs. Hoffe auch dass sich mit 3G was tut, die xda devs haben bei nachfrage kein Interesse ....
Meine Quelle ist der Developer, da ich (und andere P7500-User) gelegentlich für ihn testen dürfen.
Update auf neue Version.
Video von mrlollog in OP hinzugefügt.
Ciran
  • Ciran
Ciran
Ciran
bierma32
bierma32
Aisha
  • Aisha
Aisha
Aisha
