[ICS Kernel] OC1.4 Kernel für GT-P75XX/7100 [11.07.2012]
  • 64 Antworten
hanspampel
hanspampel
Ehrenmitglied
9.864
So ich mache hier mal nen separaten Thread für den "ICS Kernel" von Pershoot auf. Damits da nicht Problemen oder Verwirrungen kommt mit dem HC3.2er Kernel kommt.
Zum Honeycomb Kernel geht es hier
Zur Info
Dieser Kernel ist nur für die "alten" ICS ROMs!!
Wichtig
Dieser Kernel ist nicht kompatibel mit der offiziellen ICS Firmware mit dem 3.1er Kernel!!
Update (07/11):
-revert:
usb: gadget-ics: fsl_udc_core: bring back vbus_active logic in dequeue/flush
-usb: gadget-ics: fsl_udc_core: bring back fsl_udc_restart logic
-cpufreq: interactive: remove event tracing
-usb: gadget-ics: fsl_udc_core: bring back vbus_active logic
Update (07/10):
-usb: gadget-ics: fsl_udc_core: bring back vbus_active logic in dequeue/flush
-defconfig: ics: regen
-usb: gadget-ics: backport/sync from kcrudup’s ics-2.6.39
-mmc: host: sdhci: sync with nvidia’s 2.6.36
-merged (from nv-tegra):
ARM: tegra: clock: Disable boot clocks before dvfs init
Update (07/08):
-smd: update from GT-I9103_GB_Opensource_Update1
Update (06/23):
-merged (from cyanogenmod tuna):
PM / Core (Partial): Introduce struct syscore_ops for core subsystems PM
ARM: Use struct syscore_ops instead of sysdevs for PM in common code
timekeeping: Use syscore_ops instead of sysdev class and sysdev
[CPUFREQ] (Partial) Remove the pm_message_t argument from driver suspend
cpufreq: Use syscore_ops for boot CPU suspend/resume (v2)
PM: Fix error code paths executed after failing syscore_suspend()
PM (Partial): Remove sysdev suspend, resume and shutdown operations
PM / Suspend: Do not ignore error codes returned by suspend_enter()
PM / Suspend: Off by one in pm_suspend()
-merged (from lkml):
PM: Reintroduce dropped call to check_wakeup_irqs
Quelle
ICS
10.1-Wifi (GT-P7510/7511):
boot-cm_2636.4_p4wifi_ics-oc-xtra-vfpv3-d16_fp-071112.zip:
Download: boot-cm_2636.4_p4wifi_ics-oc-xtra-vfpv3-d16_fp-071112.zip
10.1 3G (GT-P7500/7501):
boot-cm_2636.4_p4_ics-oc-xtra-vfpv3-d16_fp-071112.zip:
Download: boot-cm_2636.4_p4_ics-oc-xtra-vfpv3-d16_fp-071112.zip
10.1v (GT-P7100):
boot-cm_2636.4_p3_ics-oc-xtra-vfpv3-d16_fp-071112.zip:
Download: boot-cm_2636.4_p3_ics-oc-xtra-vfpv3-d16_fp-071112.zip
Geflasht wird das Ganze per Recovery. Der Kernel funzt natürlich auch für die N-Modelle, 7501 und 7511. Sollten des Weiteren für alle ICS-ROMs funzen. Egal ob CM9 oder AOKP. Natürlich sollte man keine uralten Version drauf der Kangs drauf haben.;)
Wie flashe ich den Kernel?
Einfach per Recovery, dabei vorher Cache und Dalvik Cache wipen und dann die Zip-Datei mit "install zip from SD card" flashen. Danach rebooten. Bitte den Kernel nach dem ROM flashen, sonst bringt es nix!!!;)
Edit: OP geupdatet (11.07.2012)
Reaktionen: sc00ter98, aurel81, bartlinux und 2 andere
Wobei bei AOKP nur fuer die neueren gelten soll. Habs gestern mit meiner v23 probiert und und wifi konnte nicht aktiviert werden. Pershoot gab mir den Tipp.
Hi
Ja das ist richtig. Habs auch gelesen, aber wer hat denn noch die 23 drauf:lol:. Ist doch lang nicht mehr aktuell.
Ich habs immer noch oben, obwohl ich aktiv roman's und pershoot's threads verfolge. Aber laut Postings zu den v24 - v32 gab es immer wider mal Probleme mal mit 3G, der NavBar, etc.
Die v23 lauft bisher wirklich sehr stabil im täglichen Einsatz - bin jetzt am überlegen entweder die v34 oder pershoot's "naked" CM9 zu flashen um wieder mitmischen zu können :)
Hi
Ich hab die 34er drauf und kann dir sagen es gibt bisher keine Probs mehr mit der Navbar. Hab zudem den aktuellen Kernel am laufen. Alles paletti .:thumbsup:
Reaktionen: aquillum
hanspampel schrieb:
Hi
Der oben beschriebene Kernel ist doch in der 34 drin, oder?
Sent from my GT-P7500 using Tapatalk 2
Moin
Nein, afiak nicht. Deswegen hatte ich ihn ja geflasht. Das 34er kam ja viel früher raus, sprich am 24.04, der Kernel ist vom 26.04.
Btw. gibt nen neuen von heute.
Update (04/27):
-ARM: add irq_enter/exit() around an additional ipi_timer()
-Revert:
cpufreq: interactive: use idle notifier
Move x86_64 idle notifiers to generic
-merged (from github.com/ch33kybutt):
ARM: fix rcu stalls on SMP platforms
ARM: SMP: use a timing out completion for cpu hotplug
Klick
OP geupdatet.
@hanspampel. Bin auch seid gestern auf aokp 34 und ganz zufrieden! Welchen kernel empfiehlst du, und warum? Welchen vorteil bringts ggenüber dem standart kernel von 34?
Lg socko
Es sind eingige Anpassungen gemacht worden. Von der Performance her sehe ich aber keinen bis kaum einen Unterschied. Die Benchmarks spiegeln das wieder. Der Kernel im 34er ist aber auch ein Pershoot, nur afaik halt der vom 19.04. Muss den von heute aber auch noch probieren.
Neue Version von Pershoots Kernel ist online. OP somit geupdatet, hab den Kernel fürs 10.1v mit reingenommen.
Reaktionen: aurel81 und roger mexico
OP mit neuesten Pershoot-Kernel upgedatet.
Reaktionen: roger mexico
Neue Version von Pershoot ist up. OP ist geupdatet.
Update (05/31):
-defconfig: ics: set NVMAP_VPR
Note:
-This is intended to be used with a recent CM9 build from get.cm
-If you are using Voodoo CP, please uncheck Map Volume Keys.
-If you want to bench, it is advised that you set min/max to the same number.
Reaktionen: Mathias321
Man Pershoot scheint wohl gerade Urlaub zu haben, wieder ein neuer Kernel.:D Im OP.
Update (06/02):
-Revert “bcmdhd: Fix IBSS (ad-hoc) network support”
-merged (from kcrudup)
net: wireless: bcmdhd: Make responce waiting uninterruptible
net: wireless: bcmdhd: Fix P2P driver crash for MFG firmware
net: wireless: bcmdhd: Update to version 5.90.195.75
Reaktionen: Mathias321 und roger mexico
Tja Leute, gibt schon wieder was zu flashen. Im OP.
Update (06/03):
-touchscreen: atmel_mxt1386: sync with GSIII, Update 1
-tegra: board-p4*: sync with params from GSIII, Update 1, for atmel_mxt1386
Kann man den Kernel auch unter HC 3.2 nutzen?
Gesendet von meinem GT-P7510 mit Tapatalk 2
Nein, hatte ich ja im OP geschrieben. Deswegen hab ich nen extra Thread dafür aufgemacht um Verwirrungen auszuschliessen.;)
Der für 3.2 ist hier im Bereich angepinnt. Gibt auch keinen aktuellen Kernel mehr dafür seit Januar.
Reaktionen: bartlinux
Ok danke, das habe ich sicher nur überlesen.
Danke für deine Arbeit hanspampel.
Könnte einer der Mods den Thread anpinnen, wie den 3.2er Thread auch? Danke :)
bierma32
bierma32
Ciran
  • Ciran
Ciran
Ciran
Aisha
  • Aisha
Aisha
Aisha
