[ROM][G930F][7.1.2] *Final* Resurrection Remix 5.8.5 [Official]
  • 251 Antworten
Black_Focus
Black_Focus
Dauer-User
622
Hier stelle ich euch die Resurrection Remix Rom vor, die auf dem LineageOS 14.1 (ehemals CyanogenMod) basiert! Heisst dies ist eine AOSP (Android Open Source Project) Rom und hat somit nichts mit dem herkömmlichen TouchWiz zu tun! .
XDA LINK:
[ROM][G930F/FD/W8/S/K/L][UNOFFICIAL][7.1.1][NIGHTLY] Resurrection Remix OS Nougat
Homepage:
Resurrection Remix OS | Get Resurrected
Features:
● Main Features
● Theme Engine
- Full Substratum(OMS) Theme Support
● Navigation bar
- Enable/Disable Navbar
- Navbar color tint
- Navbar Button Customization smartbar
- Navbar Pulse
- Navbar Fling
- Double Tap to sleep navbar
● Statusbar
- Brightness Slider
- Enable/Disable Show Notification Count
- SuperUser Indicator Switch
- Double Tap To sleep Statusbar
- Carrier Label
- Carrier Label Switch
- Carrier label Color
- Carrier Label Size
- Clock Customizations
- Time & date
- Day & date Toogle
- Center/Right/Left Clock Choice
- Date Format
- Clock Font Styles
● Battery
- Battery Bar customization
- Battery Icon Customization(circle/landscape/Potrait and more)
- Battery % Text
● Network Traffic Indicator
- Network Traffic Arrows Switch
- Incoming/OutGoing Traffic
- Network traffic Color
● Statusbar RR Logo
- RR logo Color
- Position
● Custom Logos
- logo Color
- Position
- Style
● StatusBar Weather
- Weather Color
- Weather Position(left/right)
- Weather Font Style
- Weather Size
● StatusBar Ticker
- Ticker Text color
- Ticker Icon Color
● Animations
- Toast Animations
- ListView Animations
- System Animations
- QS tile Animations
- Power Menu Animations
- Misc Animations
● Gestures
- Gestures Anywhere Feature
- 3 Finger Swipe Screenshot Gesture
● App Circle Bar
- Choose apps in AppSidebar
- Trigger Width
- Trigger Hieght
- Trigger Position
● App Sidebar
- Choose apps in App circle
- Trigger Width
- Trigger Hieght
- Trigger Position
● Pie Control
- Pie Trigger(left ,Right ,Bottom)
- Pie Targets
- Pie Colors
- More Pie Features
● Recents Panel
- Clear All button Switch
- Clear All Tasks Switch
- Clear All Button Location(Top right,Top Left,Top Center,Bottom Left,Bottom Right,Bottom Center)
- Full Screen Recents
- Recents Styles
- OmniSwitch
● Cclock Widget
- CLock And Alarm Customizations
- Weather Panel Customizations
- Calender Events
● LockScreen
- Lockscreen Bottom Shortcuts
- Lockscreen General Shorcuts
- 100+ Icons for Shortcuts
- Double Tap to Sleep Lockscreen
- Lockscreen Media Art/Enable Disable
- Quick PIN/Patter Unlock
- LockScreen Wallpaper
- Lockscreen Weather Widget
- Lockscreen Icons Color
● Quick Settings Draggable Tiles
- Customizable Tiles
- Dyanamic Tiles Adjustment
- Number of columns/rows
- Tile Animations
● Notification Drawer
- Task manager
- Custom headers
- LongPress Toogles to Enter Settings
- Disable Immersive Mode Messages
- Force Expand Notification
- Quick PullDown
- Smart Pulldown
- Notification Panel Transperency
- Volume Dialog Transperency
- Notification Panel Stroke
- Volume Dialog Stroke
● Buttons
- Backlight Timer
- Backlight Strength
● Advanced Reboot Menu
- Power Off
- Reboot(Recovery, Bootloader, Hot Reboot)
- ScreenShot
- Power Menu End Calls Switch
- Restart SystemUI
- Airplane Mode
- ScreenRecord
- On the Go Mode
- Sound Panel
● Home Button(For devices with HW keys Only)
- Home Button answer call
- Long Press Actions
- Double Tap Actions
● Menu Button(For devices with HW keys Only)
- Short Press Actions
● Search Button(If Device Supports)
- Long Press Action
● Volume Buttons
- Wake Up Device
- Playback Control
- Ringtone Volume Control
- Keyboard Cursor Control
- Swap Buttons on Landscape mode
- Volume Key Answer
● Miscellaneous
- Selinux Switch (Switch Between Permissive and Enforcing Selinux if Device has Selinux Enabled)
- cLock Shortcut
- Disable Battery Saver Warning Color
- OTA Updates
- Cammera Shutter Sound Enable/Disable
● SystemUI Tuner
- Enabled By default
- Removed Demo mode and Tweaked SystemUI Tuner As compared To AOSP
- StatusBar Icons Cuzomizations
- Quick Settings Customizations
● Other Features
- Perfomance Profiles
- LCD Density
- Expanded Desktop Mode
- Heads Up Switch and customizations
- Live Display
- Configurable 0,90,180,270 Degree Rotation
- Lock Screen Autorotate Switch
- Native Tap to Wake From Marshmallow
- Double Tap Power Button To enable Camera gesture
- Prevent Accidental Wakeup
- Wake Phone on Charging Plug
- Battery Light Customizations
- Notification Light Customizations
- Font Size
- CM privacy guard
- RR OTA
- CM root inbuilt
- New RR Configurations
- Overall Smoothness Improvements
- Optimizations to Improve Battery
- Includes all Android Nougat Features
- Includes all CM14.1 Features
- And much much more ...
Was nicht (richtig) funktioniert:
- Lautsprecher beim Telefonieren - Der Gegenüber hört einen nicht mehr
Screenshots
Download:
Androidrom.io - Browse /ResurrectionRemix/herolte at SourceForge.net
Beans Gapps:
[GAPPS] [7.1.2] [ARM/ARM64] [April 15th] Beans GApps
Open Gapps:
The Open GApps Project
Hier müsst ihr die arm64 - 7.1 wählen
Weitere Links:
Aktuelle Bootloader und Modem: [MODEM][Boot Loader][ODIN] Samsung Galaxy S7 (flat) SM-G930F (Upd. Apr. 22 - 2017)
SuperSU Beta: [BETA][2017.01.14] SuperSU v2.79 SR3
TWRP Recovery: [Recovery][Exynos] Official TWRP for Galaxy S7 (herolte)
Magisk: [2017.3.31] Magisk v12.0 - Root & Universal Systemless Interface [Android 5.0+]
HTC-Kamera: HTC Camera APKs - APKMirror
Installations-Anleitung:
0. Euer Gerät darf nicht verschlüsselt sein und die OEM-Entsperrung muss aktiviert sein!
1. Ladet die TWRP recovery herunter (TWRP) und folgt den Schritten in der Anleitung!
2. Rom herunterladen und auf die externe SD-Karte kopieren
3. Sichert all eure Daten (Auf die SD-Karte z.b.)
4. Bootloader immer den aktuellen nehmen!
5. Installiert den Bootloader und das neuste Modem mit Odin mit den CP und BL Tabs.
6. Anschließen bootet in die Recovery.
7. Nun auf "wipe" - format data - yes eintippen (um die Verschlüsselung zu entfernen)
8. Installiert die Rom und Gapps
9. Gerät neustarten (Erster Neustart dauert immer etwas länger!)
10. Unterbrecht diesen Vorgang nicht. Wartet ab!
11. Viel Spaß mit der neuen Rom
Donation:
@jesec
@Fevax
Reaktionen: Nufan, matze6989 und nudelz
ich nutze diese ROM seit dem ersten Tag und schon damals auf meinem S5 ... einfach "Yes"!
Reaktionen: Lexuzz
Nutzt Ressurection Remix die Camera App von Samsung?
Bzw. gibt es einen Unterschied zur Qualität der geknipsten Fotos im Vergleich zur Stock ROM?
Da muss ich dich leider enttäuschen. Die Qualität ist in meinen Augen schlechter, da die Stock Kamera voll ins Touchwiz System greift. Aber es gibt zum Glück auch sehr gute Kamera Apps im PlayStore. Die Entwickler sind trotzdem dran, die Kamera App zu verbessern.
Ich selber nutze diese Rom auf dem S2, Tab S2 und dem S7.. einfach genial und sau schnell in aller Hinsicht :D
In Kombination mit dem Nova Launcher für mich unschlagbar! Ich bin mal gespannt wie lange es dauert, bis es für das 7.1.1 endlich einen Theme Editor gibt. Kanns kaum erwarten ^^
Ui, bei deiner Beschreibung jubelt schon wieder mein Flasher Herz :D
Wie siehts denn mit dem Akkuverbrauch aus, kannste da schon was zu sagen?
Werde die Rom auf jedenfall am WE austesten <3
Hier müsste eigentlich auch die Substratum Theme engine funktionieren!? Zu finden im Play Store..
Also ich hab mein S7 mit der Rom noch nicht bis ans Limit getrieben, kann aber sagen, dass sie mir ziemlich stromsparend erscheint ^^
Finde das muss jeder selber ausprobieren..
UND NIMMT AM BESTEN DIE MINI DYNAMIC GAPPS !!! Damit habt ihr am wenigsten Google-Mist auf euren Geräten :p -----> HIER <------
Reaktionen: Mr. Hase
@Mr. Hase
nach nun einigen Wochen des ausprobierens, muss ich sagen, dass der Akkuverbrauch besser ist als mit der StockRom ...
aosp roms haben zwar definitiv viele vorteile, aber auch einige große nachteile...samsung hat mit seiner software vieles besser als stock gemacht unter anderem auch die kamera. deswegen bin ich mir so unsicher , welche ich benutzen soll :)
Nabend.. Ich habe mir vorgenommen das gute Stück morgen mal zu installieren. Muss ich bei der Installation iwas beachten?
vielen dank im vorraus
Hi. Eigentlich nicht besonderes. Lade die open gapps pico runter und das letzte RR. Damit bist du auf der besten Seite :)
Reaktionen: Sash1405
Dann mit Odin flashen? Entschuldige die vielleicht blöde frage, wo muss ich die md5 datei einfügen??
gruss
Das md5 wird nirgendwo mit installiert. Lade es trotzdem mit runter und lege es auf die SD Karte, wo auch die Rom liegt... Flasht du zum ersten mal? Ist nur so ne Frage..
Die Rom wird über das TWRP Recovery gelasht, die Open Gapps gleich hinterher
Reaktionen: numenic74 und Sash1405
Nein habe schon öfters mein S7 gequält.. War mir nur nicht ganz sicher bei der Datei.. Und bevor was in die Buchse geht, frage ich lieber kurz nach.
dank dir
Ok dann bin ich beruhigt :)
Hab den letzten Post nochmal bearbeitet..
Edit:
Ganz wichtig ist das Rom Backup übers Recovery und Titanium Backup, vor jedem Flash einer anderen Rom!!!! Kann man nicht oft genug sagen :)
Durch die anfänglichen eher negativen Erfahrungen die man gemacht hat, hat man dazu gelernt. Belese mich immer erst viel und sowas bevor ich anfange zu flashen... Das eine grosse Missgeschick hat mir gereicht.. Deswegen Frage ich lieber einmal nach.
Und am besten eine Stock Firmware parat haben, falls doch mal irgendwas voll in die Hose geht. So mach ich das immer..
Ok die habe ich nicht.. Habe im Moment die Superman drauf.. Aber wenn alle Stricke reißen, ziehe ich ne Stock frisch drauf. Aber Danke für den Tip
Reaktionen: Lexuzz
Servus, hab gestern es auf das S7 installiert, hatte ewig Probleme mit den Gapps weil in Android dann immer die g-apps beendet wurden. Am ende liefen die: Mini_Dynamic_GApps-7.1.x-20170107. Wo liegen den in der Regel die Probleme wenn dann immer die Gapps flasht aber dann in Android die Play-Dienste die ganze Zeit beendent werden?
Nun zu mein Problem: Ich kann nicht vom PC daten auf das Gerät übertragen. Also in Android und dann halt über den Windows Explorer. Wenn ich n Foto z.B, übertrage geht der Windows-Ladebalken bis etwa 80% und hört dann auf. Kann es an der Formatierung mit dem S7 liegen? Nach etwa 2 Minuten kommt dann von Windows die Fehlermeldung das die Datei nicht kopiert werden (Das Gerät regaiert nicht oder Verbindung wurde getrennt).
Kann mir jmd helfen?
Wlancall und volte?
  • SP-Fotodesign
3 4 5
Roger123
FliegerNRW
bananensaft
Black_Focus
AVTR84
AVTR84
