Black_Focus
Dauer-User
- 622
- Themenstarter
- #161
SuperMan-Rom V2.3:
- Rebased on top of DQBO release
- Updated all kernel with latest ramdisk to version V2.2.1
- Added a note to aroma that busybox is needed for romcontrol/synapse
- Removed the cache init.d in aroma which caused bootloop
- Updated bootloader to DQBO
- Reworked SuperMan Settings app (will now show "free" in addition)
- Free means that this is the app with the rom and not the one on playstore, I will release a "pro" app (same functions) with translations and just to donate me
- Added Back to kill option
- Added Recent to kill option
- Fingerprint unlock without enabling display added (works only as long as fingerprint sensor doesn't go to deepsleep)
- New icons inside the SuperMan settings app
- Added blur effect on pulldown menu
- Added clock on lockscreen is now colorable to different colors (MM/H/SECS)
- Added notification colorable with notification text colorable
- Added search bar colorable and hidden switch
- Added fully working secure folder to the rom (will also be display in pulldown menu)
- Added Samsung Pay to Knox in debloat option (since it works together)
- Updated samsung pay and samsung pay framework with latest apps from sammobile, if that doesn NOT work well just uninstall the updates (those are not system files so you can easily uninstall them)
- Added custom icons for Signal/Alarm/Wifi in romcontrol
- Fixed left clock being displayed on lockscreen, is now hidden
- Added "clear all" and "notification settings" colorable
- Added colorable background the notification pulldown
- Basically everything is colorable now in pulldown
- Updated AdAway to most recent version
- Updated included adblocker files
- Updated included bloat apps (as instagram, snapchat, signal etc)
- Updated Magisk Manager to latest 4.2.6 (which fixed all fc's)
- Fixed OTA/Rom Control icon displaying a grey background
- Updated OTA app to match superman design
- Added new superman gifs in romcontrol (black/blue and red/yellow)
- Possibly more things to mod which I already forgot again
Download V2.3
All Bootloader and Modem files
Download V2.3
