Kvitja
Stamm-User
- 270
Das ist lediglich ein Support-Thread für EchoeRom sowei AEL Kernel. Weder Rom noch Kernel werden hier zur Verfügung gestellt noch weitergegeben. Der Thread soll/wird nur als Hilfestellung dienen. Auf Anfragen der Downloadlinks wird nicht reagiert.
The S7 Edge Echoe Rom
(Please check Post #2 for Latest Releases and Changelogs)
Features/ Highlights:
- Based on the newest Official S7 Edge Base that is available
- FULL AROMA Installer with extensive options
- Multi CSC
- With Patched Stock Kernel
- Fully Deodex Rom
- Pre-rooted with supersu 2.68
- Busybox 1.24.1
- 5 way reboot menu
- all apps multiwindow
- fixed private mode
- fixed external sd r/w ppermissions
- Enabled display scaling (dpi scaling) in settings (settings/display)
[You can change dpi from 640 (stock) to 560 (condensed) and vice versa]
- Removed the annoying external card notification on every boot
- Removed the high volume warning for headphones
- Fixed the auto brightness bug in dark environments
- Added more than 150 additional system fonts
- Enabled TouchKey Light duration in settings (settings/display)
- New build.prop modifications for even smoother experience and better ram management
- Enabled ALL feeds by default
- Added @ zubi182's incredible “dual speaker” sound mod (xda thread:forum.xda-developers.com/s7-ed…-surround-mod-v4-t3340601)
- Call Recording
- No SMS to MMS conversion for long sms
- Save/ Restore feature for sms
- a lot more csc mods
- With the Echoe fluidity and speed (battery is really nice also) http://www.************/wcf/images/smilies/wink.png
- Mildly debloated
- External cards are recognized and are fully functional no matter what format they are http://www.************/wcf/images/smilies/smile.png http://www.************/wcf/images/smilies/smile.png http://www.************/wcf/images/smilies/smile.png
- GEAR VR IS FULLY FUNCTIONAL ON THIS ROM!!
- New, exclusive build.prop modifications
- Many many more mods availalble as aroma options
Installation Anleitung:
Bitte beachtet das Ihr das Gerät vorher nicht extra Rooten müsst! Es muss nur ein Custom Recovery installiert sein!
Danke und Credits gehen an:
S7 Ael Kernel*
FEATURES:
- Built from the newest official Samsung Kernel Source Code G935FXXU1APF2
- Built with the incredible SaberMod 5.3 Toolchain
- Newest Linux Base 3.18.34
- Ability to Overclock the "Big Cores" up to 2.9 ghz
- Ability to Overclock the "Little" Cores up to 1.8ghz
- Ability to Underclock the "Big Cores" down to 312 mhz
- Ability to Underclock the "Little Cores" down to 338 mhz
- Voltage Control for both core clusters
- GPU Voltage Control
- Added the following additional CPU Governors:
Conservative, ondemand, bluactive, dancedance, lionheart, ondemandplus, nightmare, darkness, alucard, conservativex, intelliactive,
bioshock, preservative, barry_allen, wave, interactive_pro, yankactive, smartmax_eps, electrodemand, ondemand_x, intellimm, pegasusq, smartassv2
- Added the following additional I/O schedulers:
. Tripndroid, vr, sio, sioplus, fifo, deadline, zen, fiops, bfq
- Added Screen Sleep Functions
(Double Tap 2 Sleep ans Sweep 2 Sleep)
- GPU OC up to 806 mhz and UC down to 160mhz
- Added Powersuspend v1.7
- Added LED Fading controls
- USB/Keyboard Mouse Hack (use your phone as a mouse or keyboard to control any other device in which you plug your usb)
You need this app: play.google.com/store/apps/det…hid.keyboard.client&hl=en )
- Enabled DriveDroid Compatibility (you can flash .iso images from your phone to your pc for example)
For all the info you may need: forum.xda-developers.com/showthread.php?t=2196707
- Ported the Motorolla "quickwakeup" driver (pls google it.. i have been publishing kernels for the last 3 years.. i have explained everything a million times)
- Added Dynamic FSync v1.5
- Ported HTC'S Async Fsync
- Added "ZenTune" v4.5 (its enabled by default)
- Enabled UKSM (Ultra Kernel SamePage Merging)
- Reduced wireless wakelock timeout (its tunable via Synapse "Misc")
- Applied Google Services Wakelock fix
- Network speed tweaks
- Enabled Advanced TCP algorithm and a shitload of more congestion algorithms
- Permissive kernel from source
- Ram management enhancements
- Insecure and adb insecure ramdisk
- Used and modified G935FXXU1APE9 ramdisk
- FULL SYNAPSE SUPPORT
INSTALLATION INSTRUCTIONS:
- Please make a full backup
- Flash the kernel (no wipes are really necessary)
- Please enjoy and lets make this fun http://www.************/wcf/images/smilies/smile.png
Tip: Use the app "Synapse" to set the kernel tunables. The options Synapse has are implemented by the developer of the kernel. Synapse itself is created by the GREAT @Andreilux
CREDITS:
- @jesec for fixing the fingeprints!!! Its 100% him and only him!!!
forum.xda-developers.com/s7-ed…e-kernel-s7-edge-t3389528
- @UpInTheAir and my brother @thehacker911 for some of the synapse files
*** Please check my github for the most accurate credits and contributions to my repo ***
Ich bitten jeden insgeheim, liest bitte und haltest euch an die Anleitungen. Dann dürfte es was die Rom und den Kernel betrifft keine Probleme geben. Ich würde den Thread gerne sauber halten und bitte euch wirklich den Thread zu lesen, damit nicht auf jeder Seite immer wieder gleich Fragen und Themen auftauchen. Vielen Dank und viel Spaß hier.
- Multi CSC
- Fully Deodex Rom
- Busybox 1.24.1
- 5 way reboot menu
- Call Recording
- Mildly debloated
- ROM Downloaden
- ins Recovery booten
- [SEHR WICHTIG] unter der Option WIPE "FORMAT DATA" [NICHT WIPE DATA ABER FORMAT DATA]. Dies "formatiert" die kompletten System und Data Partitionen und all eure Persönlichen Daten und Einstellungen werden gelöscht / zurückgesetzt. Stellt also sicher das ihr diese gesichert habt! OHNE diese Formatierung werdet ihr nicht alle Funktionen des ROMs installieren können!
- ROM flashen
- Nach der AROMA Installation nicht auf Reboot klicken sondern einen manuellen Neustart über das Recovery machen
- Gerät rebooten und ca- 8 bis 10 Minuten (der erste Start kann etwas länger dauern als gewohnt!)
- SuperR für die wundervolle Kitchen: forum.xda-developers.com/chef-…-superrs-kitchen-t3202296
- Chainfire für den Root Zugriff und SuperSU
- friedrich420 für den ROM
S7 Ael Kernel*
FEATURES:
CREDITS:
