[ROM][G93xF][7.0][AQI7] *12.10.2017* BatMan-Rom v1.4.0 [Stable]
  • 383 Antworten
RomBeast
RomBeast
6-threadheader1-jpg
!!!Weder ich noch Android-Hilfe übernehmen eine Haftung sollte durch das flaschen dieser Rom euer S7 (edge) oder S8(+) defekt werden!!
Kompatibel mit S7 (Edge) und S8 (+)
Rom features of V1.4.0 Nougat:
- Based on latest G955FXXU1AQI7 Nougat base
- Prerooted with SuperSU V2.82 SR5, Phh root r310 or MagiskSU (choose in aroma)
- Magisk V14.2 (aroma selectable)
- Latest Busybox installed (aroma selectable)
- Aroma installer! with support up to 4GB zip files
- CSC features can be choosen and installed in aroma (such as Applock, Floating Message, Call recording and more!)
- Adblocker enabled or disabled (choose in aroma)
- Full rom control!! App name is BatMan Settings Free
- Fully deodexed (also framework)
- Multi device installation, this rom supports all exynos models of the S7 and the S8!!
- Rom informations and logo inside settings
- LED indicator settings
- choose IOS or stock emojis in aroma
- DM-Verity disabled
- Force encrypt disabled
- ADB fully working
- Modded SystemUI with many tweaks in RomControl (like header colors, qs colors and notification colors)
- 3Minit Clock/battery in romcontrol
- Custom clock positions and customizations in romcontrol
- USB Plug/Unplug disable wake up
- Remove high volume warning for headphones
- Torch on lockscreen
- Use volume key on lockscreen to switch music titles
- Many other mods in the romcontrol, please check it out it's worth it!
- Knox stuff can be choosen in aroma
- Back to kill (in RomControl)
- BatStock-Kernel(choose in aroma)
- Based off from latest touchwiz source available at this moment
- Many apps are selectable in aroma debloat menu
- Selinux permissive on custom kernel
- Ram bar in recents
- Matrix animation in recents
- Sound Mod V19 with lot improvements! (choose in aroma)
- Latest August Security Patches
- Many other features, can't list them all, please read changelog to see what changed over the time
BatMan-Rom V1.2.0:
- Rebased on latest AQGB release (I know AQH3 is out, but until samsung releases a new kernel source it normally takes a few weeks that's why this base is used for now)
- July security patch
- Added navbar icon colors mwilky
- Added navbar to get colors from statusbar (as long as the app doesn't set a default color) mwilky
- Added in "misc" batman settings to disable touchkey light (s7 only of course)
- Readded custom color selection for navbar in stock settings
- Removed a few camera mods which weren't working
- Updated CSC to AQGB, also added all CSC in OMX (including BTU)
- Updated all Kernels to latest source and ramdisk
- Updated SuperSU to 2.82 SR3
- Added a the S Power Planning feature (forward ported from galaxy j7 prime), choosable in aroma as a csc mod
- Updated OperaMax apk to not show as chinese apk, many people meant it's a trojan lol :D
- Updated adblocker host file
- Updated all included modems and bootloaders
- Added a stock kernel even for the s7, so you can choose stock there as well!
- Updated Magisk to latest V13.5 beta version
- Added modded camera into aroma @zeroprobe
- Added 100+ fonts apk into aroma
- Updated busybox to most recent version
- Updated dual speaker mod to most recent version
- Added VoLTE and wificalling into pulldown menu
- Reduced download size to 3GB only (hahahaha only 3GB :D )
S7 specific changes:
- Include sticker fix by default
- Use much less s7 libs, I hope to fix: camera crashing and some call issues with this!
- Included google face unlock, you find it in security, smart lock (to get samsungs one working I'm almost sure it's hardware related), but at least face unlock works!
- The scripts do now change build.prop to G930/G935 if a s7 model is detected, this fixes: wallpaper stretch, samsung vr and games launching in black screen mode (because the phone thoughts we use a navbar and we had to reload the game) however if you wish you can always change that back to G950/G955 manually in /system/build.prop with a root explorer!
- Updated all libs from s7 with latest base libs from DQG1
- Small other changes which bring hopefully less issues!
Changelog V1.1.1:
- fixed camera modes (works only with clean data)
- updated kernel and gpu drivers to most recent one (you are the first guys running it on a s7/s7e, no one else has this yet in the world!!)
About the kernel: That means no other kernel will run except ours, the reason is: other kernel developers have to update their GPU drivers as well, otherwise no boot.
- added s7 gamelauncher if you have choosen without navbar
- fixed a gap on launcher without navbar (but if you update the launcher, guess what, the gap will be back)
- official magisk 13.1 update included
Changelog V1.1.0:
- Based on latest G955FXXU1AQF7 Nougat base
- Prerooted with SuperSU V2.82 SR1, Phh root r310 or MagiskSU (choose in aroma)
- Magisk V13 (aroma selectable)
- Viper4Android included (choose in aroma, works only with custom kernel)
- VIper4A with magisk support (choose in aroma, works only with custom kernel)
- DAP sound mod included (choose in aroma, works only with custom kernel)
- ADB fully working
- Sound Mod V20 with lot improvements! (choose in aroma)
- Latest June Security Patches
Download:
V1.4.0 on Android File Host
Bootloader/Modems SM-G93XF/FD/K/L/S/W8
CSC Selection V1.2.1
Telegram Links:
BatMan-Rom S7/S8 Deutsch
BatMan News Channel
BatMan-Rom Chat Englisch
Dark Knight Theme
Bugs:
-Face unlock
-Iris Scanner (Hardware)
Credits:
- Samsung for the base
- SuperR for his awesome Kitchen
- Chainfire for his SuperSU
- topjohnwu for systemless Magisk V12
- amarullz for aroma and nkk71 to make it compatible with bigger zip files
- wubydax and daxgirl for basic RomControl
- All my team mates and helpers!
- myellow for all the great animations!
- TheFreak for his work as designer and his help with the website
- mwilky for his fingerprint after reboot mod and other mods
- Asc1977 for a few mods I already used on SuperMan
[ROM][STABLE][N][7.0][AQGB][14.08.17][SM-G93XF/FD/K/L/S/W8] BatMan-Rom - Grifo Development
Reaktionen: numenic74, FalcoKubny, Peha13 und 8 andere
Na dann werde ich die mal testen, kann denn schon einer sagen ob das umschalten zwischen WLAN und mobile Daten funktioniert?
Bei Csc mit Dbt oder dtm für Telekom?
Also ich kann dazu nicht viel sagen hatte glaube ich noch nie Probleme mit dem Umschalten, und ich habe die DBT drauf
Reaktionen: nobody573
Ich bin absolut begeistert von der Rom. Das ist der erste Port mit der volte und der dbt csc im o2 Netz funktioniert. Ich konnte bis jetzt auch absolut keine Fehler feststellen. Das wird sich natürlich erst über die Tage genauer sagen lassen aber für den ersten wurf bin ich begeistert. Genauso wenn man in der telefon app in die rufumleitung geht wird es jetzt genauso schnell angezeigt wie bei der stock rom. Das war bis jetzt bei keinem port so.
Die Superman Rom war schon gut aber die Rom hat das auf anhieb getoppt. Wenn jetzt noch die ganzen alten mods rein kommen wird er die download zahlen von der Superman rom toppen :)
Ich kann nur sagen das Luca da top Arbeit geleistet hat.
Und danke das du den thread auf gemacht hast.
Reaktionen: FalcoKubny und nobody573
Bin auch begeistert von der Rom, aber man muss sagen die und Minotaurus tun sich beide nicht viel, was features usw. angeht. Zu VOLTE kann ich leider nichts sagen, da ich von BASE auf O2 umgestellt wurde und immer noch diese Dienste nicht habe.....
Gerne mache ich ja auch für mich und mal sehen wie die ankommt dann könnte man auch vielleicht eine Telegram Gruppe erstellen.
Reaktionen: matze6989 und nobody573
Hallo Zusammen... vielen Dank Für den neuen Thread.. ich werde die Rom jetzt mal Testen... falls ich es heute Abend noch gedownloaded bekomme... der Server ist langsam... bin schon sehr gespannt ob VoLTE funktioniert...
Bei mir gehts perfekt. Ich lade die immer mit einem downloader aus dem playstore damit geht das recht schnell.
Advanced Download Manager – Android-Apps auf Google Play
Achso ich habe das Samsung s7 flat. Nicht das meinungs Verschiedenheiten aufkommen.
Edit: morgen kommen noch mehr csc Dateien dazu falls jemand eine andere braucht die nicht in der rom ist. Obwohl da schon fast alle abgedeckt sind.
Ich lade am PC mit JDownloader runter und der Download dauert schon was sind ja auch immer hin 3GB was viel für eine Rom ist.
Sollte es ja eigentlich nicht wenn nur was das Thema Akku angeht,
Also... hab es endlich geschafft. Und es funktioniert!!!!!!!:biggrin::biggrin::biggrin::biggrin:
Sehr geil!!
Wie mich das gefuchst hat dass VoLTE nicht funktionierte...
Nunja bis jetzt kann ich nur positives über diese Custom Rom sagen.
[doublepost=1499813511,1499810879][/doublepost]@matze6989
Vielen Dank für den Tipp
Bin sehr zufrieden
[doublepost=1499813666][/doublepost]@nobody573
augenscheinlich hat das umschalten bis jetzt geklappt..!
( DBT und Telekom)
Verstehe ich das richtig das es ein S8 Port ist. Muss ich Bootloader und Modem vorher installieren oder ist der beim flashen der Rom schon dabei. Gibt es ein Aromainstaller wo man die Samsung Apps abwählen kann.
Steht alles im ersten post
@controlled
S8 Port? JA!
Bootloader und Modem? Ja ! Mit TWRP ist bei der Installation wählbar. Bin von Minotaurus v14 direkt auf Batman rüber ohne vorher eins von beiden zu installieren.
Aroma Installer? Ja! Mit sehr umfangreichen Auswahl Möglichkeiten. Viel mehr als Minotaurus.
Reaktionen: controlled
Der Download link führt zu 404 error im ersten post, zumindest bei mir
@nobody573
Bei mir auch
Klappt nur über den Link der Develloper Homepage..
Werde ich dann später mal nachschauen, bin gerade aufm Weg zur Schule spätestens heute Abend ist der neue Link drin. ;)
Ja so hab ich das auch gemacht, dachte nur das andere nicht lange sich wundern müssen und suchen
@nobody573
Recht hast Du.
Hat einer eine bearbeitete imsservices.apk für diese Rom, damit die wolke weg ist von Volte?
Die wolke hab ich garnicht gehabt.
@nobody573
ich dachte die Wolke ist das Symbol für Rich comunikation (erweiterter Nachrichtenservice von Google) ?
