[ROM][G93xF][6.0.1][BPHJ] *31.10.2016* BoBCatRoM v.2.0
  • 6 Antworten
dumbo1
dumbo1
Stamm-User
403
!!!Weder ich noch Android-Hilfe übernehmen eine Haftung sollte durch das flaschen dieser Rom euer S7 edge defekt werden!!!
mitte-png.533371
BoBCaTROM_V2.0.3_MM_6.0.1
• BoBCaTROM V2.0.3 - October 2016 update
• Based on Samsumg firmware Android 6.0.1 - XXU1BPHJ
- Multi CSC
- Deodexed – busybox - root
- Magisk v.8 Thx @topjohnwu
- Phh's SuperUser Thx @phhusson
- Support to S7 Flat Variants
- Auto Backup EFS @Tkkg1994
- SuperStock Kernel @Tkkg1994
- Removed Knox
- Statusbar Icons
- Private MODE
- CSC Features
- Call Recording
- Reboot menu 5 way
- Disable Volume Warning
- Dual Speaker v17
- SD Card Notification Removed
- All SMS/MMS Mods
- Disable Signature Check
- FIX Permission Ext SDCard
- FiX Do Not Disturb
- Rounded Corners in recents and in the notifications.
- Screenshot ScreenRec and Flashlight in Power Menu
- Fixed Gear VR
- Floating Message
- Virtual Buttons in Statusbar
- Viper Android FX
- Xposed Installer
• Rom Control
* Systemui Mods
- Signal switch left-Right
- Network Traffic on/off
- 3Minit Battery Settings
- Potato clock
- Potato Gradient
- Notification Panel Background
- Visible Toggles Show
- Quick Connect Color
- Colorize Lockscreen Clock and Date
- Toggles Buttons Background
- Gear Reboot in Statusbar Expanded
- APP Lock
Colorize systemui
Notification background color
Notification text
Notification icons background color
Notifications number Shown on Lockscreen
Toggles on color
Toggles off color
Toggles text colors
Colorize Expanded panel:
- Expanded header bg color
- Quick settings panel bg color
- Brightness background color
- Data usage bg color
- data usage text color
Colorize quick connect bg and text color
Colorize Lockscreen Clock and data
Colorize statusbar expanded Clock and data
Colorize edit text
Colorize statusbar icons
Custom Carrier Text
Color carrier text
Statusbar icons colors
Color CLEAR Button
Percentage color
Brightness slider Shown/Hide
Usb plug in/out wakeup
all notifications are removable
• in OTA
-TouchWiz UX
Phone Mods
- Gear Custom bg settings
• Framework and General Mods
- DPI Settings
- Gesture on Home Screen
- Number Columns in Settings
• Useful Apps
- Phone Info
- Partition Backup
- AdAway
- Air WakeUP
- Universal Init.d enabler
- Root Checker
- Log Cat
- Dpi Changer
-CPU Spy
• Sound Settings
- Skip Tracks Volume Control
- Enable/Disable Increase Ringtones
• OTA Update
- BoBMods OTA
- BoBCat Themes free
• more to come
1. Odin hier Downloaden
2. Die neusten Bootloader und Modem hier downloaden
3. Rom hier oder hier Downloaden und auf sd-Karte kopieren, bevor ihr Twrp aufspielt die Entwickleroption frei schalten und die OEM-Entsperrung + USB Debugging anschalten.
4. TWRP hier ziehen und über Odin flashen, wenn neu startet sofortLautstärke+/Home/Powertaste gedrückt halten. Wenn zu spät einfach Lautstärke -/Powertaste getrückt halten, startet neu
5. Im TWRP erst formatieren und dann wipe, delvik cache
6. Das Verzeichnis auswählen wo die Rom liegt und starten
7. den Anweisung von BoBCaT folgen, dauert ca. 10-20 min und startet neu
8. Spaß haben
9. Wer noch andere Themes will, kann sie hier downloaden und installieren.
natürlich vielen Dank an BoBCaT
HIER noch der Link zu xda
Was soll ich sagen, läuft hervorragend und hat hat wirklich viel Extras.
Also, jetzt drei Tage am laufen, komplett ohne Probleme. :thumbsup:
Ich kann die Rom nur empfehlen.
Hallo an alle!
Kann man über den hier installierten Xposed Installer sich einfach das Framework downloaden, oder brauche ich das Custom Xposed von Wanam?
Was hat es denn eigentlich mit diedem Magisk auf sich?
Danke schonmal für eure Hilfe!
Du kannst wanam testen, ich brauche kein xposed. Bin auch weg von Android 6.0.1.
Habe noch eine Kurze Frage zur Installation. Mein Modem und der Bootloader scheinen doch aktueller zu sein, als die im angebotenen Download. Also kann ich doch einfach das Rom flashen, oder liege ich da falsch?
Installier das was vorn drin ist
