dumbo1
Stamm-User
- 422
!!!Weder ich noch Android-Hilfe übernehmen eine Haftung sollte durch das flaschen dieser Rom euer S7 edge defekt werden!!!
BoBCaTROM V5.0 NOUGAT DQG1
- Multi CSC
- Deodexed – busybox - root
- Magisk v.8 Thx @topjohnwu
- Phh's SuperUser Thx @phhusson
- Support to S7 Flat Variants
- Auto Backup EFS @Tkkg1994
- SuperStock Kernel @Tkkg1994
- Removed Knox
- Statusbar Icons
- Private MODE
- CSC Features
- Call Recording
- Reboot menu 5 way
- Disable Volume Warning
- Dual Speaker v17
- SD Card Notification Removed
- All SMS/MMS Mods
- Disable Signature Check
- FIX Permission Ext SDCard
- FiX Do Not Disturb
- Rounded Corners in recents and in the notifications.
- Screenshot ScreenRec and Flashlight in Power Menu
- Fixed Gear VR
- Floating Message
- Virtual Buttons in Statusbar
- Viper Android FX
- Xposed Installer
• Rom Control
* Systemui Mods
- Signal switch left-Right
- Network Traffic on/off
- 3Minit Battery Settings
- Potato clock
- Potato Gradient
- Notification Panel Background
- Visible Toggles Show
- Quick Connect Color
- Colorize Lockscreen Clock and Date
- Toggles Buttons Background
- Gear Reboot in Statusbar Expanded
- APP Lock
Colorize systemui
Notification background color
Notification text
Notification icons background color
Notifications number Shown on Lockscreen
Toggles on color
Toggles off color
Toggles text colors
Colorize Expanded panel:
- Expanded header bg color
- Quick settings panel bg color
- Brightness background color
- Data usage bg color
- data usage text color
Colorize quick connect bg and text color
Colorize Lockscreen Clock and data
Colorize statusbar expanded Clock and data
Colorize edit text
Colorize statusbar icons
Custom Carrier Text
Color carrier text
Statusbar icons colors
Color CLEAR Button
Percentage color
Brightness slider Shown/Hide
Usb plug in/out wakeup
all notifications are removable
• in OTA
-TouchWiz UX
• Phone Mods
- Gear Custom bg settings
• Framework and General Mods
- DPI Settings
- Gesture on Home Screen
- Number Columns in Settings
• Useful Apps
- Phone Info
- Partition Backup
- AdAway
- Air WakeUP
- Universal Init.d enabler
- Root Checker
- Log Cat
- Dpi Changer
-CPU Spy
• Sound Settings
- Skip Tracks Volume Control
- Enable/Disable Increase Ringtones
• OTA Update
- BoBMods OTA
- BoBCat Themes free
• more to come
- Removed Knox
- Statusbar Icons
- Private MODE
- CSC Features
- Call Recording
- Reboot menu 5 way
- Dual Speaker v17
- All SMS/MMS Mods
- Fixed Gear VR
- Floating Message
- Viper Android FX
- Xposed Installer
• Rom Control
* Systemui Mods
- Potato clock
- Potato Gradient
- APP Lock
Colorize systemui
Notification text
Toggles on color
Toggles off color
Toggles text colors
Colorize edit text
Custom Carrier Text
Color carrier text
Color CLEAR Button
Percentage color
• in OTA
-TouchWiz UX
• Phone Mods
- DPI Settings
• Useful Apps
- Phone Info
- Partition Backup
- AdAway
- Air WakeUP
- Root Checker
- Log Cat
- Dpi Changer
-CPU Spy
• Sound Settings
• OTA Update
- BoBMods OTA
• more to come
1. Odin hier Downloaden
2. Die neusten Bootloader und Modem downloaden und über TWRP, nach der Rom, installieren, nicht über Odin.
3. TWRP hier ziehen und über Odin flashen, wenn neu startet sofort Lautstärke+/Home/Powertaste gedrückt halten. Wenn zu spät einfach Lautstärke -/Powertaste getrückt halten, startet neu
4. Rom's Hier Downloaden und auf sd-Karte kopieren, BEVOR ihr Twrp aufspielt die Entwickleroption frei schalten und die OEM-Entsperrung + USB Debugging anschalten.
5.Im TWRP erst formatieren und dann wipe, delvik cache
6. Das Verzeichnis auswählen wo die Rom liegt und starten
7. die Installation dauert ca. 5 - 8 min und startet neu
6. Reboot und Spaß haben
natürlich vielen Dank an BoBCaT
HIER noch Link zu xda wo ihr auch verschiedene Themen downloaden könnt
