[ROM][G935F][7.0][DQD3] *08.05.2017* SuperMan-Rom V2.5 [AROMA][KERNEL][OTA][STABLE]
  • 193 Antworten
bodyXY
bodyXY
!!! Knox 0x1 wird ausgelöst und Samsung Pay ist nicht mehr nutzbar !!!
WICHTIG : Ihr handelt auf eigene Gefahr! Ich übernehmen keinerlei Haftung für euer Handeln oder einen Brick!!!
Wenn ihr der Anleitung folgt, gehen alle eure Daten verloren!!! Vorher absichern
SuperMan-Rom V2.5
by TKKG1994
- Based on latest G935FXXU1DQD3 Nougat base
- Prerooted with SuperSU V2.79 SR3, Phh root r310 or MagiskSU (choose in aroma)
- Magisk V12 (aroma selectable)
- Latest Busybox installed (1.26.2)
- Aroma installer! with support up to 4GB zip files
- Full edge support features support
- Adblocker enabled or disabled (choose in aroma)
- Viper4Android included (choose in aroma)
- VIper4A with magisk support (choose in aroma)
- DAP sound mod included
- Full rom control!! V2.1
- Zipaligned
- First fully deodexed rom without odex framework
- Rom informations and logo
- choose IOS or stock emojis in aroma
- DM-Verity disabled
- Force encrypt disabled
- ADB fully working
- Modded SystemUI with many tweaks in RomControl
- Applock feature supported
- Floating Message support
- Many csc tweaks!
- No sms to mms auto convertion
- Auto Call recording
- 3Minit Clock/battery in romcontrol
- Custom clock positions and customizations in romcontrol
- LED indicator in settings
- Autostart in settings
- Allow all apps in multiwindow
- USB Plug/Unplug disable wake up
- Remove high volume warning for headphones
- Private mode fixed for all kernels
- Enable TouchKey light duration in RomControl
- Knox stuff is removed
- Stock DQD3 Kernel, SuperStock-Kernel or SuperKernel (choose in aroma)
- Based off from latest touchwiz source available at this moment
- Many apps are selectable in aroma debloat menu now
- Selinux permissive on custom kernels
- UDS - Ultra Data Saving
- quicklauncher in recents app
- Sound Mod V19 with lot improvements! (choose in aroma)
- April Security Patches
- Camera Mod V8.1 included (choose in aroma)
- Many other features, please read changelog to see what changed over the time
Was ihr benötigt:
ODIN3
ODIN_3.XX.X
Samsung Mobile USB Driver
SAMSUNG_USB_Driver_for_Mobile_Phones.zip
TWRP 3.x.x-x
G935
Latest Bootloader
ARCHIV
Latest Modem
ARCHIV
SuperMan ROM
( wenn ihr TWRP schon habt, könnt ihr weiter machen mit Rom-Install )
Anleitung TWRP:
- geht zuerst in eure Einstellungen / Geräte Information / Softwareinfo und tippt 7 mal auf die Buildnummer um die Entwickleroptionen freizuschalten. Diese findet ihr dann unter Einstellungen / Entwickleroptionen.
!!!DIESER SCHRITT IST GANZ WICHTIG DA ES SONST ZU EINEM BOOTLOOP KOMMT !!!
!!! - aktiviert dort die [ OEM- Entsperrung ] und das [ USB-Debugging ] !!!
- entpackt jetzt ODIN auf eurem Computer
- installiert die Samsung Mobile Phone Driver auf eurem PC
- schaltet euer Smartphone aus und startet den Downloadmodus [ Lautstärke-Taste nach unten + Home-Button + Power-Taste ] gleichzeitig gedrückt halten und dann beim Warnhinweis die [ Lautstärke-Taste nach oben ] drücken
- ODIN als Administrator starten, AP anklicken und die TWRP.tar.md5 Datei auswählen. Sonst nichts an den Einstellungen ändern!!!
- Smartphone per USB-Kabel an den PC anschließen und START anklicken
Anleitung Rom-Install:
- Ladet auch die SuperMan-Rom herunter und kopiert sie auf eure externe Speicherkarte
- schaltet euer Smartphone aus und startet den Downloadmodus durch [ Lautstärke-Taste nach unten + Home-Button + Power-Taste ] gleichzeitig gedrückt halten und dann beim Warnhinweis die [ Lautstärke-Taste nach oben ] drücken
- Bootlaoder und Modem herunterladen und ODIN als Administrator starten, BL anklicken und die BL_XX.tar Datei auswählen, CP anklicken und die CP_XX.tar Datei auswählen.
- geht bei ODIN auf Optionen und wählt das Häkchen bei Auto-Reboot ab. steckt euer Smartphone an den PC per USB-Kabel und drückt START bei ODIN
- nach erfolgreichen Flash schaltet ihr euer Smartphone manuell aus indem ihr [ Lautstärke-Taste nach unten + nach oben + Power-Taste ] gleichzeitig gedrückt haltet und sobald das Display aus geht, haltet ihr [ Lautstärke-Taste nach oben + Home-Button + Power-Taste ] gleichzeitig gedrückt um in den Recovery Modus zu kommen
!!! DIESEN SCHRITT BENÖTIGT IHR NUR, WENN IHR VON EINER ORIGINAL FIRMWARE KOMMT !!!
(ansonsten diesen einen Schritt überspringen)
Partition DATA entcrypten
- im TWRP-Hauptmenü auf [Wipe] klicken, weiter auf [Format Data] und dort werdet ihr noch mal nach einer Bestätigung gefragt, mit [YES] bestätigen
!!! Data entcrypten ENDE !!!
- im TWRP-Hauptmenü auf [Wipe] klicken, weiter auf [Advance-Wipe] und dort Dalvik / System / Data / Internal Storage / Cache auswählen, mit [Swipe to Wipe] bestätigen
- danach bleibt ihr im TWRP und geht zurück ins Hauptmenü mit der [Zurück-Taste]
- geht auf Install und klickt dort [Select Storage] an und wählt [Micro-SDCard] aus, sucht das Verzeichnis aus wo ihr die SuperMan-Rom abgespeichert habt und klickt die Rom an. Dann [Swipe to confirme Flash] und folgt den Aroma-Installer Anweisungen
Reboot dauert bis zu 10 min.
Fertig!
Original SuperMan Thread bei XDA
ALL CREDITS TO TKKG1994 & Friends
SCREENSHOTS SUPER-MAN-ROM
freue mich über jedes Danke ;)
Reaktionen: numenic74, MH63, petlura und 5 andere
Latest Nougat V2.X Changelogs:
SuperMan-Rom V2.5.0:
- Rebased on latest DQD3 release
- Remodded everything from scratch (this base had many changes compared to previous updates)
- April Security patch
- Updated Magisk to V12
- Updated Magisk Manager
- Updated phh superuser to r310
- Updated included adblocker host files
- Updated included BL/CP to DQD3/DQD2
- Fixed barometer displaying weird stuff on lockscreen
- Updated all bloat apps such as telegram/snapchat/titanium etc
- Updated Kernels to V2.5.1 version (new linux and new ramdisk)
- Updated included modded camera thanks to @djb77
- Added S8 camera to aroma, thanks to @_alex74_
- This update is mostly for stability and security!
SuperMan-Rom V2.0:
- Updated to DQAS (FULL REBASE TO ANDROID N 7.0)
- All kernels updated to DQAS (Stock, Super and SuperStock)
- Latest Busybox 1.26.2 included
- Latest SuperSU SR3 included
- Latest BL DQAS and CP DQA3 included
- Latest Magisk Manager APK included
- Latest TWRP 3.0.2-5 included
- Latest SuperUser Beta11 apk included
- Latest Sound Mod V19 included (updated for Nougat)
- Latest Camera Mod V7 included (updated for Nougat)
- Removed Xposed (not compatible with Nougat)
- Added many additional apps to bloat selection
- Added support to aroma to support 4GB zip files
- ARISE sound mod updated to V2.4
- Many Nougat CSC features included
- Floating message working
- AppLock working
- Private Mode working
- Aroma Theme reworked
- All SuperMan icons reworked
- Bootanimation reworked
- Splash screen reworked
- Multi User fully functional
- 3minit clock included (romcontrol option)
- Battery bar included
- Safe volume warning removed
- Weather on lockscreen enabled (can be a bit buggy, N just got released LOL)
- Hide or show lockscreen clock (inclusive seconds)
- Quick launch in recents
- Network speed indicator with tint
- Background colors for QS tiles colorable
- Statusbar icons colorable
- 3minit clock aroma choosable
- Virtual lock buttons
- Ambiente display
- Data usage in statusbar
- Dynamic statusbar
- Reboot to recovery, screenshot toggle, screencast toggle etc added
- Gear reboot on statusbar (romcontrol)
- Gear device info
- Latest adblocker included
- 0.25 animation speed in settings added
- Some more things I maybe forgot again
- For all credits please check my V2.0 release Post
SuperMan-Rom V2.1:
- Rebased and retweaked on latest DQB3 release
- Bootloader updated to DQB3 and modem to DQB1
- CSC updated to most recent BTU version as well
- Updated Magisk to V11.1 (removed phh's apk, root for Magisk is now INSIDE Magisk apk)
- Updated Magisk Manager to 4.1
- Fixed a busybox problem which didn't install it correctly
- Updated all kernels with latest ramdisk and source code (DQB3 isn't released yet)
- Updated adblockers hostfiles
- Removed ARISE sound mod, they have their own aroma installer and everything now, download it here
- Updated Camera Mod to V8
- Updated my own romcontrol a bit, changed colors and stuff
hope you like it
- Removed knox entry from settings
- Added custom clock settings
- 3Minit clock can now be enabled and disabled inside RC (no need to choose in aroma)
- Clock can now be moved left, in the middle, right or disabled
- Clock can be colored
- Clock style can be choosen
- Date in statusbar can be choosen etc etc (just check the clock settings in RomControl)
- For lockscreen I've fixed the weather issue, however flat users may have some problems since the display is smaller than on edge phones. I got a S7 flat and I know what I'm talking about (let me know what you think)
- Fixed weather widget displaying time twice
- Added 18 different analog clocks in RomControl (to display on lockscreen)
- Added rambar back to romcontrol (it will be displayed at the top so you can't use it at the same time as recent quick launch)
- Volume skip added (skip tracks with volume control)
- Fixed ambient display not working
- Added auto call recording
- Updated pulldown statusbar colorizing
- Fixed alarm on lockscreen
- Added app shortcuts to romcontrol
- Added launcher gestures (all working fine except enabling flashlight)
- Added touchkey light duration in settings
- Added autostart manager in setting
- Added LED indicator in settings
- Updated all toggles in restart menu to match nougat design
- Updated shutdown animation (looks perfect now)
- Added many default superman wallpapers (will only appear after a clean wipe)
- Added the dark side of superman theme
- Someone requested me to add knox apps in aroma. So there you go, knox is in debloat menu but for sure I did not flash that onto my phone
- Added google assistant in aroma choice (debloat settings)
- Added brightness fix
- Updated all additional (none samsung & google) apps to most recent version
- Added CPU-Z and Tapatalk in debloat settings
- Removed amplify in debloat (sorry for confusion!)
- Disabled signature check for apps
- Probably some more things, but I can't remember sorry guys!
- Before someone ask, all credits can be found on V2.1 Release post!
SuperMan-Rom V2.2:
- Updated to latest DQB7 base with February security patch
- Full rebased and remodded since last base
- All mods have been updated
- Kernel are all updated to DQB7 ramdisk
- Kernels do now fake knox 0x0 on running system
- Added a much better selection of build.prop and init.d tweaks in aroma (you will see what I mean)
- Added new 3d boot animations by
- Moved themes into seperate aroma installer by Check this post here
- Added an aroma choice for ambient display (should fix lockscreen lag, please report back to me)
- Added another google assistant, this hopefully fixes the problems (you have to update the google app after installation in google playstore)
- Updated BL to DQB7 (modem is still the same)
- Added new toast animations in romcontrol
- Changed some default values in romcontrol
- reboot background menu is now colorable
- matrix in recents
- Move signal and wifi to the left in romcontrol
- added an option in romcontrol to change your carrier on lockscreen
- Camera mod updated to V8.1
- Possibly some other things I already forgot again sorry
SuperMan-Rom V2.3:
- Rebased on top of DQBO release
- Updated all kernel with latest ramdisk to version V2.2.1
- Added a note to aroma that busybox is needed for romcontrol/synapse
- Removed the cache init.d in aroma which caused bootloop
- Updated bootloader to DQBO
- Reworked SuperMan Settings app (will now show "free" in addition)
- Free means that this is the app with the rom and not the one on playstore, I will release a "pro" app (same functions) with translations and just to donate me
- Added Back to kill option
- Added Recent to kill option
- Fingerprint unlock without enabling display added (works only as long as fingerprint sensor doesn't go to deepsleep)
- New icons inside the SuperMan settings app
- Added blur effect on pulldown menu
- Added clock on lockscreen is now colorable to different colors (MM/H/SECS)
- Added notification colorable with notification text colorable
- Added search bar colorable and hidden switch
- Added fully working secure folder to the rom (will also be display in pulldown menu)
- Added Samsung Pay to Knox in debloat option (since it works together)
- Updated samsung pay and samsung pay framework with latest apps from sammobile, if that doesn NOT work well just uninstall the updates (those are not system files so you can easily uninstall them)
- Added custom icons for Signal/Alarm/Wifi in romcontrol
- Fixed left clock being displayed on lockscreen, is now hidden
- Added "clear all" and "notification settings" colorable
- Added colorable background the notification pulldown
- Basically everything is colorable now in pulldown
- Updated AdAway to most recent version
- Updated included adblocker files
- Updated included bloat apps (as instagram, snapchat, signal etc)
- Updated Magisk Manager to latest 4.2.6 (which fixed all fc's)
- Fixed OTA/Rom Control icon displaying a grey background
- Updated OTA app to match superman design
- Added new superman gifs in romcontrol (black/blue and red/yellow)
- Possibly more things to mod which I already forgot again (sorry
SuperMan-Rom V2.4.1:
- Updated base to DQCG
- Reworked from scratch!
- March security update included
- Improved permissions in system/bin (rom should now work even better)
- Update stock kernel to DQC5
- Update SuperStock to V2.4.1 (with flicker free included)
- Update SuperKernel to V2.4.1 (with flicker free included)
- Updated Bootloader and Modem to DQCG / DQCG
- Added W8 BL/CP files to be flashed with the rom
- Added font apk (installs many fonts), it's choosable in debloat menu
- Moved romcontrol and OTA to debloat menu too (if you don't want them, don't install them)
- Removed framework selection, ambient is now called a different way
- Ambient is now also working without AOD (thanks to @mwilky)
- Updated Magisk to V11.6 (safetynet shall pass with usb debugging on now)
- Updated Magisk Manager to latest version
- Updated included bloatware apps
- Updated AirMessage and Applock app
- Updated TWRP to 3.1.0
- Added a switch in SuperMan settings to enable or disable RCS (cloud icon) (thanks to @MisterEvo)
- Added a switch in SuperMan setting to toggle 4G/LTE (thanks to @MisterEvo)
- Added a choice in aroma to include software keys
- If you choose knox, tima and knox will be enabled automatically, if not they will be disabled
- Aroma log will be saved at sdcard/SuperMan/aroma/
- Music and the Simcard notification of the FD variants should be colored too (let me know if it works!)
- Adjusted weather on lockscreen to match better, in next version there will be a big rework
- Fixed alarm icon being weird on theme ( @_alex74_)
- Added blur effect on pulldown colorable
- Added a switch to hide brightness slider on pulldown ( @mwilky)
- Added SystemUI tuner thanks to @lyapota (long press on settings icon in pulldown to activate it)
- Added option to color stock battery icon
- Added a switch to enable rounded notifications (aren't colorable for now)
- Added blur effect on recents
- Added many new items on pulldown menu
- Added back "Torch on Lockscreen", it's now in SuperMan settings under "misc systemui"
- Enabled lockscreen notification limit can be raised from 1-3
- Updated smali/baksmali for deodexing
- Updated all social media bloat apps (for example "signal" got secure video call feature)
Reaktionen: petlura und shamanous
Gute Rom bis jetzt wer cool wenn der dev gleich noch mit einbauen könnte die neuen Statusbar icons zu entfernen für Volte
Edit:
Gibt es die Möglichkeit die schriftfarbe für die Benachrichtigungen zu ändern
Klasse Rom !! Der Dev war zwar diesmal nicht der erste mit der neuen Android Version.
Aber dafür hat er mal wieder eine saubere stabile Version rausgehaut.....
In alter Supermanrom Qualität.[emoji108][emoji122][emoji106]
Ambient Display geht aber nicht...
Was meinst du mit Ambient Display?
Andere auf XDA haben das bestätigt und Luca (Tkkg1994) schaut sich das an...
Ambient Diaplay lässt sich einschalten- jedoch ohne Wirkung (Mitteilungen wie WhatsApp, SMS, Mail, usw werden dann kurz mit Absender und Betreff kurz im AOD eingeblendet und verschwinden wieder.)
[doublepost=1485860479,1485860048][/doublepost]Bei der Minotaurus ROM lässt sich das mit der Pro App sogar zeitlich einstellen!
Reaktionen: nobody573
Ich hab da auch ein problem, alle meine bilder und music datein von meiner mikrosd karte werden nicht angezeigt.
Der Player sagt, keine lieder vorhanden und in der gallerie sind nur bilder zu sehen die im geräte speicher liegen.
merkwürdig das ganze.
Clean flash von V1.19.1
Mal eine andere Frage gibt es schon cyanogenmod bzw. Lineage für das s7 edge?
Ja gibt es hat aber hier nichts zu suchen Sorry
@Conan paar mehr Infos von dir wären da nicht schlecht sollten schon wissen wie und was du alles geflasht hast
Sry aber ich weis nicht wo ich sonst fragen soll, was mich wundert warum es kein Eintrag dazu gibt? Ich wollte bloß wissen ob es ein test gibt bzw. was geht und was nicht
Bearbeitet von: Onslaught - Grund: Direktzitat entfernt; Gruß Onslaught
@nobody573 was soll es da ngross zu sagen geben, superman-rom mit superkernel, kein xposed, kein Magisk, supersu SR3.
Mit der vor version hatte ich Magisk und xposed geflashed, da ging alles.
@DeFibRi schau mal bei xda da gibt es einige Roms schon da steht auch dabei was geht und was nicht
@Conan das sind ja schonmal etwas mehr Infos womit man etwas anfangen kann, also das es am root liegt kann ich mir nicht vorstellen hast mal versucht deine Ordner manuell einzubinden und neu einlesen zu lassen? Ich nutze schon seit Jahren poweramp und musste dort aber auch die externe sd meine Ordner wählen
Reaktionen: DeFibRi
nutzte den stock player seid jahren, da muss man ordner nicht hinzufügen, weil es die MEdiandatenbank der Sasmung FW nimmt.
Ja mehrmals, ich hab von "Medienspeicher" die daten gelöscht und hab das handy neustartet.
Hab ein kleines Problem hab die Rom mit Stock kernel geflasht, dann den superstock kernel und dann root erneuern müssen scheint wohl normal zu sein Problem ist ich hab kein Ton mehr für Benachrichtigungen weiß da einer Rat? Mit dem TG kernel genau das selbe
Hey Nobody, das hatte ich auch mal und da lag es am Theme und musste dann den Ton für die Benachrichtigung selbst einstellen. Vielleicht liegt es bei dir auch daran. Wenn nicht, dann hab ich leider keine Hilfe.
Super das wars warum auch immer das damit zusammen hängt
Weil Themes auch Töne enthalten können und wenn anscheinend keiner drin ist im Theme wird es komischerweise auf stumm gestellt. Aber cool das es daran lag.
Weiß jemand zufällig wie ich diese komische Wolke neben dem WiFi Symbol wegbekomme? Teilweise verschwindet sie automatisch kommt dann aber wieder. Danke :)
