[ROM][G935F][7.0][DQCG] *14.04.2017* Minotaurus v8.1 [Aroma]
  • 1.623 Antworten
dumbo1
dumbo1
Stamm-User
422
!!!Weder ich noch Android-Hilfe übernehmen eine Haftung sollte durch das flaschen dieser Rom euer S7 edge defekt werden!!!
Im voraus Vielen, vielen Dank an asc1977
android-jpg.552909
100% deodexed
Fully working knox
Fully working SecureFolder
Build.prop tweaks for faster and better rom
Fully working SBrowser with secure mode
Working Private mode
Changed 4g icon to LTE
BetterBatteryStats to V2.2.0.0
1060 Fonts to Samsung settings
Root Explorer app
Shutter Sound option in camera settings
Call Recording Button
Support Recent App Protection
Show Data usage in expanded SystemUI
Removed low battery warning
Whitepages /identify unsaved numbers
Fixed SD-Card permissions problem
Removed SD-Card notification
Fixed Overlay bug for some apps
Camera flash work with low battery
Unlock after reboot with fingerprint without pin or pattern
Removed high volume warning
Removed confirm buttons in Reboot Menu
Rom Status official
Applock
Screencast and Screenshot toggle
Screenrecorder app with option to show/hide floating button
Minotaurus Boot- and Shutdown animation
Aircommand Spen feature
Knox 0x0 Fixed Fingerprint on new bases Increased all sounds from 32 to 35 Keyboard with subsymbols on all languages
Disabled signature check
Systemui tuner
Features Pro:
>>>>ROMCONTROL PRO ON PLAYSTORE CLICK HERE<<<<
-German, turkish and italian translation of RomControlPro app from Playstore
-Switch for show/hide lockscreen clock and date in RC
-Option for lockscreen widgets (18 different analog clocks or weather widget) in RC
-Battery Bar with settings in RC
-Matrix effect for recent panel with RC Settings
-Lockscreen rotation option with on/off switch in RC
-Virtual lock, home and recent buttons for statusbar with options in RC
-Clock center and left with much options in RC
-Colored Statusbar Icons with settings in RC and grey icons on white apps
-DataUsage settings with options in RC
-Switch for enable/disable headsup notifications in RC
-Notification background color in RC
-Quicklaunch panel in recent apps with show/hide in RC
-Colorable Expanded Statusbar background with settings in RC
-TW-Launcher Transition effects with settings in RC
-Network traffic with options in RC
-Custom background notification panel
-Hardkeys backlight duration time settings to RC
-InCallUI custom background
-12-way reboot menu chooseable with settings in RC
-Custom Background for reboot menu
Changelog V8.1
-added double tap feature to S8 launcher
-added converter to S8 calculator
-added round google search widget for better matching S8 look
-fixed optical design of searchbar in appdrawer (color)
-S8 AOD
-fixed Smart Select on edge panel
-S8 Lockscreen clock
-fixed Info not shown at Analog clock
-removed last unlock and charging texts which missing if disabled in RomControl
-added option to colorize owner info on lockscreen
-add memory cleaner with settings in Romcontrol to rom beside brightness slider
Changelog V8
-S8 Weather app
-S8 Weather Widget
-S8 TW Launcher >>6 apps in dock
-AOD with S8 clock
-S8 SMS/MMS
-S8 MyFiles
-S8 Gallery
-S8 Clock
-S8 Calendar
-S8 Calculator
-S8 Samsung E-Mail
-Modded Samsung Browser V5.2 with new icon of S8
-S8 RebootMenu icons
-S8 Dialer
-S8 Contacts
-S8 SetupWizard
-S8 SmartClipEdgeService
-S8 Wallpapers
-S8 Musik (with fixed forceclose and textcolor)
-S8 Bixby
-S8 New Upday for Bixby
-S8 Keyboard V5
-S8 Bootanimation optional in Aroma Manager
-S8 Media folder (UI and notification sounds, ringtones and charging animations)
-S8 Samsung Themes
-S8 Edge Panel
-S8 Samsung Health
-S8 Recorder
-updated RootExplorer to V4.1
-fixed notification icon color if off
-changed Camera apk icon to S8 one
-added Systemui Tuner back
Changelog OTA V5.0.1
-Added Mainswitch for togglecolor on/off
-Fixed clock grey on white apps
-Fixed notification transparent
-Other fixes
Changelog V5
!!!!!! ITS HIGHLY RECOMMEND TO DO A CLEAN INSTALL !!!!!!
-Rebased to DQCG and remake all apk with mods new. No old apk used on new base
-Updated SuperStockKernel to V2.4.3 -Updated Magisk to V12
-Added switch between LTE and 4G icon in statusbar with RomControl settings
Changelog V4.6
-fixed wipe option at boot
-option to remove carrier on lockscreen and replace with custom text and color with settings in RomControl
-fixed MultiWindow with recent button
-removed high brightness warning
-added color option to blur effect
-updated csc chooser
-Updated Magisk to V11.6
-Sim slot panel now colorable with brightnessslider background together
-remade mod for custom background of notification panel. Now background not removed if notifications expanded.
Additional now removed in notification settings and added to expanded statusbar settings
-Added switch for unlock after reboot without pin or pattern to lockscreen options
-Notification icons and progressbar colorable
-Updated Kernel to SuperStock V2.4
-Added customized colors for expanded statusbar date,time,settings icon and 3Dot icon
-Added reboot menu button to statusbar with settings in RomControl
-Changed Signalicon 4 to bigger size
Changelog V4.5
-fixed notification text color, now full working
-added upday to debloater option
-fixed wrong description in aroma at debloater, tick is remove
-fixed switched TRR and THL csc
-Notification background noe possible to make transparent
-Smusic text now also colorable -Updates SBrowser to 5.2
-Disabled signature check
-option to remove Sfinder search bar in expanded view with switch in RomControl
-added blur effect to notification panel with settings in RomControl -added option to wipe to aroma
-added option to choose splash to aroma
Changelog V4.4
-removed phh.superuser app from appdrawer
-added back to kill with settings in RomControl app
-added CSC: COS, OPV, PHE, PHN, TEL, XID, XEO, Mulit csc TMH, DBT standalone csc, NZC, TNZ, PNG, SEB, TTR Multi-CSC, AMO, H3G, OPS, XSA, VIA, VAU
-removed text please connect charger if battery empty from lockscrenn as additional to remove charging text
-updated Kernel to V2.3.0
-updated translation in RomControl
-added debloat options in Aroma
Changelog OTA V4.3.3
-added gestures on homescreen with settings in RonControl app
Changelog OTA V4.3.2
--- needs base update V4.3 --
-Bug fixing
Changelog OTA V4.3.1
---needs base update V4.3---
-added option to remove charging text from lockscreen in RC
-fixed safetynet not work on some kernels
-fixed links in RomControl app
-added some missing translations in RomControl app
Changelog V4.3
-Fixed Google Assistant. Now work with updates too
-added notification text color with settings in RomControl
-adden option in RomControl to enable/disable unlock fingerprint with screen off
-moved notification backgrond color settings from expanded statusbar to notification settings
-option to remove swipe to unlock text in RC
-Remaked CSC features that all is there like older rom versions
-added Systemui tuner to rom
Changelog V4.2
-fixed install of viper and dolby mod
-try to fix clock at cover
-added aroma option to choose between no root, chainfire root or magisk
-updated superstock kernel to V2.2
-added fully working knox to rom
-updated Screenrecorder app, now you can record lockscreen too
-added fully working SecureFolder
-removed RichCommunication icon from statusbar
-keyboard with subsymbols on all languages
Changelog V4.1
-Added Viper-Dolby mod as option in aroma
-Added CSC chooser as option in aroma with a lot of CSC
-Fixed Volte
-Fixed USSD codes
Changelog V4
-Base update to DQB7
-Kernel changed to Superstock Kernel
-Knox 0x0
-Fixed Fingerprint on new bases
-Removed all Sound mods because most users cant handle it. so decide byself what and if you want and flash please byself
-Increased all sounds from 32 to 35
-Update RootExplorer to V4.0.7
-Removed free RomControl app
Changelog V3
-Base update to DQB3
-Remade all mods
-Updated Bootloader and Modem
-Updated to latest TPG Kernel
-Wifi Signal Chooser (PRO)
-Show/Hide activity arrows at wifi (PRO)
-Minotaurus Boot- and Shutdown animation (FREE)
-Aircommand Spen feature (FREE)
-Multiuser Switch show/hide with settings in RomControl pro (PRO)
-Removed csc chooser from aroma because volte not working
-Readd Multi BTU csc to rom
-Removed old Sound mod
-Added Arya Soundmod V3
Changelog OTA V2.3.2
Changelog V2.3
-Signal icon chooser with 16 options
-Signal icon chooser Sim2 with 16 options
-updated to SuperSU-v2.79-SR3
-Google Assistant newest version
-Changed Kernel to TPG 4.10
-Updated Root Explorer to V4.0.6
-Updated Screenrecorder app with option to show/hide floating button
-added 6 new indian csc
-added possibility to start and stop screenrecorder with toggle
-added option to choose color of stock battery icon
-Alarm icon chooses with 6 options
-Gif animation chooser with 33 options for notificationpanel at dropdown area
Changelog V2.2
-Rom now 100% deodexed, no more odex arm folders (FREE)
-option for change color of toggle, dividers and toggletext (PRO)
-Screencast and Screenshot toggle (FREE)
-removed stock kernel from rom (FREE)
-added Superkernel from TKKG for 930F and 935F to rom with automatik choose right kernel (FREE)
-removed MM CSC from rom because a bit buggy, added all available nougat csc (41) (FREE)
-changed app for screencast with newer on with more options like quality settings and floating stop button (FREE)
-Not removeable notifications optional removeable with a switch in RC (PRO)
- All available CSC:
BTU,CPW,DBT,ITV,NEE,XEF,XEO,XEU,ACR,AFG,AFR,BTC,DKR,DRC,ECT,EGY,KSA,LYS,MAT,MID,MRT,MRU,MTZ,MWD,PAK,SMG,THR,TMC,TUN,TUR,WTL,XFA,XFE,XFM,XFU,XSG,CAC,CAU,SEK,SER,SKZ
Changelog V2.1
-Rom Status official (FREE)
-Immersive mode (PRO)
-Ambient Display (PRO)
-Applock (FREE)
-Signal Position Chooser Left/Right in RC (PRO)
-Device Info view in notification panel with settings in RC (PRO)
-Custm Carrier in notification panel with settings in RC (PRO)
-New CSC in Aroma to choose: EUR, INS, RWC, TLS, XAC, XFA, XME and XSG
1. Odin hier Downloaden
2. Die neusten Bootloader und Modem werden mit installiert
3. Rom HIER Downloaden und auf sd-Karte kopieren, BEVOR ihr Twrp aufspielt die Entwickleroption frei schalten und die OEM-Entsperrung + USB Debugging anschalten.
4. TWRP
hier ziehen und über Odin flashen, wenn neu startet sofort Lautstärke+/Home/Powertaste gedrückt halten. Wenn zu spät einfach Lautstärke -/Powertaste getrückt halten, startet neu
5. Im TWRP erst formatieren und dann wipe, delvik cache
6. Das Verzeichnis auswählen wo die Rom liegt und starten
7. die Installation dauert ca. 5 - 8 min und startet neu
8. Spaß haben
9. Natürlich bei asc1977 bedanken
HIER gibt's die Romcontrol für Einsteiger
HIER könnt ihr die App Romcontrol Minotaurus ziehen, über diese App gibt es alle updates
Nach der Rom über TWRP hintereinander flashen
SuperStock-Kernel v2.5 oder,
TGPkernel v4.63 und dazu,
SuperSU-v2.79-SR3
Einfach über TWRP installieren und Spaß haben
HIER der link zur Minotaurus Webseite
HIER der link zur deutschen Telegrammgruppe
HIER der link zu G+
(Deutsch & Englisch)
HIER der link zu xda
Reaktionen: James_Blond, AMG Design, Andrix2013 und 10 andere
Clean installieren wenn ich von der v7 komme oder?
Ja würde ich machen
@controlled
Ja musst neu aufsetzen.
Da einzige Problem was ich jetzt festgestellt habe, ich kann mir das Traffic nicht anzeigen lassen.
[doublepost=1482619623,1482618741][/doublepost]@nobody573
Jetzt schaut's doch besser aus, oder?
Gibt es sonst positive Unterschiede wie zur v7.
Was ist mit der Akkulaufzeit.
@controlled
Kann ich dir noch nicht sagen, hab's ja auch erst heute aufgespielt
Also kann bis jetzt nicht klagen aber ist eh subjektiv, da jedes Handy anders ist
Und Akku war ungefähr bei 80% beim flashen von der Rom
Bearbeitet von: hagex - Grund: Bild verkleinert, Gruß von hagex
@controlled
Es ist kein grosser Unterschied. Das System ist anders. Es wird einmalig die Stock geflasht und der DEV bringt immer nur eine kleine OTA mit Änderungen heraus. Der Vorteil ist das man nicht bei jedem Update die ganzen 1,7 GB flashen muss. Geht auch schneller.
kk
Akku müsste relativ gleich sein, weil im Kernel ist nicht viel Unterschied. Weil offiziell noch keine Sourcen draußen sind. Die wird Samsung erst öffentlich machen wenn Nougat offiziell ist. Deswegen gibt's noch keine Custom Kernel.
Hat einer ne Idee wie ich mir das Traffic anzeigen lassen kann. Ich hab zwar asc1977 schon gefragt aber noch keine Antwort.
Reaktionen: kunodownhill
Die Funktion wird noch kommen. Solange kannst ja mal im Playstore schauen, gibt's ja einige Apps die das anzeigen. Aber ob die alle schon Nougat kompatibel sind, weiß ich nicht.
So wichtig ist das nicht, ich kann auch warten.
Dumbo denke mal also lange musst nicht warten [emoji5] [emoji1]
@pill
Ja denk ich auch asc1977 scheint richtig fit zu sein.:thumbsup:
und motiviert trotz blöder Bemerkungen
kk
Genau so:lol::lol::lol:
Hab irgendwie das Gefühl das ein Update heute kommen könnte [emoji1] [emoji1] [emoji1]
hi
wg. den OTA-Updates
kann man gleich das 1.2 drüberbügeln oder erst 1.1 dann 1.2 usw.
na klar.
kk
hat jemand von euch schon adaway bzw irgend einen anderen adblocker zum laufen bekommen?
