[ROM][G935F][6.0.1][XXU1BPIF] *05.10.2016* PhoeniX ROM V3.0 [Customizable | Unique | Fast | Stable]
  • 353 Antworten
petlura
petlura
Hello Flashers!
I'm proud to present you my latest work!
PhoeniX ROM For Samsung Galaxy S7 Flat/Edge G93XF.
Important note:
I do not own the device, all ROM tests are made by @_alex74_ .
Also, ROM will not be updated frequently because my main projects are myown devices - Galaxy S5 and Galaxy Tab S.
Anyways, I'm not responsible for any damaged caused by using this rom. Use at your own risk.
Devs Pay Attention!!!
You are not allowed to take/kang anything from my ROM without asking for permission from me!!
Taking without a permission will lead to report on you.
Special PhoeniX Dark Theme by @_alex74_ :
If you want the best PhoeniX Dark Theme experience, you must use our special theme by @_alex74_ :
http://forum.xda-developers.com/show...88&postcount=3
Based on the lastest stock firmware: Android 6.0.1 XXU1BPH6 (build date: 09/08/2016)
Modified Stock Kernel by @Tkkg1994
This ROM is 200% Knox Free - You can say "Cya Knox!"
Fully Deodexed
Added latest BusyBox
Added latest SuperSU+Bin files
Updated all stock apps to their latest version(Gmail, Google search, Google Maps ,Play store etc.)
Unique PhoeniX bootanimation & shutdown animation - Huge thank to the artist @anbech
Mods:
Sysro & sysrw support
Disabled scrolling cache
All supported languages enabled
PhoeniX First Setup
Ported the following from the lastest C5 firmware:
- App Lock
- Smart Manager
- Ultra Data Saving Mode
- And more!
Hacked SMS app - No SMS to MMS Conversion
Multiwindow with the following features:
* All apps in Multiwindow
* Abillity to open same app
* Popup Window
* Open WIndows from Recents
* Resize window from the corner
Multidpi support in ROM Control
Improved SD Read/Write Speed
Option for 12 apps in Toolbox
TWSWipe by daxgirl and Wuby
Added Air Messages
Added Call/Message Block option in settings
All supported languages for Samsung Keyboard enabled
Permanently removed SysSCOPE from system and forcer System Status to show "Official" - Special thanks to Aou
Shutter Sound menu Enabled to stock camera
New PhoeniX Mods's protection - Well, apparently some clowns think they can take my mods without giving credits or asking for permissions. I don't all
Apps that was marked as bloatware and can be installed/removed in the aroma:
Google Chrome
Google Maps
DropBox
Flipboard Briefing
Google TalkBack
Google Hangouts
Mobileprint services
S Health
GeoLookout
YouTube
Kids Mode
Game Features
ES File Explorer
Genie widget
Google Music
Google Search
Kies
Samsung Apps
SMemo
S Voice
Samsung Gear Support
Samsung Gear VR Support
Video Editor
Google Drive
Google TTS
Car Mode
My Files
MirrorLink
OperaMax
Added as options in the Aroma:
You can choose now tweaks you want to install!
Tweaks list:
EXT4 Tweaks:
Quote:
This mod will turn ON data_writeback for all 3 partitions - system, data and cache. This will drastically improve I/O performance (mostly on write operations) at the expense of file system integrity in certain situations, like unexpected system shutdown. The risk is not extreme, but still bigger then regular. Use this to improve your system performance, but you flash it at your own risk!
- thx to mike1983.
OpenVPN Tweaks
SQLite Tweaks
Tweak: Force Launcher into memory
Tweak: 3G Tweaks - Speed up 3G connection
Tweak: Net Speed Tweaks - Tweak to speed up internet connection
Tweak: Latest Seeder thx to lambgx02 his thread
Scrolling tweaks - Better, faster and stronger scrolling
Flash-Led Tweaks - Better flash-led intensity and camera-flash quality
Video-Streaming tweaks - Smoother and faster internet video streaming
Warning!!
Choosing all tweaks can cause for lags, etc. Choose only if you really need it.
You can choose now mods you would like to install!
Mods list:
Install Increased volume(thx to @zubi182) :
- Lite Increased Volume
- Mid Increased Volume
- Balanced Increased Volume
Added option to choose between original PhoeniX Boot&Shut down animation to Stock Boot& Shut down animation
Added Option select several mods
Added Touchwiz options:
- tamirda's TouchWiz Mod with 5x5 apps grid, 4x4 Folder apps, smaller icons and 6 hotseat apps
- Stock Touchwiz
Option to choose 560 DPI instead of 640 DPI
PhoeniX ROM Control
The new ROM control is available only thanks to @daxgirl and @Wuby986 opensource project
Status Bar Mods
Custom clock settings - Position, AM/PM, Weekday, Color
Status Bar Color and Wallpaper overlay
Premade Custom Status Bar (Thanks to rompnit)
Backup, restore, or delete Status bar image
Option to change Battery Percentage color
3Minit Battery Mod (Thanks to gharrington)
Customizable Stock Battery
Customizable Battery Bar
Single swipe for Quickpanel
Traffic Meter
Statusbar Lock Button
Statusbar Icon Toggles
Statusbar Icon Colors
Double Tap To Sleep
Notification Panel Mods:
Backgrounds
Header Preferences
Main Body Options
Toggle Settings
Carrier Label Mods
Device Info
Sound Notification Mods:
Music Control
System sound levels
System sound toggles
Volume Slider Sound
Charging Sounds
ScreenShot Sound
Notifications and Dialogue
General Mods:
Phone mods: Call Recording, End Call Delay, Auto Call Record
Lockscreen Options: Lockscreen Rotation, Use Custom Carrier Text, Lockscreen weather, Lockscreen Colors and more
Touchwiz Launcher: Wallpaper Scrolling, Launcher Effects, apps color, Launcher Gestures
NFC Icon Type
Power Menu Extended Toggles: S5/S7 Reboot Menu, Power Off, Data Mode, Airplane Mode, Restart Menu, FlashLight, Screenshot, Screen Record, Emergency Mode, Volume Toggles
Settings Mods
Email Exchange Security
Keyboard Secondary Symbols
Recent Panel Mods
Mokee Listview Animations
Buttons and Display:
Button control mod: Home double tap, Home long press, Left short press, Left long press, Power Double Tap, Right long press(Will work only when mulwindow is off) :
Quote:
Application
Flashlight
Kill App
Menu
Recent Apps
Screenshot
Screen Recorder
Google Now
Voice Command
Lock Phone
Allow 360 Rotation
Utility:
Phone Info
Terminal Emulator
Restart Options:
Restart InCallUI
Restart Phone
Restart TW Launcher
Restart SystemUI
Restart Device
Restart Recovery
Restart Download
Restart Safe Mode
PhoeniX ROM Control Pro
Mit Odin Bootloader und Modem instalieren
Bootloader klick
Modem klick
ROM INSTALIEREN
Ins Recowery booten
full wipe- wipe Dalvik Cache, Cache, System, Daten
Phoenix Rom V3.0 instalieren
Neustart
Der erste Start dauert ca. 5-8 min.
Nicht die Gedult verlieren
I'm not responsible for any damaged caused by using this rom. I give testers the rom before i publish it so you shuoldn't have any problems
Do Not Publish Any Mirror For the Rom!
MAKE SURE YOU HAVE EFS BACKUP!!
If you publish my rom in other forums, post a link to this thread + credit
V 3.0
HIER
Wer dem DEV ein Bier ausgeben möchte bitte hier entlang
pavelol
anbech- For his amazing design of - bootanimation, signatures and logo!
Dsixda
Chainfire
ikogsakanding - for thread & rom graphics
_alex74_ - A big thanks to my big friend for all the help, themes and fun!
daxgirl - master of everything, thank you for helping in all
Wuby986 - thanks for all special treatments you developed with Anna
tdunham - Master of smali, thank you for all Learned alot
slink_59‏
sac23
geiti94
thereassaad
albe95
darkera13
ale95
Tkkg1994
WerWolv
Sammobile & Samsung Updates
vndnguyen (for Phone Info)
OptimalKiller
Goldie
soloilmeglio
ALEXNDR
ambasadii
OsamaGhareeb
jesec - fix mcRegistry files
rompnit
slim80
Team Trickster
Faux123
OTA Update Center
Jack Palevich For Terminal Emulator
P.M Me if i had forggoten some one!
All XDA Comunnity
New in v3.0:
Build rom for 0! Based on the latest Official Marshmallow 6.0.1 version XXU1BPIF (build date: 12/09/2016)
SuperStock kernel V1.4 by @Tkkg1994
Added Option to color notifications background
Added option to disabled notification colors
Added option to color everything in Notifications: Title, Main Test, Time, Action Buttons
Added upday option in Launcher
Ported Note 7 Browser
Ported Note 7 Weather Widget
Ported Note 7 Calendar
Ported Note 7 My Files
Ported Note 7 Photo Editor
Fully ported Note 7 Launcher with 3D Touch, Native Blur and more
SuperSU is System-Mode now.
Enabled fingerprint unlock after reboot.
Added option to disable Launcher Blur in RC
Added Back Launcher Rotation Toggle in RC
Added option to select during installation S7 Camera or Note 7 Camera
Improved performance and stability
Removed useless apps from aroma
Fixed:
Nothing to fix
Updated:
Updated all mods in the Aroma.
Updated System Apps to their latest version
Updated Apps to their latest version
Updated SuperSU
Updated BusyBox
- And more
Attention everyone!
To get a good battery performance, you have to make Battery Calibration. To make that, search Battery Calibration at Play Store.
And more that i must have forgotten
Original Thread bei XDA
Screenshots
!!!Viel Spaß!!!​
Reaktionen: MuetzeOfficial, Hefeprinz, shamanous und 2 andere
Ein super Rom, ich nutze es als wertigen Ersatz zu Echoe. Konnte bisher noch keine Fehler feststellen.
War auf dem S5 schon perfekt! Danke für den Thread.
[doublepost=1469886301,1469885929][/doublepost]Dann direkt mal eine Frage, habt ihr mal einen Screenshot vom Lockscreen mit der Wetteranzeige für mich? Und funktionieren die SubSymbols auch auf dem deutschen Keyboard? Daaanke! ;)
Reaktionen: petlura
Bitteschön
Reaktionen: Cyricks
Sieht super aus! Dankeschön!
Reaktionen: petlura
Das kommt darauf an was du beim flashen vom Kernel einstellst. Du kannst da beim flashen die Taktung auswählen. Mach am besten einen Thread zu dem Kernel auf. Hier geht es um das Rom.
Mir ist aufgefallen das ich nach dem flashen ein schiefen "Samsung Galaxy S7 Screen" beim Hochfahren habe?
Er ist jetzt ehr rechtsbündig statt mittig.
Gibts dafür einen Fix?
Versuch mal den Bootloader neu zu installieren
Reaktionen: ReeMiqxX
hast du vor dem Install ,wipe gemacht?
mach fomat wipe und install nochmal
Bearbeitet von: SaschaKH - Grund: Keine Vollzitate! - SaschaKH
Ich habe alles gewiped vorher also alles komplett sauber und im nachhinein nochmal.
Wo bekomm ich denn den Bootloader (eventuell auch Modem) her?
Steht alles im post #1
Ah alles klar und das sind die neusten?
Hat geklappt!
Ja, sind die neuesten.
Ich nutze jetzt auch den Vogel aus der Asche. Topteil! Sehr viele Einstellmöglichkeiten über die "PhoeniX ROM Control" und zwar soviele, dass ich ernsthaft überlege, ob ich noch Xposed brauche. Zumindest die Module "GravitiyBox (MM)" und"XTouchWiz" dürften entbehrlich sein.
Einen "Riesenfehler" habe ich allerdings entdeckt: Unter den Systemeinstellungen kann ich nur maximal 14 von 15 Schnelleinstellungen auswählen. Lol; natürlich stört das überhaupt nicht.
Ich kann also die PhoeniX wärmstens empfehlen (und das LED Cover funktioniert ebenfalls bestens, was bei der BobCatRom nicht ging)
hi
was ist das Allow 360 Rotation und wie funktioniert es.
habe PhoeniX ROM Control pro.
mfg
"Allow 360 Rotation" heiß, dass du das S7 Edge drehen kannst, wie du willst und der Bildschirm bleibt immer lesbar. Also drehen (längs und quer (zum Filme gugen zB) und dann noch mal in derselben Richtung auf längs und noch weiter wieder auf quer) Ohne 360 Rotation geht's wohl nicht über Kopf (also Samsung Schriftzug unten und der home Button oben), quer links und quer rechts geht wohl immer. (Entspricht der Funktion "Bildschirm drehen")
Uups, ich stelle gerade fest, dass Überkopf (längs) bei mir nicht geht. Und jetzt weiß ich auch nicht, warum...
Hab mir gestern diese Rom hier clean geflasht.
Soweit mit allem zufrieden.
Hätte nur ne kleine Frage.
Ich nutze eigentlich die App "Upday",aber wenn ich sie über den Playstore installieren möchte,
bekomme ich nur angezeigt das sie nicht kompatibel mit dem Gerät sei.
Hat jemand nen Tip für mich?
Hat sich erledigt.
weis wer wo es die deutsche dbt gibt habe keine mobile daten
Lass dir die daten von O2 einfach zu schicken hier oder gib die von hand ein
Name: O2 DE-Internet
APN: surfo2
proxy:
port:
username:
passwort:
server:
MMSC:
MMS Proxy:
MMS Port:
MCC: 262
MNC: 07
APN Typ: default
petlura
petlura
petlura
Cloud
Cloud
Cloud
FalcoKubny
controlled
controlled
