[EOL][ROM][G93x/N950][7.1.1][BRA8] *18.02.2018* IronMan-Rom 1.2.0 FINAL[STABLE]
  • 179 Antworten
Funktioniert leider immernoch nicht, schade.
Schon eine Info wie es mit ein Update aussieht Sicherheitspatch November.
@controlled
Ja der Luca wartet noch auf die Freigabe des Quellcode von Samsung.. das update ist ja schon draußen..
Aber der erfahrung nach dauert es meist nur ein paar Tage nach dem er nen Kernel update macht bis die neue Rom Version kommt
EDIT 06.12.17
BIN SCHEINBAR NICHT UP TO DATE GEWESEN
IronMan-Rom V1.1.0:
- Updated the base from the rom to latest BQK6 release
- This base includes the Krack fix
- Fully remodded with all romcontrol features (There are no new features added for now in the RC)
- Updated kernels to latest BQK6 source code (version 1.2.0)
- Updated included csc to BQK6
- Updated all bootloader and modem files to latest for their model
- Added SM-G955N, SM-G950N and SM-N950N bootloader/modem to aroma. So they can also update directly via recovery!
- Updated modded Youtube vanced to most recent version
- Updated patched camera bins thanks to Noxxx!
- Added vision to the bixby debloat section, means if you don't select bixby in aroma you also won't get bixby vision this time
- Added a new "edge" debloat feature, if you don't choose it you get the system without all edge functions
- Updated the modded camera thanks to zeroprobe (based on BQK6 release)
- Updated all included recoveries to 3.2.0-0 (except the note 8 didn't got an update yet)
- Removed many google apps from aroma, you can download them via the playstore, this prevents an issue people had with "symlink failed"
S8/S8+ specific changes:
- Updated all libs to AQK7 base
S7/S7e specific changes:
- Fixed wifi issues on some devices, under any circumstances wifi/connection will NOT BE LOST ANYMORE (works only with IronKernel, you may ask your kernel dev to include this fix too)
- The other issues with resolution/backkey light won't be fixed till a similar devices as the s7 gets android 7.1.1
TO-DO:
- Add IronMan animation
- Add IronMan splash
- Add IronMan gifs in pulldown
- Rework the settings IronMan logo
- Design for Pro app
Download for S7/S7e:
[ROM][STABLE][N][7.1.1][BQK6][06.12.17][SM-G93XF/FD/K/L/S/W8] IronMan-Rom - Grifo Development
For support please visit my Paypal (thank you already ❤️):
Luca Grifo Geld mit PayPal.Me senden
Reaktionen: Hefeprinz
Ist da der Securitypatch für November mit bei???
andr0ide schrieb:
Guten Tag,
ich habe heute die Iron Man Rom geflasht und im Aroma Installer Magisk ausgewählt. Nach mehreren Versuchen und verschiedenen Einstellungen in Magisk kann ich immernoch nicht Snapchat nutzen, safety net failed! Kennt irgendjemand eine Lösung um den Root zuverlässig zu verstecken?
Ansonsten bin ich nämlich mit der Rom sehr zufrieden, nur ohne Snapchat werde ich sie wieder deinstallieren.
Magisk deaktivieren/entfernen, Snapchat installieren und anmelden, Magisk wieder aktivieren/installieren. So, habe ich gelesen, funktioniert es.
@controlled
Ja klar.. ich aktualisier auch demnächst den Startbeitrag... muss mich erst mal fertig machen.
Also ein schönes Nikolaus Geschenk
Reaktionen: Hefeprinz und controlled
Hab ich das richtig gelesen,das es für die RC ne pro App gibt?
Solang es nicht so wie bei Mini abläuft,würde ich es gut finden
@Hefeprinz
Die Pro app kann nicht mehr als die free RC bei Grifodev gibt es aus prinzip alles möglichkeiten der Romeinstellung in einer free RC die Pro RC ist nur zum Spenden da... die ist eben in verschiedenen Sprachen verhanden so auch in deutsch... die free RC ist ja in englisch
Die Pro RC kann ich ja von BatMan dann nehmen oder???
@controlled
Ja noch ... allerdings weis ich nicht wie das dann sein wird wenn ironmandesign für die pro app steht... ??
Bis jetzt müsste die pro app von batman klappen
Reaktionen: controlled
So hab es Dirty drüber geflasht.
Bis jetzt keine Probleme
@Hefeprinz
Ich clean...
Auch alles gut :biggrin:
So nach längerem Benutzen kann ich nur sagen,wieder ne Hammer Rom in gewohnter Qualität.
Die Akkuverbrauch ist etwas höher als vorher aber noch vertretbar
Reaktionen: controlled und FalcoKubny
Kann mich nur anschließen:biggrin:
Also zum Akkuverbrauch kann ich nur positives sagen. Komme über zwei Tage mit normaler Benutzung.
@controlled
Wow krass wie hast Du es eingestellt das der Akku so lange hält?
@Hefeprinz
Ich nur ca. 1,5 Tage.. manchmal 1 Tag... nutze aber ständig bluetooth manchmal mir 2 geräten gleichzeitig.. und gleichzeitig auch viel Musik usw.
Hefeprinz schrieb:
@controlled
Ich habe da nicht viel eingestellt. Apps aus dem Autostart und die meisten apps nach einer gewissen Zeit in den Standby schicken.
@controlled
Wo kann man Autostart an und ausschalten
Cloud
Cloud
Cloud
petlura
petlura
petlura
dumbo1
Marlow
Marlow
