maxe
Ehrenmitglied
- 4.769
Originaler Thread XDA-Developers: [ALEXIS ROM 8.0 BETA1][SM-G92xF/I/D/K/L/S/T/W8][03/01/2017][6.0.1 5DPL4][BOOM SOUND]
Entwickler: AlexisXDA
*/Fast Description/*
Based on latest firmware by Samsung with November Update (5DPL4)
Odexed, 100%Deknoxed, Zipaligned, SU.D tweaks...
Better performance with lowest battery usage
Pre-Rooted with SuperSU 2.79
Busybox Pre-Installed
Surround Mod
Ac Display Support (Ambient Display)
Csc Tweaks
Fast Bootanimation
Heavy debloated with aroma support where you can choose what you want!
SystemUI GraceUI Themed
And much more...
Features:
Chagelog:
Anleitung:
Vorrausetzungen:
Installation:
Go into Recovery and Flash NougatGraceUI_For Alexis Rom 8.0
Select the UI that you want and later reboot
Now you can set fingerprint without having any issue!!!
ADVICES FOR HAVE BEST EXPERIENCE:
Surround Mod
Csc Tweaks
Fast Bootanimation
And much more...
Features:
MAIN ZIP:
Wipes option
Wipe System, Data, Cache and Dalvik
Wipe Data and Cache
Select Kernel
Stock kernel for all devices
Select CSC Tweaks
Show on/off text on switch button
Data Usage in Notification Panel
Shutter Sound Option for Camera
Identify Numbers Unkowned
Block Notification Swiping on Notification Panel
Select Sound Mod
Alexis Surround Audio Mod (Only for SM-G92x F/K/L/S)
T-Mobile Surround Mod (by sshfranko) (for SM-G92x T/W8)
EXTRA PACKAGE ZIP:
Select for S6, Note7/S7 or Google Apps
Phone and Contacts
Messages App
Launcher
Smart Manager
Camera App
Keyboard
Calculator
Clock App
Select Features Removed by default because unuseful
Edge Features
Ultra Power Saving Mode
All Android Smartwatch support
Beam Service
Car Mode Support
Easy Mode
USSD Codes
IMS Telephony Apks (for Volte)
Quick Connect
Samsung Themes
SPrint Support
GearVR Support
Smart Switch Support
VPN Support
Samsung Magnifier
Wifi Direct and AllShare Support
Mirror Link
S-Cloud
Galaxy Themes
Accessibility Functions
Google Search and Google TTS
Select SystemUI Edits
Stock SystemUI
All Rounded SystemUI
SystemUI with 3Minit Battery Mod
Select System Animations
Stock Animations
iOS Animations
MIUI Animations
Note7 Animations
Select Apps Removed by Default
Samsung Memo
Samsung E-Mail App
Flipboard Briefing
Samsung Galaxy Apps
S-Finder
Peel Smart Remote
Sim ToolKit
S-Browser from Note7
S-Voice from Note7
Samsung Video App from Note7
Weather Widget from Note7
Samsung My Files
Samsung Galaxy Apps
Samsung Music App
Select Ported Features
AirCommand
Game Launcher
Galaxy Labs
Toolbox
Dual column settings
1060+ Fonts Mod
Viper and Dolby
Adaway
FasterGPS
Select Emojis
Stock Emoji
iOS 9.3 Emoji
iOS 10 Emoji (thanks to geiti94)
Android N Emoji
*/Supported Devices/*
This Rom works with every Galaxy S6 and Galaxy S6 Edge
If audio doesn't work in T-Mobile find in XDA forums the fix!
If you have problems with VOLTE, you can go on this thread and use THIS AROMA TOOL for extract manually your csc country.
Wipes option
Wipe Data and Cache
Select Kernel
Select CSC Tweaks
Select Sound Mod
EXTRA PACKAGE ZIP:
Phone and Contacts
Messages App
Launcher
Smart Manager
Camera App
Keyboard
Calculator
Clock App
Edge Features
Beam Service
Car Mode Support
Easy Mode
USSD Codes
Quick Connect
Samsung Themes
SPrint Support
GearVR Support
VPN Support
Samsung Magnifier
Mirror Link
S-Cloud
Galaxy Themes
Stock SystemUI
Stock Animations
iOS Animations
MIUI Animations
Note7 Animations
Samsung Memo
Samsung E-Mail App
Flipboard Briefing
Samsung Galaxy Apps
S-Finder
Peel Smart Remote
Sim ToolKit
S-Voice from Note7
Samsung My Files
Samsung Galaxy Apps
Samsung Music App
AirCommand
Game Launcher
Galaxy Labs
Toolbox
1060+ Fonts Mod
Viper and Dolby
Adaway
FasterGPS
Select Emojis
Stock Emoji
iOS 9.3 Emoji
Android N Emoji
Chagelog:
Version 8.0 BETA1
Based on Alexis 7.8 Odex firmware
Deleted su.d support and added init.d one, this prevent the slow boot
Added some init.d for performance and battery life
Improved RAM management
Fixed busybox installation
Added Samsung Cloud from S7 Nougat(Select in aroma, I'm not sure if will work)
Added fix for Screen Overlay detected and Scroll Capture fc
Re-moved Themes apps on main zip, this because Alexis Black Theme will be installed as default
Updated Alexis Black Theme, now it supports GraceUx Icons
Started partnership with @TheRoyalSeeker, all thanks to him for Divine Beats Sound Mod added on this Beta
Added for the first time in my ROM the Rom Control, at the moment I added only few things like:
- Network speed in statusbar
- Data Usage editable in Notification Panel
- And Device Informations in Notification Panel
All thanks go to @daxgirl, @Wuby986 and @theressaad that helped me a lot!
Then, removed Alexis Settings App and removed the option to choose the icons to see in Power Menu
Now in power menu there is shown : Power Off, Reboot, Screenshot and Screenrecorder; The Emergency Mode is now moved in settings
Edited Settings Apk with a tons of new features:
- Led Indicators options in Display Settings
- Toolbox, Adaway, RomControl and SuperSU are now in Settings Menu and deleted from Launcher (looks better)
- Added by default to choose, not more only 9 tiles, but 15 tiles in Quick Tiles
Added LTE Only Mode in Connections Settings
Updated GraceUi SystemUI now with:
- Colorized icons in statusbar like S7 Nougat
- 6 toggles in a column
- Empty Recent icon from S7 Nougat
Edited Extra Package, obviously removed the apps that now are by default on settings and removed FasterGPS that was useless at least for me!
Added the option for choose between SoundAlive and Divine Beats SoundMod
Added the option in Main Zip for choose between BlackTheme with GraceUx Icons and BlackTheme with 5.0.2 Icons
THIS IS CALLED BETA, BUT IT IS STABLE LIKE THE PREVIOUS VERSION, I WANT TO ADD ONLY SOMETHING NEW FOR IMPROVE YOUR TOUCHWIZ EXPERIENCE, LET ME KNOW IF THIS IS GOING WELL!
SOURCE CODE FOR ROM CONTROL WILL BE SHARED SHORTLY!
Version 7.8
Now the base is Odex:
-Better Performance
-Better Battery
-Apps open faster than deodex
Removed 'All Apps in multiwindows' won't work on odex
Added Dual Sim fix by default
Fixed 'Identify Numbers Unkown'
Fixed Screen Recorder
Switched to Stock Gallery App for fix photos switch after take it on camera app
Re-added Scroll Capture from Note7 (I forgot to add it in 7.7)
Allowed Google Play Services and Samsung Push Service to power saving
Version 7.7
Based on latest Samsung Update 5DPL4 with November Security Patch
Now heavy debloated, but don't worry, what I've removed is now on extra package
Fixed Secret Mode on S7 Nougat Browser (Thanks to Repulsa)
Re-removed DC Icon instead of H+ in statusbar
Fixed LTE icon instead of 4G icon in statusbar
Removed 1060+ fonts mod, it gives only more size to rom but isn't needed, you can find it easily on XDA.
Tweaked installation
Optimized Ram Management
Added more su.d tweaks for best performance and battery!!!
Version 7.6.1
Added fix for that apps downloaded from play store that force close
Fixed Messages App Fc
Added new Alexis Surround Mod v2:
Fixed echo during calls
Optimized Audio quality
Increased audio in headset/bluetooth
Version 7.6
Reverted to old UI and Fixed Unlock with Pin/Password/Pattern Fc
Updated SuperSU to Version 2.79 Stable
Fixed Wallpaper Choose options icons on Gallery
Changed Note7 Keyboard to S7 Nougat Keyboard
Updated S-Browser to S7 Nougat Version
Updated Google Keyboard to latest and newer version by Google
Updated all other Google Apps
Added option in Aroma for choose if you want LTE icon instead of 4G icon on statusbar
Removed my own theme because buggy (wait official release for it)
Removed DC icon instead of H+ icon on status bar
Version 7.5
Added Fix for USSD
Fixed App Lock
Improved Fingeprint Speed Unlock
Added ITV csc by default, and added in csc folder BTU and DBT csc too
Removed "Remove permanent notifications mod"
Re-added DualColumn Settings Option to Aroma
Added AirMessage support for Note7 and S6 Message App (doesn't work on Google Messages App)
Themed SystemUI to looks like GraceUI
Theme Store pre-installed for who had problems with my theme installation
!ATTENTION!
With this version you can find at 99% a bug where you can't unlock your phone with pattern or pin
I'm sorry for this bug, but apktool made me crazy all day and I can't fix it, sorry again, I hope you can live with it.
Version 7.4
Deleted Note 7 Apps that had bugs, like Calendar and E-mail
Added Note7 Gallery by default (don't worry if it appear with old icon)
Updated Toolbox App (fix app selection bug with 640dpi)
Updated Google Play Store
Updated Google Play Services
Updated WebView Google
Updated Google Keyboard (aroma)
Updated Google Phone and Contacts App(aroma)
Updated Google Calculator (aroma)
Updated Google Messages (aroma)
Updated Google Pixel Launcher (aroma)
Removed some build.prop tweaks, was useless
Added new csc country, now VOLTE should be supported... repeating, I can't test so only you can say me if it is fixed (Thanks to a friend on telegram)
Fixed some problems related to aroma
Added fstrim, zipalign and sqlite tweaks.
Added new su.d tweaks
Improved general stability, battery and performance
Improved installation script
Fixed battery capacity and device model information in Settings
Alexis Black Theme will be applied automatically if you make a clean install and flash Main zip + Extra Package, selecting theme option in aroma.
Maybe you will find a little error on settings.. In informations about rom/date of release of this update there is written 5.11.2016 instead of 5.12.2016, I made a little mistake lol
Version 7.3
Fixed the option in aroma for Data Usage on Notification Panel that got installed without selecting it
Fixed Ac Display that was resetting its settings at every reboot
Added Google Assistant on Aroma (thanks to @thereassaad) (Don't update Google App or you will lose this feature)
Deleted more than 30 apks
Added more option in aroma for Debloat
Moved some options from First zip to Extra Package
Updated Note7 Camera App (Only selfie flash features from Note7 doesn't work)(thanks to @khongloi113)
Added a lot of tweaks for:
-Audio
-Performance, now rom seems more smooth and fast!
-Battery
-Ram Management, really optimized for best multitasking!
And there is much more..
Version 7.2
Based on latest DPJN base with November Security Update
Changed the build of aroma, now there are two zips:
-The first zip is already a ready ROM, with all important S6 Apps pre-installed with an aroma for choose Debloat and Mods
-The second zip is an Extra Package where you can choose N7 or Google Apps instead of pre-installed S6 and choose other apps debloated, you can choose your favourite emoji too..
Now Ac Display should be enabled by default
Fixed Screenrecorder App
Removed Emoji Switcher because fc
Removed OTA Update Center because was causing only problems XD
Fixed Note7 Keyboard problems with downloading languages
Fixed Call/Messages Blocking in Stock and Note7 Smart Manager
Re-added the option like on Note7 for screenshoots
Optimized general performance and optimized battery..
For better feeling with the ROM:
-Don't use some Note7 Apps, can cause incompatibilies
-Use less Viper and Dolby, are good but sucks battery
Report for battery after 2/3 complete cycles of battery
Version 7.1
Based on latest Samsung Firmware DPJ2 with October Security Update
Fixed Ac Display Fingerprint Unlock Bug
Reverted to Note5 Beta2 Touchwiz Launcher for better stability
Deleted Bootlogos from aroma (useless)
Added Note7 Animations in Aroma
New App for set up your Power Menu icons where there are OTA Support and Ac Display settings
Optimized updater-script and busybox installation
Optimized battery and general performance
Notes About battery life:
Report about battery life with this ROM after have done three cycles of battery..
If this won't work, try changing kernel with that you feel better
Version 7.0
After this, I optimized and clearified AROMA with less option, but you must know that all features that I removed from Aroma are added by default in system..
From Alexis Rom 6.3 I added new things like:
-iOS 10 Emoji
-Ota Updates
-Ac Display support
A part of this I optimized the installation of system and added newest tweaks for performance and battery
--Ac Display
This is a similar but more better feature than normal Ambient Display, on my rom you find it in Settings/Display
For activate it, you must open Ac Display, press 3dot menu and enter into settings of app; later you must navigate into Notification settings and active Quick Glance option, later reboot and you got this beautiful feature
--OTA Updates
This is a big feature, adapted by me for fix (when needed) some little bugs, but sometimes you will get MD5 error when updating; don't worry, you must wait some mins or some hours and you will get the ota update
--VOLTE
I removed all csc choosing from AROMA for missing country, if your VOLTE doesn't work, extract or find in internet your csc country and VOLTE will work
Now this is the time to speak you about the bugs of this update (lol)
My ROM haven't serious bugs, but has some little bugs that are mentioned in AROMA, so as always READ CAREFULLY EVERY LINE OF AROMA for better and stable ROM!
Version 6.3
Completely redesigned Aroma with New Alexis Logo and:
- Option to select CSC country (choose one of 80+ countries)
- Option to Select CSC tweaks
- Option to Select Advanced or Stock Advanced Reboot Menu
- Option to return to Stock Bootlogo
- Option to select Emoji
- Option to select the Ringtones that you want (Added iOS 10 too, exclusive of Alexis Rom)
- Option to select new mods like Toolbox or AirMessage and AirCommand
- Option to select Google Phone and Contacts App
- Option to choose what you want!
Updated all Google Apps present in aroma
Fixed S-View Cover
Fixed S-Voice
Fixed almost all as well
Updated SuperSU to SR1 version (this can cause some delay in bootsplash at every reboot)
Selected tweaks accurately
Now better performance without loosing so much battery (Tested and had 5h Screen on time)
Remember more size means more stable
Version 6.2
Based on latest firmware DPGW with latest security update (01.08.2016)
Optimized aroma
Added AirCommand on aroma
Added Note7 Camera on aroma
Added Note7 bootlogo on aroma
Optimized battery and other things
Added Surround Mod Audio in aroma for T-Mobile device too
Version 6.1
Based on DPG2 Firmware from Italy with latest Security Patch
Added new option on aroma and reordered for better feel
Now Extra package is integrated in the same zip of system
Fixed all bugs presented on 6.0
Added multilanguage on some apps of NoteUX port
Tried to add support for all S6 and S6 Edge
Better performance and general optimizationes
Version 6.0
Based on newest Samsung base DPFX with July Security Patch
Optimized Aroma: Now you can choos more than 50 apps to debloat and mods, and you can choose what sound mod install
Updated Supersu at 2.76 and put on settings
Added all mods on services.jar
Added all mods on framework.jar
Added option in aroma to choose to install Ambient Display and Settings with Dual Colomn (with fixed option)
Added all apps from note ux firmware all fixed by Albe95's devs thread
So optimized for battery and performance
Added new Smart Manager from new NoteUX
BUGS: Private mode, maybe USSD and VOLTE with Wifi Calling..
If anyone know how to fix contact me on pm or by telegram group!
Version 7.8
-Better Performance
-Better Battery
Version 7.7
Version 7.6.1
Version 7.6
Version 7.5
Added Fix for USSD
Fixed App Lock
!ATTENTION!
Version 7.4
Version 7.3
-Audio
-Battery
Version 7.2
Version 7.1
Version 7.0
-iOS 10 Emoji
-Ota Updates
-Ac Display support
--Ac Display
--OTA Updates
--VOLTE
Version 6.3
Fixed S-View Cover
Fixed S-Voice
Version 6.2
Optimized aroma
Version 6.1
Version 6.0
Anleitung:
Vorrausetzungen:
Installation:
- ROM und Extra Package downloaden und auf das S6 kopieren
- in die Recovery booten
- Factory-Reset (Wipe Data) durchführen
- ROM auswählen und installieren
- Extra Package auswählen und installieren
- Reboot
- Setup abschließen
- Clean install this time is recommended
- Keep the ROM more stock possible, sometimes Note7 Apps could give some lags/bugs
- Find the 1060 Fonts mod here
- If you select Google Assistant don't update Google App or you will lose Google Assistant
- Try to don't use Xposed, it could be the first cause for your bugs
- Keep Stock kernel if you don't want Private Mode/Viper, it gives best performance and battery
- If you want Private Mode/Dolby use any custom kernel
- If you have any problem with Accessibility Settings with apps like Greenify, install from Extra Package: Accessibility functions, Google Assistant and S-Voice
- If anyone wants VOLTE working should select "IMS" in Extra Package and flash his country csc removing feature.xml added by me by default. (If this won't work, I don't know what to say because I can't test it with my carrier)
