Wicki
Ehrenmitglied
- 5.436
- Themenstarter
- #61
Das kann sein. Ändert aber nichts daran, dass ich in dieser Richtung noch keinerlei Problem hatte.
edgarf28 schrieb:XtreStoLite Deo Mod Edition ROM + Aroma add-on package v.2.2 RELEASED!!!
Changelog for the ROM:
- Updated ROM to firmware base XXU2BOGG (G925F) Android 5.1.1 (Build date July 24th)
- Updated the UniKernel to v.6-0001 (Much smoother now!)
- Deodexed the ROM using the latest oat2dex.jar (v.0.83)
- Done the mods using the latest Apktool.jar (v.2.0.1)
- Added Dual-sim (G920FD) support (make sure that you select the dual-sim option while installing the ROM)
- Fixed the extra quick toggles
- Removed 3 files from /system/bin
- Fixed different Catlog warning/error messages
- Added log cleaning init.d script
- Added 'Disable SMS -> MMS conversion when exceeds 480 characters' Mod for the Samsung Messaging app at default
- Removed the TCP4 & Google DNS tweaks (because these were giving issues for some people)
- Removed the FHA/DHA tweaks option, because it's now fully controlled by the Unikernel
- Moved the 'Disable scrolling cache' & 'Disable keyboard notification switcher' mods from the ROM to the Aroma add-on package
- Updated T/W8 audio fix files to the ones from the COF8 T firmware
- Updated Google Play Services to v.7.8.95
- Updated Google System WebView to v.45.0.2454.19
- Updated Sqlite3 binary to v.3.8.11.1
- Various optimisations/fixes that I doesn't remember anymore...
Changelog for the Aroma add-on package:
- Re-based to the G925F XXU2BOGG firmware (build date July 24th)
- Re-added the Alliance Framework (v.3.0 for BOGG)
- Added 'Disable screen wake when unplug/plug-in' Mod
- Above 2 mods are now also comptible with the 'Edge features' add-on
- Added Modded Samsung Messages app with the 'Disable turn on screen when receiving message' mod (+ the default 'SMS -> MMS conversion mod)
- Added Video Telephony add-on
- Added Vindicator (R3) universal custom kernel option (by [MENTION=4517211]Xileforce[/MENTION])
- Updated S-Health to v.4.4.0.0119
- Updated Google Search app to v.4.9.22.19.arm64
- Updated Theme Store & Samsung Billing apps to their latest versions
- Updated UniKernel (to: v.6-0001) and UniBase kernel (to: BOG8 v2)
Download links of both packages are now online in the first & second posts!
Also the BOGG & BOGH Bootloaders/modems are uploaded for the G920F & G925F models here.
And welcome to the G920FD Dual-sim users! :good:
edgarf28 schrieb:XtreStoLite Aroma add-on Package v.2.2a Released!
- Fixed NFC Smart Card add-on (fixed the SmartCardManager FC that you got on every boot with v.2.2)
- Fixed Video Telephony add-on
Download link is up at post #2
XtreStoLite_S6_Odexed_Pure_Aroma_Add-on_Package_XXU2BOFJ_v.2.0.zip | XtreStoLite_S6_Odexed_Pure_Aroma_Add-on_Package_XXU2BOFJ_v.2.0.zip | by Edgarf28 for Galaxy S6edgarf28 schrieb:Forgot to mention...
XtreStoLite Aroma add-on Package v.2.2b is Released!!
Changelog:
- Updated Alliance Framework to v.3.1 (Fixed volume warning, Fixed data toggle warning, Swapped square toggle bg type for indent)
https://de1.androidfilehost.com/dl/...-Edition_XXU2COH2-9_G920-5-F-I-T-W8-K-L-S.zipedgarf28 schrieb:I've token the RC6 build offline (the one from my signature)
Because I'm zipping up the public release build right now, will upload it right after it.
You can find the final public release build in the OP in an hour or something.
The Final public release build have these changes in comparison to the RC6 build from my signature:
- Fixed Samsung Test applications add-on (forgot to add 2 CSC files to the /system/etc folder in the Rc6 build) (ROM)
- Fixed wrong string in the Unikernel.prop file when using the DHA/FHA tweaks, so that the optimized VM tweaks are working now. (ROM & Aroma add-on package)
- Updated Vindicator kernel in the Aroma add-on package to R4 T20 (Aroma add-on package)
