maxe
Ehrenmitglied
- 4.763
Volltreffer Sven, danke!
(manchmal hat man ein Brett vorm Kopf :blushing: )
Install a Rom based on BOG8 or later - I recommend edgars awesome XtreStockLite.
edgarf28 schrieb:Yep, already started development of v.2.4 based on this firmware, since yesterday.
Edit: oh and btw, it will include an fix that prevents that apps gets killed automatically in the background (SwiftKey, Viber, SetCPU etc.)
See attached screenshot, all my apps are running for 13 hours in the background... Including SwiftKey.
So SwiftKey (and all other keyboards) will always pop up instantly with the next update!
