[ROM][G92xF][5.1.1][XXS2AOK9] *18.12.2015* NobleRom v6.0 [Odexed/Deodexed][Edge+]
  • 129 Antworten
DaniYüah
DaniYüah
Dauer-User
536
Tested on G920F | G925F
This porting gives the best performance on the memory and many finishing touches on performance compared to the original rom of galaxy s6 and give new features. So this ROM , contains a portion of the firmware s6 edge + for the Galaxy S6 maintaining customizations.
Galaxy S6 Edge + Port :
ROM Info:
Version Rom: V6.0
Currently Based on G928FXXS2AOK9
Model Number G928F
Kernel: Unikernel v8.002
V6.0 Final Lollipop :
Dedicated for fixes and stabilities of system for the daily usage
Fixed colors bug framework
Fixed calls +48 and other number
Fixed clock fc (issues on java tried with my pc and works perfectly)
Added missing apk of system
Much fastest than v5
Removed lunar chinese calendary
Removed uneless & not working strings
Gear Manager
Google search & voice
S-Healt
Very stable , cool and fresh build for daily usage :p
V1 Beta :
Debloated removed about 400mb of bloatware
Optimized
De-Knoxed
Smooth Spinner applied on the framework-res
All Edge + system full port base 100% original no mod no tweak
Clean and fast concept for the best usage
All the new features of Edge + like :
OneHand
Touchwiz
SystemUI
Keyboard ....
Stable working fingerprint & camera thanks for the lib + etc + bin file fix @arter97
Applied radio battery drain potential fix thanks to @arter97
Ported Air Message
CSC Features 34kb very slim and much features
Deodex
Meta-Inf thanks to my friend @geiti94
V2 Stable
Galaxy S6 Edge + porting full system OH4
Stagefright pre-fixed by Samsung
Air Message
SideKey Panel
ToolBox
Multi-User
ScreenMirroring working + toggle avaible
Very fast build , optimized
Fixed Camera
Fixed mics camera + 8x zoom video
Fixed Video-Recording all resoluction
Fixed Private Mode [Smali file System_Properties]
Fixed SideSync
Fixed all bugs
Stable build
Fixed Emoticon SMS/MMS
New CSC NobleRom
Light Debloat
New logo in settings added
Meta-Inf new structure build @arter97
Odex build unique fixed all bugs of odex
BusyBox new 3.1.1 custom version + root applied
SmoothSpinner applied on the new framework
V3
Thanks to @JustArchi for the best tool for linux
-Builded with Archi tool, deflated all system.
-Optimized apk
-AOJ1 Firmware updated & ported
-Fixed zoom image camera
-Fixed StageFright in the newest build
-Viper4fx , toolbox , super su , Kernel adiutor added in settings
-New logo + version rom in settings
-Dual Smart manager
-New air message
-New app sms with working blocked message section no fc
-Much fluidity & liquid
-Game Tuner by Samsung implemented
-DHA Tweak + Battery applied for the Edge + base
-Cleaned system with debloat script by me
-Added Google search
-Fixed lag in the lockscreen and multitasking
-Stable Release
-New CSC with new features
-Much battery life
-Removed busybox
-Removed sqlite3
-Added archi init.d
-Applied root with archi tool
-Removed some knox file thanks look in the credits
V5.0 Final Lollipop :
Ported AOK9 base Edge + G928F
Original Style Framework of marshmallow with new bar automatic colored
Original Style of marshmallow Settings
Original Icon of Marshmallow S6
Original Style of marshmallow S6 SystemUI
Ported Gallery 2016 from Note 5 marshmallow build
Ported Calendary from Note 5 marshmallow build
Added Fonts Note 5 marshmallow
Added support in meta-inf unmount and kernel
Fixed Wifi Leak & ported originally wifi files
Returned to stock Smart Manager
Stable build
Removed unnecessary script /reserved/
Removed unnecessary strings /reserved/
Further optimize the S6 slide fluency
Repair improve S6 in question after AOE4 Caton.
Optimized for GPU Mali.
Custom Recovery (Philz oder TWRP) wird vorausgesetzt
1. Install TWRP recovery (recommended)
2. Put ROM on your SD card
3. Enter recovery
4. Take a full data wipe
5. Flash Noble Rom
6. Disable 'Smart Stay' from Settings to gain extra more battery life
7. NOTE: For Deodexed build need 10 / 15 minutes about for firts boot up .
Odexed V6
Gabri™
Samsung for the new update
@my collaborator bulldog74ts
Alberto R. my friend tester
@my friend Albe95
MINU THEMER my themer / logo / designer collaborators:http://minuhome.tistory.com @g.lewarne for the kernel
@arter97 big thanks for philz recovery
Powered by SuperSU big thanks for the root
@scrosler for CSC Pack / Debloat list @geiti94 @sardroid for the mirror link
Für Fehler beim Flashen oder ähnlichem übernehme ich keine Haftung.
Alle Angaben OHNE GEWÄHR
Also der Edge+ Port läuft Sahne ! Sieht super aus !
Darf ich fragen ob bei dir das Screen Mirroring läuft falls du die Möglichkeit hast dieses zu testen?
Sorry nutze ich nicht ! Aber sonst bisher keinerlei Fehler bemerkt
Reaktionen: DaniYüah
Edge Nachtuhr funktioniert bei mir (G925F). Screenmirror gar nicht vorhanden, Samsung Wiederherstellung geht auch nicht.
Soll nur eine Info sein und kein Gejammer. Tolle, schnelle und smoothe ROM.
Du hast recht, es war mein Fehler, beim G920F funktioniert die Nachtuhr nicht. Alle anderen Funktionen der Edge jedoch schon. Habe es oben angepasst. Wegen der Wiederherstellung hatte ich bei XDA etwas gelesen bekomme es jedoch nicht mehr auf den Schirm.
  • Edge+ Port V2 ODEX ist da.
  • Noble Rom V4 ist in Arbeit
Changelog der V2
  • Galaxy S6 Edge + porting full system OH4
  • Stagefright pre-fixed
  • Air Message
  • SideKey Panel
  • ToolBox
  • Multi-User
  • ScreenMirroring toggle enabled
  • Very fast build , optimized
  • Fixed Camera
  • Fixed mics camera + 8x zoom video
  • Fixed Video-Recording all resoluction
  • Fixed Private Mode [Smali file System_Properties]
  • Fixed SideSync
  • Fixed all bugs
  • Stable build
  • Fixed Emoticon SMS/MMS
  • New CSC NobleRom
  • Light Debloat
  • New logo in settings added
  • Meta-Inf new structure build @arter97
  • Odex build unique fixed all bugs of odex
  • BusyBox new 3.1.1 custom version + root applied
  • SmoothSpinner applied on the new framework
Viel Spaß mit der Rom. Werde den Port bei Gelegenheit auch wieder flashen da ja nun Screen Mirroring gefixt wurde, bis ich dazu komme tut es auch die Noble v3.
Kann ich die Edge+ Port V2 einfach über die V1 drüber Bügeln ohne Wipe ?
Das kann ich dir leider nicht beantworten.
Sollte ich diesbezüglich eine Antwort bekommen melde ich mich bei dir...ansonsten heisst es Try and Error.
Dazu solltest du am besten den XDA Thread im Auge behalten. Ich habe keine Ahnung ob das geht...werde nun auch den EDGE+ Port flashen und mal sehen was sich so getan hat.
Edit: Dirty Flash von Noble v3 auf Edge+ Port ohne Probleme möglich. Am besten Backup machen und testen ob es funzt. So hab ich es zumindest gemacht...keine Garantie.
Reaktionen: weberfulda
klasse :D heute nacht erst die V1 zum ersten mal drauf gemacht ;) und jetzt die V2 :D
ich warte aber noch bis zur DEODEX-Version und dann bügel ich sie drüber :)
Welchen Kernel nutzt ihr für dieses Rom?
sehe aber schon, dauert nicht mehr lange :D
Deodexed build v2 uploading
400mb/0,99GB.
Nutze den aktuellen arter97 Kernel zur Zeit.
Die v2 Edge+ Port Deodex ist im Upload von Gabri...kann den Link erst am Abend einfügen da ich auf Arbeit bin
@soundclub
Habe ich im Startpost eingefügt. Hoffe das es klappt da ich mobil unterwegs bin.
Werde am heutigen Abend den Startpost bearbeiten für eine bessere übersicht.
Kurze Frage. Ist für ein ein Thread für die 2 Roms okay oder besser die Noble und den Edge + Port seperat?
V2 über V1 gebügelt ohne Wipe, keine Probleme !
Gesehen, dass es eine "V2 fixed" gibt? Bei der alten gab es ein FC wenn man die Uhr aufgerufen hat.
DaniYüah schrieb:
@soundclub
Ich fänd 2 getrennte Threads besser!
Ich finde es auch besser mit getrennten Threads sind ja schließlich verschiedene ROM's
Ich werde mal schauen, vllt. wenn ich mal Zeit habe.
Zumindest ist es jetzt übersichtlicher.
Gibt's irgendwo den Fullscreen Caller ID zum flashen, also keine App
Kann ich nichts zu sagen leider. Am besten Gabri bei xda im Thread fragen.
Nebenbei mal ein kleiner Screen auch wenn nicht ganz Aussagekräftig weil noch viel Akku vorhanden ist.
arter97 Kernel ist denke für die Rom noch besser als der Uni.
